RTEMS
6.3
Toggle main menu visibility
include
pci.h
1
6
7
8
* Copyright 1994, Drew Eckhardt
9
* Copyright 1997, 1998 Martin Mares <mj@atrey.karlin.mff.cuni.cz>
10
11
* For more information, please consult the following manuals (look at
12
* http://www.pcisig.com/ for how to get them):
13
14
* PCI BIOS Specification
15
* PCI Local Bus Specification
16
* PCI to PCI Bridge Specification
17
* PCI System Design Guide
18
19
20
#ifndef _RTEMS_PCI_H
21
#define _RTEMS_PCI_H
22
23
#include <stdint.h>
24
25
#ifdef __cplusplus
26
extern
"C"
27
#endif
28
29
30
* Under PCI, each device has 256 bytes of configuration address space,
31
* of which the first 64 bytes are standardized as follows:
32
33
#define PCI_VENDOR_ID 0x00
/* 16 bits */
34
#define PCI_DEVICE_ID 0x02
/* 16 bits */
35
36
#define PCI_INVALID_VENDORDEVICEID 0xffffffff
37
38
#define PCI_COMMAND 0x04
/* 16 bits */
39
#define PCI_COMMAND_IO 0x0001
/* Enable response in I/O space */
40
#define PCI_COMMAND_MEMORY 0x0002
/* Enable response in Memory space */
41
#define PCI_COMMAND_MASTER 0x0004
/* Enable bus mastering */
42
#define PCI_COMMAND_SPECIAL 0x0008
/* Enable response to special cycles */
43
#define PCI_COMMAND_INVALIDATE 0x0010
/* Use memory write and invalidate */
44
#define PCI_COMMAND_VGA_PALETTE 0x0020
/* Enable palette snooping */
45
#define PCI_COMMAND_PARITY 0x0040
/* Enable parity checking */
46
#define PCI_COMMAND_WAIT 0x0080
/* Enable address/data stepping */
47
#define PCI_COMMAND_SERR 0x0100
/* Enable SERR */
48
#define PCI_COMMAND_FAST_BACK 0x0200
/* Enable back-to-back writes */
49
#define PCI_COMMAND_INTX_DISABLE 0x0400
/* Disable INTx emulation */
50
51
#define PCI_STATUS 0x06
/* 16 bits */
52
#define PCI_STATUS_66MHZ 0x0020
/* Support 66 Mhz PCI 2.1 bus */
53
#define PCI_STATUS_UDF 0x0040
/* Support User Definable Features */
54
#define PCI_STATUS_FAST_BACK 0x0080
/* Accept fast-back to back */
55
#define PCI_STATUS_PARITY 0x0100
/* Detected parity error */
56
#define PCI_STATUS_DEVSEL_MASK 0x0600
/* DEVSEL timing */
57
#define PCI_STATUS_DEVSEL_FAST 0x0000
58
#define PCI_STATUS_DEVSEL_MEDIUM 0x0200
59
#define PCI_STATUS_DEVSEL_SLOW 0x0400
60
#define PCI_STATUS_SIG_TARGET_ABORT 0x0800
/* Set on target abort */
61
#define PCI_STATUS_REC_TARGET_ABORT 0x1000
/* Master ack of " */
62
#define PCI_STATUS_REC_MASTER_ABORT 0x2000
/* Set on master abort */
63
#define PCI_STATUS_SIG_SYSTEM_ERROR 0x4000
/* Set when we drive SERR */
64
#define PCI_STATUS_DETECTED_PARITY 0x8000
/* Set on parity error */
65
66
#define PCI_CLASS_REVISION 0x08
/* High 24 bits are class, low 8 revision */
67
#define PCI_REVISION_ID 0x08
/* Revision ID */
68
#define PCI_CLASS_PROG 0x09
/* Reg. Level Programming Interface */
69
#define PCI_CLASS_DEVICE 0x0a
/* Device class */
70
#define PCI_CACHE_LINE_SIZE 0x0c
/* 8 bits */
71
#define PCI_LATENCY_TIMER 0x0d
/* 8 bits */
72
73
#define PCI_HEADER_TYPE 0x0e
/* 8 bits */
74
#define PCI_HEADER_TYPE_NORMAL 0x00
75
#define PCI_HEADER_TYPE_BRIDGE 0x01
76
#define PCI_HEADER_TYPE_CARDBUS 0x02
77
#define PCI_HEADER_TYPE_MULTI_FUNCTION 0x80
78
79
#define PCI_BIST 0x0f
/* 8 bits */
80
#define PCI_BIST_CODE_MASK 0x0f
/* Return result */
81
#define PCI_BIST_START 0x40
/* 1 to start BIST, 2 secs or less */
82
#define PCI_BIST_CAPABLE 0x80
/* 1 if BIST capable */
83
84
85
* Base addresses specify locations in memory or I/O space.
