RTEMS 6.3
recordserver.h
1/*
2 * SPDX-License-Identifier: BSD-2-Clause
3 *
4 * Copyright (C) 2018, 2019 embedded brains GmbH & Co. KG
5 *
6 * Redistribution and use in source and binary forms, with or without
7 * modification, are permitted provided that the following conditions
8 * are met:
9 * 1. Redistributions of source code must retain the above copyright
10 * notice, this list of conditions and the following disclaimer.
11 * 2. Redistributions in binary form must reproduce the above copyright
12 * notice, this list of conditions and the following disclaimer in the
13 * documentation and/or other materials provided with the distribution.
14 *
15 * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
16 * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
17 * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
18 * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
19 * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
20 * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
21 * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
22 * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
23 * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
24 * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
25 * POSSIBILITY OF SUCH DAMAGE.
26 */
27
28#ifndef _RTEMS_RECORDSERVER_H
29#define _RTEMS_RECORDSERVER_H
30
31#include "recorddata.h"
32
33#include <sys/types.h>
34#include <rtems.h>
35
36#ifdef __cplusplus
37extern "C" {
38#endif /* __cplusplus */
39
46void rtems_record_server( uint16_t port, rtems_interval period );
47
55rtems_status_code rtems_record_start_server(
56 rtems_task_priority priority,
57 uint16_t port,
58 rtems_interval period
59);
60
62
63#ifdef __cplusplus
64}
65#endif /* __cplusplus */
66
67#endif /* _RTEMS_RECORDSERVER_H */
rtems_status_code
Definition status.h:85
uint32_t rtems_task_priority
This integer type represents task priorities of the Classic API.
Definition types.h:257
Watchdog_Interval rtems_interval
This type represents clock tick intervals.
Definition types.h:114
