RTEMS 6.3
irq.h
2
9
10/*
11 * CopyRight (C) 1998 valette@crf.canon.fr
12 *
13 * This code is heavilly inspired by the public specification of STREAM V2
14 * that can be found at :
15 *
16 * <http://www.chorus.com/Documentation/index.html> by following
17 * the STREAM API Specification Document link.
18 *
19 * Redistribution and use in source and binary forms, with or without
20 * modification, are permitted provided that the following conditions
21 * are met:
22 * 1. Redistributions of source code must retain the above copyright
23 * notice, this list of conditions and the following disclaimer.
24 * 2. Redistributions in binary form must reproduce the above copyright
25 * notice, this list of conditions and the following disclaimer in the
26 * documentation and/or other materials provided with the distribution.
27 *
28 * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
29 * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
30 * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
31 * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
32 * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
33 * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
34 * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
35 * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
36 * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
37 * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
38 * POSSIBILITY OF SUCH DAMAGE.
39 */
40
41#ifndef _RTEMS_IRQ_H
42#define _RTEMS_IRQ_H
43
44#ifndef ASM
45
46#ifdef __cplusplus
47extern "C" {
48#endif
49
50
51/*
52 * Type definition for RTEMS managed interrupts
53 */
54typedef unsigned char rtems_irq_prio;
55struct __rtems_irq_connect_data__; /* forward declaratiuon */
56
57typedef unsigned int rtems_irq_number;
58typedef void *rtems_irq_hdl_param;
59typedef void (*rtems_irq_hdl) (rtems_irq_hdl_param);
60typedef void (*rtems_irq_enable) (const struct __rtems_irq_connect_data__*);
61typedef void (*rtems_irq_disable) (const struct __rtems_irq_connect_data__*);
62typedef int (*rtems_irq_is_enabled) (const struct __rtems_irq_connect_data__*);
63
65 /*
66 * IRQ line
67 */
68 rtems_irq_number name;
69 /*
70 * handler. See comment on handler properties below in function prototype.
71 */
72 rtems_irq_hdl hdl;
73 /*
74 * Handler handle to store private data
75 */
76 rtems_irq_hdl_param handle;
77 /*
78 * function for enabling interrupts at device level (ONLY!).
79 * The BSP code will automatically enable it at i8259s level.
80 * RATIONALE : anyway such code has to exist in current driver code.
81 * It is usually called immediately AFTER connecting the interrupt handler.
82 * RTEMS may well need such a function when restoring normal interrupt
83 * processing after a debug session.
84 *
85 */
86 rtems_irq_enable on;
87 /*
88 * function for disabling interrupts at device level (ONLY!).
89 * The code will disable it at i8259s level. RATIONALE : anyway
90 * such code has to exist for clean shutdown. It is usually called
91 * BEFORE disconnecting the interrupt. RTEMS may well need such
92 * a function when disabling normal interrupt processing for
93 * a debug session. May well be a NOP function.
94 */
95 rtems_irq_disable off;
96 /*
97 * function enabling to know what interrupt may currently occur
98 * if someone manipulates the i8259s interrupt mask without care...
99 */
100 rtems_irq_is_enabled isOn;
101
102#ifdef BSP_SHARED_HANDLER_SUPPORT
103 /*
104 * Set to -1 for vectors forced to have only 1 handler
105 */
106 void *next_handler;
107#endif
108
109} rtems_irq_connect_data;
110
111typedef struct {
112 /*
113 * size of all the table fields (*Tbl) described below.
114 */
115 unsigned int irqNb;
116 /*
117 * Default handler used when disconnecting interrupts.
118 */
119 rtems_irq_connect_data defaultEntry;
120 /*
121 * Table containing initials/current value.
122 */
123 rtems_irq_connect_data* irqHdlTbl;
124 /*
125 * actual value of BSP_ISA_IRQ_VECTOR_BASE...
126 */
127 rtems_irq_number irqBase;
128 /*
129 * software priorities associated with interrupts.
130 * if (*irqPrio [i] > intrPrio [j] it means that
131 * interrupt handler hdl connected for interrupt name i
132 * will not be interrupted by the handler connected for interrupt j
133 * The interrupt source will be physically masked at i8259 level.
134 */
135 rtems_irq_prio* irqPrioTbl;
137
138/*-------------------------------------------------------------------------+
139| Function Prototypes.
