RTEMS 6.3
printer.h File Reference
User print interface to the bspIO print plug in. More...
#include <rtems/print.h>
#include <rtems/chain.h>
#include <rtems/rtems/intr.h>
struct  rtems_printer
struct  rtems_printer_task_context
typedef int(*) rtems_print_printer(void *, const char *format, va_list ap)
void rtems_print_printer_printk (rtems_printer *printer)
 Initializes the printer to print via printk().
void rtems_print_printer_printf (rtems_printer *printer)
 Initializes the printer to print via printf().
void rtems_print_printer_fprintf (rtems_printer *printer, FILE *file)
 Initializes the printer to print via fprintf() using the specified file stream.
void rtems_print_printer_fprintf_putc (rtems_printer *printer)
 Initializes the printer to print via fprintf() using an unbuffered FILE stream with output through rtems_putc().
int rtems_print_printer_task (rtems_printer *printer, rtems_printer_task_context *context)
 Creates a printer task.
void rtems_printer_task_drain (rtems_printer_task_context *context)
 Drains the work queue of the printer task.
This include file defines the user interface to kernel print methods.
