| #define | T_ARRAY_SIZE(array) |
#define | T_FILE_NAME __FILE__ |
#define | T_ZERO_LENGTH_ARRAY 1 |
#define | T_NO_RETURN _Noreturn |
#define | T_CHECK_STOP 1U |
#define | T_CHECK_QUIET 2U |
#define | T_CHECK_FMT 4U |
#define | T_CHECK_STEP_FLAG 8U |
| #define | T_CHECK_STEP_TO_FLAGS(step) |
| #define | T_CHECK_STEP_FROM_FLAGS(flags) |
| #define | T_CHECK_STEP(step) |
| #define | T_VA_ARGS_FIRST(...) |
| #define | T_VA_ARGS_FIRST_SELECT(first, ...) |
| #define | T_VA_ARGS_MORE(...) |
| #define | T_VA_ARGS_XEXPAND(kind, ...) |
| #define | T_VA_ARGS_EXPAND(kind, ...) |
#define | T_VA_ARGS_EXPAND_0U(first) |
| #define | T_VA_ARGS_EXPAND_4U(first, ...) |
| #define | T_VA_ARGS_KIND(...) |
| #define | T_VA_ARGS_SELECT(a1, a2, a3, a4, a5, a6, a7, a8, a9, a10, ...) |
| #define | T_flags_true(flags, ...) |
| #define | T_flags_eq(flags, a, ...) |
| #define | T_flags_ne(flags, a, ...) |
| #define | T_flags_eq_ptr(a, e, flags, sa, se) |
| #define | T_flags_ne_ptr(a, e, flags, sa, se) |
| #define | T_flags_null(a, flags, sa) |
| #define | T_flags_not_null(a, flags, sa) |
| #define | T_flags_eq_mem(a, e, n, flags, sa, se, sn) |
| #define | T_flags_ne_mem(a, e, n, flags, sa, se, sn) |
| #define | T_flags_eq_str(a, e, flags) |
| #define | T_flags_ne_str(a, e, flags) |
| #define | T_flags_eq_nstr(a, e, n, flags) |
| #define | T_flags_ne_nstr(a, e, n, flags) |
| #define | T_flags_eq_char(a, e, flags) |
| #define | T_flags_ne_char(a, e, flags) |
| #define | T_flags_eq_int(a, e, flags) |
| #define | T_flags_ne_int(a, e, flags) |
| #define | T_flags_ge_int(a, e, flags) |
| #define | T_flags_gt_int(a, e, flags) |
| #define | T_flags_le_int(a, e, flags) |
| #define | T_flags_lt_int(a, e, flags) |
| #define | T_flags_eq_uint(a, e, flags) |
| #define | T_flags_ne_uint(a, e, flags) |
| #define | T_flags_ge_uint(a, e, flags) |
| #define | T_flags_gt_uint(a, e, flags) |
| #define | T_flags_le_uint(a, e, flags) |
| #define | T_flags_lt_uint(a, e, flags) |
| #define | T_flags_eq_long(a, e, flags) |
| #define | T_flags_ne_long(a, e, flags) |
| #define | T_flags_ge_long(a, e, flags) |
| #define | T_flags_gt_long(a, e, flags) |
| #define | T_flags_le_long(a, e, flags) |
| #define | T_flags_lt_long(a, e, flags) |
| #define | T_flags_eq_ulong(a, e, flags) |
| #define | T_flags_ne_ulong(a, e, flags) |
| #define | T_flags_ge_ulong(a, e, flags) |
| #define | T_flags_gt_ulong(a, e, flags) |
| #define | T_flags_le_ulong(a, e, flags) |
| #define | T_flags_lt_ulong(a, e, flags) |
| #define | T_flags_eq_ll(a, e, flags) |
| #define | T_flags_ne_ll(a, e, flags) |
| #define | T_flags_ge_ll(a, e, flags) |
| #define | T_flags_gt_ll(a, e, flags) |
| #define | T_flags_le_ll(a, e, flags) |
| #define | T_flags_lt_ll(a, e, flags) |
| #define | T_flags_eq_ull(a, e, flags) |
| #define | T_flags_ne_ull(a, e, flags) |
| #define | T_flags_ge_ull(a, e, flags) |
| #define | T_flags_gt_ull(a, e, flags) |
| #define | T_flags_le_ull(a, e, flags) |
| #define | T_flags_lt_ull(a, e, flags) |
| #define | T_flags_eno(a, e, flags) |
| #define | T_flags_eno_success(a, flags) |
| #define | T_flags_psx_error(a, eno, flags) |
| #define | T_flags_psx_success(a, flags) |
| #define | T_true(...) |
| #define | T_assert_true(...) |
| #define | T_quiet_true(...) |
| #define | T_step_true(s, ...) |
| #define | T_step_assert_true(s, ...) |
| #define | T_false(...) |
| #define | T_assert_false(...) |
| #define | T_quiet_false(...) |
| #define | T_step_false(s, ...) |
| #define | T_step_assert_false(s, ...) |
| #define | T_eq(a, ...) |
| #define | T_assert_eq(a, ...) |
| #define | T_quiet_eq(a, ...) |
| #define | T_step_eq(s, a, ...) |
| #define | T_step_assert_eq(s, a, ...) |
| #define | T_ne(a, ...) |
| #define | T_assert_ne(a, ...) |
| #define | T_quiet_ne(a, ...) |
| #define | T_step_ne(s, a, ...) |
| #define | T_step_assert_ne(s, a, ...) |
| #define | T_eq_ptr(a, e) |
| #define | T_assert_eq_ptr(a, e) |
| #define | T_quiet_eq_ptr(a, e) |
| #define | T_step_eq_ptr(s, a, e) |
| #define | T_step_assert_eq_ptr(s, a, e) |
| #define | T_ne_ptr(a, e) |
| #define | T_assert_ne_ptr(a, e) |
| #define | T_quiet_ne_ptr(a, e) |
| #define | T_step_ne_ptr(s, a, e) |
| #define | T_step_assert_ne_ptr(s, a, e) |
| #define | T_null(a) |
| #define | T_assert_null(a) |
| #define | T_quiet_null(a) |
| #define | T_quiet_assert_null(a) |
| #define | T_step_null(s, a) |
| #define | T_step_assert_null(s, a) |
| #define | T_not_null(a) |
| #define | T_assert_not_null(a) |
| #define | T_quiet_not_null(a) |
| #define | T_quiet_assert_not_null(a) |
| #define | T_step_not_null(s, a) |
| #define | T_step_assert_not_null(s, a) |
| #define | T_eq_mem(a, e, n) |
| #define | T_assert_eq_mem(a, e, n) |
| #define | T_quiet_eq_mem(a, e, n) |
| #define | T_step_eq_mem(s, a, e, n) |
| #define | T_step_assert_eq_mem(s, a, e, n) |
| #define | T_ne_mem(a, e, n) |
| #define | T_assert_ne_mem(a, e, n) |
| #define | T_quiet_ne_mem(a, e, n) |
