#define | PCI_VENDOR_ID 0x00 |
#define | PCI_DEVICE_ID 0x02 |
#define | PCI_INVALID_VENDORDEVICEID 0xffffffff |
#define | PCI_COMMAND 0x04 |
#define | PCI_COMMAND_IO 0x0001 |
#define | PCI_COMMAND_MEMORY 0x0002 |
#define | PCI_COMMAND_MASTER 0x0004 |
#define | PCI_COMMAND_SPECIAL 0x0008 |
#define | PCI_COMMAND_INVALIDATE 0x0010 |
#define | PCI_COMMAND_VGA_PALETTE 0x0020 |
#define | PCI_COMMAND_PARITY 0x0040 |
#define | PCI_COMMAND_WAIT 0x0080 |
#define | PCI_COMMAND_SERR 0x0100 |
#define | PCI_COMMAND_FAST_BACK 0x0200 |
#define | PCI_COMMAND_INTX_DISABLE 0x0400 |
#define | PCI_STATUS 0x06 |
#define | PCI_STATUS_66MHZ 0x0020 |
#define | PCI_STATUS_UDF 0x0040 |
#define | PCI_STATUS_FAST_BACK 0x0080 |
#define | PCI_STATUS_PARITY 0x0100 |
#define | PCI_STATUS_DEVSEL_MASK 0x0600 |
#define | PCI_STATUS_DEVSEL_FAST 0x0000 |
#define | PCI_STATUS_DEVSEL_MEDIUM 0x0200 |
#define | PCI_STATUS_DEVSEL_SLOW 0x0400 |
#define | PCI_STATUS_SIG_TARGET_ABORT 0x0800 |
#define | PCI_STATUS_REC_TARGET_ABORT 0x1000 |
#define | PCI_STATUS_REC_MASTER_ABORT 0x2000 |
#define | PCI_STATUS_SIG_SYSTEM_ERROR 0x4000 |
#define | PCI_STATUS_DETECTED_PARITY 0x8000 |
#define | PCI_CLASS_REVISION 0x08 |
#define | PCI_REVISION_ID 0x08 |
#define | PCI_CLASS_PROG 0x09 |
#define | PCI_CLASS_DEVICE 0x0a |
#define | PCI_CACHE_LINE_SIZE 0x0c |
#define | PCI_LATENCY_TIMER 0x0d |
#define | PCI_HEADER_TYPE 0x0e |
#define | PCI_HEADER_TYPE_NORMAL 0x00 |
#define | PCI_HEADER_TYPE_BRIDGE 0x01 |
#define | PCI_HEADER_TYPE_CARDBUS 0x02 |
#define | PCI_HEADER_TYPE_MULTI_FUNCTION 0x80 |
#define | PCI_BIST 0x0f |
#define | PCI_BIST_CODE_MASK 0x0f |
#define | PCI_BIST_START 0x40 |
#define | PCI_BIST_CAPABLE 0x80 |
#define | PCI_BASE_ADDRESS_0 0x10 |
#define | PCI_BASE_ADDRESS_1 0x14 |
#define | PCI_BASE_ADDRESS_2 0x18 |
#define | PCI_BASE_ADDRESS_3 0x1c |
#define | PCI_BASE_ADDRESS_4 0x20 |
#define | PCI_BASE_ADDRESS_5 0x24 |
#define | PCI_BASE_ADDRESS_SPACE 0x01 |
#define | PCI_BASE_ADDRESS_SPACE_IO 0x01 |
#define | PCI_BASE_ADDRESS_SPACE_MEMORY 0x00 |
#define | PCI_BASE_ADDRESS_MEM_TYPE_MASK 0x06 |
#define | PCI_BASE_ADDRESS_MEM_TYPE_32 0x00 |
#define | PCI_BASE_ADDRESS_MEM_TYPE_1M 0x02 |
#define | PCI_BASE_ADDRESS_MEM_TYPE_64 0x04 |
#define | PCI_BASE_ADDRESS_MEM_PREFETCH 0x08 |
#define | PCI_BASE_ADDRESS_MEM_MASK (~0x0fUL) |
#define | PCI_BASE_ADDRESS_IO_MASK (~0x03UL) |
#define | PCI_CARDBUS_CIS 0x28 |
#define | PCI_SUBSYSTEM_VENDOR_ID 0x2c |
#define | PCI_SUBSYSTEM_ID 0x2e |
#define | PCI_ROM_ADDRESS 0x30 |
#define | PCI_ROM_ADDRESS_ENABLE 0x01 |
#define | PCI_ROM_ADDRESS_MASK (~0x7ffUL) |
#define | PCI_CAPABILITY_LIST_POINTER 0x34 |
#define | PCI_INTERRUPT_LINE 0x3c |
#define | PCI_INTERRUPT_PIN 0x3d |
#define | PCI_MIN_GNT 0x3e |
#define | PCI_MAX_LAT 0x3f |
#define | PCI_PRIMARY_BUS 0x18 |
#define | PCI_SECONDARY_BUS 0x19 |
#define | PCI_SUBORDINATE_BUS 0x1a |
#define | PCI_SEC_LATENCY_TIMER 0x1b |
#define | PCI_IO_BASE 0x1c |
#define | PCI_IO_LIMIT 0x1d |
#define | PCI_IO_RANGE_TYPE_MASK 0x0f |
#define | PCI_IO_RANGE_TYPE_16 0x00 |
#define | PCI_IO_RANGE_TYPE_32 0x01 |
#define | PCI_IO_RANGE_MASK ~0x0f |
#define | PCI_SEC_STATUS 0x1e |
#define | PCI_MEMORY_BASE 0x20 |
#define | PCI_MEMORY_LIMIT 0x22 |
#define | PCI_MEMORY_RANGE_TYPE_MASK 0x0f |
#define | PCI_MEMORY_RANGE_MASK ~0x0f |
#define | PCI_PREF_MEMORY_BASE 0x24 |
#define | PCI_PREF_MEMORY_LIMIT 0x26 |
#define | PCI_PREF_RANGE_TYPE_MASK 0x0f |
#define | PCI_PREF_RANGE_TYPE_32 0x00 |
#define | PCI_PREF_RANGE_TYPE_64 0x01 |
#define | PCI_PREF_RANGE_MASK ~0x0f |
#define | PCI_PREF_BASE_UPPER32 0x28 |
#define | PCI_PREF_LIMIT_UPPER32 0x2c |
#define | PCI_IO_BASE_UPPER16 0x30 |
#define | PCI_IO_LIMIT_UPPER16 0x32 |
#define | PCI_ROM_ADDRESS1 0x38 |
#define | PCI_BRIDGE_CONTROL 0x3e |
#define | PCI_BRIDGE_CTL_PARITY 0x01 |
#define | PCI_BRIDGE_CTL_SERR 0x02 |
#define | PCI_BRIDGE_CTL_NO_ISA 0x04 |
#define | PCI_BRIDGE_CTL_VGA 0x08 |
#define | PCI_BRIDGE_CTL_MASTER_ABORT 0x20 |
#define | PCI_BRIDGE_CTL_BUS_RESET 0x40 |
#define | PCI_BRIDGE_CTL_FAST_BACK 0x80 |
#define | PCI_CB_SEC_STATUS 0x16 |
#define | PCI_CB_PRIMARY_BUS 0x18 |
#define | PCI_CB_CARD_BUS 0x19 |
#define | PCI_CB_SUBORDINATE_BUS 0x1a |
#define | PCI_CB_LATENCY_TIMER 0x1b |
#define | PCI_CB_MEMORY_BASE_0 0x1c |
#define | PCI_CB_MEMORY_LIMIT_0 0x20 |
#define | PCI_CB_MEMORY_BASE_1 0x24 |
#define | PCI_CB_MEMORY_LIMIT_1 0x28 |
#define | PCI_CB_IO_BASE_0 0x2c |
#define | PCI_CB_IO_BASE_0_HI 0x2e |
#define | PCI_CB_IO_LIMIT_0 0x30 |
#define | PCI_CB_IO_LIMIT_0_HI 0x32 |
#define | PCI_CB_IO_BASE_1 0x34 |
#define | PCI_CB_IO_BASE_1_HI 0x36 |
#define | PCI_CB_IO_LIMIT_1 0x38 |
#define | PCI_CB_IO_LIMIT_1_HI 0x3a |
#define | PCI_CB_IO_RANGE_MASK ~0x03 |
#define | PCI_CB_BRIDGE_CONTROL 0x3e |
#define | PCI_CB_BRIDGE_CTL_PARITY 0x01 |
