RTEMS
6.3
Toggle main menu visibility
include
scheduler.h
1
/* SPDX-License-Identifier: BSD-2-Clause */
2
11
12
13
* Copyright (C) 2014, 2018 embedded brains GmbH & Co. KG
14
15
16
* modification, are permitted provided that the following conditions
17
* are met:
18
* 1. Redistributions of source code must retain the above copyright
19
* notice, this list of conditions and the following disclaimer.
20
* 2. Redistributions in binary form must reproduce the above copyright
21
* notice, this list of conditions and the following disclaimer in the
22
* documentation and/or other materials provided with the distribution.
23
24
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
25
* AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
26
* IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
27
* ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
28
* LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
29
* CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
30
* SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
31
* INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
32
* CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
33
* ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
34
* POSSIBILITY OF SUCH DAMAGE.
35
36
37
#ifndef _RTEMS_SAPI_SCHEDULER_H
38
#define _RTEMS_SAPI_SCHEDULER_H
39
40
rtems/score/scheduler.h
41
42
#define SCHEDULER_CONTEXT_NAME( name ) \
43
_Configuration_Scheduler_ ## name
44
45
#if defined(RTEMS_SMP)
46
#define SCHEDULER_CONTROL_IS_NON_PREEMPT_MODE_SUPPORTED( value ) \
47
, value
48
#else
49
50
#endif
51
52
53
/* This object doesn't exist and indicates a configuration error */
54
extern
const
Scheduler_Control RTEMS_SCHEDULER_INVALID_INDEX;
55
65
#define RTEMS_SCHEDULER_ASSIGN_DEFAULT \
66
67
80
#define RTEMS_SCHEDULER_ASSIGN_PROCESSOR_OPTIONAL \
81
82
96
#define RTEMS_SCHEDULER_ASSIGN_PROCESSOR_MANDATORY \
97
98
111
#define RTEMS_SCHEDULER_ASSIGN( index, attr ) \
112
113
( index ) < RTEMS_ARRAY_SIZE( _Scheduler_Table ) ? \
114
&_Scheduler_Table[ ( index ) ] : &RTEMS_SCHEDULER_INVALID_INDEX, \
115
( attr ) \
116
117
128
#define RTEMS_SCHEDULER_ASSIGN_NO_SCHEDULER { NULL, 0 }
129
#endif
130
131
132
* This file should be only included in the context of <rtems/confdefs.h>.
133
* Define the scheduler configuration macros only in case the corresponding
134
* configure symbol is defined. This is necessary to prevent invalid workspace
135
* size estimates since we have to account for the per-thread scheduler
136
* information.
137
138
145
#define SCHEDULER_CBS_CONTEXT_NAME( name ) \
146
SCHEDULER_CONTEXT_NAME( CBS_ ## name )
147
155
#define RTEMS_SCHEDULER_CBS( name ) \
156
static Scheduler_EDF_Context SCHEDULER_CBS_CONTEXT_NAME( name )
157
170
#define RTEMS_SCHEDULER_TABLE_CBS( name, obj_name ) \
171
172
&SCHEDULER_CBS_CONTEXT_NAME( name ).Base, \
173
SCHEDULER_CBS_ENTRY_POINTS, \
174
SCHEDULER_CBS_MAXIMUM_PRIORITY, \