86
* Decoded size can be determined by writing a value of
87
* 0xffffffff to the register, and reading it back. Only
88
* 1 bits are decoded.
89
90
#define PCI_BASE_ADDRESS_0 0x10
/* 32 bits */
91
#define PCI_BASE_ADDRESS_1 0x14
/* 32 bits [htype 0,1 only] */
92
#define PCI_BASE_ADDRESS_2 0x18
/* 32 bits [htype 0 only] */
93
#define PCI_BASE_ADDRESS_3 0x1c
/* 32 bits */
94
#define PCI_BASE_ADDRESS_4 0x20
/* 32 bits */
95
#define PCI_BASE_ADDRESS_5 0x24
/* 32 bits */
96
#define PCI_BASE_ADDRESS_SPACE 0x01
/* 0 = memory, 1 = I/O */
97
#define PCI_BASE_ADDRESS_SPACE_IO 0x01
98
#define PCI_BASE_ADDRESS_SPACE_MEMORY 0x00
99
#define PCI_BASE_ADDRESS_MEM_TYPE_MASK 0x06
100
#define PCI_BASE_ADDRESS_MEM_TYPE_32 0x00
/* 32 bit address */
101
#define PCI_BASE_ADDRESS_MEM_TYPE_1M 0x02
/* Below 1M */
102
#define PCI_BASE_ADDRESS_MEM_TYPE_64 0x04
/* 64 bit address */
103
#define PCI_BASE_ADDRESS_MEM_PREFETCH 0x08
/* prefetchable? */
104
#define PCI_BASE_ADDRESS_MEM_MASK (~0x0fUL)
105
#define PCI_BASE_ADDRESS_IO_MASK (~0x03UL)
106
/* bit 1 is reserved if address_space = 1 */
107
108
/* Header type 0 (normal devices) */
109
#define PCI_CARDBUS_CIS 0x28
110
#define PCI_SUBSYSTEM_VENDOR_ID 0x2c
111
#define PCI_SUBSYSTEM_ID 0x2e
112
#define PCI_ROM_ADDRESS 0x30
/* Bits 31..11 address, 10..1 reserved */
113
#define PCI_ROM_ADDRESS_ENABLE 0x01
114
#define PCI_ROM_ADDRESS_MASK (~0x7ffUL)
115
116
/* upper 24 bits are reserved */
117
#define PCI_CAPABILITY_LIST_POINTER 0x34
118
119
/* 0x38-0x3b are reserved */
120
#define PCI_INTERRUPT_LINE 0x3c
/* 8 bits */
121
#define PCI_INTERRUPT_PIN 0x3d
/* 8 bits */
122
#define PCI_MIN_GNT 0x3e
/* 8 bits */
123
#define PCI_MAX_LAT 0x3f
/* 8 bits */
124
125
/* Header type 1 (PCI-to-PCI bridges) */
126
#define PCI_PRIMARY_BUS 0x18
/* Primary bus number */
127
#define PCI_SECONDARY_BUS 0x19
/* Secondary bus number */
128
#define PCI_SUBORDINATE_BUS 0x1a
/* Highest bus number behind the bridge */
129
#define PCI_SEC_LATENCY_TIMER 0x1b
/* Latency timer for secondary interface */
130
#define PCI_IO_BASE 0x1c
/* I/O range behind the bridge */
131
#define PCI_IO_LIMIT 0x1d
132
#define PCI_IO_RANGE_TYPE_MASK 0x0f
/* I/O bridging type */
133
#define PCI_IO_RANGE_TYPE_16 0x00
134
#define PCI_IO_RANGE_TYPE_32 0x01
135
#define PCI_IO_RANGE_MASK ~0x0f
136
137
#define PCI_SEC_STATUS 0x1e
/* Secondary status register, only bit 14 used */
138
139
#define PCI_MEMORY_BASE 0x20
/* Memory range behind */
140
#define PCI_MEMORY_LIMIT 0x22
141
#define PCI_MEMORY_RANGE_TYPE_MASK 0x0f
142
#define PCI_MEMORY_RANGE_MASK ~0x0f
143
#define PCI_PREF_MEMORY_BASE 0x24
/* Prefetchable memory range behind */
144
#define PCI_PREF_MEMORY_LIMIT 0x26
145
#define PCI_PREF_RANGE_TYPE_MASK 0x0f
146
#define PCI_PREF_RANGE_TYPE_32 0x00
147
#define PCI_PREF_RANGE_TYPE_64 0x01
148
#define PCI_PREF_RANGE_MASK ~0x0f
149
#define PCI_PREF_BASE_UPPER32 0x28
/* Upper half of prefetchable memory */
150