| #define | T_step_ne_mem(s, a, e, n) |
| #define | T_step_assert_ne_mem(s, a, e, n) |
| #define | T_eq_str(a, e) |
| #define | T_assert_eq_str(a, e) |
| #define | T_quiet_eq_str(a, e) |
| #define | T_step_eq_str(s, a, e) |
| #define | T_step_assert_eq_str(s, a, e) |
| #define | T_ne_str(a, e) |
| #define | T_assert_ne_str(a, e) |
| #define | T_quiet_ne_str(a, e) |
| #define | T_step_ne_str(s, a, e) |
| #define | T_step_assert_ne_str(s, a, e) |
| #define | T_eq_nstr(a, e, n) |
| #define | T_assert_eq_nstr(a, e, n) |
| #define | T_quiet_eq_nstr(a, e, n) |
| #define | T_step_eq_nstr(s, a, e, n) |
| #define | T_step_assert_eq_nstr(s, a, e, n) |
| #define | T_ne_nstr(a, e, n) |
| #define | T_assert_ne_nstr(a, e, n) |
| #define | T_quiet_ne_nstr(a, e, n) |
| #define | T_step_ne_nstr(s, a, e, n) |
| #define | T_step_assert_ne_nstr(s, a, e, n) |
| #define | T_eq_char(a, e) |
| #define | T_assert_eq_char(a, e) |
| #define | T_quiet_eq_char(a, e) |
| #define | T_step_eq_char(s, a, e) |
| #define | T_step_assert_eq_char(s, a, e) |
| #define | T_ne_char(a, e) |
| #define | T_assert_ne_char(a, e) |
| #define | T_quiet_ne_char(a, e) |
| #define | T_step_ne_char(s, a, e) |
| #define | T_step_assert_ne_char(s, a, e) |
| #define | T_eq_schar(a, e) |
| #define | T_assert_eq_schar(a, e) |
| #define | T_quiet_eq_schar(a, e) |
| #define | T_step_eq_schar(s, a, e) |
| #define | T_step_assert_eq_schar(s, a, e) |
| #define | T_ne_schar(a, e) |
| #define | T_assert_ne_schar(a, e) |
| #define | T_quiet_ne_schar(a, e) |
| #define | T_step_ne_schar(s, a, e) |
| #define | T_step_assert_ne_schar(s, a, e) |
| #define | T_ge_schar(a, e) |
| #define | T_assert_ge_schar(a, e) |
| #define | T_quiet_ge_schar(a, e) |
| #define | T_step_ge_schar(s, a, e) |
| #define | T_step_assert_ge_schar(s, a, e) |
| #define | T_gt_schar(a, e) |
| #define | T_assert_gt_schar(a, e) |
| #define | T_quiet_gt_schar(a, e) |
| #define | T_step_gt_schar(s, a, e) |
| #define | T_step_assert_gt_schar(s, a, e) |
| #define | T_le_schar(a, e) |
| #define | T_assert_le_schar(a, e) |
| #define | T_quiet_le_schar(a, e) |
| #define | T_step_le_schar(s, a, e) |
| #define | T_step_assert_le_schar(s, a, e) |
| #define | T_lt_schar(a, e) |
| #define | T_assert_lt_schar(a, e) |
| #define | T_quiet_lt_schar(a, e) |
| #define | T_step_lt_schar(s, a, e) |
| #define | T_step_assert_lt_schar(s, a, e) |
| #define | T_eq_uchar(a, e) |
| #define | T_assert_eq_uchar(a, e) |
| #define | T_quiet_eq_uchar(a, e) |
| #define | T_step_eq_uchar(s, a, e) |
| #define | T_step_assert_eq_uchar(s, a, e) |
| #define | T_ne_uchar(a, e) |
| #define | T_assert_ne_uchar(a, e) |
| #define | T_quiet_ne_uchar(a, e) |
| #define | T_step_ne_uchar(s, a, e) |
| #define | T_step_assert_ne_uchar(s, a, e) |
| #define | T_ge_uchar(a, e) |
| #define | T_assert_ge_uchar(a, e) |
| #define | T_quiet_ge_uchar(a, e) |
| #define | T_step_ge_uchar(s, a, e) |
| #define | T_step_assert_ge_uchar(s, a, e) |
| #define | T_gt_uchar(a, e) |
| #define | T_assert_gt_uchar(a, e) |
| #define | T_quiet_gt_uchar(a, e) |
| #define | T_step_gt_uchar(s, a, e) |
| #define | T_step_assert_gt_uchar(s, a, e) |
| #define | T_le_uchar(a, e) |
| #define | T_assert_le_uchar(a, e) |
| #define | T_quiet_le_uchar(a, e) |
| #define | T_step_le_uchar(s, a, e) |
| #define | T_step_assert_le_uchar(s, a, e) |
| #define | T_lt_uchar(a, e) |
| #define | T_assert_lt_uchar(a, e) |
| #define | T_quiet_lt_uchar(a, e) |
| #define | T_step_lt_uchar(s, a, e) |
| #define | T_step_assert_lt_uchar(s, a, e) |
| #define | T_eq_short(a, e) |
| #define | T_assert_eq_short(a, e) |
| #define | T_quiet_eq_short(a, e) |
| #define | T_step_eq_short(s, a, e) |
| #define | T_step_assert_eq_short(s, a, e) |
| #define | T_ne_short(a, e) |
| #define | T_assert_ne_short(a, e) |
| #define | T_quiet_ne_short(a, e) |
| #define | T_step_ne_short(s, a, e) |
| #define | T_step_assert_ne_short(s, a, e) |
| #define | T_ge_short(a, e) |
| #define | T_assert_ge_short(a, e) |
| #define | T_quiet_ge_short(a, e) |
| #define | T_step_ge_short(s, a, e) |
| #define | T_step_assert_ge_short(s, a, e) |
| #define | T_gt_short(a, e) |
| #define | T_assert_gt_short(a, e) |
| #define | T_quiet_gt_short(a, e) |
| #define | T_step_gt_short(s, a, e) |
| #define | T_step_assert_gt_short(s, a, e) |
| #define | T_le_short(a, e) |
| #define | T_assert_le_short(a, e) |
| #define | T_quiet_le_short(a, e) |
| #define | T_step_le_short(s, a, e) |
| #define | T_step_assert_le_short(s, a, e) |
| #define | T_lt_short(a, e) |
| #define | T_assert_lt_short(a, e) |
| #define | T_quiet_lt_short(a, e) |
| #define | T_step_lt_short(s, a, e) |
| #define | T_step_assert_lt_short(s, a, e) |
| #define | T_eq_ushort(a, e) |
| #define | T_assert_eq_ushort(a, e) |
| #define | T_quiet_eq_ushort(a, e) |
| #define | T_step_eq_ushort(s, a, e) |
| #define | T_step_assert_eq_ushort(s, a, e) |
| #define | T_ne_ushort(a, e) |
