85#define IMFS_MEMFILE_DEFAULT_BYTES_PER_BLOCK 128
86 extern const int imfs_memfile_bytes_per_block;
88#define IMFS_MEMFILE_BYTES_PER_BLOCK imfs_memfile_bytes_per_block
89#define IMFS_MEMFILE_BLOCK_SLOTS \
90 (IMFS_MEMFILE_BYTES_PER_BLOCK / sizeof(void *))
92typedef uint8_t *block_p;
93typedef block_p *block_ptr;
98#define FIRST_INDIRECT (0)
99#define LAST_INDIRECT (IMFS_MEMFILE_BLOCK_SLOTS - 1)
101#define FIRST_DOUBLY_INDIRECT (LAST_INDIRECT + 1)
102#define LAST_DOUBLY_INDIRECT \
104 (IMFS_MEMFILE_BLOCK_SLOTS * IMFS_MEMFILE_BLOCK_SLOTS))
106#define FIRST_TRIPLY_INDIRECT (LAST_DOUBLY_INDIRECT + 1)
107#define LAST_TRIPLY_INDIRECT \
108 (LAST_DOUBLY_INDIRECT +\
109 (IMFS_MEMFILE_BLOCK_SLOTS * \
110 IMFS_MEMFILE_BLOCK_SLOTS * IMFS_MEMFILE_BLOCK_SLOTS))
112#define IMFS_MEMFILE_MAXIMUM_SIZE \
113 (LAST_TRIPLY_INDIRECT * IMFS_MEMFILE_BYTES_PER_BLOCK)
136typedef IMFS_jnode_t *(*IMFS_node_control_initialize)(
156IMFS_jnode_t *IMFS_node_initialize_directory(
188typedef IMFS_jnode_t *(*IMFS_node_control_remove)(
205IMFS_jnode_t *IMFS_node_remove_directory( IMFS_jnode_t *node );
238 const rtems_filesystem_file_handlers_r *handlers;
260#define IMFS_NAME_MAX _POSIX_NAME_MAX
268 rtems_chain_node Node;
269 IMFS_jnode_t *Parent;
273 unsigned short reference_count;
287 rtems_chain_control Entries;
288 rtems_filesystem_mount_table_entry_t *mt_fs;
299 IMFS_jnode_t *link_node;
315 block_ptr doubly_indirect;
316 block_ptr triply_indirect;
334 pipe_control_t *pipe;
347static inline IMFS_jnode_t *IMFS_iop_to_node(
const rtems_libio_t *iop )
349 return (IMFS_jnode_t *) iop->pathinfo.node_access;
353 const rtems_libio_t *iop
359static inline IMFS_device_t *IMFS_iop_to_device(
364static inline IMFS_file_t *IMFS_iop_to_file(
369static inline IMFS_memfile_t *IMFS_iop_to_memfile(
388 const rtems_filesystem_operations_table *ops;
410extern int IMFS_initialize(
411 rtems_filesystem_mount_table_entry_t *mt_entry,
415extern int IMFS_initialize_support(
416 rtems_filesystem_mount_table_entry_t *mt_entry,
424 rtems_filesystem_mount_table_entry_t *mt_entry
479 const char *mountpoint,
480 const void *tar_image,
509extern int IMFS_stat_file(
567extern IMFS_jnode_t *IMFS_initialize_node(
592static inline bool IMFS_is_imfs_instance(
606#define IMFS_NODE_CONTROL_INITIALIZER( handlers, init, destroy ) \
610 IMFS_node_remove_default, \
626#define IMFS_NODE_INITIALIZER( node_control, name, namelen, mode ) \
656static inline void IMFS_node_preinitialize(
664 node->control = node_control;
666 node->namelen = namelen;
667 node->st_mode = mode;
683int IMFS_add_node(
const char *path, IMFS_jnode_t *node,
void *arg );
685extern int IMFS_make_node(
730#define IMFS_GENERIC_INITIALIZER( handlers, init, destroy ) \
731 IMFS_NODE_CONTROL_INITIALIZER( handlers, init, destroy )
740#define IMFS_GENERIC_CONTROL_INITIALIZER( handlers, init, destroy ) \
741 IMFS_NODE_CONTROL_INITIALIZER( handlers, init, destroy )
753#define IMFS_GENERIC_NODE_INITIALIZER( node_control, name, namelen, mode ) \
754 { IMFS_NODE_INITIALIZER( node_control, name, namelen, mode ), NULL }
769static inline void IMFS_generic_node_preinitialize(
777 IMFS_node_preinitialize( &node->Node, node_control, name, namelen, mode );
858 rtems_filesystem_mount_table_entry_t *mt_entry
