RTEMS
6.3
Toggle main menu visibility
include
btimer.h
1
/* SPDX-License-Identifier: BSD-2-Clause */
2
8
9
10
* COPYRIGHT (c) 2011 Ralf Corsépius Ulm/Germany
11
12
* Derived from libcsupport/include/timerdrv.h:
13
14
* COPYRIGHT (c) 1989-1999.
15
* On-Line Applications Research Corporation (OAR).
16
17
18
* modification, are permitted provided that the following conditions
19
* are met:
20
* 1. Redistributions of source code must retain the above copyright
21
* notice, this list of conditions and the following disclaimer.
22
* 2. Redistributions in binary form must reproduce the above copyright
23
* notice, this list of conditions and the following disclaimer in the
24
* documentation and/or other materials provided with the distribution.
25
26
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
27
* AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
28
* IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
29
* ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
30
* LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
31
* CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
32
* SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
33
* INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
34
* CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
35
* ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
36
* POSSIBILITY OF SUCH DAMAGE.
37
38
39
40
* All the functions declared as extern after this comment
41
* MUST be implemented in each BSP.
42
43
44
#ifndef _RTEMS_BTIMER_H
45
#define _RTEMS_BTIMER_H
46
47
#include <stdbool.h>
48
#include <stdint.h>
49
rtems/rtems/status.h
50
51
#ifdef __cplusplus
52
extern
"C"
53
#endif
54
74
80
typedef
uint32_t
benchmark_timer_t
81
88
extern
void
benchmark_timer_initialize
void
89
100
extern
benchmark_timer_t
benchmark_timer_read
void
101
107
extern
rtems_status_code
benchmark_timer_empty_function
void
108
119
extern
void
benchmark_timer_disable_subtracting_average_overhead
120
bool
find_flag
121
122
124
125
#ifdef __cplusplus
126
127
#endif
128
129
#endif
void benchmark_timer_initialize(void)
Initialize the Benchmark Timer.
Definition
btimer.c:31
benchmark_timer_t benchmark_timer_read(void)
Read the Benchmark Timer.
Definition
btimer.c:60
void benchmark_timer_disable_subtracting_average_overhead(bool find_flag)
Disable Average Overhead Removal from the Benchmark Timer.
Definition
btimer.c:89
rtems_status_code benchmark_timer_empty_function(void)
Benchmark Timer Empty Function.
benchmark_timer_t
uint32_t benchmark_timer_t
This type is used to return a Benchmark Timer value.
Definition
btimer.h:80
rtems_status_code
rtems_status_code
Definition
status.h:85
status.h
This header file provides the status codes of Classic API directives and support functions.