| #define | T_assert_ne_ushort(a, e) |
| #define | T_quiet_ne_ushort(a, e) |
| #define | T_step_ne_ushort(s, a, e) |
| #define | T_step_assert_ne_ushort(s, a, e) |
| #define | T_ge_ushort(a, e) |
| #define | T_assert_ge_ushort(a, e) |
| #define | T_quiet_ge_ushort(a, e) |
| #define | T_step_ge_ushort(s, a, e) |
| #define | T_step_assert_ge_ushort(s, a, e) |
| #define | T_gt_ushort(a, e) |
| #define | T_assert_gt_ushort(a, e) |
| #define | T_quiet_gt_ushort(a, e) |
| #define | T_step_gt_ushort(s, a, e) |
| #define | T_step_assert_gt_ushort(s, a, e) |
| #define | T_le_ushort(a, e) |
| #define | T_assert_le_ushort(a, e) |
| #define | T_quiet_le_ushort(a, e) |
| #define | T_step_le_ushort(s, a, e) |
| #define | T_step_assert_le_ushort(s, a, e) |
| #define | T_lt_ushort(a, e) |
| #define | T_assert_lt_ushort(a, e) |
| #define | T_quiet_lt_ushort(a, e) |
| #define | T_step_lt_ushort(s, a, e) |
| #define | T_step_assert_lt_ushort(s, a, e) |
| #define | T_eq_int(a, e) |
| #define | T_assert_eq_int(a, e) |
| #define | T_quiet_eq_int(a, e) |
| #define | T_step_eq_int(s, a, e) |
| #define | T_step_assert_eq_int(s, a, e) |
| #define | T_ne_int(a, e) |
| #define | T_assert_ne_int(a, e) |
| #define | T_quiet_ne_int(a, e) |
| #define | T_step_ne_int(s, a, e) |
| #define | T_step_assert_ne_int(s, a, e) |
| #define | T_ge_int(a, e) |
| #define | T_assert_ge_int(a, e) |
| #define | T_quiet_ge_int(a, e) |
| #define | T_step_ge_int(s, a, e) |
| #define | T_step_assert_ge_int(s, a, e) |
| #define | T_gt_int(a, e) |
| #define | T_assert_gt_int(a, e) |
| #define | T_quiet_gt_int(a, e) |
| #define | T_step_gt_int(s, a, e) |
| #define | T_step_assert_gt_int(s, a, e) |
| #define | T_le_int(a, e) |
| #define | T_assert_le_int(a, e) |
| #define | T_quiet_le_int(a, e) |
| #define | T_step_le_int(s, a, e) |
| #define | T_step_assert_le_int(s, a, e) |
| #define | T_lt_int(a, e) |
| #define | T_assert_lt_int(a, e) |
| #define | T_quiet_lt_int(a, e) |
| #define | T_step_lt_int(s, a, e) |
| #define | T_step_assert_lt_int(s, a, e) |
| #define | T_eq_uint(a, e) |
| #define | T_assert_eq_uint(a, e) |
| #define | T_quiet_eq_uint(a, e) |
| #define | T_step_eq_uint(s, a, e) |
| #define | T_step_assert_eq_uint(s, a, e) |
| #define | T_ne_uint(a, e) |
| #define | T_assert_ne_uint(a, e) |
| #define | T_quiet_ne_uint(a, e) |
| #define | T_step_ne_uint(s, a, e) |
| #define | T_step_assert_ne_uint(s, a, e) |
| #define | T_ge_uint(a, e) |
| #define | T_assert_ge_uint(a, e) |
| #define | T_quiet_ge_uint(a, e) |
| #define | T_step_ge_uint(s, a, e) |
| #define | T_step_assert_ge_uint(s, a, e) |
| #define | T_gt_uint(a, e) |
| #define | T_assert_gt_uint(a, e) |
| #define | T_quiet_gt_uint(a, e) |
| #define | T_step_gt_uint(s, a, e) |
| #define | T_step_assert_gt_uint(s, a, e) |
| #define | T_le_uint(a, e) |
| #define | T_assert_le_uint(a, e) |
| #define | T_quiet_le_uint(a, e) |
| #define | T_step_le_uint(s, a, e) |
| #define | T_step_assert_le_uint(s, a, e) |
| #define | T_lt_uint(a, e) |
| #define | T_assert_lt_uint(a, e) |
| #define | T_quiet_lt_uint(a, e) |
| #define | T_step_lt_uint(s, a, e) |
| #define | T_step_assert_lt_uint(s, a, e) |
| #define | T_eq_long(a, e) |
| #define | T_assert_eq_long(a, e) |
| #define | T_quiet_eq_long(a, e) |
| #define | T_step_eq_long(s, a, e) |
| #define | T_step_assert_eq_long(s, a, e) |
| #define | T_ne_long(a, e) |
| #define | T_assert_ne_long(a, e) |
| #define | T_quiet_ne_long(a, e) |
| #define | T_step_ne_long(s, a, e) |
| #define | T_step_assert_ne_long(s, a, e) |
| #define | T_ge_long(a, e) |
| #define | T_assert_ge_long(a, e) |
| #define | T_quiet_ge_long(a, e) |
| #define | T_step_ge_long(s, a, e) |
| #define | T_step_assert_ge_long(s, a, e) |
| #define | T_gt_long(a, e) |
| #define | T_assert_gt_long(a, e) |
| #define | T_quiet_gt_long(a, e) |
| #define | T_step_gt_long(s, a, e) |
| #define | T_step_assert_gt_long(s, a, e) |
| #define | T_le_long(a, e) |
| #define | T_assert_le_long(a, e) |
| #define | T_quiet_le_long(a, e) |
| #define | T_step_le_long(s, a, e) |
| #define | T_step_assert_le_long(s, a, e) |
| #define | T_lt_long(a, e) |
| #define | T_assert_lt_long(a, e) |
| #define | T_quiet_lt_long(a, e) |
| #define | T_step_lt_long(s, a, e) |
| #define | T_step_assert_lt_long(s, a, e) |
| #define | T_eq_ulong(a, e) |
| #define | T_assert_eq_ulong(a, e) |
| #define | T_quiet_eq_ulong(a, e) |
| #define | T_step_eq_ulong(s, a, e) |
| #define | T_step_assert_eq_ulong(s, a, e) |
| #define | T_ne_ulong(a, e) |
| #define | T_assert_ne_ulong(a, e) |
| #define | T_quiet_ne_ulong(a, e) |
| #define | T_step_ne_ulong(s, a, e) |
| #define | T_step_assert_ne_ulong(s, a, e) |
| #define | T_ge_ulong(a, e) |
| #define | T_assert_ge_ulong(a, e) |
| #define | T_quiet_ge_ulong(a, e) |
| #define | T_step_ge_ulong(s, a, e) |
| #define | T_step_assert_ge_ulong(s, a, e) |
| #define | T_gt_ulong(a, e) |
| #define | T_assert_gt_ulong(a, e) |
