39#ifndef CONFIGURE_SCHEDULER_CBS
40 #error "cbs.h available only with CONFIGURE_SCHEDULER_CBS"
53#define RTEMS_CBS_OK SCHEDULER_CBS_OK
54#define RTEMS_CBS_ERROR_GENERIC SCHEDULER_CBS_ERROR_GENERIC
55#define RTEMS_CBS_ERROR_NO_MEMORY SCHEDULER_CBS_ERROR_NO_MEMORY
56#define RTEMS_CBS_ERROR_INVALID_PARAMETER SCHEDULER_CBS_ERROR_INVALID_PARAM
57#define RTEMS_CBS_ERROR_UNAUTHORIZED SCHEDULER_CBS_ERROR_UNAUTHORIZED
58#define RTEMS_CBS_ERROR_UNIMPLEMENTED SCHEDULER_CBS_ERROR_UNIMPLEMENTED
59#define RTEMS_CBS_ERROR_MISSING_COMPONENT SCHEDULER_CBS_ERROR_MISSING_COMPONENT
60#define RTEMS_CBS_ERROR_INCONSISTENT_STATE SCHEDULER_CBS_ERROR_INCONSISTENT_STATE
61#define RTEMS_CBS_ERROR_SYSTEM_OVERLOAD SCHEDULER_CBS_ERROR_SYSTEM_OVERLOAD
62#define RTEMS_CBS_ERROR_INTERNAL_ERROR SCHEDULER_CBS_ERROR_INTERNAL_ERROR
63#define RTEMS_CBS_ERROR_NOT_FOUND SCHEDULER_CBS_ERROR_NOT_FOUND
64#define RTEMS_CBS_ERROR_FULL SCHEDULER_CBS_ERROR_FULL
65#define RTEMS_CBS_ERROR_EMPTY SCHEDULER_CBS_ERROR_EMPTY
66#define RTEMS_CBS_ERROR_NOSERVER SCHEDULER_CBS_ERROR_NOSERVER
84static inline int rtems_cbs_initialize (
void )
96static inline int rtems_cbs_cleanup (
void )
108static inline int rtems_cbs_create_server (
116 budget_overrun_callback,
128static inline int rtems_cbs_attach_thread (
143static inline int rtems_cbs_detach_thread (
158static inline int rtems_cbs_destroy_server (
173static inline int rtems_cbs_get_server_id (
188static inline int rtems_cbs_get_parameters (
203static inline int rtems_cbs_set_parameters (
218static inline int rtems_cbs_get_execution_time (
234static inline int rtems_cbs_get_remaining_budget (
236 time_t *remaining_budget
250static inline int rtems_cbs_get_approved_budget (
Scheduler_CBS_Parameters rtems_cbs_parameters
Definition cbs.h:75
Scheduler_CBS_Server_id rtems_cbs_server_id
Definition cbs.h:72
Scheduler_CBS_Budget_overrun rtems_cbs_budget_overrun
Definition cbs.h:69
Objects_Id rtems_id
This type represents RTEMS object identifiers.
Definition types.h:94
int _Scheduler_CBS_Get_server_id(rtems_id task_id, Scheduler_CBS_Server_id *server_id)
Gets a thread server id.
Definition schedulercbsgetserverid.c:46
int _Scheduler_CBS_Create_server(Scheduler_CBS_Parameters *params, Scheduler_CBS_Budget_overrun budget_overrun_callback, rtems_id *server_id)
Creates a new server with specified parameters.
Definition schedulercbscreateserver.c:45
int _Scheduler_CBS_Cleanup(void)
Cleans up resources associated to the CBS Library.
Definition schedulercbscleanup.c:44
void(*) Scheduler_CBS_Budget_overrun(Scheduler_CBS_Server_id server_id)
Definition schedulercbs.h:116
int _Scheduler_CBS_Get_remaining_budget(Scheduler_CBS_Server_id server_id, time_t *remaining_budget)
Retrieves remaining budget for the current server instance.
Definition schedulercbsgetremainingbudget.c:45
int _Scheduler_CBS_Get_approved_budget(Scheduler_CBS_Server_id server_id, time_t *approved_budget)
Retrieves the approved budget.
Definition schedulercbsgetapprovedbudget.c:46
int _Scheduler_CBS_Detach_thread(Scheduler_CBS_Server_id server_id, rtems_id task_id)
Detaches from the CBS Server.
Definition schedulercbsdetachthread.c:45
int _Scheduler_CBS_Destroy_server(Scheduler_CBS_Server_id server_id)
Detaches all tasks from a server and destroys it.
Definition schedulercbsdestroyserver.c:44
int _Scheduler_CBS_Get_execution_time(Scheduler_CBS_Server_id server_id, time_t *exec_time, time_t *abs_time)
Gets relative time info.
Definition schedulercbsgetexecutiontime.c:45
int _Scheduler_CBS_Attach_thread(Scheduler_CBS_Server_id server_id, rtems_id task_id)
Attaches a task to an already existing server.
Definition schedulercbsattachthread.c:45
int _Scheduler_CBS_Initialize(void)
Definition schedulercbs.c:109
int _Scheduler_CBS_Get_parameters(Scheduler_CBS_Server_id server_id, Scheduler_CBS_Parameters *params)
Retrieves CBS scheduling parameters.
Definition schedulercbsgetparameters.c:46
uint32_t Scheduler_CBS_Server_id
Definition schedulercbs.h:113
int _Scheduler_CBS_Set_parameters(Scheduler_CBS_Server_id server_id, Scheduler_CBS_Parameters *parameters)
Sets parameters for CBS scheduling.
Definition schedulercbssetparameters.c:45
This header file provides interfaces of the Constant Bandwidth Server (CBS) Scheduler which are used ...
Definition schedulercbs.h:123
