| | address.h |
| | This header file provides the interfaces of the Address Handler.
| | apimutex.h |
| | This header file provides the interfaces of the API Mutex Handler.
| | assert.h |
| | This header file provides the interfaces of the Assert Handler.
| | atomic.h |
| | This header file provides the interfaces of the Atomic Operations.
| | basedefs.h |
| | This header file provides basic definitions used by the API and the implementation.
| | bsd-tree.h |
| | This header file provides a red-black tree implementation.
| | chain.h |
| | This header file provides interfaces of the Chain Handler which are used by the implementation and the API.
| | chainimpl.h |
| | This header file provides interfaces of the Chain Handler which are only used by the implementation.
| | context.h |
| | This header file provides the interfaces of the Context Handler.
| | copyrt.h |
| | This header file provides the interfaces of the Copyright Notice.
| | corebarrier.h |
| | This header file provides interfaces of the Barrier Handler which are used by the implementation and the Application Configuration.
| | corebarrierimpl.h |
| | This header file provides interfaces of the Barrier Handler which are only used by the implementation.
| | coremsg.h |
| | This header file provides interfaces of the Message Queue Handler which are only used by the implementation.
| | coremsgbuffer.h |
| | This header file provides interfaces of the Message Queue Handler which are used by the implementation, the Application Configuration, and the API.
| | coremsgimpl.h |
| | This header file provides interfaces of the Message Queue Handler which are used by the implementation and the Application Configuration.
| | coremutex.h |
| | This header file provides interfaces of the Mutex Handler which are used by the implementation and the Application Configuration.
| | coremuteximpl.h |
| | This header file provides interfaces of the Mutex Handler which are only used by the implementation.
| | corerwlockimpl.h |
| | This header file provides interfaces of the Read-Write Lock which are only used by the implementation.
| | coresem.h |
| | This header file provides interfaces of the Semaphore Handler which are used by the implementation and the Application Configuration.
| | coresemimpl.h |
| | This header file provides interfaces of the Semaphore Handler which are only used by the implementation.
| | exception.h |
| | This header file provides the interfaces for mapping exceptions to signsls.
| | freechain.h |
| | This header file provides interfaces of the Freechain Handler which are used by the implementation and the Application Configuration.
| | freechainimpl.h |
| | hash.h |
| | This header file provides the interfaces of the Hash Handler.
| | heap.h |
| | This header file provides interfaces of the Heap Handler which are used by the implementation and the Application Configuration.
| | heapimpl.h |
| | heapinfo.h |
| | This header file provides interfaces of the Barrier Handler which are used by the implementation and the API.
| | interr.h |
| | This header file provides the interfaces of the Internal Error Handler.
| | isr.h |
| | This header file provides the main interfaces of the ISR Handler.
| | isrlevel.h |
| | This header file provides the ISR_Level related interfaces of the ISR Handler.
| | isrlock.h |
| | This header file provides the interfaces of the ISR Locks.
| | memory.h |
| | This header file provides the interfaces of the Memory Handler.
| | mpci.h |
| | This header file provides interfaces of the MPCI Handler which are used by the implementation and the Application Configuration.
| | mpciimpl.h |
| | This header file provides interfaces of the MPCI Handler which are only used by the implementation.
| | mppkt.h |
| | This header file provides the interfaces of the Multiprocessing (MP) Packet Handler.
| | mrsp.h |
| | This header file provides interfaces of the Multiprocessor Resource Sharing Protocol (MrsP) which are used by the implementation and the Application Configuration.
| | mrspimpl.h |
| | This header file provides interfaces of the Multiprocessor Resource Sharing Protocol (MrsP) which are only used by the implementation.
| | muteximpl.h |
| | This header file provides the interfaces of the System Lock Mutex Support.
| | object.h |
| | This header file provides interfaces of the Object Handler which are used by the implementation and the Application Configuration.
| | objectdata.h |
| | This header file provides data structures used by the implementation and the Application Configuration to define instances of Objects_Information, ::_Objects_MP_Controls, and ultimately Thread_Configured_control.
| | objectimpl.h |
| | This header file provides interfaces of the Object Handler which are only used by the implementation.
| | objectmp.h |
| | This header file provides the interfaces of the Object Handler Multiprocessing (MP) Support.
| | onceimpl.h |
| | This header file provides the interfaces of the Execute Once Support.