#define | PCI_CB_BRIDGE_CTL_SERR 0x02 |
#define | PCI_CB_BRIDGE_CTL_ISA 0x04 |
#define | PCI_CB_BRIDGE_CTL_VGA 0x08 |
#define | PCI_CB_BRIDGE_CTL_MASTER_ABORT 0x20 |
#define | PCI_CB_BRIDGE_CTL_CB_RESET 0x40 |
#define | PCI_CB_BRIDGE_CTL_16BIT_INT 0x80 |
#define | PCI_CB_BRIDGE_CTL_PREFETCH_MEM0 0x100 |
#define | PCI_CB_BRIDGE_CTL_PREFETCH_MEM1 0x200 |
#define | PCI_CB_BRIDGE_CTL_POST_WRITES 0x400 |
#define | PCI_CB_SUBSYSTEM_VENDOR_ID 0x40 |
#define | PCI_CB_SUBSYSTEM_ID 0x42 |
#define | PCI_CB_LEGACY_MODE_BASE 0x44 |
#define | PCI_CLASS_NOT_DEFINED 0x0000 |
#define | PCI_CLASS_NOT_DEFINED_VGA 0x0001 |
#define | PCI_BASE_CLASS_STORAGE 0x01 |
#define | PCI_CLASS_STORAGE_SCSI 0x0100 |
#define | PCI_CLASS_STORAGE_IDE 0x0101 |
#define | PCI_CLASS_STORAGE_FLOPPY 0x0102 |
#define | PCI_CLASS_STORAGE_IPI 0x0103 |
#define | PCI_CLASS_STORAGE_RAID 0x0104 |
#define | PCI_CLASS_STORAGE_OTHER 0x0180 |
#define | PCI_BASE_CLASS_NETWORK 0x02 |
#define | PCI_CLASS_NETWORK_ETHERNET 0x0200 |
#define | PCI_CLASS_NETWORK_TOKEN_RING 0x0201 |
#define | PCI_CLASS_NETWORK_FDDI 0x0202 |
#define | PCI_CLASS_NETWORK_ATM 0x0203 |
#define | PCI_CLASS_NETWORK_OTHER 0x0280 |
#define | PCI_BASE_CLASS_DISPLAY 0x03 |
#define | PCI_CLASS_DISPLAY_VGA 0x0300 |
#define | PCI_CLASS_DISPLAY_XGA 0x0301 |
#define | PCI_CLASS_DISPLAY_OTHER 0x0380 |
#define | PCI_BASE_CLASS_MULTIMEDIA 0x04 |
#define | PCI_CLASS_MULTIMEDIA_VIDEO 0x0400 |
#define | PCI_CLASS_MULTIMEDIA_AUDIO 0x0401 |
#define | PCI_CLASS_MULTIMEDIA_OTHER 0x0480 |
#define | PCI_BASE_CLASS_MEMORY 0x05 |
#define | PCI_CLASS_MEMORY_RAM 0x0500 |
#define | PCI_CLASS_MEMORY_FLASH 0x0501 |
#define | PCI_CLASS_MEMORY_OTHER 0x0580 |
#define | PCI_BASE_CLASS_BRIDGE 0x06 |
#define | PCI_CLASS_BRIDGE_HOST 0x0600 |
#define | PCI_CLASS_BRIDGE_ISA 0x0601 |
#define | PCI_CLASS_BRIDGE_EISA 0x0602 |
#define | PCI_CLASS_BRIDGE_MC 0x0603 |
#define | PCI_CLASS_BRIDGE_PCI 0x0604 |
#define | PCI_CLASS_BRIDGE_PCMCIA 0x0605 |
#define | PCI_CLASS_BRIDGE_NUBUS 0x0606 |
#define | PCI_CLASS_BRIDGE_CARDBUS 0x0607 |
#define | PCI_CLASS_BRIDGE_OTHER 0x0680 |
#define | PCI_BASE_CLASS_COMMUNICATION 0x07 |
#define | PCI_CLASS_COMMUNICATION_SERIAL 0x0700 |
#define | PCI_CLASS_COMMUNICATION_PARALLEL 0x0701 |
#define | PCI_CLASS_COMMUNICATION_OTHER 0x0780 |
#define | PCI_BASE_CLASS_SYSTEM 0x08 |
#define | PCI_CLASS_SYSTEM_PIC 0x0800 |
#define | PCI_CLASS_SYSTEM_DMA 0x0801 |
#define | PCI_CLASS_SYSTEM_TIMER 0x0802 |
#define | PCI_CLASS_SYSTEM_RTC 0x0803 |
#define | PCI_CLASS_SYSTEM_OTHER 0x0880 |
#define | PCI_BASE_CLASS_INPUT 0x09 |
#define | PCI_CLASS_INPUT_KEYBOARD 0x0900 |
#define | PCI_CLASS_INPUT_PEN 0x0901 |
#define | PCI_CLASS_INPUT_MOUSE 0x0902 |
#define | PCI_CLASS_INPUT_OTHER 0x0980 |
#define | PCI_BASE_CLASS_DOCKING 0x0a |
#define | PCI_CLASS_DOCKING_GENERIC 0x0a00 |
#define | PCI_CLASS_DOCKING_OTHER 0x0a01 |
#define | PCI_BASE_CLASS_PROCESSOR 0x0b |
#define | PCI_CLASS_PROCESSOR_386 0x0b00 |
#define | PCI_CLASS_PROCESSOR_486 0x0b01 |
#define | PCI_CLASS_PROCESSOR_PENTIUM 0x0b02 |
#define | PCI_CLASS_PROCESSOR_ALPHA 0x0b10 |
#define | PCI_CLASS_PROCESSOR_POWERPC 0x0b20 |
#define | PCI_CLASS_PROCESSOR_CO 0x0b40 |
#define | PCI_BASE_CLASS_SERIAL 0x0c |
#define | PCI_CLASS_SERIAL_FIREWIRE 0x0c00 |
#define | PCI_CLASS_SERIAL_ACCESS 0x0c01 |
#define | PCI_CLASS_SERIAL_SSA 0x0c02 |
#define | PCI_CLASS_SERIAL_USB 0x0c03 |
#define | PCI_CLASS_SERIAL_FIBER 0x0c04 |
#define | PCI_CLASS_OTHERS 0xff |
#define | PCI_VENDOR_ID_COMPAQ 0x0e11 |
#define | PCI_DEVICE_ID_COMPAQ_1280 0x3033 |
#define | PCI_DEVICE_ID_COMPAQ_TRIFLEX 0x4000 |
#define | PCI_DEVICE_ID_COMPAQ_SMART2P 0xae10 |
#define | PCI_DEVICE_ID_COMPAQ_NETEL100 0xae32 |
#define | PCI_DEVICE_ID_COMPAQ_NETEL10 0xae34 |
#define | PCI_DEVICE_ID_COMPAQ_NETFLEX3I 0xae35 |
#define | PCI_DEVICE_ID_COMPAQ_NETEL100D 0xae40 |
#define | PCI_DEVICE_ID_COMPAQ_NETEL100PI 0xae43 |
#define | PCI_DEVICE_ID_COMPAQ_NETEL100I 0xb011 |
#define | PCI_DEVICE_ID_COMPAQ_THUNDER 0xf130 |
#define | PCI_DEVICE_ID_COMPAQ_NETFLEX3B 0xf150 |
#define | PCI_VENDOR_ID_NCR 0x1000 |
#define | PCI_DEVICE_ID_NCR_53C810 0x0001 |
#define | PCI_DEVICE_ID_NCR_53C820 0x0002 |
#define | PCI_DEVICE_ID_NCR_53C825 0x0003 |
#define | PCI_DEVICE_ID_NCR_53C815 0x0004 |
#define | PCI_DEVICE_ID_NCR_53C860 0x0006 |
#define | PCI_DEVICE_ID_NCR_53C896 0x000b |
#define | PCI_DEVICE_ID_NCR_53C895 0x000c |
#define | PCI_DEVICE_ID_NCR_53C885 0x000d |
#define | PCI_DEVICE_ID_NCR_53C875 0x000f |
#define | PCI_DEVICE_ID_NCR_53C875J 0x008f |
#define | PCI_VENDOR_ID_ATI 0x1002 |
#define | PCI_DEVICE_ID_ATI_68800 0x4158 |
#define | PCI_DEVICE_ID_ATI_215CT222 0x4354 |
#define | PCI_DEVICE_ID_ATI_210888CX 0x4358 |
#define | PCI_DEVICE_ID_ATI_215GB 0x4742 |
#define | PCI_DEVICE_ID_ATI_215GD 0x4744 |
#define | PCI_DEVICE_ID_ATI_215GI 0x4749 |
