RTEMS 6.3
Files | |
| asr.h | |
| This header file defines the parts of the Signal Manager API. | |
| asrdata.h | |
| This header file provides data structures used by the implementation and the Application Configuration to ultimately define Thread_Configured_control. | |
| attr.h | |
| This header file provides Classic API directive attributes. | |
| attrimpl.h | |
| This header file provides the implementation interfaces of the Directive Attributes support. | |
| barrier.h | |
| This header file defines the Barrier Manager API. | |
| barrierdata.h | |
| This header file provides data structures used by the implementation and the Application Configuration to define _Barrier_Information. | |
| barrierimpl.h | |
| This header file provides the implementation interfaces of the Barrier Manager. | |
| cache.h | |
| This header file defines the Cache Manager API. | |
| clock.h | |
| This header file defines the Clock Manager API. | |
| clockimpl.h | |
| This header file provides the implementation interfaces of the Clock Manager. | |
| config.h | |
| This header file provides parts of the application configuration information API. | |
| dpmem.h | |
| This header file defines the Dual-Ported Memory Manager API. | |
| dpmemdata.h | |
| This header file provides data structures used by the implementation and the Application Configuration to define _Dual_ported_memory_Information. | |
| dpmemimpl.h | |
| This header file provides the implementation interfaces of the Dual-Ported Memory Manager. | |
| event.h | |
| This header file provides the Event Manager API. | |
| eventdata.h | |
| eventimpl.h | |
| This header file provides the implementation interfaces of the Event Manager. | |
| eventmp.h | |
| This header file provides the implementation interfaces of the Event Manager Multiprocessing (MP) Support. | |
| intr.h | |
| This header file defines the Interrupt Manager API. | |
| modes.h | |
| This header file provides the task modes API of the Task Manager. | |
| modesimpl.h | |
| This header file provides the implementation interfaces of the Task Modes support. | |
| mp.h | |
| This header file defines the Multiprocessing Manager API. | |
| msgmp.h | |
| This header file provides the implementation interfaces of the Message Manager Multiprocessing (MP) Support. | |
| object.h | |
| This header file provides the Object Services API. | |
| objectimpl.h | |
| This header file provides the implementation interfaces of the Object Services. | |
| options.h | |
| This header file provides the Classic API directive options. | |
| optionsimpl.h | |
| This header file provides the implementation interfaces of the Directive Options support. | |
| part.h | |
| This header file provides the Partition Manager API. | |
| partdata.h | |
| This header file provides data structures used by the implementation and the Application Configuration to define _Partition_Information. | |
| partimpl.h | |
| This header file provides the implementation interfaces of the Partition Manager. | |
| partmp.h | |
| This header file provides the implementation interfaces of the Partition Manager Multiprocessing (MP) Support. | |
| ratemon.h | |
| This header file defines the Rate-Monotonic Manager API. | |
| ratemondata.h | |
| This header file provides data structures used by the implementation and the Application Configuration to define _Rate_monotonic_Information. | |
| ratemonimpl.h | |
| This header file provides the implementation interfaces of the Rate Monotonic Manager. | |
| region.h | |
| This header file defines the Region Manager API. | |
| regiondata.h | |
| This header file provides data structures used by the implementation and the Application Configuration to define _Region_Information. | |
| regionimpl.h | |
| This header file provides the implementation interfaces of the Region Manager. | |
| scheduler.h | |
| This header file defines the main parts of the Scheduler Manager API. | |
| sem.h | |
| This header file defines the Semaphore Manager API. | |
| semdata.h | |
| This header file provides data structures used by the implementation and the Application Configuration to define _Semaphore_Information. | |
| semimpl.h | |
| This header file provides the implementation interfaces of the Semaphore Manager. | |
| semmp.h | |
| This header file provides the implementation interfaces of the Semaphore Manager Multiprocessing (MP) Support. | |
| signal.h | |
| signalimpl.h | |
| This header file provides the implementation interfaces of the Signal Manager. | |
| signalmp.h | |
| This header file provides the implementation interfaces of the Signal Manager Multiprocessing (MP) Support. | |
| status.h | |
| This header file provides the status codes of Classic API directives and support functions. | |
| statusimpl.h | |
| This header file provides the implementation interfaces of the Directive Status support. | |
| support.h | |
| This header file defines support services of the API. | |
| taskmp.h | |
| This header file provides the implementation interfaces of the Task Manager Multiprocessing (MP) Support. | |
| tasks.h | |
| This header file defines the main parts of the Tasks Manager API. | |
| tasksdata.h | |
| This header file provides data structures used by the implementation and the Application Configuration to define the _RTEMS_tasks_User_task_table, the _RTEMS_tasks_User_task_config, _RTEMS_tasks_Information, and ultimately Thread_Configured_control. | |
| tasksimpl.h | |
| This header file provides the implementation interfaces of the Task Manager. | |
| timer.h | |
| This header file provides the Timer Manager API. | |
| timerdata.h | |
| This header file provides data structures used by the implementation and the Application Configuration to define _Timer_Information. | |
| timerimpl.h | |
| This header file provides the implementation interfaces of the Timer Manager. | |
| types.h | |
| This header file provides types used by the Classic API. | |