| #define | T_quiet_gt_ulong(a, e) |
| #define | T_step_gt_ulong(s, a, e) |
| #define | T_step_assert_gt_ulong(s, a, e) |
| #define | T_le_ulong(a, e) |
| #define | T_assert_le_ulong(a, e) |
| #define | T_quiet_le_ulong(a, e) |
| #define | T_step_le_ulong(s, a, e) |
| #define | T_step_assert_le_ulong(s, a, e) |
| #define | T_lt_ulong(a, e) |
| #define | T_assert_lt_ulong(a, e) |
| #define | T_quiet_lt_ulong(a, e) |
| #define | T_step_lt_ulong(s, a, e) |
| #define | T_step_assert_lt_ulong(s, a, e) |
| #define | T_eq_ll(a, e) |
| #define | T_assert_eq_ll(a, e) |
| #define | T_quiet_eq_ll(a, e) |
| #define | T_step_eq_ll(s, a, e) |
| #define | T_step_assert_eq_ll(s, a, e) |
| #define | T_ne_ll(a, e) |
| #define | T_assert_ne_ll(a, e) |
| #define | T_quiet_ne_ll(a, e) |
| #define | T_step_ne_ll(s, a, e) |
| #define | T_step_assert_ne_ll(s, a, e) |
| #define | T_ge_ll(a, e) |
| #define | T_assert_ge_ll(a, e) |
| #define | T_quiet_ge_ll(a, e) |
| #define | T_step_ge_ll(s, a, e) |
| #define | T_step_assert_ge_ll(s, a, e) |
| #define | T_gt_ll(a, e) |
| #define | T_assert_gt_ll(a, e) |
| #define | T_quiet_gt_ll(a, e) |
| #define | T_step_gt_ll(s, a, e) |
| #define | T_step_assert_gt_ll(s, a, e) |
| #define | T_le_ll(a, e) |
| #define | T_assert_le_ll(a, e) |
| #define | T_quiet_le_ll(a, e) |
| #define | T_step_le_ll(s, a, e) |
| #define | T_step_assert_le_ll(s, a, e) |
| #define | T_lt_ll(a, e) |
| #define | T_assert_lt_ll(a, e) |
| #define | T_quiet_lt_ll(a, e) |
| #define | T_step_lt_ll(s, a, e) |
| #define | T_step_assert_lt_ll(s, a, e) |
| #define | T_eq_ull(a, e) |
| #define | T_assert_eq_ull(a, e) |
| #define | T_quiet_eq_ull(a, e) |
| #define | T_step_eq_ull(s, a, e) |
| #define | T_step_assert_eq_ull(s, a, e) |
| #define | T_ne_ull(a, e) |
| #define | T_assert_ne_ull(a, e) |
| #define | T_quiet_ne_ull(a, e) |
| #define | T_step_ne_ull(s, a, e) |
| #define | T_step_assert_ne_ull(s, a, e) |
| #define | T_ge_ull(a, e) |
| #define | T_assert_ge_ull(a, e) |
| #define | T_quiet_ge_ull(a, e) |
| #define | T_step_ge_ull(s, a, e) |
| #define | T_step_assert_ge_ull(s, a, e) |
| #define | T_gt_ull(a, e) |
| #define | T_assert_gt_ull(a, e) |
| #define | T_quiet_gt_ull(a, e) |
| #define | T_step_gt_ull(s, a, e) |
| #define | T_step_assert_gt_ull(s, a, e) |
| #define | T_le_ull(a, e) |
| #define | T_assert_le_ull(a, e) |
| #define | T_quiet_le_ull(a, e) |
| #define | T_step_le_ull(s, a, e) |
| #define | T_step_assert_le_ull(s, a, e) |
| #define | T_lt_ull(a, e) |
| #define | T_assert_lt_ull(a, e) |
| #define | T_quiet_lt_ull(a, e) |
| #define | T_step_lt_ull(s, a, e) |
| #define | T_step_assert_lt_ull(s, a, e) |
| #define | T_eq_i8(a, e) |
| #define | T_assert_eq_i8(a, e) |
| #define | T_quiet_eq_i8(a, e) |
| #define | T_step_eq_i8(s, a, e) |
| #define | T_step_assert_eq_i8(s, a, e) |
| #define | T_ne_i8(a, e) |
| #define | T_assert_ne_i8(a, e) |
| #define | T_quiet_ne_i8(a, e) |
| #define | T_step_ne_i8(s, a, e) |
| #define | T_step_assert_ne_i8(s, a, e) |
| #define | T_ge_i8(a, e) |
| #define | T_assert_ge_i8(a, e) |
| #define | T_quiet_ge_i8(a, e) |
| #define | T_step_ge_i8(s, a, e) |
| #define | T_step_assert_ge_i8(s, a, e) |
| #define | T_gt_i8(a, e) |
| #define | T_assert_gt_i8(a, e) |
| #define | T_quiet_gt_i8(a, e) |
| #define | T_step_gt_i8(s, a, e) |
| #define | T_step_assert_gt_i8(s, a, e) |
| #define | T_le_i8(a, e) |
| #define | T_assert_le_i8(a, e) |
| #define | T_quiet_le_i8(a, e) |
| #define | T_step_le_i8(s, a, e) |
| #define | T_step_assert_le_i8(s, a, e) |
| #define | T_lt_i8(a, e) |
| #define | T_assert_lt_i8(a, e) |
| #define | T_quiet_lt_i8(a, e) |
| #define | T_step_lt_i8(s, a, e) |
| #define | T_step_assert_lt_i8(s, a, e) |
| #define | T_eq_u8(a, e) |
| #define | T_assert_eq_u8(a, e) |
| #define | T_quiet_eq_u8(a, e) |
| #define | T_step_eq_u8(s, a, e) |
| #define | T_step_assert_eq_u8(s, a, e) |
| #define | T_ne_u8(a, e) |
| #define | T_assert_ne_u8(a, e) |
| #define | T_quiet_ne_u8(a, e) |
| #define | T_step_ne_u8(s, a, e) |
| #define | T_step_assert_ne_u8(s, a, e) |
| #define | T_ge_u8(a, e) |
| #define | T_assert_ge_u8(a, e) |
| #define | T_quiet_ge_u8(a, e) |
| #define | T_step_ge_u8(s, a, e) |
| #define | T_step_assert_ge_u8(s, a, e) |
| #define | T_gt_u8(a, e) |
| #define | T_assert_gt_u8(a, e) |
| #define | T_quiet_gt_u8(a, e) |
| #define | T_step_gt_u8(s, a, e) |
| #define | T_step_assert_gt_u8(s, a, e) |
| #define | T_le_u8(a, e) |
| #define | T_assert_le_u8(a, e) |
| #define | T_quiet_le_u8(a, e) |
| #define | T_step_le_u8(s, a, e) |
| #define | T_step_assert_le_u8(s, a, e) |
| #define | T_lt_u8(a, e) |
| #define | T_assert_lt_u8(a, e) |
| #define | T_quiet_lt_u8(a, e) |
| #define | T_step_lt_u8(s, a, e) |
| #define | T_step_assert_lt_u8(s, a, e) |
| #define | T_eq_i16(a, e) |
| #define | T_assert_eq_i16(a, e) |
| #define | T_quiet_eq_i16(a, e) |
| #define | T_step_eq_i16(s, a, e) |