140+--------------------------------------------------------------------------*/
141/*
142 * -------------------- RTEMS Single Irq Handler Mngt Routines ----------------
143 */
144/*
145 * function to connect a particular irq handler. This hanlder will NOT be called
146 * directly as the result of the corresponding interrupt. Instead, a RTEMS
147 * irq prologue will be called that will :
148 *
149 * 1) save the C scratch registers,
150 * 2) switch to a interrupt stack if the interrupt is not nested,
151 * 3) store the current i8259s' interrupt masks
152 * 4) modify them to disable the current interrupt at 8259 level (and may
153 * be others depending on software priorities)
154 * 5) aknowledge the i8259s',
155 * 6) demask the processor,
156 * 7) call the application handler
157 *
158 * As a result the hdl function provided
159 *
160 * a) can perfectly be written is C,
161 * b) may also well directly call the part of the RTEMS API that can be
162 * used from interrupt level,
163 * c) It only responsible for handling the jobs that need to be done at
164 * the device level including (aknowledging/re-enabling the interrupt at
165 * device level, getting the data,...)
166 *
167 * When returning from the function, the following will be performed by
168 * the RTEMS irq epilogue :
169 *
170 * 1) masks the interrupts again,
171 * 2) restore the original i8259s' interrupt masks
172 * 3) switch back on the orinal stack if needed,
173 * 4) perform rescheduling when necessary,
174 * 5) restore the C scratch registers...
175 * 6) restore initial execution flow
176 *
177 */
178int BSP_install_rtems_irq_handler (const rtems_irq_connect_data*);
179/*
180 * function to get the current RTEMS irq handler for ptr->name. It enables to
181 * define hanlder chain...
182 */
183int BSP_get_current_rtems_irq_handler (rtems_irq_connect_data* ptr);
184/*
185 * function to get disconnect the RTEMS irq handler for ptr->name.
186 * This function checks that the value given is the current one for safety reason.
187 * The user can use the previous function to get it.
188 */
189int BSP_remove_rtems_irq_handler (const rtems_irq_connect_data*);
190
191
192/*
193 * ----------------- RTEMS Shared Irq Handler Mngt Routines ----------------
194 */
195#ifdef BSP_SHARED_HANDLER_SUPPORT
196int BSP_install_rtems_shared_irq_handler (const rtems_irq_connect_data*);
197#endif
198
199/*
200 * Less cumbersome, alternate entry points;
201 * RETURNS: more traditional, 0 on success, nonzero on error
202 *
203 * The BSP_rtems_int_connect() and BSP_rtems_int_disconnect() functions are
204 * only present on some PowerPC BSPs. Do not use them. Use
205 * rtems_interrupt_handler_install() instead.
206 */
207
208int BSP_rtems_int_connect(
209 rtems_irq_number n,
210 rtems_irq_hdl hdl,
211 rtems_irq_hdl_param p
212);
213
214int BSP_rtems_int_disconnect(
215 rtems_irq_number n,
216 rtems_irq_hdl hdl,
217 rtems_irq_hdl_param p
218);
219
220/*
221 * ----------------- RTEMS Global Irq Handler Mngt Routines ----------------
222 */
223/*
224 * (Re) Initialize the RTEMS interrupt management.
225 *
226 * The result of calling this function will be the same as if each individual
227 * handler (config->irqHdlTbl[i].hdl) different from "config->defaultEntry.hdl"
228 * has been individualy connected via
229 * BSP_install_rtems_irq_handler(&config->irqHdlTbl[i])
230 * And each handler currently equal to config->defaultEntry.hdl
231 * has been previously disconnected via
232 * BSP_remove_rtems_irq_handler (&config->irqHdlTbl[i])
233 *
234 * This is to say that all information given will be used and not just
235 * only the space.
236 *
237 * CAUTION : the various table address contained in config will be used
238 * directly by the interrupt mangement code in order to save
239 * data size so they must stay valid after the call => they should
240 * not be modified or declared on a stack.
241 */
242
243int BSP_rtems_irq_mngt_set(rtems_irq_global_settings* config);
244
245/*
246 * (Re) get info on current RTEMS interrupt management.
247 */
248int BSP_rtems_irq_mngt_get(rtems_irq_global_settings**);
249
250#ifdef __cplusplus
251}
252#endif
253
254#endif /* ASM */
255#endif /* _RTEMS_IRQ_H */
Definition irq.h:64
Definition irq.h:111
unsigned p
Definition tte.h:17
