RTEMS
6.3
Toggle main menu visibility
include
extensionimpl.h
1
/* SPDX-License-Identifier: BSD-2-Clause */
2
10
11
12
* COPYRIGHT (c) 1989-1999.
13
* On-Line Applications Research Corporation (OAR).
14
15
16
* modification, are permitted provided that the following conditions
17
* are met:
18
* 1. Redistributions of source code must retain the above copyright
19
* notice, this list of conditions and the following disclaimer.
20
* 2. Redistributions in binary form must reproduce the above copyright
21
* notice, this list of conditions and the following disclaimer in the
22
* documentation and/or other materials provided with the distribution.
23
24
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
25
* AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
26
* IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
27
* ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
28
* LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
29
* CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
30
* SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
31
* INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
32
* CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
33
* ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
34
* POSSIBILITY OF SUCH DAMAGE.
35
36
37
#ifndef _RTEMS_EXTENSIONIMPL_H
38
#define _RTEMS_EXTENSIONIMPL_H
39
40
rtems/extensiondata.h
41
rtems/score/objectimpl.h
42
43
#ifdef __cplusplus
44
extern
"C"
45
#endif
46
56
57
static
inline
Extension_Control
*_Extension_Allocate(
void
58
59
return
Extension_Control
_Objects_Allocate
_Extension_Information
60
61
62
static
inline
void
_Extension_Free (
63
Extension_Control
*the_extension
64
65
66
_Objects_Free( &
, &the_extension->Object );
67
68
69
static
inline
Extension_Control
*_Extension_Get(
Objects_Id
id
70
71
return
Extension_Control
72
_Objects_Get_no_protection
id
73
74
76
77
#ifdef __cplusplus
78
79
#endif
80
81
#endif
82
/* end of include file */
extensiondata.h
This header file provides data structures used by the implementation and the Application Configuratio...
Objects_Information _Extension_Information
The Classic Extensions objects information.
_Objects_Allocate
Objects_Control * _Objects_Allocate(Objects_Information *information)
Allocates an object.
Definition
objectallocate.c:43
Objects_Id
uint32_t Objects_Id
Definition
object.h:101
Objects_Control * _Objects_Get_no_protection(Objects_Id id, const Objects_Information *information)
Maps object ids to object control blocks.
Definition
objectgetnoprotection.c:44
objectimpl.h
This header file provides interfaces of the Object Handler which are only used by the implementation.
Extension_Control
Definition
extensiondata.h:55