| #define | T_step_assert_eq_i16(s, a, e) |
| #define | T_ne_i16(a, e) |
| #define | T_assert_ne_i16(a, e) |
| #define | T_quiet_ne_i16(a, e) |
| #define | T_step_ne_i16(s, a, e) |
| #define | T_step_assert_ne_i16(s, a, e) |
| #define | T_ge_i16(a, e) |
| #define | T_assert_ge_i16(a, e) |
| #define | T_quiet_ge_i16(a, e) |
| #define | T_step_ge_i16(s, a, e) |
| #define | T_step_assert_ge_i16(s, a, e) |
| #define | T_gt_i16(a, e) |
| #define | T_assert_gt_i16(a, e) |
| #define | T_quiet_gt_i16(a, e) |
| #define | T_step_gt_i16(s, a, e) |
| #define | T_step_assert_gt_i16(s, a, e) |
| #define | T_le_i16(a, e) |
| #define | T_assert_le_i16(a, e) |
| #define | T_quiet_le_i16(a, e) |
| #define | T_step_le_i16(s, a, e) |
| #define | T_step_assert_le_i16(s, a, e) |
| #define | T_lt_i16(a, e) |
| #define | T_assert_lt_i16(a, e) |
| #define | T_quiet_lt_i16(a, e) |
| #define | T_step_lt_i16(s, a, e) |
| #define | T_step_assert_lt_i16(s, a, e) |
| #define | T_eq_u16(a, e) |
| #define | T_assert_eq_u16(a, e) |
| #define | T_quiet_eq_u16(a, e) |
| #define | T_step_eq_u16(s, a, e) |
| #define | T_step_assert_eq_u16(s, a, e) |
| #define | T_ne_u16(a, e) |
| #define | T_assert_ne_u16(a, e) |
| #define | T_quiet_ne_u16(a, e) |
| #define | T_step_ne_u16(s, a, e) |
| #define | T_step_assert_ne_u16(s, a, e) |
| #define | T_ge_u16(a, e) |
| #define | T_assert_ge_u16(a, e) |
| #define | T_quiet_ge_u16(a, e) |
| #define | T_step_ge_u16(s, a, e) |
| #define | T_step_assert_ge_u16(s, a, e) |
| #define | T_gt_u16(a, e) |
| #define | T_assert_gt_u16(a, e) |
| #define | T_quiet_gt_u16(a, e) |
| #define | T_step_gt_u16(s, a, e) |
| #define | T_step_assert_gt_u16(s, a, e) |
| #define | T_le_u16(a, e) |
| #define | T_assert_le_u16(a, e) |
| #define | T_quiet_le_u16(a, e) |
| #define | T_step_le_u16(s, a, e) |
| #define | T_step_assert_le_u16(s, a, e) |
| #define | T_lt_u16(a, e) |
| #define | T_assert_lt_u16(a, e) |
| #define | T_quiet_lt_u16(a, e) |
| #define | T_step_lt_u16(s, a, e) |
| #define | T_step_assert_lt_u16(s, a, e) |
| #define | T_eq_i32(a, e) |
| #define | T_assert_eq_i32(a, e) |
| #define | T_quiet_eq_i32(a, e) |
| #define | T_step_eq_i32(s, a, e) |
| #define | T_step_assert_eq_i32(s, a, e) |
| #define | T_ne_i32(a, e) |
| #define | T_assert_ne_i32(a, e) |
| #define | T_quiet_ne_i32(a, e) |
| #define | T_step_ne_i32(s, a, e) |
| #define | T_step_assert_ne_i32(s, a, e) |
| #define | T_ge_i32(a, e) |
| #define | T_assert_ge_i32(a, e) |
| #define | T_quiet_ge_i32(a, e) |
| #define | T_step_ge_i32(s, a, e) |
| #define | T_step_assert_ge_i32(s, a, e) |
| #define | T_gt_i32(a, e) |
| #define | T_assert_gt_i32(a, e) |
| #define | T_quiet_gt_i32(a, e) |
| #define | T_step_gt_i32(s, a, e) |
| #define | T_step_assert_gt_i32(s, a, e) |
| #define | T_le_i32(a, e) |
| #define | T_assert_le_i32(a, e) |
| #define | T_quiet_le_i32(a, e) |
| #define | T_step_le_i32(s, a, e) |
| #define | T_step_assert_le_i32(s, a, e) |
| #define | T_lt_i32(a, e) |
| #define | T_assert_lt_i32(a, e) |
| #define | T_quiet_lt_i32(a, e) |
| #define | T_step_lt_i32(s, a, e) |
| #define | T_step_assert_lt_i32(s, a, e) |
| #define | T_eq_u32(a, e) |
| #define | T_assert_eq_u32(a, e) |
| #define | T_quiet_eq_u32(a, e) |
| #define | T_step_eq_u32(s, a, e) |
| #define | T_step_assert_eq_u32(s, a, e) |
| #define | T_ne_u32(a, e) |
| #define | T_assert_ne_u32(a, e) |
| #define | T_quiet_ne_u32(a, e) |
| #define | T_step_ne_u32(s, a, e) |
| #define | T_step_assert_ne_u32(s, a, e) |
| #define | T_ge_u32(a, e) |
| #define | T_assert_ge_u32(a, e) |
| #define | T_quiet_ge_u32(a, e) |
| #define | T_step_ge_u32(s, a, e) |
| #define | T_step_assert_ge_u32(s, a, e) |
| #define | T_gt_u32(a, e) |
| #define | T_assert_gt_u32(a, e) |
| #define | T_quiet_gt_u32(a, e) |
| #define | T_step_gt_u32(s, a, e) |
| #define | T_step_assert_gt_u32(s, a, e) |
| #define | T_le_u32(a, e) |
| #define | T_assert_le_u32(a, e) |
| #define | T_quiet_le_u32(a, e) |
| #define | T_step_le_u32(s, a, e) |
| #define | T_step_assert_le_u32(s, a, e) |
| #define | T_lt_u32(a, e) |
| #define | T_assert_lt_u32(a, e) |
| #define | T_quiet_lt_u32(a, e) |
| #define | T_step_lt_u32(s, a, e) |
| #define | T_step_assert_lt_u32(s, a, e) |
| #define | T_eq_i64(a, e) |
| #define | T_assert_eq_i64(a, e) |
| #define | T_quiet_eq_i64(a, e) |
| #define | T_step_eq_i64(s, a, e) |
| #define | T_step_assert_eq_i64(s, a, e) |
| #define | T_ne_i64(a, e) |
| #define | T_assert_ne_i64(a, e) |
| #define | T_quiet_ne_i64(a, e) |
| #define | T_step_ne_i64(s, a, e) |
| #define | T_step_assert_ne_i64(s, a, e) |
| #define | T_ge_i64(a, e) |
| #define | T_assert_ge_i64(a, e) |
| #define | T_quiet_ge_i64(a, e) |
| #define | T_step_ge_i64(s, a, e) |
| #define | T_step_assert_ge_i64(s, a, e) |
| #define | T_gt_i64(a, e) |
| #define | T_assert_gt_i64(a, e) |
| #define | T_quiet_gt_i64(a, e) |
| #define | T_step_gt_i64(s, a, e) |
