RTEMS 6.3
This group contains the gocv support. More...
Files | |
| file | cpukit/include/rtems/test-gcov.h |
| This header file provides the interfaces of the Gcov Support. | |
| file | cpukit/libtest/gcovdumpinfo.c |
| This source file contains the implementation of _Gcov_Ddump_info(). | |
| file | cpukit/libtest/gcovdumpinfobase64.c |
| This source file contains the implementation of _Gcov_Dump_info_base64(). | |
| file | cpukit/libtest/gcovinfoset.c |
| This source file contains the definition of the gcov information linker set. | |
| RTEMS_LINKER_ROSET_DECLARE (gcov_info, const struct gcov_info *) | |
| void | _Gcov_Dump_info (IO_Put_char put_char, void *arg) |
| Dumps the gcov information as a binary gcfn and gcda data stream using the put character handler. | |
| void | _Gcov_Dump_info_base64 (IO_Put_char put_char, void *arg) |
| Dumps the gcov information as a base64 encoded gcfn and gcda data stream using the put character handler. | |
| void _Gcov_Dump_info | ( | IO_Put_char | put_char, |
| void * | arg ) |
| put_char | is the put character handler used to output the data stream. |
| arg | is the argument passed to the put character handler. |
| void _Gcov_Dump_info_base64 | ( | IO_Put_char | put_char, |
| void * | arg ) |
