RTEMS
6.3
Toggle main menu visibility
include
vmeintr.h
1
/* SPDX-License-Identifier: BSD-2-Clause */
2
12
13
14
* COPYRIGHT (c) 1989-1999.
15
* On-Line Applications Research Corporation (OAR).
16
17
18
* modification, are permitted provided that the following conditions
19
* are met:
20
* 1. Redistributions of source code must retain the above copyright
21
* notice, this list of conditions and the following disclaimer.
22
* 2. Redistributions in binary form must reproduce the above copyright
23
* notice, this list of conditions and the following disclaimer in the
24
* documentation and/or other materials provided with the distribution.
25
26
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
27
* AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
28
* IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
29
* ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
30
* LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
31
* CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
32
* SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
33
* INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
34
* CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
35
* ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
36
* POSSIBILITY OF SUCH DAMAGE.
37
38
39
#ifndef _RTEMS_VMEINTR_H
40
#define _RTEMS_VMEINTR_H
41
42
#ifdef __cplusplus
43
extern
"C"
44
#endif
45
46
47
* This defines the mask which is used to determine which
48
* interrupt levels are affected by a call to this package.
49
* The LSB corresponds to VME interrupt 0 and the MSB
50
* to VME interrupt 7.
51
52
53
54
typedef
uint8_t VME_interrupt_Mask;
55
56
57
* VME_interrupt_Disable
58
59
60
61
void
VME_interrupt_Disable (
62
VME_interrupt_Mask mask
/* IN */
63
64
65
66
67
68
69
70
void
VME_interrupt_Enable (
71
/* IN */
72
73
74
#ifdef __cplusplus
75
76
#endif
77
78
#endif
/* end of include file */