865 rtems_filesystem_mount_table_entry_t *mt_entry
879extern ssize_t IMFS_memfile_write(
882 const unsigned char *source,
896extern int device_open(
898 const char *pathname,
903extern int device_close(
907extern ssize_t device_read(
913extern ssize_t device_write(
919extern int device_ioctl(
921 ioctl_command_t command,
925extern int device_ftruncate(
941 struct timespec
times[2]
1009 #define IMFS_assert(_x) assert(_x)
1011 #define IMFS_assert(_x)
1016 IMFS_jnode_t *node = (IMFS_jnode_t *) loc->node_access;
1018 loc->handlers = node->control->handlers;
1021static inline void IMFS_add_to_directory(
1022 IMFS_jnode_t *dir_node,
1023 IMFS_jnode_t *entry_node
1028 entry_node->Parent = dir_node;
1029 rtems_chain_append_unprotected( &dir->Entries, &entry_node->Node );
1032static inline void IMFS_remove_from_directory( IMFS_jnode_t *node )
1034 IMFS_assert( node->Parent != NULL );
1035 node->Parent = NULL;
1036 rtems_chain_extract_unprotected( &node->Node );
1039static inline bool IMFS_is_directory(
const IMFS_jnode_t *node )
1041 return S_ISDIR( node->st_mode );
1044#define IMFS_STAT_FMT_HARD_LINK 0
1046static inline bool IMFS_is_hard_link( mode_t mode )
1048 return ( mode & S_IFMT ) == IMFS_STAT_FMT_HARD_LINK;
1051static inline ino_t IMFS_node_to_ino(
1053 return (ino_t) ((uintptr_t) node);
1063static inline void *IMFS_generic_get_context_by_node(
1064 const IMFS_jnode_t *node
1069 return generic->context;
1072static inline void *IMFS_generic_get_context_by_location(
1076 return loc->node_access_2;
1079static inline void *IMFS_generic_get_context_by_iop(
1080 const rtems_libio_t *iop
1083 return IMFS_generic_get_context_by_location( &iop->pathinfo );
1086static inline dev_t IMFS_generic_get_device_identifier_by_node(
1087 const IMFS_jnode_t *node
1090 return rtems_filesystem_make_dev_t_from_pointer( node );
clock_t times(struct tms *ptms)
Definition __times.c:97
This header file provides the interfaces of the Assert Handler.
void IMFS_do_nothing_destroy(IMFS_jnode_t *node)
Does nothing.
Definition imfs_node.c:125
IMFS_jnode_t *(*) IMFS_node_control_initialize(IMFS_jnode_t *node, void *arg)
Initializes an IMFS node.
Definition imfs.h:136
IMFS_jnode_t * IMFS_node_initialize_default(IMFS_jnode_t *node, void *arg)
Returns the node and does nothing else.
Definition imfs_initsupp.c:91
IMFS_jnode_t * IMFS_node_remove_default(IMFS_jnode_t *node)
Definition imfs_node.c:118
IMFS_jnode_t * IMFS_node_initialize_generic(IMFS_jnode_t *node, void *arg)
Returns the node and sets the generic node context.
Definition imfs_make_generic_node.c:44
int IMFS_make_generic_node(const char *path, mode_t mode, const IMFS_node_control *node_control, void *context)
Makes a generic IMFS node.
Definition imfs_make_generic_node.c:56
void IMFS_node_destroy_default(IMFS_jnode_t *node)
Frees the node.
Definition imfs_node_destroy_default.c:44
IMFS_jnode_t *(*) IMFS_node_control_remove(IMFS_jnode_t *node)
Prepares the removal of an IMFS node from its parent directory.
Definition imfs.h:188
void(*) IMFS_node_control_destroy(IMFS_jnode_t *node)
Destroys an IMFS node.
Definition imfs.h:214
int IMFS_chown(const rtems_filesystem_location_info_t *loc, uid_t owner, gid_t group)
Change the owner of IMFS.