#define PCI_PREF_LIMIT_UPPER32 0x2c
151
#define PCI_IO_BASE_UPPER16 0x30
/* Upper half of I/O addresses */
152
#define PCI_IO_LIMIT_UPPER16 0x32
153
/* 0x34-0x3b is reserved */
154
#define PCI_ROM_ADDRESS1 0x38
/* Same as PCI_ROM_ADDRESS, but for htype 1 */
155
/* 0x3c-0x3d are same as for htype 0 */
156
#define PCI_BRIDGE_CONTROL 0x3e
157
#define PCI_BRIDGE_CTL_PARITY 0x01
/* Enable parity detection on secondary interface */
158
#define PCI_BRIDGE_CTL_SERR 0x02
/* The same for SERR forwarding */
159
#define PCI_BRIDGE_CTL_NO_ISA 0x04
/* Disable bridging of ISA ports */
160
#define PCI_BRIDGE_CTL_VGA 0x08
/* Forward VGA addresses */
161
#define PCI_BRIDGE_CTL_MASTER_ABORT 0x20
/* Report master aborts */
162
#define PCI_BRIDGE_CTL_BUS_RESET 0x40
/* Secondary bus reset */
163
#define PCI_BRIDGE_CTL_FAST_BACK 0x80
/* Fast Back2Back enabled */
164
/* on secondary interface */
165
166
/* Header type 2 (CardBus bridges) */
167
/* 0x14-0x15 reserved */
168
#define PCI_CB_SEC_STATUS 0x16
/* Secondary status */
169
#define PCI_CB_PRIMARY_BUS 0x18
/* PCI bus number */
170
#define PCI_CB_CARD_BUS 0x19
/* CardBus bus number */
171
#define PCI_CB_SUBORDINATE_BUS 0x1a
/* Subordinate bus number */
172
#define PCI_CB_LATENCY_TIMER 0x1b
/* CardBus latency timer */
173
#define PCI_CB_MEMORY_BASE_0 0x1c
174
#define PCI_CB_MEMORY_LIMIT_0 0x20
175
#define PCI_CB_MEMORY_BASE_1 0x24
176
#define PCI_CB_MEMORY_LIMIT_1 0x28
177
#define PCI_CB_IO_BASE_0 0x2c
178
#define PCI_CB_IO_BASE_0_HI 0x2e
179
#define PCI_CB_IO_LIMIT_0 0x30
180
#define PCI_CB_IO_LIMIT_0_HI 0x32
181
#define PCI_CB_IO_BASE_1 0x34
182
#define PCI_CB_IO_BASE_1_HI 0x36
183
#define PCI_CB_IO_LIMIT_1 0x38
184
#define PCI_CB_IO_LIMIT_1_HI 0x3a
185
#define PCI_CB_IO_RANGE_MASK ~0x03
186
187
188
#define PCI_CB_BRIDGE_CONTROL 0x3e
189
#define PCI_CB_BRIDGE_CTL_PARITY 0x01
/* Similar to standard bridge */
190
/* control register */
191
#define PCI_CB_BRIDGE_CTL_SERR 0x02
192
#define PCI_CB_BRIDGE_CTL_ISA 0x04
193
#define PCI_CB_BRIDGE_CTL_VGA 0x08
194
#define PCI_CB_BRIDGE_CTL_MASTER_ABORT 0x20
195
#define PCI_CB_BRIDGE_CTL_CB_RESET 0x40
/* CardBus reset */
196
#define PCI_CB_BRIDGE_CTL_16BIT_INT 0x80
/* Enable interrupt for */
197
/* 16-bit cards */
198
#define PCI_CB_BRIDGE_CTL_PREFETCH_MEM0 0x100
/* Prefetch enable for */
199
/* both memory regions */
200
#define PCI_CB_BRIDGE_CTL_PREFETCH_MEM1 0x200
201
#define PCI_CB_BRIDGE_CTL_POST_WRITES 0x400
202
203
#define PCI_CB_SUBSYSTEM_VENDOR_ID 0x40
204
#define PCI_CB_SUBSYSTEM_ID 0x42
205
206
/* 16-bit PC Card legacy mode base address (ExCa) */
207
#define PCI_CB_LEGACY_MODE_BASE 0x44
208
209
/* 0x48-0x7f reserved */
210
211
/* Device classes and subclasses */
212
213
#define PCI_CLASS_NOT_DEFINED 0x0000
214
#define PCI_CLASS_NOT_DEFINED_VGA 0x0001
215
216
#define PCI_BASE_CLASS_STORAGE 0x01
217
#define PCI_CLASS_STORAGE_SCSI 0x0100
218
#define PCI_CLASS_STORAGE_IDE 0x0101
219
