RTEMS 6.3
The application configuration defines system parameters according to configuration options (defines) provided by the application. More...
Files | |
| file | cpukit/include/rtems/confdefs/bdbuf.h |
| This header file evaluates configuration options related to the block device cache configuration. | |
| file | cpukit/include/rtems/confdefs/bsp.h |
| This header file evaluates configuration options related to the BSP configuration. | |
| file | cpukit/include/rtems/confdefs/clock.h |
| This header file evaluates configuration options related to the clock driver configuration. | |
| file | cpukit/include/rtems/confdefs/console.h |
| This header file evaluates configuration options related to the console driver configuration. | |
| file | cpukit/include/rtems/confdefs/extensions.h |
| This header file evaluates configuration options related to the user extensions configuration. | |
| file | cpukit/include/rtems/confdefs/face.h |
| This header file evaluates configuration options related to the FACE Technical Standard. | |
| file | cpukit/include/rtems/confdefs/inittask.h |
| This header file evaluates configuration options related to the Classic API initialization task configuration. | |
| file | cpukit/include/rtems/confdefs/initthread.h |
| This header file evaluates configuration options related to the POSIX initialization thread configuration. | |
| file | cpukit/include/rtems/confdefs/iodrivers.h |
| This header file evaluates configuration options related to the I/O driver configuration. | |
| file | cpukit/include/rtems/confdefs/libio.h |
| This header file evaluates configuration options related to the I/O library configuration. | |
| file | cpukit/include/rtems/confdefs/libpci.h |
| This header file evaluates configuration options related to the PCI library configuration. | |
| file | cpukit/include/rtems/confdefs/malloc.h |
| This header file evaluates configuration options related to the C Program Heap configuration. | |
| file | cpukit/include/rtems/confdefs/mpci.h |
| This header file evaluates configuration options related to the MPCI configuration. | |
| file | cpukit/include/rtems/confdefs/newlib.h |
| This header file evaluates configuration options related to the Newlib C Library configuration. | |
| file | cpukit/include/rtems/confdefs/objectsclassic.h |
| This header file evaluates configuration options related to the Classic API objects configuration. | |
| file | cpukit/include/rtems/confdefs/objectsposix.h |
| This header file evaluates configuration options related to the POSIX API objects configuration. | |
| file | cpukit/include/rtems/confdefs/obsolete.h |
| This header file evaluates configuration options related to obsolete configuration options. | |
| file | cpukit/include/rtems/confdefs/percpu.h |
| This header file evaluates configuration options related to the per-CPU configuration. | |
| file | cpukit/include/rtems/confdefs/scheduler.h |
| This header file evaluates configuration options related to the scheduler configuration. | |
| file | cpukit/include/rtems/confdefs/threads.h |
| This header file evaluates configuration options related to the thread configuration. | |
| file | cpukit/include/rtems/confdefs/unlimited.h |
| This header file evaluates configuration options related to the unlimited objects configuration. | |
| file | cpukit/include/rtems/confdefs/wkspace.h |
| This header file evaluates configuration options related to the RTEMS Workspace configuration. | |
| file | cpukit/include/rtems/confdefs/wkspacesupport.h |
| This header file provides support macros to evaluate configuration options related to the RTEMS Workspace configuration. | |