#define | PCI_DEVICE_ID_ATI_215GP 0x4750 |
#define | PCI_DEVICE_ID_ATI_215GQ 0x4751 |
#define | PCI_DEVICE_ID_ATI_215GT 0x4754 |
#define | PCI_DEVICE_ID_ATI_215GTB 0x4755 |
#define | PCI_DEVICE_ID_ATI_210888GX 0x4758 |
#define | PCI_DEVICE_ID_ATI_215LG 0x4c47 |
#define | PCI_DEVICE_ID_ATI_264LT 0x4c54 |
#define | PCI_DEVICE_ID_ATI_264VT 0x5654 |
#define | PCI_VENDOR_ID_VLSI 0x1004 |
#define | PCI_DEVICE_ID_VLSI_82C592 0x0005 |
#define | PCI_DEVICE_ID_VLSI_82C593 0x0006 |
#define | PCI_DEVICE_ID_VLSI_82C594 0x0007 |
#define | PCI_DEVICE_ID_VLSI_82C597 0x0009 |
#define | PCI_DEVICE_ID_VLSI_82C541 0x000c |
#define | PCI_DEVICE_ID_VLSI_82C543 0x000d |
#define | PCI_DEVICE_ID_VLSI_82C532 0x0101 |
#define | PCI_DEVICE_ID_VLSI_82C534 0x0102 |
#define | PCI_DEVICE_ID_VLSI_82C535 0x0104 |
#define | PCI_DEVICE_ID_VLSI_82C147 0x0105 |
#define | PCI_DEVICE_ID_VLSI_VAS96011 0x0702 |
#define | PCI_VENDOR_ID_ADL 0x1005 |
#define | PCI_DEVICE_ID_ADL_2301 0x2301 |
#define | PCI_VENDOR_ID_NS 0x100b |
#define | PCI_DEVICE_ID_NS_87415 0x0002 |
#define | PCI_DEVICE_ID_NS_87410 0xd001 |
#define | PCI_VENDOR_ID_TSENG 0x100c |
#define | PCI_DEVICE_ID_TSENG_W32P_2 0x3202 |
#define | PCI_DEVICE_ID_TSENG_W32P_b 0x3205 |
#define | PCI_DEVICE_ID_TSENG_W32P_c 0x3206 |
#define | PCI_DEVICE_ID_TSENG_W32P_d 0x3207 |
#define | PCI_DEVICE_ID_TSENG_ET6000 0x3208 |
#define | PCI_VENDOR_ID_WEITEK 0x100e |
#define | PCI_DEVICE_ID_WEITEK_P9000 0x9001 |
#define | PCI_DEVICE_ID_WEITEK_P9100 0x9100 |
#define | PCI_VENDOR_ID_DEC 0x1011 |
#define | PCI_DEVICE_ID_DEC_BRD 0x0001 |
#define | PCI_DEVICE_ID_DEC_TULIP 0x0002 |
#define | PCI_DEVICE_ID_DEC_TGA 0x0004 |
#define | PCI_DEVICE_ID_DEC_TULIP_FAST 0x0009 |
#define | PCI_DEVICE_ID_DEC_TGA2 0x000D |
#define | PCI_DEVICE_ID_DEC_FDDI 0x000F |
#define | PCI_DEVICE_ID_DEC_TULIP_PLUS 0x0014 |
#define | PCI_DEVICE_ID_DEC_21142 0x0019 |
#define | PCI_DEVICE_ID_DEC_21143 0x0019 |
#define | PCI_DEVICE_ID_DEC_21052 0x0021 |
#define | PCI_DEVICE_ID_DEC_21150 0x0022 |
#define | PCI_DEVICE_ID_DEC_21152 0x0024 |
#define | PCI_VENDOR_ID_CIRRUS 0x1013 |
#define | PCI_DEVICE_ID_CIRRUS_7548 0x0038 |
#define | PCI_DEVICE_ID_CIRRUS_5430 0x00a0 |
#define | PCI_DEVICE_ID_CIRRUS_5434_4 0x00a4 |
#define | PCI_DEVICE_ID_CIRRUS_5434_8 0x00a8 |
#define | PCI_DEVICE_ID_CIRRUS_5436 0x00ac |
#define | PCI_DEVICE_ID_CIRRUS_5446 0x00b8 |
#define | PCI_DEVICE_ID_CIRRUS_5480 0x00bc |
#define | PCI_DEVICE_ID_CIRRUS_5464 0x00d4 |
#define | PCI_DEVICE_ID_CIRRUS_5465 0x00d6 |
#define | PCI_DEVICE_ID_CIRRUS_6729 0x1100 |
#define | PCI_DEVICE_ID_CIRRUS_6832 0x1110 |
#define | PCI_DEVICE_ID_CIRRUS_7542 0x1200 |
#define | PCI_DEVICE_ID_CIRRUS_7543 0x1202 |
#define | PCI_DEVICE_ID_CIRRUS_7541 0x1204 |
#define | PCI_VENDOR_ID_IBM 0x1014 |
#define | PCI_DEVICE_ID_IBM_FIRE_CORAL 0x000a |
#define | PCI_DEVICE_ID_IBM_TR 0x0018 |
#define | PCI_DEVICE_ID_IBM_82G2675 0x001d |
#define | PCI_DEVICE_ID_IBM_MCA 0x0020 |
#define | PCI_DEVICE_ID_IBM_82351 0x0022 |
#define | PCI_DEVICE_ID_IBM_SERVERAID 0x002e |
#define | PCI_DEVICE_ID_IBM_TR_WAKE 0x003e |
#define | PCI_DEVICE_ID_IBM_MPIC 0x0046 |
#define | PCI_DEVICE_ID_IBM_3780IDSP 0x007d |
#define | PCI_DEVICE_ID_IBM_MPIC_2 0xffff |
#define | PCI_VENDOR_ID_WD 0x101c |
#define | PCI_DEVICE_ID_WD_7197 0x3296 |
#define | PCI_VENDOR_ID_AMD 0x1022 |
#define | PCI_DEVICE_ID_AMD_LANCE 0x2000 |
#define | PCI_DEVICE_ID_AMD_SCSI 0x2020 |
#define | PCI_VENDOR_ID_TRIDENT 0x1023 |
#define | PCI_DEVICE_ID_TRIDENT_9397 0x9397 |
#define | PCI_DEVICE_ID_TRIDENT_9420 0x9420 |
#define | PCI_DEVICE_ID_TRIDENT_9440 0x9440 |
#define | PCI_DEVICE_ID_TRIDENT_9660 0x9660 |
#define | PCI_DEVICE_ID_TRIDENT_9750 0x9750 |
#define | PCI_VENDOR_ID_AI 0x1025 |
#define | PCI_DEVICE_ID_AI_M1435 0x1435 |
#define | PCI_VENDOR_ID_MATROX 0x102B |
#define | PCI_DEVICE_ID_MATROX_MGA_2 0x0518 |
#define | PCI_DEVICE_ID_MATROX_MIL 0x0519 |
#define | PCI_DEVICE_ID_MATROX_MYS 0x051A |
#define | PCI_DEVICE_ID_MATROX_MIL_2 0x051b |
#define | PCI_DEVICE_ID_MATROX_MIL_2_AGP 0x051f |
#define | PCI_DEVICE_ID_MATROX_MGA_IMP 0x0d10 |
#define | PCI_VENDOR_ID_CT 0x102c |
#define | PCI_DEVICE_ID_CT_65545 0x00d8 |
#define | PCI_DEVICE_ID_CT_65548 0x00dc |
#define | PCI_DEVICE_ID_CT_65550 0x00e0 |
#define | PCI_DEVICE_ID_CT_65554 0x00e4 |
#define | PCI_DEVICE_ID_CT_65555 0x00e5 |
#define | PCI_VENDOR_ID_MIRO 0x1031 |
#define | PCI_DEVICE_ID_MIRO_36050 0x5601 |
#define | PCI_VENDOR_ID_NEC 0x1033 |
#define | PCI_DEVICE_ID_NEC_PCX2 0x0046 |
#define | PCI_VENDOR_ID_FD 0x1036 |
#define | PCI_DEVICE_ID_FD_36C70 0x0000 |
#define | PCI_VENDOR_ID_SI 0x1039 |
#define | PCI_DEVICE_ID_SI_5591_AGP 0x0001 |
#define | PCI_DEVICE_ID_SI_6202 0x0002 |
#define | PCI_DEVICE_ID_SI_503 0x0008 |
#define | PCI_DEVICE_ID_SI_ACPI 0x0009 |
#define | PCI_DEVICE_ID_SI_5597_VGA 0x0200 |