#define PCI_CLASS_STORAGE_FLOPPY 0x0102
220
#define PCI_CLASS_STORAGE_IPI 0x0103
221
#define PCI_CLASS_STORAGE_RAID 0x0104
222
#define PCI_CLASS_STORAGE_OTHER 0x0180
223
224
#define PCI_BASE_CLASS_NETWORK 0x02
225
#define PCI_CLASS_NETWORK_ETHERNET 0x0200
226
#define PCI_CLASS_NETWORK_TOKEN_RING 0x0201
227
#define PCI_CLASS_NETWORK_FDDI 0x0202
228
#define PCI_CLASS_NETWORK_ATM 0x0203
229
#define PCI_CLASS_NETWORK_OTHER 0x0280
230
231
#define PCI_BASE_CLASS_DISPLAY 0x03
232
#define PCI_CLASS_DISPLAY_VGA 0x0300
233
#define PCI_CLASS_DISPLAY_XGA 0x0301
234
#define PCI_CLASS_DISPLAY_OTHER 0x0380
235
236
#define PCI_BASE_CLASS_MULTIMEDIA 0x04
237
#define PCI_CLASS_MULTIMEDIA_VIDEO 0x0400
238
#define PCI_CLASS_MULTIMEDIA_AUDIO 0x0401
239
#define PCI_CLASS_MULTIMEDIA_OTHER 0x0480
240
241
#define PCI_BASE_CLASS_MEMORY 0x05
242
#define PCI_CLASS_MEMORY_RAM 0x0500
243
#define PCI_CLASS_MEMORY_FLASH 0x0501
244
#define PCI_CLASS_MEMORY_OTHER 0x0580
245
246
#define PCI_BASE_CLASS_BRIDGE 0x06
247
#define PCI_CLASS_BRIDGE_HOST 0x0600
248
#define PCI_CLASS_BRIDGE_ISA 0x0601
249
#define PCI_CLASS_BRIDGE_EISA 0x0602
250
#define PCI_CLASS_BRIDGE_MC 0x0603
251
#define PCI_CLASS_BRIDGE_PCI 0x0604
252
#define PCI_CLASS_BRIDGE_PCMCIA 0x0605
253
#define PCI_CLASS_BRIDGE_NUBUS 0x0606
254
#define PCI_CLASS_BRIDGE_CARDBUS 0x0607
255
#define PCI_CLASS_BRIDGE_OTHER 0x0680
256
257
#define PCI_BASE_CLASS_COMMUNICATION 0x07
258
#define PCI_CLASS_COMMUNICATION_SERIAL 0x0700
259
#define PCI_CLASS_COMMUNICATION_PARALLEL 0x0701
260
#define PCI_CLASS_COMMUNICATION_OTHER 0x0780
261
262
#define PCI_BASE_CLASS_SYSTEM 0x08
263
#define PCI_CLASS_SYSTEM_PIC 0x0800
264
#define PCI_CLASS_SYSTEM_DMA 0x0801
265
#define PCI_CLASS_SYSTEM_TIMER 0x0802
266
#define PCI_CLASS_SYSTEM_RTC 0x0803
267
#define PCI_CLASS_SYSTEM_OTHER 0x0880
268
269
#define PCI_BASE_CLASS_INPUT 0x09
270
#define PCI_CLASS_INPUT_KEYBOARD 0x0900
271
#define PCI_CLASS_INPUT_PEN 0x0901
272
#define PCI_CLASS_INPUT_MOUSE 0x0902
273
#define PCI_CLASS_INPUT_OTHER 0x0980
274
275
#define PCI_BASE_CLASS_DOCKING 0x0a
276
#define PCI_CLASS_DOCKING_GENERIC 0x0a00
277
#define PCI_CLASS_DOCKING_OTHER 0x0a01
278
279
#define PCI_BASE_CLASS_PROCESSOR 0x0b
280
#define PCI_CLASS_PROCESSOR_386 0x0b00
281
#define PCI_CLASS_PROCESSOR_486 0x0b01
282
#define PCI_CLASS_PROCESSOR_PENTIUM 0x0b02
283
#define PCI_CLASS_PROCESSOR_ALPHA 0x0b10
284
#define PCI_CLASS_PROCESSOR_POWERPC 0x0b20
285
#define PCI_CLASS_PROCESSOR_CO 0x0b40
286
287
#define PCI_BASE_CLASS_SERIAL 0x0c
288
#define PCI_CLASS_SERIAL_FIREWIRE 0x0c00
289
#define PCI_CLASS_SERIAL_ACCESS 0x0c01
290
#define PCI_CLASS_SERIAL_SSA 0x0c02
291
#define PCI_CLASS_SERIAL_USB 0x0c03
292
#define PCI_CLASS_SERIAL_FIBER 0x0c04
293
294
#define PCI_CLASS_OTHERS 0xff
295
296
297
* Vendor and card ID's: sort these numerically according to vendor
298
* (and according to card ID within vendor). Send all updates to
299
* <linux-pcisupport@cck.uni-kl.de>.
