RTEMS
6.3
Toggle main menu visibility
include
rtems-debugger.h
1
2
* Copyright (c) 2016 Chris Johns <chrisj@rtems.org>. All rights reserved.
3
4
5
* modification, are permitted provided that the following conditions
6
* are met:
7
* 1. Redistributions of source code must retain the above copyright
8
* notice, this list of conditions and the following disclaimer.
9
* 2. Redistributions in binary form must reproduce the above copyright
10
* notice, this list of conditions and the following disclaimer in the
11
* documentation and/or other materials provided with the distribution.
12
13
* THIS SOFTWARE IS PROVIDED BY THE AUTHOR AND CONTRIBUTORS ``AS IS'' AND
14
* ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
15
* IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
16
* ARE DISCLAIMED. IN NO EVENT SHALL THE AUTHOR OR CONTRIBUTORS BE LIABLE
17
* FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
18
* DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS
19
* OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
20
* HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT
21
* LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY
22
* OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
23
* SUCH DAMAGE.
24
25
26
27
* Debugger for RTEMS.
28
29
30
#ifndef _RTEMS_DEBUGGER_h
31
#define _RTEMS_DEBUGGER_h
32
33
#include <stdbool.h>
34
35
rtems.h
36
rtems/printer.h
37
38
#ifdef __cplusplus
39
extern
"C"
40
#endif
/* __cplusplus */
41
45
#define RTEMS_DEBUGGER_TIMEOUT (3)
46
50
extern
int
rtems_debugger_start(
const
char
* remote,
51
const
char
* device,
52
int
timeout,
53
rtems_task_priority
priority,
54
const
rtems_printer
* printer);
55
62
extern
int
rtems_debugger_break(
bool
wait);
63
67
extern
int
rtems_debugger_stop(
void
68
72
extern
bool
rtems_debugger_running(
void
73
77
extern
void
rtems_debugger_set_verbose(
bool
on);
78
82
extern
int
rtems_debugger_remote_debug(
bool
state);
83
84
#ifdef __cplusplus
85
86
#endif
/* __cplusplus */
87
88
89
#endif
rtems_task_priority
uint32_t rtems_task_priority
This integer type represents task priorities of the Classic API.
Definition
types.h:257
printer.h
User print interface to the bspIO print plug in.
rtems.h
rtems_printer
Definition
printer.h:76
