RTEMS 6.3
captureimpl.h File Reference
Capture Implementation file. More...
#include "capture.h"
void rtems_capture_set_extension_index (int index)
 Capture set extension index.
int rtems_capture_get_extension_index (void)
 Capture get extension index.
uint32_t rtems_capture_get_flags (void)
 Capture get flags.
void rtems_capture_set_flags (uint32_t mask)
 Capture set flags.
rtems_status_code rtems_capture_user_extension_open (void)
 Capture user extension open.
rtems_status_code rtems_capture_user_extension_close (void)
 Capture user extension close.
bool rtems_capture_trigger_fired (rtems_tcb *ft, rtems_tcb *tt, uint32_t events)
 Capture check trigger.
void rtems_capture_print_trace_records (int total, bool csv)
 Capture print trace records.
void rtems_capture_print_timestamp (uint64_t uptime)
 Capture print timestamp.
void rtems_capture_print_record_task (int cpu, const rtems_capture_record *rec, const rtems_capture_task_record *task_rec)
 Capture print record task.
void rtems_capture_print_record_capture (int cpu, const rtems_capture_record *rec, uint64_t diff, const rtems_name *name)
 Capture print capture record.
void rtems_capture_print_watch_list (void)
 Capture print watch list.
This file contains an interface between the capture engine and capture user extension methods.
◆ rtems_capture_get_extension_index()
int rtems_capture_get_extension_index ( void )
This function rturns the extension index for the capture engine.
Return values
Thismethod returns the extension index.
◆ rtems_capture_get_flags()
uint32_t rtems_capture_get_flags ( void )
Capture get flags.
This function gets the current flag settings for the capture engine.
Return values
Thismethod returns the global capture flags.
◆ rtems_capture_print_record_capture()
void rtems_capture_print_record_capture ( int cpu,
const rtems_capture_record * rec,
uint64_t diff,
const rtems_name * name )
This function prints a user extension capture record.
Parameters
[in]cpuspecifies the cpu the cpu the record was logged on.
[in]recspecifies the record.
[in]diffspecifies the time between this and the last capture record.
[in]namespecifies the name of the task, NULL if none.
[in]task_countnumber of tasks to search for.
◆ rtems_capture_print_record_task()
void rtems_capture_print_record_task ( int cpu,
const rtems_capture_task_record * task_rec )
This function prints a capture record task. This record contains information to identify a task. It is refrenced in other records by the task id.
Parameters
[in]recspecifies the task record.
◆ rtems_capture_print_timestamp()
void rtems_capture_print_timestamp ( uint64_t uptime)
This function prints uptime in a timestamp format.
Parameters
[in]uptimespecifies the timestamp to print
◆ rtems_capture_print_trace_records()
void rtems_capture_print_trace_records ( int total,
bool csv )
This function reads, prints and releases up to total trace records in either a csv format or an ascii table format.
Parameters
[in]totalspecifies the number of records to print
[in]csvspecifies a comma seperated value format
◆ rtems_capture_print_watch_list()
void rtems_capture_print_watch_list ( void )
This function prints a capture watch list
◆ rtems_capture_set_extension_index()
void rtems_capture_set_extension_index ( int index)
This function is used to set the extension index for the capture engine.
Parameters
[in]indexspecifies the extension index to be used for capture engine data.
◆ rtems_capture_set_flags()
void rtems_capture_set_flags ( uint32_t mask)
Capture set flags.
This function sets a flag in the capture engine
Parameters
[in]maskspecifies the flag to set
◆ rtems_capture_trigger_fired()
bool rtems_capture_trigger_fired ( rtems_tcb * ft,
rtems_tcb * tt,
uint32_t events )
This function checks if we have triggered or if this event is a cause of a trigger.
Parameters
[in]ftspecifies specifices the capture from task
[in]ttspecifies specifices the capture to task
[in]eventsspecifies the events
Return values
Thismethod returns true if we have triggered or if the event is a cause of a trigger.
◆ rtems_capture_user_extension_close()
rtems_status_code rtems_capture_user_extension_close ( void )
This function closes the capture user extensions.
Return values
Thismethod returns RTEMS_SUCCESSFUL upon a successful delete of the user extensions.
◆ rtems_capture_user_extension_open()
rtems_status_code rtems_capture_user_extension_open ( void )
This function creates the capture user extensions.
Return values
Thismethod returns RTEMS_SUCCESSFUL upon successful creation of the user extensions.