300
301
#define PCI_VENDOR_ID_COMPAQ 0x0e11
302
#define PCI_DEVICE_ID_COMPAQ_1280 0x3033
303
#define PCI_DEVICE_ID_COMPAQ_TRIFLEX 0x4000
304
#define PCI_DEVICE_ID_COMPAQ_SMART2P 0xae10
305
#define PCI_DEVICE_ID_COMPAQ_NETEL100 0xae32
306
#define PCI_DEVICE_ID_COMPAQ_NETEL10 0xae34
307
#define PCI_DEVICE_ID_COMPAQ_NETFLEX3I 0xae35
308
#define PCI_DEVICE_ID_COMPAQ_NETEL100D 0xae40
309
#define PCI_DEVICE_ID_COMPAQ_NETEL100PI 0xae43
310
#define PCI_DEVICE_ID_COMPAQ_NETEL100I 0xb011
311
#define PCI_DEVICE_ID_COMPAQ_THUNDER 0xf130
312
#define PCI_DEVICE_ID_COMPAQ_NETFLEX3B 0xf150
313
314
#define PCI_VENDOR_ID_NCR 0x1000
315
#define PCI_DEVICE_ID_NCR_53C810 0x0001
316
#define PCI_DEVICE_ID_NCR_53C820 0x0002
317
#define PCI_DEVICE_ID_NCR_53C825 0x0003
318
#define PCI_DEVICE_ID_NCR_53C815 0x0004
319
#define PCI_DEVICE_ID_NCR_53C860 0x0006
320
#define PCI_DEVICE_ID_NCR_53C896 0x000b
321
#define PCI_DEVICE_ID_NCR_53C895 0x000c
322
#define PCI_DEVICE_ID_NCR_53C885 0x000d
323
#define PCI_DEVICE_ID_NCR_53C875 0x000f
324
#define PCI_DEVICE_ID_NCR_53C875J 0x008f
325
326
#define PCI_VENDOR_ID_ATI 0x1002
327
#define PCI_DEVICE_ID_ATI_68800 0x4158
328
#define PCI_DEVICE_ID_ATI_215CT222 0x4354
329
#define PCI_DEVICE_ID_ATI_210888CX 0x4358
330
#define PCI_DEVICE_ID_ATI_215GB 0x4742
331
#define PCI_DEVICE_ID_ATI_215GD 0x4744
332
#define PCI_DEVICE_ID_ATI_215GI 0x4749
333
#define PCI_DEVICE_ID_ATI_215GP 0x4750
334
#define PCI_DEVICE_ID_ATI_215GQ 0x4751
335
#define PCI_DEVICE_ID_ATI_215GT 0x4754
336
#define PCI_DEVICE_ID_ATI_215GTB 0x4755
337
#define PCI_DEVICE_ID_ATI_210888GX 0x4758
338
#define PCI_DEVICE_ID_ATI_215LG 0x4c47
339
#define PCI_DEVICE_ID_ATI_264LT 0x4c54
340
#define PCI_DEVICE_ID_ATI_264VT 0x5654
341
342
#define PCI_VENDOR_ID_VLSI 0x1004
343
#define PCI_DEVICE_ID_VLSI_82C592 0x0005
344
#define PCI_DEVICE_ID_VLSI_82C593 0x0006
345
#define PCI_DEVICE_ID_VLSI_82C594 0x0007
346
#define PCI_DEVICE_ID_VLSI_82C597 0x0009
347
#define PCI_DEVICE_ID_VLSI_82C541 0x000c
348
#define PCI_DEVICE_ID_VLSI_82C543 0x000d
349
#define PCI_DEVICE_ID_VLSI_82C532 0x0101
350
#define PCI_DEVICE_ID_VLSI_82C534 0x0102
351
#define PCI_DEVICE_ID_VLSI_82C535 0x0104
352
#define PCI_DEVICE_ID_VLSI_82C147 0x0105
353
#define PCI_DEVICE_ID_VLSI_VAS96011 0x0702
354
355
#define PCI_VENDOR_ID_ADL 0x1005
356
#define PCI_DEVICE_ID_ADL_2301 0x2301
357
358
#define PCI_VENDOR_ID_NS 0x100b
359
#define PCI_DEVICE_ID_NS_87415 0x0002
360
#define PCI_DEVICE_ID_NS_87410 0xd001
361
362
#define PCI_VENDOR_ID_TSENG 0x100c