| #define | T_step_assert_gt_i64(s, a, e) |
| #define | T_le_i64(a, e) |
| #define | T_assert_le_i64(a, e) |
| #define | T_quiet_le_i64(a, e) |
| #define | T_step_le_i64(s, a, e) |
| #define | T_step_assert_le_i64(s, a, e) |
| #define | T_lt_i64(a, e) |
| #define | T_assert_lt_i64(a, e) |
| #define | T_quiet_lt_i64(a, e) |
| #define | T_step_lt_i64(s, a, e) |
| #define | T_step_assert_lt_i64(s, a, e) |
| #define | T_eq_u64(a, e) |
| #define | T_assert_eq_u64(a, e) |
| #define | T_quiet_eq_u64(a, e) |
| #define | T_step_eq_u64(s, a, e) |
| #define | T_step_assert_eq_u64(s, a, e) |
| #define | T_ne_u64(a, e) |
| #define | T_assert_ne_u64(a, e) |
| #define | T_quiet_ne_u64(a, e) |
| #define | T_step_ne_u64(s, a, e) |
| #define | T_step_assert_ne_u64(s, a, e) |
| #define | T_ge_u64(a, e) |
| #define | T_assert_ge_u64(a, e) |
| #define | T_quiet_ge_u64(a, e) |
| #define | T_step_ge_u64(s, a, e) |
| #define | T_step_assert_ge_u64(s, a, e) |
| #define | T_gt_u64(a, e) |
| #define | T_assert_gt_u64(a, e) |
| #define | T_quiet_gt_u64(a, e) |
| #define | T_step_gt_u64(s, a, e) |
| #define | T_step_assert_gt_u64(s, a, e) |
| #define | T_le_u64(a, e) |
| #define | T_assert_le_u64(a, e) |
| #define | T_quiet_le_u64(a, e) |
| #define | T_step_le_u64(s, a, e) |
| #define | T_step_assert_le_u64(s, a, e) |
| #define | T_lt_u64(a, e) |
| #define | T_assert_lt_u64(a, e) |
| #define | T_quiet_lt_u64(a, e) |
| #define | T_step_lt_u64(s, a, e) |
| #define | T_step_assert_lt_u64(s, a, e) |
| #define | T_eq_iptr(a, e) |
| #define | T_assert_eq_iptr(a, e) |
| #define | T_quiet_eq_iptr(a, e) |
| #define | T_step_eq_iptr(s, a, e) |
| #define | T_step_assert_eq_iptr(s, a, e) |
| #define | T_ne_iptr(a, e) |
| #define | T_assert_ne_iptr(a, e) |
| #define | T_quiet_ne_iptr(a, e) |
| #define | T_step_ne_iptr(s, a, e) |
| #define | T_step_assert_ne_iptr(s, a, e) |
| #define | T_ge_iptr(a, e) |
| #define | T_assert_ge_iptr(a, e) |
| #define | T_quiet_ge_iptr(a, e) |
| #define | T_step_ge_iptr(s, a, e) |
| #define | T_step_assert_ge_iptr(s, a, e) |
| #define | T_gt_iptr(a, e) |
| #define | T_assert_gt_iptr(a, e) |
| #define | T_quiet_gt_iptr(a, e) |
| #define | T_step_gt_iptr(s, a, e) |
| #define | T_step_assert_gt_iptr(s, a, e) |
| #define | T_le_iptr(a, e) |
| #define | T_assert_le_iptr(a, e) |
| #define | T_quiet_le_iptr(a, e) |
| #define | T_step_le_iptr(s, a, e) |
| #define | T_step_assert_le_iptr(s, a, e) |
| #define | T_lt_iptr(a, e) |
| #define | T_assert_lt_iptr(a, e) |
| #define | T_quiet_lt_iptr(a, e) |
| #define | T_step_lt_iptr(s, a, e) |
| #define | T_step_assert_lt_iptr(s, a, e) |
| #define | T_eq_uptr(a, e) |
| #define | T_assert_eq_uptr(a, e) |
| #define | T_quiet_eq_uptr(a, e) |
| #define | T_step_eq_uptr(s, a, e) |
| #define | T_step_assert_eq_uptr(s, a, e) |
| #define | T_ne_uptr(a, e) |
| #define | T_assert_ne_uptr(a, e) |
| #define | T_quiet_ne_uptr(a, e) |
| #define | T_step_ne_uptr(s, a, e) |
| #define | T_step_assert_ne_uptr(s, a, e) |
| #define | T_ge_uptr(a, e) |
| #define | T_assert_ge_uptr(a, e) |
| #define | T_quiet_ge_uptr(a, e) |
| #define | T_step_ge_uptr(s, a, e) |
| #define | T_step_assert_ge_uptr(s, a, e) |
| #define | T_gt_uptr(a, e) |
| #define | T_assert_gt_uptr(a, e) |
| #define | T_quiet_gt_uptr(a, e) |
| #define | T_step_gt_uptr(s, a, e) |
| #define | T_step_assert_gt_uptr(s, a, e) |
| #define | T_le_uptr(a, e) |
| #define | T_assert_le_uptr(a, e) |
| #define | T_quiet_le_uptr(a, e) |
| #define | T_step_le_uptr(s, a, e) |
| #define | T_step_assert_le_uptr(s, a, e) |
| #define | T_lt_uptr(a, e) |
| #define | T_assert_lt_uptr(a, e) |
| #define | T_quiet_lt_uptr(a, e) |
| #define | T_step_lt_uptr(s, a, e) |
| #define | T_step_assert_lt_uptr(s, a, e) |
| #define | T_eq_ssz(a, e) |
| #define | T_assert_eq_ssz(a, e) |
| #define | T_quiet_eq_ssz(a, e) |
| #define | T_step_eq_ssz(s, a, e) |
| #define | T_step_assert_eq_ssz(s, a, e) |
| #define | T_ne_ssz(a, e) |
| #define | T_assert_ne_ssz(a, e) |
| #define | T_quiet_ne_ssz(a, e) |
| #define | T_step_ne_ssz(s, a, e) |
| #define | T_step_assert_ne_ssz(s, a, e) |
| #define | T_ge_ssz(a, e) |
| #define | T_assert_ge_ssz(a, e) |
| #define | T_quiet_ge_ssz(a, e) |
| #define | T_step_ge_ssz(s, a, e) |
| #define | T_step_assert_ge_ssz(s, a, e) |
| #define | T_gt_ssz(a, e) |
| #define | T_assert_gt_ssz(a, e) |
| #define | T_quiet_gt_ssz(a, e) |
| #define | T_step_gt_ssz(s, a, e) |
| #define | T_step_assert_gt_ssz(s, a, e) |
| #define | T_le_ssz(a, e) |
| #define | T_assert_le_ssz(a, e) |
| #define | T_quiet_le_ssz(a, e) |
| #define | T_step_le_ssz(s, a, e) |
| #define | T_step_assert_le_ssz(s, a, e) |
| #define | T_lt_ssz(a, e) |
| #define | T_assert_lt_ssz(a, e) |
| #define | T_quiet_lt_ssz(a, e) |
| #define | T_step_lt_ssz(s, a, e) |
| #define | T_step_assert_lt_ssz(s, a, e) |
| #define | T_eq_sz(a, e) |
| #define | T_assert_eq_sz(a, e) |
| #define | T_quiet_eq_sz(a, e) |