175
( obj_name ) \
176
SCHEDULER_CONTROL_IS_NON_PREEMPT_MODE_SUPPORTED( true ) \
177
178
179
#ifdef CONFIGURE_SCHEDULER_CBS
180
rtems/score/schedulercbs.h
181
182
/* Provided for backward compatibility */
183
184
#define RTEMS_SCHEDULER_CONTEXT_CBS( name ) \
185
186
187
#define RTEMS_SCHEDULER_CONTROL_CBS( name, obj_name ) \
188
189
#endif
190
197
#define SCHEDULER_EDF_CONTEXT_NAME( name ) \
198
SCHEDULER_CONTEXT_NAME( EDF_ ## name )
199
207
#define RTEMS_SCHEDULER_EDF( name ) \
208
static Scheduler_EDF_Context SCHEDULER_EDF_CONTEXT_NAME( name )
209
222
#define RTEMS_SCHEDULER_TABLE_EDF( name, obj_name ) \
223
224
&SCHEDULER_EDF_CONTEXT_NAME( name ).Base, \
225
SCHEDULER_EDF_ENTRY_POINTS, \
226
SCHEDULER_EDF_MAXIMUM_PRIORITY, \
227
( obj_name ) \
228
229
230
231
#ifdef CONFIGURE_SCHEDULER_EDF
232
rtems/score/scheduleredf.h
233
234
235
236
#define RTEMS_SCHEDULER_CONTEXT_EDF( name ) \
237
238
239
#define RTEMS_SCHEDULER_CONTROL_EDF( name, obj_name ) \
240
241
#endif
242
249
#define SCHEDULER_EDF_SMP_CONTEXT_NAME( name ) \
250
SCHEDULER_CONTEXT_NAME( EDF_SMP_ ## name )
251
259
#define RTEMS_SCHEDULER_EDF_SMP( name ) \
260
static struct { \
261
Scheduler_EDF_SMP_Context Base; \
262
Scheduler_EDF_SMP_Ready_queue Ready[ CONFIGURE_MAXIMUM_PROCESSORS + 1 ]; \
263
} SCHEDULER_EDF_SMP_CONTEXT_NAME( name )
264
277
#define RTEMS_SCHEDULER_TABLE_EDF_SMP( name, obj_name ) \
278
279
&SCHEDULER_EDF_SMP_CONTEXT_NAME( name ).Base.Base.Base, \
280
SCHEDULER_EDF_SMP_ENTRY_POINTS, \
281
282
( obj_name ) \
283
SCHEDULER_CONTROL_IS_NON_PREEMPT_MODE_SUPPORTED( false ) \
284
285
286
#ifdef CONFIGURE_SCHEDULER_EDF_SMP
287
#ifndef RTEMS_SMP
288
#error "CONFIGURE_SCHEDULER_EDF_SMP cannot be used if RTEMS_SMP is disabled"
289
#endif
290
291
#ifndef CONFIGURE_MAXIMUM_PROCESSORS
292
#error "CONFIGURE_MAXIMUM_PROCESSORS must be defined to configure the EDF SMP Scheduler"
293
#endif
294
295
rtems/score/scheduleredfsmp.h
296
297
298
299
#define RTEMS_SCHEDULER_CONTEXT_EDF_SMP( name, max_cpu_count ) \
300
301
302
#define RTEMS_SCHEDULER_CONTROL_EDF_SMP( name, obj_name ) \
303
304
#endif
305
312
#define SCHEDULER_PRIORITY_CONTEXT_NAME( name ) \
313
SCHEDULER_CONTEXT_NAME( priority_ ## name )
314
324
#define RTEMS_SCHEDULER_PRIORITY( name, prio_count ) \
325
static struct { \
326
Scheduler_priority_Context Base; \
327
Chain_Control Ready[ ( prio_count ) ]; \
328
} SCHEDULER_PRIORITY_CONTEXT_NAME( name )
329
343
#define RTEMS_SCHEDULER_TABLE_PRIORITY( name, obj_name ) \
344
345
&SCHEDULER_PRIORITY_CONTEXT_NAME( name ).Base.Base, \
346
SCHEDULER_PRIORITY_ENTRY_POINTS, \
347
RTEMS_ARRAY_SIZE( \
348
SCHEDULER_PRIORITY_CONTEXT_NAME( name ).Ready \
349
) - 1, \
350
( obj_name ) \
351
352
353
354
#ifdef CONFIGURE_SCHEDULER_PRIORITY
355
rtems/score/schedulerpriority.h
356
357
358
359
#define RTEMS_SCHEDULER_CONTEXT_PRIORITY( name, prio_count ) \
360
361
362
