RTEMS
6.3
Toggle main menu visibility
include
ftpfs.h
1
/* SPDX-License-Identifier: BSD-2-Clause */
2
8
9
10
* Copyright (c) 2009 embedded brains GmbH & Co. KG
11
12
* Copyright (c) 2002 IMD Ingenieurbuero fuer Microcomputertechnik
13
* All rights reserved.
14
* Modified by Sebastian Huber <sebastian.huber@embedded-brains.de>.
15
16
* This code has been created after closly inspecting "tftpdriver.c" from Eric
17
* Norum.
18
19
20
* modification, are permitted provided that the following conditions
21
* are met:
22
* 1. Redistributions of source code must retain the above copyright
23
* notice, this list of conditions and the following disclaimer.
24
* 2. Redistributions in binary form must reproduce the above copyright
25
* notice, this list of conditions and the following disclaimer in the
26
* documentation and/or other materials provided with the distribution.
27
28
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
29
* AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
30
* IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
31
* ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
32
* LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
33
* CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
34
* SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
35
* INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
36
* CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
37
* ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
38
* POSSIBILITY OF SUCH DAMAGE.
39
40
41
#ifndef _RTEMS_FTPFS_H
42
#define _RTEMS_FTPFS_H
43
44
#include <sys/time.h>
45
#include <sys/ioctl.h>
46
47
rtems/libio.h
48
49
#ifdef __cplusplus
50
extern
"C"
51
#endif
52
86
90
#define RTEMS_FTPFS_CTRL_PORT 21
91
95
#define RTEMS_FTPFS_MOUNT_POINT_DEFAULT "/FTP"
96
100
typedef
enum
101
RTEMS_FTPFS_IOCTL_GET_VERBOSE = _IOR(
'd'
, 1,
bool
102
RTEMS_FTPFS_IOCTL_SET_VERBOSE = _IOW(
'd'
, 1,
bool
103
RTEMS_FTPFS_IOCTL_GET_TIMEOUT = _IOR(
'd'
, 2,
struct
timeval *),
104
RTEMS_FTPFS_IOCTL_SET_TIMEOUT = _IOW(
'd'
, 2,
struct
timeval *)
105
rtems_ftpfs_ioctl_numbers
106
114
rtems_status_code
rtems_ftpfs_get_verbose
const
char
*mount_point,
bool
*verbose);
115
126
rtems_status_code
rtems_ftpfs_set_verbose
const
char
*mount_point,
bool
verbose);
127
135
rtems_status_code
rtems_ftpfs_get_timeout
136
const
char
*mount_point,
137
struct
timeval *timeout
138
139
151
rtems_status_code
rtems_ftpfs_set_timeout
152
const
char
*mount_point,
153
const
struct
timeval *timeout
154
155
157
161
int
rtems_ftpfs_initialize
162
rtems_filesystem_mount_table_entry_t *mt_entry,
163
const
void
*data
164
165
166
#ifdef __cplusplus
167
168
#endif
169
170
#endif
int rtems_ftpfs_initialize(rtems_filesystem_mount_table_entry_t *mt_entry, const void *data)
Do not call directly, use mount().
Definition
ftpfs.c:1266
rtems_status_code
rtems_status_code
Definition
status.h:85
rtems_status_code rtems_ftpfs_set_verbose(const char *mount_point, bool verbose)
Enables or disables the verbose mode if verbose is true or false respectively for the file system at ...
Definition
ftpfs.c:225
rtems_status_code rtems_ftpfs_get_timeout(const char *mount_point, struct timeval *timeout)
Returns the current timeout value in timeout for the file system at mount_point.
Definition
ftpfs.c:234
FTP file system IO control requests.
Definition
ftpfs.h:100
rtems_status_code rtems_ftpfs_set_timeout(const char *mount_point, const struct timeval *timeout)
Sets the timeout value to timeout for the file system at mount_point.
Definition
ftpfs.c:246
rtems_status_code rtems_ftpfs_get_verbose(const char *mount_point, bool *verbose)
Returns in verbose if the verbose mode is enabled or disabled for the file system at mount_point.
Definition
ftpfs.c:216
libio.h
Basic IO API.