#define | PCI_DEVICE_ID_SI_6205 0x0205 |
#define | PCI_DEVICE_ID_SI_501 0x0406 |
#define | PCI_DEVICE_ID_SI_496 0x0496 |
#define | PCI_DEVICE_ID_SI_601 0x0601 |
#define | PCI_DEVICE_ID_SI_5107 0x5107 |
#define | PCI_DEVICE_ID_SI_5511 0x5511 |
#define | PCI_DEVICE_ID_SI_5513 0x5513 |
#define | PCI_DEVICE_ID_SI_5571 0x5571 |
#define | PCI_DEVICE_ID_SI_5591 0x5591 |
#define | PCI_DEVICE_ID_SI_5597 0x5597 |
#define | PCI_DEVICE_ID_SI_7001 0x7001 |
#define | PCI_VENDOR_ID_HP 0x103c |
#define | PCI_DEVICE_ID_HP_J2585A 0x1030 |
#define | PCI_DEVICE_ID_HP_J2585B 0x1031 |
#define | PCI_VENDOR_ID_PCTECH 0x1042 |
#define | PCI_DEVICE_ID_PCTECH_RZ1000 0x1000 |
#define | PCI_DEVICE_ID_PCTECH_RZ1001 0x1001 |
#define | PCI_DEVICE_ID_PCTECH_SAMURAI_0 0x3000 |
#define | PCI_DEVICE_ID_PCTECH_SAMURAI_1 0x3010 |
#define | PCI_DEVICE_ID_PCTECH_SAMURAI_IDE 0x3020 |
#define | PCI_VENDOR_ID_DPT 0x1044 |
#define | PCI_DEVICE_ID_DPT 0xa400 |
#define | PCI_VENDOR_ID_OPTI 0x1045 |
#define | PCI_DEVICE_ID_OPTI_92C178 0xc178 |
#define | PCI_DEVICE_ID_OPTI_82C557 0xc557 |
#define | PCI_DEVICE_ID_OPTI_82C558 0xc558 |
#define | PCI_DEVICE_ID_OPTI_82C621 0xc621 |
#define | PCI_DEVICE_ID_OPTI_82C700 0xc700 |
#define | PCI_DEVICE_ID_OPTI_82C701 0xc701 |
#define | PCI_DEVICE_ID_OPTI_82C814 0xc814 |
#define | PCI_DEVICE_ID_OPTI_82C822 0xc822 |
#define | PCI_DEVICE_ID_OPTI_82C825 0xd568 |
#define | PCI_VENDOR_ID_SGS 0x104a |
#define | PCI_DEVICE_ID_SGS_2000 0x0008 |
#define | PCI_DEVICE_ID_SGS_1764 0x0009 |
#define | PCI_VENDOR_ID_BUSLOGIC 0x104B |
#define | PCI_DEVICE_ID_BUSLOGIC_MULTIMASTER_NC 0x0140 |
#define | PCI_DEVICE_ID_BUSLOGIC_MULTIMASTER 0x1040 |
#define | PCI_DEVICE_ID_BUSLOGIC_FLASHPOINT 0x8130 |
#define | PCI_VENDOR_ID_TI 0x104c |
#define | PCI_DEVICE_ID_TI_TVP4010 0x3d04 |
#define | PCI_DEVICE_ID_TI_TVP4020 0x3d07 |
#define | PCI_DEVICE_ID_TI_PCI1130 0xac12 |
#define | PCI_DEVICE_ID_TI_PCI1031 0xac13 |
#define | PCI_DEVICE_ID_TI_PCI1131 0xac15 |
#define | PCI_DEVICE_ID_TI_PCI1250 0xac16 |
#define | PCI_DEVICE_ID_TI_PCI1220 0xac17 |
#define | PCI_VENDOR_ID_OAK 0x104e |
#define | PCI_DEVICE_ID_OAK_OTI107 0x0107 |
#define | PCI_VENDOR_ID_WINBOND2 0x1050 |
#define | PCI_DEVICE_ID_WINBOND2_89C940 0x0940 |
#define | PCI_VENDOR_ID_MOTOROLA 0x1057 |
#define | PCI_DEVICE_ID_MOTOROLA_MPC105 0x0001 |
#define | PCI_DEVICE_ID_MOTOROLA_MPC106 0x0002 |
#define | PCI_DEVICE_ID_MOTOROLA_RAVEN 0x4801 |
#define | PCI_DEVICE_ID_MOTOROLA_HAWK 0x4803 |
#define | PCI_VENDOR_ID_PROMISE 0x105a |
#define | PCI_DEVICE_ID_PROMISE_20246 0x4d33 |
#define | PCI_DEVICE_ID_PROMISE_5300 0x5300 |
#define | PCI_VENDOR_ID_N9 0x105d |
#define | PCI_DEVICE_ID_N9_I128 0x2309 |
#define | PCI_DEVICE_ID_N9_I128_2 0x2339 |
#define | PCI_DEVICE_ID_N9_I128_T2R 0x493d |
#define | PCI_VENDOR_ID_UMC 0x1060 |
#define | PCI_DEVICE_ID_UMC_UM8673F 0x0101 |
#define | PCI_DEVICE_ID_UMC_UM8891A 0x0891 |
#define | PCI_DEVICE_ID_UMC_UM8886BF 0x673a |
#define | PCI_DEVICE_ID_UMC_UM8886A 0x886a |
#define | PCI_DEVICE_ID_UMC_UM8881F 0x8881 |
#define | PCI_DEVICE_ID_UMC_UM8886F 0x8886 |
#define | PCI_DEVICE_ID_UMC_UM9017F 0x9017 |
#define | PCI_DEVICE_ID_UMC_UM8886N 0xe886 |
#define | PCI_DEVICE_ID_UMC_UM8891N 0xe891 |
#define | PCI_VENDOR_ID_X 0x1061 |
#define | PCI_DEVICE_ID_X_AGX016 0x0001 |
#define | PCI_VENDOR_ID_PICOP 0x1066 |
#define | PCI_DEVICE_ID_PICOP_PT86C52X 0x0001 |
#define | PCI_DEVICE_ID_PICOP_PT80C524 0x8002 |
#define | PCI_VENDOR_ID_APPLE 0x106b |
#define | PCI_DEVICE_ID_APPLE_BANDIT 0x0001 |
#define | PCI_DEVICE_ID_APPLE_GC 0x0002 |
#define | PCI_DEVICE_ID_APPLE_HYDRA 0x000e |
#define | PCI_VENDOR_ID_NEXGEN 0x1074 |
#define | PCI_DEVICE_ID_NEXGEN_82C501 0x4e78 |
#define | PCI_VENDOR_ID_QLOGIC 0x1077 |
#define | PCI_DEVICE_ID_QLOGIC_ISP1020 0x1020 |
#define | PCI_DEVICE_ID_QLOGIC_ISP1022 0x1022 |
#define | PCI_VENDOR_ID_CYRIX 0x1078 |
#define | PCI_DEVICE_ID_CYRIX_5510 0x0000 |
#define | PCI_DEVICE_ID_CYRIX_PCI_MASTER 0x0001 |
#define | PCI_DEVICE_ID_CYRIX_5520 0x0002 |
#define | PCI_DEVICE_ID_CYRIX_5530_LEGACY 0x0100 |
#define | PCI_DEVICE_ID_CYRIX_5530_SMI 0x0101 |
#define | PCI_DEVICE_ID_CYRIX_5530_IDE 0x0102 |
#define | PCI_DEVICE_ID_CYRIX_5530_AUDIO 0x0103 |
#define | PCI_DEVICE_ID_CYRIX_5530_VIDEO 0x0104 |
#define | PCI_VENDOR_ID_LEADTEK 0x107d |
#define | PCI_DEVICE_ID_LEADTEK_805 0x0000 |
#define | PCI_VENDOR_ID_CONTAQ 0x1080 |
#define | PCI_DEVICE_ID_CONTAQ_82C599 0x0600 |
#define | PCI_DEVICE_ID_CONTAQ_82C693 0xc693 |
#define | PCI_VENDOR_ID_FOREX 0x1083 |
#define | PCI_VENDOR_ID_OLICOM 0x108d |
#define | PCI_DEVICE_ID_OLICOM_OC3136 0x0001 |
#define | PCI_DEVICE_ID_OLICOM_OC2315 0x0011 |
#define | PCI_DEVICE_ID_OLICOM_OC2325 0x0012 |
#define | PCI_DEVICE_ID_OLICOM_OC2183 0x0013 |
#define | PCI_DEVICE_ID_OLICOM_OC2326 0x0014 |
