RTEMS
6.3
Toggle main menu visibility
include
watchdogdrv.h
1
/* SPDX-License-Identifier: BSD-2-Clause */
2
11
12
13
14
* COPYRIGHT (c) 1989-2008.
15
* On-Line Applications Research Corporation (OAR).
16
17
18
* modification, are permitted provided that the following conditions
19
* are met:
20
* 1. Redistributions of source code must retain the above copyright
21
* notice, this list of conditions and the following disclaimer.
22
* 2. Redistributions in binary form must reproduce the above copyright
23
* notice, this list of conditions and the following disclaimer in the
24
* documentation and/or other materials provided with the distribution.
25
26
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
27
* AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
28
* IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
29
* ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
30
* LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
31
* CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
32
* SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
33
* INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
34
* CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
35
* ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
36
* POSSIBILITY OF SUCH DAMAGE.
37
38
39
#ifndef _RTEMS_WATCHDOGDRV_H
40
#define _RTEMS_WATCHDOGDRV_H
41
42
#ifdef __cplusplus
43
extern
"C"
44
#endif
45
49
#define WATCHDOG_DRIVER_TABLE_ENTRY \
50
{ Watchdog_initialize, NULL, NULL, NULL, NULL, Watchdog_control }
51
63
rtems_device_driver
Watchdog_initialize
64
rtems_device_major_number
major,
65
rtems_device_minor_number
minor,
66
void
*arguments
67
68
79
rtems_device_driver
Watchdog_control
80
major,
81
minor,
82
void
*arguments
83
84
85
#ifdef __cplusplus
86
87
#endif
88
89
#endif
90
/* end of include file */
rtems_device_driver
rtems_status_code rtems_device_driver
This type shall be used in device driver entry declarations and definitions.
Definition
io.h:90
uint32_t rtems_device_major_number
This integer type represents the major number of devices.
Definition
io.h:103
uint32_t rtems_device_minor_number
This integer type represents the minor number of devices.
Definition
io.h:115
Watchdog_control
rtems_device_driver Watchdog_control(rtems_device_major_number major, rtems_device_minor_number minor, void *arguments)
Watchdog Driver IO Control.
Watchdog_initialize
rtems_device_driver Watchdog_initialize(rtems_device_major_number major, rtems_device_minor_number minor, void *arguments)
Watchdog Driver Initialization.
