RTEMS
6.3
Toggle main menu visibility
include
version.h
1
/* SPDX-License-Identifier: BSD-2-Clause */
2
10
11
12
* Copyright (C) 2017.
13
* Chris Johns <chrisj@rtems.org>
14
15
16
* modification, are permitted provided that the following conditions
17
* are met:
18
* 1. Redistributions of source code must retain the above copyright
19
* notice, this list of conditions and the following disclaimer.
20
* 2. Redistributions in binary form must reproduce the above copyright
21
* notice, this list of conditions and the following disclaimer in the
22
* documentation and/or other materials provided with the distribution.
23
24
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
25
* AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
26
* IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
27
* ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
28
* LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
29
* CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
30
* SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
31
* INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
32
* CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
33
* ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
34
* POSSIBILITY OF SUCH DAMAGE.
35
36
37
#ifndef _RTEMS_VERSION_H
38
#define _RTEMS_VERSION_H
39
40
#include <stdbool.h>
41
42
#ifdef __cplusplus
43
extern
"C"
44
#endif
45
77
83
const
char
rtems_version
void
84
90
int
rtems_version_major
void
91
97
int
rtems_version_minor
void
98
104
int
rtems_version_revision
void
105
120
const
char
rtems_version_control_key
void
121
130
static
inline
bool
rtems_version_control_key_is_valid(
const
char
*key )
131
132
return
key[ 0 ] !=
'\0'
133
134
147
const
char
rtems_version_release_label
void
148
155
bool
rtems_version_release_label_is_valid
void
156
162
const
char
rtems_board_support_package
void
163
165
166
#ifdef __cplusplus
167
168
#endif
169
170
#endif
171
/* end of include file */
rtems_version_major
int rtems_version_major(void)
Returns the version's major number.
Definition
version.c:65
rtems_version
const char * rtems_version(void)
Returns the version string.
Definition
version.c:56
bool rtems_version_release_label_is_valid(void)
Returns true, if the release label is valid, otherwise false.
Definition
version.c:102
int rtems_version_revision(void)
Returns the version's revision number.
Definition
version.c:75
const char * rtems_version_control_key(void)
Returns the version control key for the current version of code that has been built.
Definition
version.c:80
const char * rtems_board_support_package(void)
Returns the board support package name.
Definition
rtems-version.c:42
rtems_version_minor
int rtems_version_minor(void)
Returns the version's minor number.
Definition
version.c:70
const char * rtems_version_release_label(void)
Returns the revision label for the current version of code that has been built.
Definition
version.c:89
