RTEMS 6.3
This header file provides the interfaces of the RTEMS Termios Device Support. More...
| struct | rtems_termios_device_context |
| Termios device context. More... | |
| struct | rtems_termios_device_handler |
| Termios device handler. More... | |
| struct | rtems_termios_device_flow |
| Termios device flow control handler. More... | |
| #define | RTEMS_TERMIOS_DEVICE_CONTEXT_INITIALIZER(name) |
| Initializer for static initialization of Termios device contexts. | |
Typedefs | |
| typedef struct rtems_termios_device_context | rtems_termios_device_context |
| Termios device context. | |
Enumerations | |
| enum | rtems_termios_device_mode { TERMIOS_POLLED , TERMIOS_IRQ_DRIVEN , TERMIOS_TASK_DRIVEN , TERMIOS_IRQ_SERVER_DRIVEN } |
| void | rtems_termios_device_lock_acquire_default (rtems_termios_device_context *ctx, rtems_interrupt_lock_context *lock_context) |
| void | rtems_termios_device_lock_release_default (rtems_termios_device_context *ctx, rtems_interrupt_lock_context *lock_context) |
| #define RTEMS_TERMIOS_DEVICE_CONTEXT_INITIALIZER | ( | name | ) |
| name | The name for the interrupt lock. It must be a string. The name is only used if profiling is enabled. |
| typedef struct rtems_termios_device_context rtems_termios_device_context |