363
#define PCI_DEVICE_ID_TSENG_W32P_2 0x3202
364
#define PCI_DEVICE_ID_TSENG_W32P_b 0x3205
365
#define PCI_DEVICE_ID_TSENG_W32P_c 0x3206
366
#define PCI_DEVICE_ID_TSENG_W32P_d 0x3207
367
#define PCI_DEVICE_ID_TSENG_ET6000 0x3208
368
369
#define PCI_VENDOR_ID_WEITEK 0x100e
370
#define PCI_DEVICE_ID_WEITEK_P9000 0x9001
371
#define PCI_DEVICE_ID_WEITEK_P9100 0x9100
372
373
#define PCI_VENDOR_ID_DEC 0x1011
374
#define PCI_DEVICE_ID_DEC_BRD 0x0001
375
#define PCI_DEVICE_ID_DEC_TULIP 0x0002
376
#define PCI_DEVICE_ID_DEC_TGA 0x0004
377
#define PCI_DEVICE_ID_DEC_TULIP_FAST 0x0009
378
#define PCI_DEVICE_ID_DEC_TGA2 0x000D
379
#define PCI_DEVICE_ID_DEC_FDDI 0x000F
380
#define PCI_DEVICE_ID_DEC_TULIP_PLUS 0x0014
381
#define PCI_DEVICE_ID_DEC_21142 0x0019
382
#define PCI_DEVICE_ID_DEC_21143 0x0019
383
#define PCI_DEVICE_ID_DEC_21052 0x0021
384
#define PCI_DEVICE_ID_DEC_21150 0x0022
385
#define PCI_DEVICE_ID_DEC_21152 0x0024
386
387
#define PCI_VENDOR_ID_CIRRUS 0x1013
388
#define PCI_DEVICE_ID_CIRRUS_7548 0x0038
389
#define PCI_DEVICE_ID_CIRRUS_5430 0x00a0
390
#define PCI_DEVICE_ID_CIRRUS_5434_4 0x00a4
391
#define PCI_DEVICE_ID_CIRRUS_5434_8 0x00a8
392
#define PCI_DEVICE_ID_CIRRUS_5436 0x00ac
393
#define PCI_DEVICE_ID_CIRRUS_5446 0x00b8
394
#define PCI_DEVICE_ID_CIRRUS_5480 0x00bc
395
#define PCI_DEVICE_ID_CIRRUS_5464 0x00d4
396
#define PCI_DEVICE_ID_CIRRUS_5465 0x00d6
397
#define PCI_DEVICE_ID_CIRRUS_6729 0x1100
398
#define PCI_DEVICE_ID_CIRRUS_6832 0x1110
399
#define PCI_DEVICE_ID_CIRRUS_7542 0x1200
400
#define PCI_DEVICE_ID_CIRRUS_7543 0x1202
401
#define PCI_DEVICE_ID_CIRRUS_7541 0x1204
402
403
#define PCI_VENDOR_ID_IBM 0x1014
404
#define PCI_DEVICE_ID_IBM_FIRE_CORAL 0x000a
405
#define PCI_DEVICE_ID_IBM_TR 0x0018
406
#define PCI_DEVICE_ID_IBM_82G2675 0x001d
407
#define PCI_DEVICE_ID_IBM_MCA 0x0020
408
#define PCI_DEVICE_ID_IBM_82351 0x0022
409
#define PCI_DEVICE_ID_IBM_SERVERAID 0x002e
410
#define PCI_DEVICE_ID_IBM_TR_WAKE 0x003e
411
#define PCI_DEVICE_ID_IBM_MPIC 0x0046
412
#define PCI_DEVICE_ID_IBM_3780IDSP 0x007d
413
#define PCI_DEVICE_ID_IBM_MPIC_2 0xffff
414
415
#define PCI_VENDOR_ID_WD 0x101c
416
#define PCI_DEVICE_ID_WD_7197 0x3296
417
418
#define PCI_VENDOR_ID_AMD 0x1022
419
#define PCI_DEVICE_ID_AMD_LANCE 0x2000
420
#define PCI_DEVICE_ID_AMD_SCSI 0x2020
421
422
#define PCI_VENDOR_ID_TRIDENT 0x1023
423
#define PCI_DEVICE_ID_TRIDENT_9397 0x9397
424
#define PCI_DEVICE_ID_TRIDENT_9420 0x9420
425
#define PCI_DEVICE_ID_TRIDENT_9440 0x9440
426