#define | PCI_DEVICE_ID_OLICOM_OC6151 0x0021 |
#define | PCI_VENDOR_ID_SUN 0x108e |
#define | PCI_DEVICE_ID_SUN_EBUS 0x1000 |
#define | PCI_DEVICE_ID_SUN_HAPPYMEAL 0x1001 |
#define | PCI_DEVICE_ID_SUN_SIMBA 0x5000 |
#define | PCI_DEVICE_ID_SUN_PBM 0x8000 |
#define | PCI_DEVICE_ID_SUN_SABRE 0xa000 |
#define | PCI_VENDOR_ID_CMD 0x1095 |
#define | PCI_DEVICE_ID_CMD_640 0x0640 |
#define | PCI_DEVICE_ID_CMD_643 0x0643 |
#define | PCI_DEVICE_ID_CMD_646 0x0646 |
#define | PCI_DEVICE_ID_CMD_647 0x0647 |
#define | PCI_DEVICE_ID_CMD_670 0x0670 |
#define | PCI_VENDOR_ID_VISION 0x1098 |
#define | PCI_DEVICE_ID_VISION_QD8500 0x0001 |
#define | PCI_DEVICE_ID_VISION_QD8580 0x0002 |
#define | PCI_VENDOR_ID_BROOKTREE 0x109e |
#define | PCI_DEVICE_ID_BROOKTREE_848 0x0350 |
#define | PCI_DEVICE_ID_BROOKTREE_849A 0x0351 |
#define | PCI_DEVICE_ID_BROOKTREE_8474 0x8474 |
#define | PCI_VENDOR_ID_SIERRA 0x10a8 |
#define | PCI_DEVICE_ID_SIERRA_STB 0x0000 |
#define | PCI_VENDOR_ID_ACC 0x10aa |
#define | PCI_DEVICE_ID_ACC_2056 0x0000 |
#define | PCI_VENDOR_ID_WINBOND 0x10ad |
#define | PCI_DEVICE_ID_WINBOND_83769 0x0001 |
#define | PCI_DEVICE_ID_WINBOND_82C105 0x0105 |
#define | PCI_DEVICE_ID_WINBOND_83C553 0x0565 |
#define | PCI_VENDOR_ID_DATABOOK 0x10b3 |
#define | PCI_DEVICE_ID_DATABOOK_87144 0xb106 |
#define | PCI_VENDOR_ID_PLX 0x10b5 |
#define | PCI_DEVICE_ID_PLX_9050 0x9050 |
#define | PCI_DEVICE_ID_PLX_9060 0x9060 |
#define | PCI_DEVICE_ID_PLX_9060ES 0x906E |
#define | PCI_DEVICE_ID_PLX_9060SD 0x906D |
#define | PCI_DEVICE_ID_PLX_9080 0x9080 |
#define | PCI_VENDOR_ID_PLX2 0x3388 |
#define | PCI_DEVICE_ID_PLX2_PCI6154_HB2 0x0026 |
#define | PCI_VENDOR_ID_MADGE 0x10b6 |
#define | PCI_DEVICE_ID_MADGE_MK2 0x0002 |
#define | PCI_DEVICE_ID_MADGE_C155S 0x1001 |
#define | PCI_VENDOR_ID_3COM 0x10b7 |
#define | PCI_DEVICE_ID_3COM_3C339 0x3390 |
#define | PCI_DEVICE_ID_3COM_3C590 0x5900 |
#define | PCI_DEVICE_ID_3COM_3C595TX 0x5950 |
#define | PCI_DEVICE_ID_3COM_3C595T4 0x5951 |
#define | PCI_DEVICE_ID_3COM_3C595MII 0x5952 |
#define | PCI_DEVICE_ID_3COM_3C900TPO 0x9000 |
#define | PCI_DEVICE_ID_3COM_3C900COMBO 0x9001 |
#define | PCI_DEVICE_ID_3COM_3C905TX 0x9050 |
#define | PCI_DEVICE_ID_3COM_3C905T4 0x9051 |
#define | PCI_DEVICE_ID_3COM_3C905B_TX 0x9055 |
#define | PCI_VENDOR_ID_SMC 0x10b8 |
#define | PCI_DEVICE_ID_SMC_EPIC100 0x0005 |
#define | PCI_VENDOR_ID_AL 0x10b9 |
#define | PCI_DEVICE_ID_AL_M1445 0x1445 |
#define | PCI_DEVICE_ID_AL_M1449 0x1449 |
#define | PCI_DEVICE_ID_AL_M1451 0x1451 |
#define | PCI_DEVICE_ID_AL_M1461 0x1461 |
#define | PCI_DEVICE_ID_AL_M1489 0x1489 |
#define | PCI_DEVICE_ID_AL_M1511 0x1511 |
#define | PCI_DEVICE_ID_AL_M1513 0x1513 |
#define | PCI_DEVICE_ID_AL_M1521 0x1521 |
#define | PCI_DEVICE_ID_AL_M1523 0x1523 |
#define | PCI_DEVICE_ID_AL_M1531 0x1531 |
#define | PCI_DEVICE_ID_AL_M1533 0x1533 |
#define | PCI_DEVICE_ID_AL_M3307 0x3307 |
#define | PCI_DEVICE_ID_AL_M4803 0x5215 |
#define | PCI_DEVICE_ID_AL_M5219 0x5219 |
#define | PCI_DEVICE_ID_AL_M5229 0x5229 |
#define | PCI_DEVICE_ID_AL_M5237 0x5237 |
#define | PCI_DEVICE_ID_AL_M7101 0x7101 |
#define | PCI_VENDOR_ID_MITSUBISHI 0x10ba |
#define | PCI_VENDOR_ID_SURECOM 0x10bd |
#define | PCI_DEVICE_ID_SURECOM_NE34 0x0e34 |
#define | PCI_VENDOR_ID_NEOMAGIC 0x10c8 |
#define | PCI_DEVICE_ID_NEOMAGIC_MAGICGRAPH_NM2070 0x0001 |
#define | PCI_DEVICE_ID_NEOMAGIC_MAGICGRAPH_128V 0x0002 |
#define | PCI_DEVICE_ID_NEOMAGIC_MAGICGRAPH_128ZV 0x0003 |
#define | PCI_DEVICE_ID_NEOMAGIC_MAGICGRAPH_NM2160 0x0004 |
#define | PCI_VENDOR_ID_ASP 0x10cd |
#define | PCI_DEVICE_ID_ASP_ABP940 0x1200 |
#define | PCI_DEVICE_ID_ASP_ABP940U 0x1300 |
#define | PCI_DEVICE_ID_ASP_ABP940UW 0x2300 |
#define | PCI_VENDOR_ID_MACRONIX 0x10d9 |
#define | PCI_DEVICE_ID_MACRONIX_MX98713 0x0512 |
#define | PCI_DEVICE_ID_MACRONIX_MX987x5 0x0531 |
#define | PCI_VENDOR_ID_CERN 0x10dc |
#define | PCI_DEVICE_ID_CERN_SPSB_PMC 0x0001 |
#define | PCI_DEVICE_ID_CERN_SPSB_PCI 0x0002 |
#define | PCI_DEVICE_ID_CERN_HIPPI_DST 0x0021 |
#define | PCI_DEVICE_ID_CERN_HIPPI_SRC 0x0022 |
#define | PCI_VENDOR_ID_NVIDIA 0x10de |
#define | PCI_VENDOR_ID_IMS 0x10e0 |
#define | PCI_DEVICE_ID_IMS_8849 0x8849 |
#define | PCI_VENDOR_ID_TEKRAM2 0x10e1 |
#define | PCI_DEVICE_ID_TEKRAM2_690c 0x690c |
#define | PCI_VENDOR_ID_TUNDRA 0x10e3 |
#define | PCI_DEVICE_ID_TUNDRA_CA91C042 0x0000 |
#define | PCI_VENDOR_ID_AMCC 0x10e8 |
#define | PCI_DEVICE_ID_AMCC_MYRINET 0x8043 |
#define | PCI_DEVICE_ID_AMCC_PARASTATION 0x8062 |
#define | PCI_DEVICE_ID_AMCC_S5933 0x807d |
#define | PCI_DEVICE_ID_AMCC_S5933_HEPC3 0x809c |
#define | PCI_VENDOR_ID_INTERG 0x10ea |
#define | PCI_DEVICE_ID_INTERG_1680 0x1680 |
#define | PCI_DEVICE_ID_INTERG_1682 0x1682 |
#define | PCI_VENDOR_ID_REALTEK 0x10ec |
#define | PCI_DEVICE_ID_REALTEK_8029 0x8029 |