| | percpu.h |
| | This header file provides the interfaces of the Per-CPU Information.
| | percpudata.h |
| | This header file provides the interfaces of the Flexible Per-CPU Data.
| | priority.h |
| | This header file provides interfaces of the Priority Handler which are used by the implementation and the Application Configuration.
| | prioritybitmap.h |
| | This header file provides interfaces of the Priority Bitmap which are used by the implementation and the Application Configuration.
| | prioritybitmapimpl.h |
| | This header file provides interfaces of the Priority Bitmap which are only used by the implementation.
| | priorityimpl.h |
| | This header file provides interfaces of the Priority Handler which are only used by the implementation.
| | processormask.h |
| | This header file provides the interfaces of the Processor Mask.
| | processormaskimpl.h |
| | profiling.h |
| | This header file provides the interfaces of the Profiling Support.
| | protectedheap.h |
| | This header file provides the interfaces of the Protected Heap Handler.
| | rbtree.h |
| | This header file provides interfaces of the Red-Black Tree Handler which are used by the implementation, the Application Configuration, and the API.
| | rbtreeimpl.h |
| | This header file provides interfaces of the Red-Black Tree Handler which are only used by the implementation.
| | scheduler.h |
| | This header file provides interfaces of the Scheduler Handler which are used by the implementation and the Application Configuration.
| | schedulercbs.h |
| | This header file provides interfaces of the Constant Bandwidth Server (CBS) Scheduler which are used by the implementation and the Application Configuration.
| | schedulercbsimpl.h |
| | This header file provides interfaces of the Constant Bandwidth Server (CBS) Scheduler which are only used by the implementation.
| | scheduleredf.h |
| | This header file provides interfaces of the EDF Scheduler which are used by the implementation and the Application Configuration.
| | scheduleredfimpl.h |
| | This header file provides interfaces of the EDF Scheduler which are only used by the implementation.
| | scheduleredfsmp.h |
| | This header file provides the interfaces of the Earliest Deadline First (EDF) Priority SMP Scheduler.
| | schedulerimpl.h |
| | This header file provides interfaces of the Scheduler Handler which are only used by the implementation.
| | schedulernode.h |
| | This header file provides interfaces of the Scheduler Handler related to scheduler nodes which are used by the implementation and the Application Configuration.
| | schedulernodeimpl.h |
| | This header file provides interfaces of the Scheduler Handler related to scheduler nodes which are only used by the implementation.
| | schedulerpriority.h |
| | This header file provides interfaces of the Deterministic Priority Scheduler which are used by the implementation and the Application Configuration.
| | schedulerpriorityaffinitysmp.h |
| | This header file provides the interfaces of the Deterministic Priority Affinity SMP Scheduler.
| | schedulerpriorityimpl.h |
| | This header file provides interfaces of the Deterministic Priority Scheduler which are only used by the implementation.
| | schedulerprioritysmp.h |
| | This header file provides interfaces of the Deterministic Priority SMP Scheduler which are used by the implementation and the Application Configuration.
| | schedulerprioritysmpimpl.h |
| | This header file provides interfaces of the Deterministic Priority SMP Scheduler which are only used by the implementation.
| | schedulersimple.h |
| | This header file provides interfaces of the Simple Priority Scheduler which are used by the implementation and the Application Configuration.
| | schedulersimpleimpl.h |
| | This header file provides interfaces of the Simple Priority Scheduler which are only used by the implementation.
| | schedulersimplesmp.h |
| | This header file provides the interfaces of the Simple Priority SMP Scheduler.
| | schedulersmp.h |
| | This header file provides interfaces of the SMP Scheduler which are used by the implementation and the Application Configuration.
| | schedulersmpimpl.h |
| | This header file provides interfaces of the SMP Scheduler which are only used by the implementation.
| | schedulerstrongapa.h |
| | This header file provides the interfaces of the Strong APA Scheduler.
| | scheduleruniimpl.h |
| | This header file provides interfaces of the supporting the implementation of uniprocessor schedulers.
| | semaphoreimpl.h |
| | This header file provides the interfaces of the System Lock Semaphore Support.
| | smp.h |
| | This header file provides interfaces of the SMP Support which are used by the implementation and the Application Configuration.
| | smpbarrier.h |
| | This header file provides the interfaces of the SMP Barriers.
