RTEMS
6.3
Toggle main menu visibility
include
init.h
1
/* SPDX-License-Identifier: BSD-2-Clause */
2
10
11
12
* Copyright (C) 2015, 2021 embedded brains GmbH & Co. KG
13
* Copyright (C) 1988, 2008 On-Line Applications Research Corporation (OAR)
14
15
16
* modification, are permitted provided that the following conditions
17
* are met:
18
* 1. Redistributions of source code must retain the above copyright
19
* notice, this list of conditions and the following disclaimer.
20
* 2. Redistributions in binary form must reproduce the above copyright
21
* notice, this list of conditions and the following disclaimer in the
22
* documentation and/or other materials provided with the distribution.
23
24
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
25
* AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
26
* IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
27
* ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
28
* LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
29
* CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
30
* SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
31
* INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
32
* CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
33
* ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
34
* POSSIBILITY OF SUCH DAMAGE.
35
36
37
38
* This file is part of the RTEMS quality process and was automatically
39
* generated. If you find something that needs to be fixed or
40
* worded better please post a report or patch to an RTEMS mailing list
41
* or raise a bug report:
42
43
* https://www.rtems.org/bugs.html
44
45
* For information on updating and regenerating please refer to the How-To
46
* section in the Software Requirements Engineering chapter of the
47
* RTEMS Software Engineering manual. The manual is provided as a part of
48
* a release. For development sources please refer to the online
49
* documentation at:
50
51
* https://docs.rtems.org
52
53
54
/* Generated from spec:/rtems/init/if/header */
55
56
#ifndef _RTEMS_INIT_H
57
#define _RTEMS_INIT_H
58
59
#include <stdint.h>
60
rtems/score/basedefs.h
61
62
#ifdef __cplusplus
63
extern
"C"
64
#endif
65
66
/* Generated from spec:/rtems/init/if/group */
67
80
81
/* Generated from spec:/rtems/init/if/initialize-executive */
82
104
RTEMS_NO_RETURN
void
rtems_initialize_executive
void
105
106
/* Generated from spec:/rtems/fatal/if/shutdown-executive */
107
136
RTEMS_NO_RETURN
void
rtems_shutdown_executive
( uint32_t fatal_code );
137
138
#ifdef __cplusplus
139
140
#endif
141
142
#endif
/* _RTEMS_INIT_H */
basedefs.h
This header file provides basic definitions used by the API and the implementation.
RTEMS_NO_RETURN
#define RTEMS_NO_RETURN
Tells the compiler in a function declaration that this function does not return.
Definition
basedefs.h:386
RTEMS_NO_RETURN void rtems_shutdown_executive(uint32_t fatal_code)
Invokes the fatal error handler.
Definition
exshutdown.c:47
RTEMS_NO_RETURN void rtems_initialize_executive(void)
Initializes the system and starts multitasking.
Definition
exinit.c:149