#define RTEMS_SCHEDULER_CONTROL_PRIORITY( name, obj_name ) \
363
364
#endif
365
372
#define SCHEDULER_PRIORITY_AFFINITY_SMP_CONTEXT_NAME( name ) \
373
SCHEDULER_CONTEXT_NAME( priority_affinity_SMP_ ## name )
374
385
#define RTEMS_SCHEDULER_PRIORITY_AFFINITY_SMP( name, prio_count ) \
386
static struct { \
387
Scheduler_priority_SMP_Context Base; \
388
389
} SCHEDULER_PRIORITY_AFFINITY_SMP_CONTEXT_NAME( name )
390
404
#define RTEMS_SCHEDULER_TABLE_PRIORITY_AFFINITY_SMP( name, obj_name ) \
405
406
&SCHEDULER_PRIORITY_AFFINITY_SMP_CONTEXT_NAME( name ).Base.Base.Base, \
407
SCHEDULER_PRIORITY_AFFINITY_SMP_ENTRY_POINTS, \
408
RTEMS_ARRAY_SIZE( \
409
SCHEDULER_PRIORITY_AFFINITY_SMP_CONTEXT_NAME( name ).Ready \
410
) - 1, \
411
( obj_name ) \
412
413
414
415
#ifdef CONFIGURE_SCHEDULER_PRIORITY_AFFINITY_SMP
416
#ifndef RTEMS_SMP
417
#error "CONFIGURE_SCHEDULER_PRIORITY_AFFINITY_SMP cannot be used if RTEMS_SMP is disabled"
418
#endif
419
420
rtems/score/schedulerpriorityaffinitysmp.h
421
422
423
424
#define RTEMS_SCHEDULER_CONTEXT_PRIORITY_AFFINITY_SMP( name, prio_count ) \
425
426
427
#define RTEMS_SCHEDULER_CONTROL_PRIORITY_AFFINITY_SMP( name, obj_name ) \
428
429
#endif
430
437
#define SCHEDULER_PRIORITY_SMP_CONTEXT_NAME( name ) \
438
SCHEDULER_CONTEXT_NAME( priority_SMP_ ## name )
439
449
#define RTEMS_SCHEDULER_PRIORITY_SMP( name, prio_count ) \
450
static struct { \
451
452
453
} SCHEDULER_PRIORITY_SMP_CONTEXT_NAME( name )
454
468
#define RTEMS_SCHEDULER_TABLE_PRIORITY_SMP( name, obj_name ) \
469
470
&SCHEDULER_PRIORITY_SMP_CONTEXT_NAME( name ).Base.Base.Base, \
471
SCHEDULER_PRIORITY_SMP_ENTRY_POINTS, \
472
RTEMS_ARRAY_SIZE( \
473
SCHEDULER_PRIORITY_SMP_CONTEXT_NAME( name ).Ready \
474
) - 1, \
475
( obj_name ) \
476
477
478
479
#ifdef CONFIGURE_SCHEDULER_PRIORITY_SMP
480
#ifndef RTEMS_SMP
481
#error "CONFIGURE_SCHEDULER_PRIORITY_SMP cannot be used if RTEMS_SMP is disabled"
482
#endif
483
484
rtems/score/schedulerprioritysmp.h
485
486
487
488
#define RTEMS_SCHEDULER_CONTEXT_PRIORITY_SMP( name, prio_count ) \
489
490
491
#define RTEMS_SCHEDULER_CONTROL_PRIORITY_SMP( name, obj_name ) \
492
493
#endif
494
501
#define SCHEDULER_STRONG_APA_CONTEXT_NAME( name ) \
502
SCHEDULER_CONTEXT_NAME( strong_APA_ ## name )
503
511
#define RTEMS_SCHEDULER_STRONG_APA( name, prio_count ) \
512
static struct { \
513
Scheduler_strong_APA_Context Base; \
514
Scheduler_strong_APA_CPU CPU[ CONFIGURE_MAXIMUM_PROCESSORS ]; \
515
} SCHEDULER_STRONG_APA_CONTEXT_NAME( name )
516
529
#define RTEMS_SCHEDULER_TABLE_STRONG_APA( name, obj_name ) \
530
531
&SCHEDULER_STRONG_APA_CONTEXT_NAME( name ).Base.Base.Base, \
532
SCHEDULER_STRONG_APA_ENTRY_POINTS, \
533
SCHEDULER_STRONG_APA_MAXIMUM_PRIORITY, \
534
( obj_name ) \
535
536
537
538
#ifdef CONFIGURE_SCHEDULER_STRONG_APA
539
#ifndef RTEMS_SMP
540
#error "CONFIGURE_SCHEDULER_STRONG_APA cannot be used if RTEMS_SMP is disabled"
541
#endif
542
543
544
