RTEMS
6.3
Toggle main menu visibility
include
ringbuf.h
1
/* SPDX-License-Identifier: BSD-2-Clause */
2
10
11
12
* COPYRIGHT (C) 1989-1999 On-Line Applications Research Corporation (OAR).
13
14
15
* modification, are permitted provided that the following conditions
16
* are met:
17
* 1. Redistributions of source code must retain the above copyright
18
* notice, this list of conditions and the following disclaimer.
19
* 2. Redistributions in binary form must reproduce the above copyright
20
* notice, this list of conditions and the following disclaimer in the
21
* documentation and/or other materials provided with the distribution.
22
23
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
24
* AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
25
* IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
26
* ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
27
* LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
28
* CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
29
* SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
30
* INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
31
* CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
32
* ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
33
* POSSIBILITY OF SUCH DAMAGE.
34
35
36
#ifndef _RTEMS_RINGBUF_H
37
#define _RTEMS_RINGBUF_H
38
39
rtems.h
40
41
#ifndef RINGBUF_QUEUE_LENGTH
42
#define RINGBUF_QUEUE_LENGTH 128
43
#endif
44
45
typedef
struct
46
uint8_t buffer[RINGBUF_QUEUE_LENGTH];
47
volatile
int
head;
48
volatile
int
tail;
49
rtems_interrupt_lock
lock;
50
Ring_buffer_t
51
52
#define Ring_buffer_Initialize( _buffer ) \
53
do { \
54
(_buffer)->head = (_buffer)->tail = 0; \
55
rtems_interrupt_lock_initialize(&(_buffer)->lock, "ring buffer"); \
56
} while ( 0 )
57
58
#define Ring_buffer_Destory( _buffer ) \
59
do { \
60
rtems_interrupt_lock_destroy(&(_buffer)->lock); \
61
} while ( 0 )
62
63
#define Ring_buffer_Is_empty( _buffer ) \
64
( (_buffer)->head == (_buffer)->tail )
65
66
#define Ring_buffer_Is_full( _buffer ) \
67
( (_buffer)->head == ((_buffer)->tail + 1) % RINGBUF_QUEUE_LENGTH )
68
69
#define Ring_buffer_Add_character( _buffer, _ch ) \
70
do { \
71
rtems_interrupt_lock_context lock_context; \
72
73
rtems_interrupt_lock_acquire( &(_buffer)->lock, &lock_context ); \
74
(_buffer)->tail = ((_buffer)->tail+1) % RINGBUF_QUEUE_LENGTH; \
75
(_buffer)->buffer[ (_buffer)->tail ] = (_ch); \
76
rtems_interrupt_lock_release( &(_buffer)->lock, &lock_context ); \
77
} while ( 0 )
78
79
#define Ring_buffer_Remove_character( _buffer, _ch ) \
80
do { \
81
82
83
84
(_buffer)->head = ((_buffer)->head+1) % RINGBUF_QUEUE_LENGTH; \
85
(_ch) = (_buffer)->buffer[ (_buffer)->head ]; \
86
87
} while ( 0 )
88
89
#endif
char rtems_interrupt_lock
This structure represents an ISR lock.
Definition
intr.h:532
rtems.h
Ring_buffer_t
Definition
ringbuf.h:45