#define | PCI_DEVICE_ID_REALTEK_8129 0x8129 |
#define | PCI_DEVICE_ID_REALTEK_8139 0x8139 |
#define | PCI_VENDOR_ID_TRUEVISION 0x10fa |
#define | PCI_DEVICE_ID_TRUEVISION_T1000 0x000c |
#define | PCI_VENDOR_ID_INIT 0x1101 |
#define | PCI_DEVICE_ID_INIT_320P 0x9100 |
#define | PCI_DEVICE_ID_INIT_360P 0x9500 |
#define | PCI_VENDOR_ID_TTI 0x1103 |
#define | PCI_DEVICE_ID_TTI_HPT343 0x0003 |
#define | PCI_VENDOR_ID_VIA 0x1106 |
#define | PCI_DEVICE_ID_VIA_82C505 0x0505 |
#define | PCI_DEVICE_ID_VIA_82C561 0x0561 |
#define | PCI_DEVICE_ID_VIA_82C586_1 0x0571 |
#define | PCI_DEVICE_ID_VIA_82C576 0x0576 |
#define | PCI_DEVICE_ID_VIA_82C585 0x0585 |
#define | PCI_DEVICE_ID_VIA_82C586_0 0x0586 |
#define | PCI_DEVICE_ID_VIA_82C595 0x0595 |
#define | PCI_DEVICE_ID_VIA_82C597_0 0x0597 |
#define | PCI_DEVICE_ID_VIA_82C926 0x0926 |
#define | PCI_DEVICE_ID_VIA_82C416 0x1571 |
#define | PCI_DEVICE_ID_VIA_82C595_97 0x1595 |
#define | PCI_DEVICE_ID_VIA_82C586_2 0x3038 |
#define | PCI_DEVICE_ID_VIA_82C586_3 0x3040 |
#define | PCI_DEVICE_ID_VIA_86C100A 0x6100 |
#define | PCI_DEVICE_ID_VIA_82C597_1 0x8597 |
#define | PCI_VENDOR_ID_VORTEX 0x1119 |
#define | PCI_DEVICE_ID_VORTEX_GDT60x0 0x0000 |
#define | PCI_DEVICE_ID_VORTEX_GDT6000B 0x0001 |
#define | PCI_DEVICE_ID_VORTEX_GDT6x10 0x0002 |
#define | PCI_DEVICE_ID_VORTEX_GDT6x20 0x0003 |
#define | PCI_DEVICE_ID_VORTEX_GDT6530 0x0004 |
#define | PCI_DEVICE_ID_VORTEX_GDT6550 0x0005 |
#define | PCI_DEVICE_ID_VORTEX_GDT6x17 0x0006 |
#define | PCI_DEVICE_ID_VORTEX_GDT6x27 0x0007 |
#define | PCI_DEVICE_ID_VORTEX_GDT6537 0x0008 |
#define | PCI_DEVICE_ID_VORTEX_GDT6557 0x0009 |
#define | PCI_DEVICE_ID_VORTEX_GDT6x15 0x000a |
#define | PCI_DEVICE_ID_VORTEX_GDT6x25 0x000b |
#define | PCI_DEVICE_ID_VORTEX_GDT6535 0x000c |
#define | PCI_DEVICE_ID_VORTEX_GDT6555 0x000d |
#define | PCI_DEVICE_ID_VORTEX_GDT6x17RP 0x0100 |
#define | PCI_DEVICE_ID_VORTEX_GDT6x27RP 0x0101 |
#define | PCI_DEVICE_ID_VORTEX_GDT6537RP 0x0102 |
#define | PCI_DEVICE_ID_VORTEX_GDT6557RP 0x0103 |
#define | PCI_DEVICE_ID_VORTEX_GDT6x11RP 0x0104 |
#define | PCI_DEVICE_ID_VORTEX_GDT6x21RP 0x0105 |
#define | PCI_DEVICE_ID_VORTEX_GDT6x17RP1 0x0110 |
#define | PCI_DEVICE_ID_VORTEX_GDT6x27RP1 0x0111 |
#define | PCI_DEVICE_ID_VORTEX_GDT6537RP1 0x0112 |
#define | PCI_DEVICE_ID_VORTEX_GDT6557RP1 0x0113 |
#define | PCI_DEVICE_ID_VORTEX_GDT6x11RP1 0x0114 |
#define | PCI_DEVICE_ID_VORTEX_GDT6x21RP1 0x0115 |
#define | PCI_DEVICE_ID_VORTEX_GDT6x17RP2 0x0120 |
#define | PCI_DEVICE_ID_VORTEX_GDT6x27RP2 0x0121 |
#define | PCI_DEVICE_ID_VORTEX_GDT6537RP2 0x0122 |
#define | PCI_DEVICE_ID_VORTEX_GDT6557RP2 0x0123 |
#define | PCI_DEVICE_ID_VORTEX_GDT6x11RP2 0x0124 |
#define | PCI_DEVICE_ID_VORTEX_GDT6x21RP2 0x0125 |
#define | PCI_VENDOR_ID_EF 0x111a |
#define | PCI_DEVICE_ID_EF_ATM_FPGA 0x0000 |
#define | PCI_DEVICE_ID_EF_ATM_ASIC 0x0002 |
#define | PCI_VENDOR_ID_FORE 0x1127 |
#define | PCI_DEVICE_ID_FORE_PCA200PC 0x0210 |
#define | PCI_DEVICE_ID_FORE_PCA200E 0x0300 |
#define | PCI_VENDOR_ID_IMAGINGTECH 0x112f |
#define | PCI_DEVICE_ID_IMAGINGTECH_ICPCI 0x0000 |
#define | PCI_VENDOR_ID_PHILIPS 0x1131 |
#define | PCI_DEVICE_ID_PHILIPS_SAA7145 0x7145 |
#define | PCI_DEVICE_ID_PHILIPS_SAA7146 0x7146 |
#define | PCI_VENDOR_ID_CYCLONE 0x113c |
#define | PCI_DEVICE_ID_CYCLONE_SDK 0x0001 |
#define | PCI_VENDOR_ID_ALLIANCE 0x1142 |
#define | PCI_DEVICE_ID_ALLIANCE_PROMOTIO 0x3210 |
#define | PCI_DEVICE_ID_ALLIANCE_PROVIDEO 0x6422 |
#define | PCI_DEVICE_ID_ALLIANCE_AT24 0x6424 |
#define | PCI_DEVICE_ID_ALLIANCE_AT3D 0x643d |
#define | PCI_VENDOR_ID_SK 0x1148 |
#define | PCI_DEVICE_ID_SK_FP 0x4000 |
#define | PCI_DEVICE_ID_SK_TR 0x4200 |
#define | PCI_DEVICE_ID_SK_GE 0x4300 |
#define | PCI_VENDOR_ID_VMIC 0x114a |
#define | PCI_DEVICE_ID_VMIC_VME 0x7587 |
#define | PCI_VENDOR_ID_DIGI 0x114f |
#define | PCI_DEVICE_ID_DIGI_EPC 0x0002 |
#define | PCI_DEVICE_ID_DIGI_RIGHTSWITCH 0x0003 |
#define | PCI_DEVICE_ID_DIGI_XEM 0x0004 |
#define | PCI_DEVICE_ID_DIGI_XR 0x0005 |
#define | PCI_DEVICE_ID_DIGI_CX 0x0006 |
#define | PCI_DEVICE_ID_DIGI_XRJ 0x0009 |
#define | PCI_DEVICE_ID_DIGI_EPCJ 0x000a |
#define | PCI_DEVICE_ID_DIGI_XR_920 0x0027 |
#define | PCI_VENDOR_ID_MUTECH 0x1159 |
#define | PCI_DEVICE_ID_MUTECH_MV1000 0x0001 |
#define | PCI_VENDOR_ID_RENDITION 0x1163 |
#define | PCI_DEVICE_ID_RENDITION_VERITE 0x0001 |
#define | PCI_DEVICE_ID_RENDITION_VERITE2100 0x2000 |
#define | PCI_VENDOR_ID_TOSHIBA 0x1179 |
#define | PCI_DEVICE_ID_TOSHIBA_601 0x0601 |
#define | PCI_DEVICE_ID_TOSHIBA_TOPIC95 0x060a |
#define | PCI_DEVICE_ID_TOSHIBA_TOPIC97 0x060f |
#define | PCI_VENDOR_ID_RICOH 0x1180 |
#define | PCI_DEVICE_ID_RICOH_RL5C465 0x0465 |
#define | PCI_DEVICE_ID_RICOH_RL5C466 0x0466 |
#define | PCI_DEVICE_ID_RICOH_RL5C475 0x0475 |
#define | PCI_DEVICE_ID_RICOH_RL5C478 0x0478 |