#error "CONFIGURE_MAXIMUM_PROCESSORS must be defined to configure the Strong APA Scheduler"
545
#endif
546
547
rtems/score/schedulerstrongapa.h
548
549
550
551
#define RTEMS_SCHEDULER_CONTEXT_STRONG_APA( name, prio_count ) \
552
553
554
#define RTEMS_SCHEDULER_CONTROL_STRONG_APA( name, obj_name ) \
555
556
#endif
557
564
#define SCHEDULER_SIMPLE_CONTEXT_NAME( name ) \
565
SCHEDULER_CONTEXT_NAME( simple_ ## name )
566
574
#define RTEMS_SCHEDULER_SIMPLE( name ) \
575
static Scheduler_simple_Context \
576
577
590
#define RTEMS_SCHEDULER_TABLE_SIMPLE( name, obj_name ) \
591
592
&SCHEDULER_SIMPLE_CONTEXT_NAME( name ).Base, \
593
SCHEDULER_SIMPLE_ENTRY_POINTS, \
594
SCHEDULER_SIMPLE_MAXIMUM_PRIORITY, \
595
( obj_name ) \
596
597
598
599
#ifdef CONFIGURE_SCHEDULER_SIMPLE
600
rtems/score/schedulersimple.h
601
602
603
604
#define RTEMS_SCHEDULER_CONTEXT_SIMPLE( name ) \
605
606
607
#define RTEMS_SCHEDULER_CONTROL_SIMPLE( name, obj_name ) \
608
609
#endif
610
617
#define SCHEDULER_SIMPLE_SMP_CONTEXT_NAME( name ) \
618
SCHEDULER_CONTEXT_NAME( simple_SMP_ ## name )
619
627
#define RTEMS_SCHEDULER_SIMPLE_SMP( name ) \
628
static Scheduler_simple_SMP_Context \
629
630
643
#define RTEMS_SCHEDULER_TABLE_SIMPLE_SMP( name, obj_name ) \
644
645
&SCHEDULER_SIMPLE_SMP_CONTEXT_NAME( name ).Base.Base, \
646
SCHEDULER_SIMPLE_SMP_ENTRY_POINTS, \
647
SCHEDULER_SIMPLE_SMP_MAXIMUM_PRIORITY, \
648
( obj_name ) \
649
650
651
652
#ifdef CONFIGURE_SCHEDULER_SIMPLE_SMP
653
#ifndef RTEMS_SMP
654
#error "CONFIGURE_SCHEDULER_SIMPLE_SMP cannot be used if RTEMS_SMP is disabled"
655
#endif
656
657
rtems/score/schedulersimplesmp.h
658
659
660
661
#define RTEMS_SCHEDULER_CONTEXT_SIMPLE_SMP( name ) \
662
663
664
#define RTEMS_SCHEDULER_CONTROL_SIMPLE_SMP( name, obj_name ) \
665
666
#endif
667
668
#endif
/* _RTEMS_SAPI_SCHEDULER_H */
schedulercbs.h
This header file provides interfaces of the Constant Bandwidth Server (CBS) Scheduler which are used ...
scheduleredf.h
This header file provides interfaces of the EDF Scheduler which are used by the implementation and th...
scheduleredfsmp.h
This header file provides the interfaces of the Earliest Deadline First (EDF) Priority SMP Scheduler.
schedulerpriority.h
This header file provides interfaces of the Deterministic Priority Scheduler which are used by the im...
This header file provides the interfaces of the Deterministic Priority Affinity SMP Scheduler.
This header file provides interfaces of the Deterministic Priority SMP Scheduler which are used by th...
schedulersimple.h
This header file provides interfaces of the Simple Priority Scheduler which are used by the implement...
This header file provides the interfaces of the Simple Priority SMP Scheduler.
This header file provides the interfaces of the Strong APA Scheduler.
scheduler.h
This header file provides interfaces of the Scheduler Handler which are used by the implementation an...
