RTEMS 6.3
confdefs Directory Reference
bdbuf.h
 This header file evaluates configuration options related to the block device cache configuration.
bsp.h
 This header file evaluates configuration options related to the BSP configuration.
clock.h
 This header file evaluates configuration options related to the clock driver configuration.
console.h
 This header file evaluates configuration options related to the console driver configuration.
extensions.h
 This header file evaluates configuration options related to the user extensions configuration.
face.h
 This header file evaluates configuration options related to the FACE Technical Standard.
inittask.h
 This header file evaluates configuration options related to the Classic API initialization task configuration.
initthread.h
 This header file evaluates configuration options related to the POSIX initialization thread configuration.
iodrivers.h
 This header file evaluates configuration options related to the I/O driver configuration.
libio.h
 This header file evaluates configuration options related to the I/O library configuration.
libpci.h
 This header file evaluates configuration options related to the PCI library configuration.
malloc.h
 This header file evaluates configuration options related to the C Program Heap configuration.
mpci.h
 This header file evaluates configuration options related to the MPCI configuration.
newlib.h
 This header file evaluates configuration options related to the Newlib C Library configuration.
objectsclassic.h
 This header file evaluates configuration options related to the Classic API objects configuration.
objectsposix.h
 This header file evaluates configuration options related to the POSIX API objects configuration.
obsolete.h
 This header file evaluates configuration options related to obsolete configuration options.
percpu.h
 This header file evaluates configuration options related to the per-CPU configuration.
scheduler.h
 This header file evaluates configuration options related to the scheduler configuration.
threads.h
 This header file evaluates configuration options related to the thread configuration.
unlimited.h
 This header file evaluates configuration options related to the unlimited objects configuration.
wkspace.h
 This header file evaluates configuration options related to the RTEMS Workspace configuration.
wkspacesupport.h
 This header file provides support macros to evaluate configuration options related to the RTEMS Workspace configuration.
