RTEMS
6.3
Toggle main menu visibility
include
test-gcov.h
1
/* SPDX-License-Identifier: BSD-2-Clause */
2
10
11
12
* Copyright (C) 2013, 2014 embedded brains GmbH & Co. KG
13
14
15
* modification, are permitted provided that the following conditions
16
* are met:
17
* 1. Redistributions of source code must retain the above copyright
18
* notice, this list of conditions and the following disclaimer.
19
* 2. Redistributions in binary form must reproduce the above copyright
20
* notice, this list of conditions and the following disclaimer in the
21
* documentation and/or other materials provided with the distribution.
22
23
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
24
* AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
25
* IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
26
* ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
27
* LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
28
* CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
29
* SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
30
* INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
31
* CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
32
* ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
33
* POSSIBILITY OF SUCH DAMAGE.
34
35
36
#ifndef _RTEMS_TEST_GCOV_H
37
#define _RTEMS_TEST_GCOV_H
38
39
#include <gcov.h>
40
41
rtems/linkersets.h
42
rtems/dev/io.h
43
44
#ifdef __cplusplus
45
extern
"C"
46
#endif
/* __cplusplus */
47
57
58
RTEMS_LINKER_ROSET_DECLARE( gcov_info,
const
struct
gcov_info * );
59
68
void
_Gcov_Dump_info
IO_Put_char
put_char,
void
*arg );
69
78
void
_Gcov_Dump_info_base64
IO_Put_char
put_char,
void
*arg );
79
81
82
#ifdef __cplusplus
83
84
#endif
/* __cplusplus */
85
86
#endif
/* _RTEMS_TEST_GCOV_H */
io.h
This header file provides the interfaces of the Device I/O Support.
IO_Put_char
void(*) IO_Put_char(int c, void *arg)
This type defines the put character handler.
Definition
io.h:65
void _Gcov_Dump_info_base64(IO_Put_char put_char, void *arg)
Dumps the gcov information as a base64 encoded gcfn and gcda data stream using the put character hand...
Definition
gcovdumpinfobase64.c:97
_Gcov_Dump_info
void _Gcov_Dump_info(IO_Put_char put_char, void *arg)
Dumps the gcov information as a binary gcfn and gcda data stream using the put character handler.
Definition
gcovdumpinfo.c:79
linkersets.h
This header file provides the linker sets API.