| | smpimpl.h |
| | This header file provides interfaces of the SMP Support which are only used by the implementation.
| | smplock.h |
| | This header file provides the main interfaces of the SMP Locks.
| | smplockmcs.h |
| | This header file provides the interfaces of the SMP Locks related to MCS locks.
| | smplockseq.h |
| | This header file provides the interfaces of the SMP Locks related to sequence locks.
| | smplockstats.h |
| | This header file provides the interfaces of the SMP Locks related to lock statistics.
| | smplockticket.h |
| | This header file provides the interfaces of the SMP Locks related to ticket locks.
| | stack.h |
| | This header file provides interfaces of the Stack Handler which are used by the implementation and the Application Configuration.
| | stackimpl.h |
| | This header file provides interfaces of the Stack Handler which are only used by the implementation.
| | states.h |
| | This header file provides interfaces of the Thread States which are used by the implementation and the Application Configuration.
| | statesimpl.h |
| | This header file provides interfaces of the Thread States which are only used by the implementation.
| | status.h |
| | This header file provides the interfaces of the Operation Status Support.
| | sysstate.h |
| | This header file provides the interfaces of the System State Handler.
| | thread.h |
| | This header file provides interfaces of the Thread Handler which are used by the implementation and the Application Configuration.
| | threadcpubudget.h |
| | This header file provides interfaces used to implement the CPU budget management of threads.
| | threaddispatch.h |
| | This header file provides the interfaces of the Thread Handler related to thread dispatching.
| | threadidledata.h |
| | This header file provides data structures used by the implementation and the Application Configuration to define _Thread_Idle_stack_size and _Thread_Idle_body.
| | threadimpl.h |
| | This header file provides interfaces of the Thread Handler which are only used by the implementation.
| | threadmp.h |
| | This header file provides the interfaces of the Thread Handler Multiprocessing (MP) Support.
| | threadq.h |
| | This header file provides interfaces of the Thread Queue Handler which are used by the implementation and the Application Configuration.
| | threadqimpl.h |
| | This header file provides interfaces of the Thread Queue Handler which are only used by the implementation.
| | threadqops.h |
| | This header file provides interfaces related to thread queue operations.
| | timecounter.h |
| | This header file provides interfaces of the Timecounter Handler which are used by the implementation and the API.
| | timecounterimpl.h |
| | This header file provides interfaces of the Timecounter Handler which are only used by the implementation.
| | timespec.h |
| | This header file provides the interfaces of the Timespec Helpers.
| | timestamp.h |
| | This header file provides interfaces of the Timestamp Handler which are used by the implementation and the Application Configuration.
| | timestampimpl.h |
| | This header file provides interfaces of the Timestamp Handler which are only used by the implementation.
| | tls.h |
| | This header file provides the interfaces of the Thread-Local Storage (TLS).
| | todimpl.h |
| | This header file provides the interfaces of the Time of Day Handler and the Time of Day Handler Action Hooks.
| | userext.h |
| | This header file provides interfaces of the User Extensions Handler which are used by the implementation and the Application Configuration.
| | userextdata.h |
| | This header file provides data structures used by the implementation and the Application Configuration to define _User_extensions_Initial_count, _User_extensions_Initial_extensions, and _User_extensions_Initial_switch_controls.
| | userextimpl.h |
| | This header file provides interfaces of the User Extensions Handler which are only used by the implementation.
| | watchdog.h |
| | This header file provides interfaces of the Watchdog Handler which are used by the implementation and the Application Configuration.
| | watchdogimpl.h |
| | This header file provides interfaces of the Watchdog Handler which are only used by the implementation.
| | watchdogticks.h |
| | This header file provides the interfaces of the Watchdog Handler related to watchdog ticks which are used by the implementation and the Application Configuration.
| | wkspace.h |
| | This header file provides interfaces of the Workspace Handler which are only used by the implementation.
| | wkspacedata.h |
| | This header file provides data structures used by the implementation and the Application Configuration to define _Workspace_Size, _Workspace_Is_unified, and _Workspace_Malloc_initializer.
| | wkspaceinitmulti.h |
| | This header file provides the implementation of _Workspace_Initialize_for_multiple_areas().
| | wkspaceinitone.h |
| | This header file provides the implementation of _Workspace_Initialize_for_one_area().
