RTEMS 6.3
rtems Directory Reference
Directories
confdefs
debugger
dev
posix
rfs
rtl
score
trace
assoc.h
 RTEMS Associativity Routines.
base64.h
 This header file provides the interfaces of the Base64 Encoding and Decoding.
bdbuf.h
 Block Device Buffer Management.
bdpart.h
 Block Device Partition Management.
blkdev.h
 Block Device Management.
bsd.h
 BSD Compatibility API.
bspcmdline.h
 BSP Command Line Handler.
bspIo.h
 This header file provides the kernel character input/output support API.
btimer.h
 RTEMS Benchmark Timer API for all Boards.
capture-cli.h
capture.h
 Capture Engine Component of the RTEMS Measurement and Monitoring System.
captureimpl.h
 Capture Implementation file.
cbs.h
 Constants and Structures Associated with the CBS library in RTEMS.
chain.h
 This header file provides the Chains API.
clockdrv.h
 This header file defines the Clock Driver API.
concat.h
confdefs.h
 This header file evaluates the application configuration options defined by the application.
config.h
 This header file provides parts of the application configuration information API.
console.h
 Console Driver for all Boards.
counter.h
 This header file defines the Free-Running Counter and Busy Wait Delay API.
cpuuse.h
 This header file provides the CPU usage reporting API.
crc.h
 This header file provides the interfaces of the Cyclic Redundancy Check (CRC) Support.
deviceio.h
 Operations on IMFS Device Nodes.
devnull.h
 RTEMS /dev/null Device Driver.
devzero.h
 RTEMS /dev/zero Device Driver.
diskdevs.h
 Block Device Disk Management API.
dosfs.h
 Application Interface to FAT Filesystem.
dumpbuf.h
 Print a Memory Buffer.
endian.h
 Includes endian information about the target.
error.h
 RTEMS Error Reporting.
error.hpp
 RTEMS Error exception.
extension.h
 This header file defines the User Extensions Manager API.
extensiondata.h
 This header file provides data structures used by the implementation and the Application Configuration to define _Extension_Information.
extensionimpl.h
 Classic User Extensions Implementation.
fatal.h
 This header file defines the Fatal Error Manager API.
fb.h
 Frame Buffer Device Driver.
flashdisk.h
 Interface to a Flash Disk Block Device.
framebuffer.h
 Frame Buffer Device Driver for all Boards.
fs.h
 Basic Filesystem Types.
fsmount.h
ftpd.h
 FTP Server Information.
ftpfs.h
 File Transfer Protocol file system (FTP client).
ide_part_table.h
 "MS-DOS-style" Partition Tables Support
imfs.h
 This header file defines the API of the In-Memory File System.
imfsimpl.h
 This header file contains interfaces used by the implementation of the In-Memory File System.
init.h
 This header file defines the Initialization Manager API.
inttypes.h
 Provide printf() PRIxxx Constante Beyond Standards.
io.h
 This header file defines the IO Manager API.
ioimpl.h
 This header file provides interfaces used by the I/O Manager implementation.
iosupp.h
irq-extension.h
 This header file is provided for backward compatiblility.
irq.h
jffs2.h
libcsupport.h
 Standard C Library Support.
libi2c.h
 Legacy I2C Library.
libio.h
 Basic IO API.
libio_.h
 LibIO Internal Interface.
linkersets.h
 This header file provides the linker sets API.
malloc.h
 This header file defines interfaces to support and use dynamic memory allocation.
mallocinitmulti.h
 This header file provides the implementation of _Malloc_Initialize_for_multiple_areas().
mallocinitone.h
 This header file provides the implementation of _Malloc_Initialize_for_one_area().
media.h
 Media Manager API.
monitor.h
 The RTEMS Monitor Task.
mouse_parser.h
 Initialize Mouse Parser Engine.
mptables.h
 Executive's Pre-Initialized Tables used in a Multiprocessor Configuration.
mw_uid.h
 Input Devices for MicroWindows.
nvdisk-sram.h
nvdisk.h
 Non-volatile Disk Block Device Implementation.
passwd.h
 Default password for telnetd.
pci.h
pipe.h
 POSIX FIFO/pipe File System Support.
print.h
 User print interface to the bspIO print plug in.
printer.h
profiling.h
 This header file provides the Profiling Support API.
pty.h
 /dev/ptyXX (A first version for pseudo-terminals)
qreslib.h
 Constants and Structures Associated with the QoS RES library in RTEMS.
ramdisk.h
 RAM Disk Block Device API.
rbheap.h
 This header file provides the Red-Black Tree Heap API.
rbtree.h
 This header file provides the Red-Black Trees API.
record.h
recordclient.h
recorddata.h
recorddump.h
recordserver.h
regulator.h
 This header file defines the Regulator API.
regulatorimpl.h
 Regulator Library Implementation Support.
ringbuf.h
 Simple Ring Buffer Functionality.
rtc.h
 Real-Time Clock Driver Interface.
rtems-debugger-remote-tcp.h
rtems-debugger.h
rtems-fdt-shell.h
 RTEMS Flattened Device Tree Shell Command.
rtems-fdt.h
 RTEMS Flattened Device Tree.
rtems-rfs-format.h
 RTEMS File System Format.
rtems-rfs-shell.h
 RTEMS File Systems Shell Commands.
rtems-rfs.h
 RFS File system Initialization.
scheduler.h
 This header file contains interfaces to define a scheduler configuration for an application.
serial_mouse.h
 Serial Mouse Driver.
seterr.h
 This header file defines macros to set errno and return minus one.
shell.h
 Instantatiate a New Terminal Shell.
shellconfig.h
sparse-disk.h
 Sparse disk block device API.
spurious.h
stackchk.h
 This header file provides the Stack Checker API.
status-checks.h
 Header File for Status Checks.
stdio-redirect.h
stringto.h
 Convert String to Pointer (with validation).
sysinit.h
 This header file provides the API of the System Initialization Support.
telnetd.h
 Telnet Daemon Interface.
termiosdevice.h
 This header file provides the interfaces of the RTEMS Termios Device Support.
termiostypes.h
test-gcov.h
 This header file provides the interfaces of the Gcov Support.
test-info.h
 This header file provides interfaces of the RTEMS Test Support.
test-printer.h
test-scheduler.h
 This header file defines the scheduler test support API.
test.h
 This header file provides interfaces of the RTEMS Test Framework.
tftp.h
 This header file provides interfaces and functions used to implement the TFTP file system.
thread.h
 This header file provides the API of Self-Contained Objects.
thread.hpp
 C++ standard thread support with thread attribute control.
timecounter.h
 This header file provides the Timecounter Support API.
timespec.h
 Timespec API.
tm27-default.h
 Empty stub for tm27.h.
tod.h
 Real Time Clock Time of Day API Definition.
untar.h
 Untar an Image.
userenv.h
 User Environment Support.
version.h
 This header file provides the Version API.
vmeintr.h
 VMEbus Interface Library.
watchdogdrv.h
