RTEMS 6.3
ide_part_table.h File Reference
"MS-DOS-style" Partition Tables Support More...
#include <rtems/chain.h>
#include <sys/ioctl.h>
#include <sys/types.h>
#include <sys/endian.h>
#include <sys/stat.h>
#include <unistd.h>
#include <fcntl.h>
#include <rtems/blkdev.h>
#include <rtems/libio.h>
#include <rtems/libio_.h>
#include <rtems/bdbuf.h>
#include <rtems/seterr.h>
struct  rtems_sector_data_s
struct  rtems_part_desc_s
struct  rtems_disk_desc_s
#define RTEMS_IDE_SECTOR_BITS   9
#define RTEMS_IDE_SECTOR_SIZE   512
#define RTEMS_IDE_PARTITION_DESCRIPTOR_SIZE   16
#define RTEMS_IDE_PARTITION_MAX_PARTITION_NUMBER   63
#define RTEMS_IDE_PARTITION_MAX_SUB_PARTITION_NUMBER   4
#define RTEMS_IDE_PARTITION_DEV_NAME_LENGTH_MAX   16
#define RTEMS_IDE_PARTITION_MSDOS_SIGNATURE_DATA1   0x55
#define RTEMS_IDE_PARTITION_MSDOS_SIGNATURE_DATA2   0xaa
#define RTEMS_IDE_PARTITION_MSDOS_SIGNATURE_OFFSET   0x1fe
#define RTEMS_IDE_PARTITION_TABLE_OFFSET   0x1be
#define RTEMS_IDE_PARTITION_TABLE_SIZE   (4 * 16)
#define RTEMS_IDE_PARTITION_BOOTABLE_OFFSET   0
#define RTEMS_IDE_PARTITION_SYS_TYPE_OFFSET   4
#define RTEMS_IDE_PARTITION_START_OFFSET   8
#define RTEMS_IDE_PARTITION_SIZE_OFFSET   12
#define LE_TO_CPU_U16(v)
#define LE_TO_CPU_U32(v)
#define CPU_TO_LE_U16(v)
#define CPU_TO_LE_U32(v)
typedef struct rtems_sector_data_s rtems_sector_data_t
typedef struct rtems_part_desc_s rtems_part_desc_t
typedef struct rtems_disk_desc_s rtems_disk_desc_t
enum  {
  EMPTY_PARTITION = 0x00 , DOS_FAT12_PARTITION = 0x01 , DOS_FAT16_PARTITION = 0x04 , EXTENDED_PARTITION = 0x05 ,
  DOS_P32MB_PARTITION = 0x06 , FAT32_PARTITION = 0x0B , FAT32_LBA_PARTITION = 0x0C , FAT16_LBA_PARTITION = 0x0E ,
  DM6_PARTITION = 0x54 , EZD_PARTITION = 0x55 , DM6_AUX1PARTITION = 0x51 , DM6_AUX3PARTITION = 0x53 ,
  LINUX_SWAP = 0x82 , LINUX_NATIVE = 0x83 , LINUX_EXTENDED = 0x85
void rtems_ide_part_table_free (rtems_disk_desc_t *disk_desc) RTEMS_DEPRECATED
rtems_status_code rtems_ide_part_table_get (const char *dev_name, rtems_disk_desc_t *disk_desc) RTEMS_DEPRECATED
rtems_status_code rtems_ide_part_table_initialize (const char *dev_name) RTEMS_DEPRECATED
◆ CPU_TO_LE_U16
#define CPU_TO_LE_U16 ( v)
Value:
htole16(v)
◆ CPU_TO_LE_U32
#define CPU_TO_LE_U32 ( v)
Value:
htole32(v)
◆ LE_TO_CPU_U16
#define LE_TO_CPU_U16 ( v)
Value:
le16toh(v)
◆ LE_TO_CPU_U32
#define LE_TO_CPU_U32 ( v)
Value:
le32toh(v)
◆ rtems_ide_part_table_free()
void rtems_ide_part_table_free ( rtems_disk_desc_t * disk_desc)
◆ rtems_ide_part_table_get()
rtems_status_code rtems_ide_part_table_get ( const char * dev_name,
rtems_disk_desc_t * disk_desc )
◆ rtems_ide_part_table_initialize()
rtems_status_code rtems_ide_part_table_initialize ( const char * dev_name)