#define PCI_DEVICE_ID_TRIDENT_9660 0x9660
427
#define PCI_DEVICE_ID_TRIDENT_9750 0x9750
428
429
#define PCI_VENDOR_ID_AI 0x1025
430
#define PCI_DEVICE_ID_AI_M1435 0x1435
431
432
#define PCI_VENDOR_ID_MATROX 0x102B
433
#define PCI_DEVICE_ID_MATROX_MGA_2 0x0518
434
#define PCI_DEVICE_ID_MATROX_MIL 0x0519
435
#define PCI_DEVICE_ID_MATROX_MYS 0x051A
436
#define PCI_DEVICE_ID_MATROX_MIL_2 0x051b
437
#define PCI_DEVICE_ID_MATROX_MIL_2_AGP 0x051f
438
#define PCI_DEVICE_ID_MATROX_MGA_IMP 0x0d10
439
440
#define PCI_VENDOR_ID_CT 0x102c
441
#define PCI_DEVICE_ID_CT_65545 0x00d8
442
#define PCI_DEVICE_ID_CT_65548 0x00dc
443
#define PCI_DEVICE_ID_CT_65550 0x00e0
444
#define PCI_DEVICE_ID_CT_65554 0x00e4
445
#define PCI_DEVICE_ID_CT_65555 0x00e5
446
447
#define PCI_VENDOR_ID_MIRO 0x1031
448
#define PCI_DEVICE_ID_MIRO_36050 0x5601
449
450
#define PCI_VENDOR_ID_NEC 0x1033
451
#define PCI_DEVICE_ID_NEC_PCX2 0x0046
452
453
#define PCI_VENDOR_ID_FD 0x1036
454
#define PCI_DEVICE_ID_FD_36C70 0x0000
455
456
#define PCI_VENDOR_ID_SI 0x1039
457
#define PCI_DEVICE_ID_SI_5591_AGP 0x0001
458
#define PCI_DEVICE_ID_SI_6202 0x0002
459
#define PCI_DEVICE_ID_SI_503 0x0008
460
#define PCI_DEVICE_ID_SI_ACPI 0x0009
461
#define PCI_DEVICE_ID_SI_5597_VGA 0x0200
462
#define PCI_DEVICE_ID_SI_6205 0x0205
463
#define PCI_DEVICE_ID_SI_501 0x0406
464
#define PCI_DEVICE_ID_SI_496 0x0496
465
#define PCI_DEVICE_ID_SI_601 0x0601
466
#define PCI_DEVICE_ID_SI_5107 0x5107
467
#define PCI_DEVICE_ID_SI_5511 0x5511
468
#define PCI_DEVICE_ID_SI_5513 0x5513
469
#define PCI_DEVICE_ID_SI_5571 0x5571
470
#define PCI_DEVICE_ID_SI_5591 0x5591
471
#define PCI_DEVICE_ID_SI_5597 0x5597
472
#define PCI_DEVICE_ID_SI_7001 0x7001
473
474
#define PCI_VENDOR_ID_HP 0x103c
475
#define PCI_DEVICE_ID_HP_J2585A 0x1030
476
#define PCI_DEVICE_ID_HP_J2585B 0x1031
477
478
#define PCI_VENDOR_ID_PCTECH 0x1042
479
#define PCI_DEVICE_ID_PCTECH_RZ1000 0x1000
480
#define PCI_DEVICE_ID_PCTECH_RZ1001 0x1001
481
#define PCI_DEVICE_ID_PCTECH_SAMURAI_0 0x3000
482
#define PCI_DEVICE_ID_PCTECH_SAMURAI_1 0x3010
483
#define PCI_DEVICE_ID_PCTECH_SAMURAI_IDE 0x3020
484
485
#define PCI_VENDOR_ID_DPT 0x1044
486
#define PCI_DEVICE_ID_DPT 0xa400
487
488
#define PCI_VENDOR_ID_OPTI 0x1045
489
#define PCI_DEVICE_ID_OPTI_92C178 0xc178
490
#define PCI_DEVICE_ID_OPTI_82C557 0xc557
491
#define PCI_DEVICE_ID_OPTI_82C558 0xc558
492
#define PCI_DEVICE_ID_OPTI_82C621 0xc621
493
#define PCI_DEVICE_ID_OPTI_82C700 0xc700
494
#define PCI_DEVICE_ID_OPTI_82C701 0xc701
495