Definition imfs_chown.c:47
int IMFS_rmnod(const rtems_filesystem_location_info_t *parentloc, const rtems_filesystem_location_info_t *loc)
IMFS node removal handler.
Definition imfs_rmnod.c:46
int IMFS_link(const rtems_filesystem_location_info_t *parentloc, const rtems_filesystem_location_info_t *targetloc, const char *name, size_t namelen)
Create a new IMFS link node.
Definition imfs_link.c:45
int IMFS_rename(const rtems_filesystem_location_info_t *oldparentloc, const rtems_filesystem_location_info_t *oldloc, const rtems_filesystem_location_info_t *newparentloc, const char *name, size_t namelen)
Rename the IMFS.
Definition imfs_rename.c:69
void IMFS_fsunmount(rtems_filesystem_mount_table_entry_t *mt_entry)
Unmount this instance of IMFS.
Definition imfs_fsunmount.c:55
int IMFS_make_linearfile(const char *path, mode_t mode, const void *data, size_t size)
Makes a linear IMFS file.
Definition imfs_make_linfile.c:34
int rtems_tarfs_load(const char *mountpoint, const void *tar_image, size_t tar_size)
RTEMS load tarfs.
Definition imfs_load_tar.c:46
void IMFS_node_free(const rtems_filesystem_location_info_t *loc)
Free an IMFS node.
Definition imfs_node.c:107
int IMFS_unmount(rtems_filesystem_mount_table_entry_t *mt_entry)
Unmount an IMFS.
Definition imfs_unmount.c:46
void IMFS_node_destroy(IMFS_jnode_t *node)
Destroy an IMFS node.
Definition imfs_node.c:100
int IMFS_symlink(const rtems_filesystem_location_info_t *parentloc, const char *name, size_t namelen, const char *target)
Create a new IMFS symbolic link node.
Definition imfs_symlink.c:47
int IMFS_add_node(const char *path, IMFS_jnode_t *node, void *arg)
Adds an IMFS node.
Definition imfs_add_node.c:42
int IMFS_node_clone(rtems_filesystem_location_info_t *loc)
Clone an IMFS node.
Definition imfs_node.c:91
int IMFS_mount(rtems_filesystem_mount_table_entry_t *mt_entry)
Mount an IMFS.
Definition imfs_mount.c:46
int IMFS_utimens(const rtems_filesystem_location_info_t *loc, struct timespec times[2])
Set IMFS file access and modification times.
Definition imfs_utimens.c:44
int IMFS_mknod(const rtems_filesystem_location_info_t *parentloc, const char *name, size_t namelen, mode_t mode, dev_t dev)
Create an IMFS node.
Definition imfs_mknod.c:63
void IMFS_eval_path(rtems_filesystem_eval_path_context_t *ctx)
IMFS evaluation node support.
Definition imfs_eval.c:195
IMFS_jnode_t * IMFS_create_node(const rtems_filesystem_location_info_t *parentloc, const IMFS_node_control *node_control, size_t node_size, const char *name, size_t namelen, mode_t mode, void *arg)
Definition imfs_creat.c:45
int IMFS_stat(const rtems_filesystem_location_info_t *loc, struct stat *buf)
Perform a status processing for the IMFS.
Definition imfs_stat.c:46
ssize_t IMFS_readlink(const rtems_filesystem_location_info_t *loc, char *buf, size_t bufsize)
Put IMFS symbolic link into buffer.
Definition imfs_symlink.c:76
int IMFS_fchmod(const rtems_filesystem_location_info_t *loc, mode_t mode)
Change the IMFS file mode.
Definition imfs_fchmod.c:43
void IMFS_eval_path_devfs(rtems_filesystem_eval_path_context_t *ctx)
IMFS device filesystem evaluation node support.
Definition imfs_eval_devfs.c:123
struct rtems_filesystem_location_info_tt rtems_filesystem_location_info_t
File system location.
uint32_t rtems_device_major_number
This integer type represents the major number of devices.
Definition io.h:103
uint32_t rtems_device_minor_number
This integer type represents the minor number of devices.
Definition io.h:115
LibIO Internal Interface.
POSIX FIFO/pipe File System Support.
IMFS node control.
Definition imfs.h:237
Path evaluation context.
Definition libio.h:105
Contain file system specific information which is required to support fpathconf().
Definition libio.h:1309
unsigned context
Definition tlb.h:1