| #define | T_step_eq_sz(s, a, e) |
| #define | T_step_assert_eq_sz(s, a, e) |
| #define | T_ne_sz(a, e) |
| #define | T_assert_ne_sz(a, e) |
| #define | T_quiet_ne_sz(a, e) |
| #define | T_step_ne_sz(s, a, e) |
| #define | T_step_assert_ne_sz(s, a, e) |
| #define | T_ge_sz(a, e) |
| #define | T_assert_ge_sz(a, e) |
| #define | T_quiet_ge_sz(a, e) |
| #define | T_step_ge_sz(s, a, e) |
| #define | T_step_assert_ge_sz(s, a, e) |
| #define | T_gt_sz(a, e) |
| #define | T_assert_gt_sz(a, e) |
| #define | T_quiet_gt_sz(a, e) |
| #define | T_step_gt_sz(s, a, e) |
| #define | T_step_assert_gt_sz(s, a, e) |
| #define | T_le_sz(a, e) |
| #define | T_assert_le_sz(a, e) |
| #define | T_quiet_le_sz(a, e) |
| #define | T_step_le_sz(s, a, e) |
| #define | T_step_assert_le_sz(s, a, e) |
| #define | T_lt_sz(a, e) |
| #define | T_assert_lt_sz(a, e) |
| #define | T_quiet_lt_sz(a, e) |
| #define | T_step_lt_sz(s, a, e) |
| #define | T_step_assert_lt_sz(s, a, e) |
| #define | T_eno(a, e) |
| #define | T_assert_eno(a, e) |
| #define | T_quiet_eno(a, e) |
| #define | T_step_eno(s, a, e) |
| #define | T_step_assert_eno(s, a, e) |
| #define | T_eno_success(a) |
| #define | T_assert_eno_success(a) |
| #define | T_quiet_eno_success(a) |
| #define | T_step_eno_success(s, a) |
| #define | T_step_assert_eno_success(s, a) |
| #define | T_psx_error(a, eno) |
| #define | T_assert_psx_error(a, eno) |
| #define | T_quiet_psx_error(a, eno) |
| #define | T_step_psx_error(s, a, eno) |
| #define | T_step_assert_psx_error(s, a, eno) |
| #define | T_psx_success(a) |
| #define | T_assert_psx_success(a) |
| #define | T_quiet_psx_success(a) |
| #define | T_step_psx_success(s, a) |
| #define | T_step_assert_psx_success(s, a) |
| #define | T_flags_step(a, flags) |
| #define | T_step(e) |
| #define | T_step_assert(e) |
| #define | T_unreachable() |
| #define | T_TEST_CASE_FIXTURE(name, fixture) |
| #define | T_TEST_CASE(name) |
#define | T_MEASURE_RUNTIME_ALLOW_CLOCK_ISR 0x1 |
#define | T_MEASURE_RUNTIME_REPORT_SAMPLES 0x2 |
#define | T_MEASURE_RUNTIME_DISABLE_FULL_CACHE 0x10 |
#define | T_MEASURE_RUNTIME_DISABLE_HOT_CACHE 0x20 |
#define | T_MEASURE_RUNTIME_DISABLE_DIRTY_CACHE 0x40 |
#define | T_MEASURE_RUNTIME_DISABLE_MINOR_LOAD 0x80 |
#define | T_MEASURE_RUNTIME_DISABLE_MAX_LOAD 0x100 |
void | T_case_register (T_case_context *) |
void | T_check (const T_check_context *, bool,...) |
void | T_check_eq_ptr (const T_check_context_msg *, uintptr_t, uintptr_t) |
void | T_check_ne_ptr (const T_check_context_msg *, uintptr_t, uintptr_t) |
void | T_check_null (const T_check_context_msg *, uintptr_t) |
void | T_check_not_null (const T_check_context_msg *, uintptr_t) |
void | T_check_eq_mem (const T_check_context_msg *, const void *, const void *, size_t) |
void | T_check_ne_mem (const T_check_context_msg *, const void *, const void *, size_t) |
void | T_check_eq_str (const T_check_context *, const char *, const char *) |
void | T_check_ne_str (const T_check_context *, const char *, const char *) |
void | T_check_eq_nstr (const T_check_context *, const char *, const char *, size_t) |
void | T_check_ne_nstr (const T_check_context *, const char *, const char *, size_t) |
void | T_check_eq_char (const T_check_context *, char, char) |
void | T_check_ne_char (const T_check_context *, char, char) |
void | T_check_eq_int (const T_check_context *, int, int) |
void | T_check_ne_int (const T_check_context *, int, int) |
void | T_check_ge_int (const T_check_context *, int, int) |
void | T_check_gt_int (const T_check_context *, int, int) |
void | T_check_le_int (const T_check_context *, int, int) |
void | T_check_lt_int (const T_check_context *, int, int) |
void | T_check_eq_uint (const T_check_context *, unsigned int, unsigned int) |
void | T_check_ne_uint (const T_check_context *, unsigned int, unsigned int) |
void | T_check_ge_uint (const T_check_context *, unsigned int, unsigned int) |
void | T_check_gt_uint (const T_check_context *, unsigned int, unsigned int) |
void | T_check_le_uint (const T_check_context *, unsigned int, unsigned int) |
void | T_check_lt_uint (const T_check_context *, unsigned int, unsigned int) |
void | T_check_eq_long (const T_check_context *, long, long) |
void | T_check_ne_long (const T_check_context *, long, long) |
void | T_check_ge_long (const T_check_context *, long, long) |
void | T_check_gt_long (const T_check_context *, long, long) |
void | T_check_le_long (const T_check_context *, long, long) |
void | T_check_lt_long (const T_check_context *, long, long) |
void | T_check_eq_ulong (const T_check_context *, unsigned long, unsigned long) |
void | T_check_ne_ulong (const T_check_context *, unsigned long, unsigned long) |
void | T_check_ge_ulong (const T_check_context *, unsigned long, unsigned long) |
void | T_check_gt_ulong (const T_check_context *, unsigned long, unsigned long) |
void | T_check_le_ulong (const T_check_context *, unsigned long, unsigned long) |
