RTEMS 6.3
This group contains the User Extensions Manager implementation. More...
Files | |
| file | cpukit/include/rtems/extension.h |
| This header file defines the User Extensions Manager API. | |
| file | cpukit/include/rtems/extensiondata.h |
| This header file provides data structures used by the implementation and the Application Configuration to define _Extension_Information. | |
| file | cpukit/include/rtems/extensionimpl.h |
| Classic User Extensions Implementation. | |
| file | cpukit/sapi/src/extension.c |
| This source file contains a definition of the _Extension_Information with zero objects. | |
| file | cpukit/sapi/src/extensioncreate.c |
| This source file contains the implementation of rtems_extension_create() and the User Extensions Manager system initialization. | |
| file | cpukit/sapi/src/extensiondelete.c |
| This source file contains the implementation of rtems_extension_delete(). | |
| file | cpukit/sapi/src/extensionident.c |
| This source file contains the implementation of rtems_extension_ident(). | |
| struct | Extension_Control |
| #define | EXTENSION_INFORMATION_DEFINE(max) |
| Macro to define the objects information for the Classic Extensions objects. | |
| Objects_Information | _Extension_Information |
| The Classic Extensions objects information. | |
| #define EXTENSION_INFORMATION_DEFINE | ( | max | ) |
This macro should only be used by <rtems/confdefs.h>.
| max | The configured object maximum (the OBJECTS_UNLIMITED_OBJECTS flag may be set). |