#define | PCI_VENDOR_ID_ARTOP 0x1191 |
#define | PCI_DEVICE_ID_ARTOP_ATP8400 0x0004 |
#define | PCI_DEVICE_ID_ARTOP_ATP850UF 0x0005 |
#define | PCI_VENDOR_ID_ZEITNET 0x1193 |
#define | PCI_DEVICE_ID_ZEITNET_1221 0x0001 |
#define | PCI_DEVICE_ID_ZEITNET_1225 0x0002 |
#define | PCI_VENDOR_ID_OMEGA 0x119b |
#define | PCI_DEVICE_ID_OMEGA_82C092G 0x1221 |
#define | PCI_VENDOR_ID_MARVELL 0x11ab |
#define | PCI_DEVICE_ID_MARVELL_GT6426xAB 0x6430 |
#define | PCI_VENDOR_ID_LITEON 0x11ad |
#define | PCI_DEVICE_ID_LITEON_LNE100TX 0x0002 |
#define | PCI_VENDOR_ID_NP 0x11bc |
#define | PCI_DEVICE_ID_NP_PCI_FDDI 0x0001 |
#define | PCI_VENDOR_ID_ATT 0x11c1 |
#define | PCI_DEVICE_ID_ATT_L56XMF 0x0440 |
#define | PCI_VENDOR_ID_SPECIALIX 0x11cb |
#define | PCI_DEVICE_ID_SPECIALIX_IO8 0x2000 |
#define | PCI_DEVICE_ID_SPECIALIX_XIO 0x4000 |
#define | PCI_DEVICE_ID_SPECIALIX_RIO 0x8000 |
#define | PCI_VENDOR_ID_AURAVISION 0x11d1 |
#define | PCI_DEVICE_ID_AURAVISION_VXP524 0x01f7 |
#define | PCI_VENDOR_ID_IKON 0x11d5 |
#define | PCI_DEVICE_ID_IKON_10115 0x0115 |
#define | PCI_DEVICE_ID_IKON_10117 0x0117 |
#define | PCI_VENDOR_ID_ZORAN 0x11de |
#define | PCI_DEVICE_ID_ZORAN_36057 0x6057 |
#define | PCI_DEVICE_ID_ZORAN_36120 0x6120 |
#define | PCI_VENDOR_ID_KINETIC 0x11f4 |
#define | PCI_DEVICE_ID_KINETIC_2915 0x2915 |
#define | PCI_VENDOR_ID_COMPEX 0x11f6 |
#define | PCI_DEVICE_ID_COMPEX_ENET100VG4 0x0112 |
#define | PCI_DEVICE_ID_COMPEX_RL2000 0x1401 |
#define | PCI_VENDOR_ID_RP 0x11fe |
#define | PCI_DEVICE_ID_RP32INTF 0x0001 |
#define | PCI_DEVICE_ID_RP8INTF 0x0002 |
#define | PCI_DEVICE_ID_RP16INTF 0x0003 |
#define | PCI_DEVICE_ID_RP4QUAD 0x0004 |
#define | PCI_DEVICE_ID_RP8OCTA 0x0005 |
#define | PCI_DEVICE_ID_RP8J 0x0006 |
#define | PCI_DEVICE_ID_RPP4 0x000A |
#define | PCI_DEVICE_ID_RPP8 0x000B |
#define | PCI_DEVICE_ID_RP8M 0x000C |
#define | PCI_VENDOR_ID_CYCLADES 0x120e |
#define | PCI_DEVICE_ID_CYCLOM_Y_Lo 0x0100 |
#define | PCI_DEVICE_ID_CYCLOM_Y_Hi 0x0101 |
#define | PCI_DEVICE_ID_CYCLOM_Z_Lo 0x0200 |
#define | PCI_DEVICE_ID_CYCLOM_Z_Hi 0x0201 |
#define | PCI_VENDOR_ID_ESSENTIAL 0x120f |
#define | PCI_DEVICE_ID_ESSENTIAL_ROADRUNNER 0x0001 |
#define | PCI_VENDOR_ID_O2 0x1217 |
#define | PCI_DEVICE_ID_O2_6729 0x6729 |
#define | PCI_DEVICE_ID_O2_6730 0x673a |
#define | PCI_DEVICE_ID_O2_6832 0x6832 |
#define | PCI_DEVICE_ID_O2_6836 0x6836 |
#define | PCI_VENDOR_ID_3DFX 0x121a |
#define | PCI_DEVICE_ID_3DFX_VOODOO 0x0001 |
#define | PCI_DEVICE_ID_3DFX_VOODOO2 0x0002 |
#define | PCI_VENDOR_ID_SIGMADES 0x1236 |
#define | PCI_DEVICE_ID_SIGMADES_6425 0x6401 |
#define | PCI_VENDOR_ID_CCUBE 0x123f |
#define | PCI_VENDOR_ID_DIPIX 0x1246 |
#define | PCI_VENDOR_ID_STALLION 0x124d |
#define | PCI_DEVICE_ID_STALLION_ECHPCI832 0x0000 |
#define | PCI_DEVICE_ID_STALLION_ECHPCI864 0x0002 |
#define | PCI_DEVICE_ID_STALLION_EIOPCI 0x0003 |
#define | PCI_VENDOR_ID_OPTIBASE 0x1255 |
#define | PCI_DEVICE_ID_OPTIBASE_FORGE 0x1110 |
#define | PCI_DEVICE_ID_OPTIBASE_FUSION 0x1210 |
#define | PCI_DEVICE_ID_OPTIBASE_VPLEX 0x2110 |
#define | PCI_DEVICE_ID_OPTIBASE_VPLEXCC 0x2120 |
#define | PCI_DEVICE_ID_OPTIBASE_VQUEST 0x2130 |
#define | PCI_VENDOR_ID_SATSAGEM 0x1267 |
#define | PCI_DEVICE_ID_SATSAGEM_PCR2101 0x5352 |
#define | PCI_DEVICE_ID_SATSAGEM_TELSATTURBO 0x5a4b |
#define | PCI_VENDOR_ID_HUGHES 0x1273 |
#define | PCI_DEVICE_ID_HUGHES_DIRECPC 0x0002 |
#define | PCI_VENDOR_ID_ENSONIQ 0x1274 |
#define | PCI_DEVICE_ID_ENSONIQ_AUDIOPCI 0x5000 |
#define | PCI_VENDOR_ID_ALTEON 0x12ae |
#define | PCI_DEVICE_ID_ALTEON_ACENIC 0x0001 |
#define | PCI_VENDOR_ID_PICTUREL 0x12c5 |
#define | PCI_DEVICE_ID_PICTUREL_PCIVST 0x0081 |
#define | PCI_VENDOR_ID_NVIDIA_SGS 0x12d2 |
#define | PCI_DEVICE_ID_NVIDIA_SGS_RIVA128 0x0018 |
#define | PCI_VENDOR_ID_CBOARDS 0x1307 |
#define | PCI_DEVICE_ID_CBOARDS_DAS1602_16 0x0001 |
#define | PCI_VENDOR_ID_SYMPHONY 0x1c1c |
#define | PCI_DEVICE_ID_SYMPHONY_101 0x0001 |
#define | PCI_VENDOR_ID_TEKRAM 0x1de1 |
#define | PCI_DEVICE_ID_TEKRAM_DC290 0xdc29 |
#define | PCI_VENDOR_ID_3DLABS 0x3d3d |
#define | PCI_DEVICE_ID_3DLABS_300SX 0x0001 |
#define | PCI_DEVICE_ID_3DLABS_500TX 0x0002 |
#define | PCI_DEVICE_ID_3DLABS_DELTA 0x0003 |
#define | PCI_DEVICE_ID_3DLABS_PERMEDIA 0x0004 |
#define | PCI_DEVICE_ID_3DLABS_MX 0x0006 |
#define | PCI_VENDOR_ID_AVANCE 0x4005 |
#define | PCI_DEVICE_ID_AVANCE_ALG2064 0x2064 |
#define | PCI_DEVICE_ID_AVANCE_2302 0x2302 |
#define | PCI_VENDOR_ID_NETVIN 0x4a14 |
#define | PCI_DEVICE_ID_NETVIN_NV5000SC 0x5000 |
#define | PCI_VENDOR_ID_S3 0x5333 |
#define | PCI_DEVICE_ID_S3_PLATO_PXS 0x0551 |
#define | PCI_DEVICE_ID_S3_ViRGE 0x5631 |
#define | PCI_DEVICE_ID_S3_TRIO 0x8811 |
#define | PCI_DEVICE_ID_S3_AURORA64VP 0x8812 |
#define | PCI_DEVICE_ID_S3_TRIO64UVP 0x8814 |