void | T_check_lt_ulong (const T_check_context *, unsigned long, unsigned long) |
void | T_check_eq_ll (const T_check_context *, long long, long long) |
void | T_check_ne_ll (const T_check_context *, long long, long long) |
void | T_check_ge_ll (const T_check_context *, long long, long long) |
void | T_check_gt_ll (const T_check_context *, long long, long long) |
void | T_check_le_ll (const T_check_context *, long long, long long) |
void | T_check_lt_ll (const T_check_context *, long long, long long) |
void | T_check_eq_ull (const T_check_context *, unsigned long long, unsigned long long) |
void | T_check_ne_ull (const T_check_context *, unsigned long long, unsigned long long) |
void | T_check_ge_ull (const T_check_context *, unsigned long long, unsigned long long) |
void | T_check_gt_ull (const T_check_context *, unsigned long long, unsigned long long) |
void | T_check_le_ull (const T_check_context *, unsigned long long, unsigned long long) |
void | T_check_lt_ull (const T_check_context *, unsigned long long, unsigned long long) |
void | T_check_eno (const T_check_context *, int, int) |
void | T_check_eno_success (const T_check_context *, int) |
void | T_check_psx_error (const T_check_context *, int, int) |
void | T_check_psx_success (const T_check_context *, int) |
int | T_printf (char const *,...) |
int | T_vprintf (char const *, va_list) |
int | T_puts (const char *, size_t) |
int | T_snprintf (char *, size_t, const char *,...) |
void | T_log (T_verbosity, char const *,...) |
const char * | T_case_name (void) |
T_verbosity | T_set_verbosity (T_verbosity) |
const char * | T_strerror (int) |
void | T_plan (unsigned int) |
void | T_push_plan (T_fixture_node *, unsigned int) |
void | T_pop_plan (void) |
void | T_check_step (const T_check_context *, unsigned int) |
const char * | T_time_to_string_ns (T_time, T_time_string) |
const char * | T_time_to_string_us (T_time, T_time_string) |
const char * | T_time_to_string_ms (T_time, T_time_string) |
const char * | T_time_to_string_s (T_time, T_time_string) |
const char * | T_ticks_to_string_ns (T_ticks, T_time_string) |
const char * | T_ticks_to_string_us (T_ticks, T_time_string) |
const char * | T_ticks_to_string_ms (T_ticks, T_time_string) |
const char * | T_ticks_to_string_s (T_ticks, T_time_string) |
T_time | T_ticks_to_time (T_ticks) |
T_ticks | T_time_to_ticks (T_time) |
T_time | T_seconds_and_nanoseconds_to_time (uint32_t, uint32_t) |
void | T_time_to_seconds_and_nanoseconds (T_time, uint32_t *, uint32_t *) |
T_time | T_now (void) |
T_ticks | T_tick (void) |
T_time | T_now_clock (void) |
T_time | T_now_dummy (void) |
T_time | T_now_tick (void) |
T_time | T_case_begin_time (void) |
void * | T_malloc (size_t) |
void * | T_calloc (size_t, size_t) |
void * | T_zalloc (size_t, void(*)(void *)) |
void | T_free (void *) |
void | T_register (void) |
void | T_putchar_default (int, void *) |
int | T_main (const T_config *) |
void | T_make_runner (void) |
bool | T_is_runner (void) |
void | T_run_initialize (const T_config *) |
void | T_run_all (void) |
void | T_run_by_name (const char *) |
void * | T_case_begin (const char *, const T_fixture *) |
void | T_case_end (void) |
bool | T_run_finalize (void) |
void | T_set_putchar (T_putchar, void *, T_putchar *, void **) |
void * | T_fixture_context (void) |
void | T_set_fixture_context (void *) |
void | T_add_remark (T_remark *) |
void * | T_push_fixture (T_fixture_node *, const T_fixture *) |
void | T_pop_fixture (void) |
T_NO_RETURN void | T_stop (void) |
| size_t | T_get_scope (const char *const *const *desc, char *buf, size_t n, const size_t *second_indices) |
| | Gets the scope for nested fixtures.
size_t | T_str_copy (char *, const char *, size_t) |
void | T_busy (uint_fast32_t) |
uint_fast32_t | T_get_one_clock_tick_busy (void) |
T_interrupt_test_state | T_interrupt_test_change_state (T_interrupt_test_state, T_interrupt_test_state) |
T_interrupt_test_state | T_interrupt_test_get_state (void) |
void | T_interrupt_test_busy_wait_for_interrupt (void) |
T_interrupt_test_state | T_interrupt_test (const T_interrupt_test_config *config, void *arg) |
T_thread_switch_log * | T_thread_switch_record (T_thread_switch_log *) |
T_thread_switch_log * | T_thread_switch_record_2 (T_thread_switch_log_2 *) |
T_thread_switch_log * | T_thread_switch_record_4 (T_thread_switch_log_4 *) |
T_thread_switch_log * | T_thread_switch_record_10 (T_thread_switch_log_10 *) |
void | T_report_hash_sha256 (T_event, const char *) |
void | T_report_hash_sha256_update (char c) |
void | T_check_heap (T_event, const char *) |
void | T_add_destructor (T_destructor *, void(*)(T_destructor *)) |
void | T_remove_destructor (T_destructor *) |
T_measure_runtime_context * | T_measure_runtime_create (const T_measure_runtime_config *) |
void | T_measure_runtime (T_measure_runtime_context *, const T_measure_runtime_request *) |
