RTEMS 6.3
regulatorimpl.h
2
10
11/*
12 * Copyright (C) 2023 On-Line Applications Research Corporation (OAR)
13 *
16 * are met:
22 *
34 */
35
43
44#ifndef RTEMS_REGULATORIMPL_H
45#define RTEMS_REGULATORIMPL_H
46
47#include <stdatomic.h>
48
49#include <rtems/chain.h>
50
51
57#define REGULATOR_INITIALIZED 0xDeadF00d
58
64typedef struct {
66 void *buffer;
68 size_t length;
70
78typedef struct {
80 atomic_size_t obtained;
81
83 atomic_size_t released;
84
86 atomic_size_t delivered;
88
134
135#endif /* RTEMS_REGULATORIMPL_H */
This header file provides the Chains API.
Objects_Id rtems_id
This type represents RTEMS object identifiers.
Definition types.h:94
Regulator Instance Private Structure.
Definition regulatorimpl.h:96
rtems_id delivery_thread_id
Definition regulatorimpl.h:116
rtems_id delivery_thread_period_id
Definition regulatorimpl.h:119
uint32_t initialized
Definition regulatorimpl.h:98
bool delivery_thread_is_running
Definition regulatorimpl.h:122
rtems_id messages_partition_id
Definition regulatorimpl.h:113
bool delivery_thread_has_exited
Definition regulatorimpl.h:128
rtems_id queue_id
Definition regulatorimpl.h:110
void * message_queue_storage
Definition regulatorimpl.h:107
rtems_regulator_attributes Attributes
Definition regulatorimpl.h:101
_Regulator_Statistics Statistics
Definition regulatorimpl.h:131
bool delivery_thread_request_exit
Definition regulatorimpl.h:125
void * message_memory
Definition regulatorimpl.h:104
Regulator Message Instance Management Structure.
Definition regulatorimpl.h:64
size_t length
Definition regulatorimpl.h:68
void * buffer
Definition regulatorimpl.h:66
Regulator Statistics Private Structure.
Definition regulatorimpl.h:78
Definition regulatorimpl.h:80
Definition regulatorimpl.h:86
Definition regulatorimpl.h:83
Attributes for Regulator Instance.
Definition regulator.h:243