#define | PCI_DEVICE_ID_S3_ViRGE_VX 0x883d |
#define | PCI_DEVICE_ID_S3_868 0x8880 |
#define | PCI_DEVICE_ID_S3_928 0x88b0 |
#define | PCI_DEVICE_ID_S3_864_1 0x88c0 |
#define | PCI_DEVICE_ID_S3_864_2 0x88c1 |
#define | PCI_DEVICE_ID_S3_964_1 0x88d0 |
#define | PCI_DEVICE_ID_S3_964_2 0x88d1 |
#define | PCI_DEVICE_ID_S3_968 0x88f0 |
#define | PCI_DEVICE_ID_S3_TRIO64V2 0x8901 |
#define | PCI_DEVICE_ID_S3_PLATO_PXG 0x8902 |
#define | PCI_DEVICE_ID_S3_ViRGE_DXGX 0x8a01 |
#define | PCI_DEVICE_ID_S3_ViRGE_GX2 0x8a10 |
#define | PCI_DEVICE_ID_S3_ViRGE_MX 0x8c01 |
#define | PCI_DEVICE_ID_S3_ViRGE_MXP 0x8c02 |
#define | PCI_DEVICE_ID_S3_ViRGE_MXPMV 0x8c03 |
#define | PCI_DEVICE_ID_S3_SONICVIBES 0xca00 |
#define | PCI_VENDOR_ID_INTEL 0x8086 |
#define | PCI_DEVICE_ID_INTEL_82375 0x0482 |
#define | PCI_DEVICE_ID_INTEL_82424 0x0483 |
#define | PCI_DEVICE_ID_INTEL_82378 0x0484 |
#define | PCI_DEVICE_ID_INTEL_82430 0x0486 |
#define | PCI_DEVICE_ID_INTEL_82434 0x04a3 |
#define | PCI_DEVICE_ID_INTEL_82544EI_COPPER 0x1008 |
#define | PCI_DEVICE_ID_INTEL_82092AA_0 0x1221 |
#define | PCI_DEVICE_ID_INTEL_82092AA_1 0x1222 |
#define | PCI_DEVICE_ID_INTEL_7116 0x1223 |
#define | PCI_DEVICE_ID_INTEL_82596 0x1226 |
#define | PCI_DEVICE_ID_INTEL_82865 0x1227 |
#define | PCI_DEVICE_ID_INTEL_82557 0x1229 |
#define | PCI_DEVICE_ID_INTEL_82437 0x122d |
#define | PCI_DEVICE_ID_INTEL_82371FB_0 0x122e |
#define | PCI_DEVICE_ID_INTEL_82371FB_1 0x1230 |
#define | PCI_DEVICE_ID_INTEL_82371MX 0x1234 |
#define | PCI_DEVICE_ID_INTEL_82437MX 0x1235 |
#define | PCI_DEVICE_ID_INTEL_82441 0x1237 |
#define | PCI_DEVICE_ID_INTEL_82380FB 0x124b |
#define | PCI_DEVICE_ID_INTEL_82439 0x1250 |
#define | PCI_DEVICE_ID_INTEL_82371SB_0 0x7000 |
#define | PCI_DEVICE_ID_INTEL_82371SB_1 0x7010 |
#define | PCI_DEVICE_ID_INTEL_82371SB_2 0x7020 |
#define | PCI_DEVICE_ID_INTEL_82437VX 0x7030 |
#define | PCI_DEVICE_ID_INTEL_82439TX 0x7100 |
#define | PCI_DEVICE_ID_INTEL_82371AB_0 0x7110 |
#define | PCI_DEVICE_ID_INTEL_82371AB 0x7111 |
#define | PCI_DEVICE_ID_INTEL_82371AB_2 0x7112 |
#define | PCI_DEVICE_ID_INTEL_82371AB_3 0x7113 |
#define | PCI_DEVICE_ID_INTEL_82443LX_0 0x7180 |
#define | PCI_DEVICE_ID_INTEL_82443LX_1 0x7181 |
#define | PCI_DEVICE_ID_INTEL_82443BX_0 0x7190 |
#define | PCI_DEVICE_ID_INTEL_82443BX_1 0x7191 |
#define | PCI_DEVICE_ID_INTEL_82443BX_2 0x7192 |
#define | PCI_DEVICE_ID_INTEL_P6 0x84c4 |
#define | PCI_DEVICE_ID_INTEL_82450GX 0x84c5 |
#define | PCI_VENDOR_ID_KTI 0x8e2e |
#define | PCI_DEVICE_ID_KTI_ET32P2 0x3000 |
#define | PCI_VENDOR_ID_ADAPTEC 0x9004 |
#define | PCI_DEVICE_ID_ADAPTEC_7810 0x1078 |
#define | PCI_DEVICE_ID_ADAPTEC_7850 0x5078 |
#define | PCI_DEVICE_ID_ADAPTEC_7855 0x5578 |
#define | PCI_DEVICE_ID_ADAPTEC_5800 0x5800 |
#define | PCI_DEVICE_ID_ADAPTEC_1480A 0x6075 |
#define | PCI_DEVICE_ID_ADAPTEC_7860 0x6078 |
#define | PCI_DEVICE_ID_ADAPTEC_7861 0x6178 |
#define | PCI_DEVICE_ID_ADAPTEC_7870 0x7078 |
#define | PCI_DEVICE_ID_ADAPTEC_7871 0x7178 |
#define | PCI_DEVICE_ID_ADAPTEC_7872 0x7278 |
#define | PCI_DEVICE_ID_ADAPTEC_7873 0x7378 |
#define | PCI_DEVICE_ID_ADAPTEC_7874 0x7478 |
#define | PCI_DEVICE_ID_ADAPTEC_7895 0x7895 |
#define | PCI_DEVICE_ID_ADAPTEC_7880 0x8078 |
#define | PCI_DEVICE_ID_ADAPTEC_7881 0x8178 |
#define | PCI_DEVICE_ID_ADAPTEC_7882 0x8278 |
#define | PCI_DEVICE_ID_ADAPTEC_7883 0x8378 |
#define | PCI_DEVICE_ID_ADAPTEC_7884 0x8478 |
#define | PCI_DEVICE_ID_ADAPTEC_1030 0x8b78 |
#define | PCI_VENDOR_ID_ADAPTEC2 0x9005 |
#define | PCI_DEVICE_ID_ADAPTEC2_2940U2 0x0010 |
#define | PCI_DEVICE_ID_ADAPTEC2_7890 0x001f |
#define | PCI_DEVICE_ID_ADAPTEC2_3940U2 0x0050 |
#define | PCI_DEVICE_ID_ADAPTEC2_7896 0x005f |
#define | PCI_VENDOR_ID_ATRONICS 0x907f |
#define | PCI_DEVICE_ID_ATRONICS_2015 0x2015 |
#define | PCI_VENDOR_ID_HOLTEK 0x9412 |
#define | PCI_DEVICE_ID_HOLTEK_6565 0x6565 |
#define | PCI_VENDOR_ID_TIGERJET 0xe159 |
#define | PCI_DEVICE_ID_TIGERJET_300 0x0001 |
#define | PCI_VENDOR_ID_ARK 0xedd8 |
#define | PCI_DEVICE_ID_ARK_STING 0xa091 |
#define | PCI_DEVICE_ID_ARK_STINGARK 0xa099 |
#define | PCI_DEVICE_ID_ARK_2000MT 0xa0a1 |
| #define | PCI_DEVFN(_slot, _func) |
| #define | PCI_SLOT(_devfn) |
| #define | PCI_FUNC(_devfn) |
#define | PCIBIOS_SUCCESSFUL 0x00 |
#define | PCIBIOS_FUNC_NOT_SUPPORTED 0x81 |
#define | PCIBIOS_BAD_VENDOR_ID 0x83 |
#define | PCIBIOS_DEVICE_NOT_FOUND 0x86 |
#define | PCIBIOS_BAD_REGISTER_NUMBER 0x87 |
#define | PCIBIOS_SET_FAILED 0x88 |
#define | PCIBIOS_BUFFER_TOO_SMALL 0x89 |
#define | PCI_MAX_DEVICES 32 |
#define | PCI_MAX_FUNCTIONS 8 |
#define | PCIB_ERR_SUCCESS (0) |
#define | PCIB_ERR_UNINITIALIZED (-1) |
#define | PCIB_ERR_NOTPRESENT (-2) |
#define | PCIB_ERR_NOFUNC (-3) |
#define | PCIB_ERR_BADVENDOR (-4) |
#define | PCIB_ERR_DEVNOTFOUND (-5) |
#define | PCIB_ERR_BADREG (-6) |
