RTEMS 6.3
This header file defines interfaces to support and use dynamic memory allocation. More...
#include <rtems/bspIo.h>
#include <rtems/libcsupport.h>
#include <stdint.h>
typedef void *(*) rtems_heap_extend_handler(Heap_Control *heap, size_t alloc_size)
typedef void(*) rtems_malloc_dirtier_t(void *, size_t)
void _Malloc_Initialize (void)
void * rtems_heap_extend_via_sbrk (Heap_Control *heap, size_t alloc_size)
 RTEMS Extend Heap via Sbrk.
void * rtems_heap_null_extend (Heap_Control *heap, size_t alloc_size)
void rtems_heap_set_sbrk_amount (ptrdiff_t sbrk_amount)
void rtems_heap_sbrk_greedy_allocate (Heap_Control *heap, size_t alloc_size)
 Greedy allocate that empties the sbrk memory.
void rtems_malloc_dirty_memory (void *start, size_t size)
 Dirty Memory Function.
int rtems_memalign (void **pointer, size_t alignment, size_t size)
 RTEMS Variation on Aligned Memory Allocation.
void * rtems_heap_allocate_aligned_with_boundary (size_t size, uintptr_t alignment, uintptr_t boundary) RTEMS_MALLOCLIKE RTEMS_ALLOC_SIZE(1) RTEMS_ALLOC_ALIGN(2) RTEMS_WARN_UNUSED_RESULT
 Allocates a memory area of size size bytes from the heap.
void * rtems_malloc (size_t size) RTEMS_MALLOCLIKE RTEMS_ALLOC_SIZE(1) RTEMS_WARN_UNUSED_RESULT
 Allocates a memory area of the specified size from the heap.
void * rtems_calloc (size_t nelem, size_t elsize) RTEMS_MALLOCLIKE RTEMS_ALLOC_SIZE_2(1
 Allocates a memory area for the specified count of elements from the heap.
rtems_status_code rtems_heap_extend (void *area_begin, uintptr_t area_size)
 Extends the memory available for the heap using the memory area starting at area_begin of size area_size bytes.
void * rtems_heap_greedy_allocate (const uintptr_t *block_sizes, size_t block_count)
 Greedy allocate that empties the heap.
void * rtems_heap_greedy_allocate_all_except_largest (uintptr_t *allocatable_size)
 Greedy allocate all blocks except the largest free block.
void rtems_heap_greedy_free (void *opaque)
 Frees space of a greedy allocation.
Heap_Control * RTEMS_Malloc_Heap
 C program heap control.
const rtems_heap_extend_handler rtems_malloc_extend_handler
rtems_malloc_dirtier_t rtems_malloc_dirty_helper
void RTEMS_WARN_UNUSED_RESULT
