RTEMS
6.3
Toggle main menu visibility
include
spurious.h
1
/* SPDX-License-Identifier: BSD-2-Clause */
2
8
9
10
* COPYRIGHT (c) 1989-2011.
11
* On-Line Applications Research Corporation (OAR).
12
13
14
* modification, are permitted provided that the following conditions
15
* are met:
16
* 1. Redistributions of source code must retain the above copyright
17
* notice, this list of conditions and the following disclaimer.
18
* 2. Redistributions in binary form must reproduce the above copyright
19
* notice, this list of conditions and the following disclaimer in the
20
* documentation and/or other materials provided with the distribution.
21
22
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
23
* AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
24
* IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
25
* ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
26
* LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
27
* CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
28
* SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
29
* INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
30
* CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
31
* ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
32
* POSSIBILITY OF SUCH DAMAGE.
33
34
35
#ifndef _RTEMS_SPURIOUS_H
36
#define _RTEMS_SPURIOUS_H
37
38
rtems/rtems/types.h
/* rtems_id */
39
rtems/io.h
/* rtems_device_driver */
40
41
#ifdef __cplusplus
42
extern
"C"
43
#endif
44
45
#define SPURIOUS_DRIVER_TABLE_ENTRY \
46
{ Spurious_Initialize, NULL, NULL, NULL, NULL, NULL }
47
48
rtems_device_driver
Spurious_Initialize(
49
rtems_device_major_number
50
rtems_device_minor_number
51
void
52
rtems_id
53
uint32_t *
54
55
56
#ifdef __cplusplus
57
58
#endif
59
60
#endif
61
/* end of include file */
io.h
This header file defines the IO Manager API.
types.h
This header file provides types used by the Classic API.
rtems_device_driver
rtems_status_code rtems_device_driver
This type shall be used in device driver entry declarations and definitions.
Definition
io.h:90
uint32_t rtems_device_major_number
This integer type represents the major number of devices.
Definition
io.h:103
uint32_t rtems_device_minor_number
This integer type represents the minor number of devices.
Definition
io.h:115
rtems_id
Objects_Id rtems_id
This type represents RTEMS object identifiers.
Definition
types.h:94