#define PCI_DEVICE_ID_OPTI_82C814 0xc814
496
#define PCI_DEVICE_ID_OPTI_82C822 0xc822
497
#define PCI_DEVICE_ID_OPTI_82C825 0xd568
498
499
#define PCI_VENDOR_ID_SGS 0x104a
500
#define PCI_DEVICE_ID_SGS_2000 0x0008
501
#define PCI_DEVICE_ID_SGS_1764 0x0009
502
503
#define PCI_VENDOR_ID_BUSLOGIC 0x104B
504
#define PCI_DEVICE_ID_BUSLOGIC_MULTIMASTER_NC 0x0140
505
#define PCI_DEVICE_ID_BUSLOGIC_MULTIMASTER 0x1040
506
#define PCI_DEVICE_ID_BUSLOGIC_FLASHPOINT 0x8130
507
508
#define PCI_VENDOR_ID_TI 0x104c
509
#define PCI_DEVICE_ID_TI_TVP4010 0x3d04
510
#define PCI_DEVICE_ID_TI_TVP4020 0x3d07
511
#define PCI_DEVICE_ID_TI_PCI1130 0xac12
512
#define PCI_DEVICE_ID_TI_PCI1031 0xac13
513
#define PCI_DEVICE_ID_TI_PCI1131 0xac15
514
#define PCI_DEVICE_ID_TI_PCI1250 0xac16
515
#define PCI_DEVICE_ID_TI_PCI1220 0xac17
516
517
#define PCI_VENDOR_ID_OAK 0x104e
518
#define PCI_DEVICE_ID_OAK_OTI107 0x0107
519
520
#define PCI_VENDOR_ID_WINBOND2 0x1050
521
#define PCI_DEVICE_ID_WINBOND2_89C940 0x0940
522
523
#define PCI_VENDOR_ID_MOTOROLA 0x1057
524
#define PCI_DEVICE_ID_MOTOROLA_MPC105 0x0001
525
#define PCI_DEVICE_ID_MOTOROLA_MPC106 0x0002
526
#define PCI_DEVICE_ID_MOTOROLA_RAVEN 0x4801
527
#define PCI_DEVICE_ID_MOTOROLA_HAWK 0x4803
528
529
#define PCI_VENDOR_ID_PROMISE 0x105a
530
#define PCI_DEVICE_ID_PROMISE_20246 0x4d33
531
#define PCI_DEVICE_ID_PROMISE_5300 0x5300
532
533
#define PCI_VENDOR_ID_N9 0x105d
534
#define PCI_DEVICE_ID_N9_I128 0x2309
535
#define PCI_DEVICE_ID_N9_I128_2 0x2339
536
#define PCI_DEVICE_ID_N9_I128_T2R 0x493d
537
538
#define PCI_VENDOR_ID_UMC 0x1060
539
#define PCI_DEVICE_ID_UMC_UM8673F 0x0101
540
#define PCI_DEVICE_ID_UMC_UM8891A 0x0891
541
#define PCI_DEVICE_ID_UMC_UM8886BF 0x673a
542
#define PCI_DEVICE_ID_UMC_UM8886A 0x886a
543
#define PCI_DEVICE_ID_UMC_UM8881F 0x8881
544
#define PCI_DEVICE_ID_UMC_UM8886F 0x8886
545
#define PCI_DEVICE_ID_UMC_UM9017F 0x9017
546
#define PCI_DEVICE_ID_UMC_UM8886N 0xe886
547
#define PCI_DEVICE_ID_UMC_UM8891N 0xe891
548
549
#define PCI_VENDOR_ID_X 0x1061
550
#define PCI_DEVICE_ID_X_AGX016 0x0001
551
552
#define PCI_VENDOR_ID_PICOP 0x1066
553
#define PCI_DEVICE_ID_PICOP_PT86C52X 0x0001
554
#define PCI_DEVICE_ID_PICOP_PT80C524 0x8002
555
556
#define PCI_VENDOR_ID_APPLE 0x106b
557
#define PCI_DEVICE_ID_APPLE_BANDIT 0x0001
558
#define PCI_DEVICE_ID_APPLE_GC 0x0002
559
#define PCI_DEVICE_ID_APPLE_HYDRA 0x000e
560
561
#define PCI_VENDOR_ID_NEXGEN 0x1074
562
#define PCI_DEVICE_ID_NEXGEN_82C501 0x4e78
563
564
#define PCI_VENDOR_ID_QLOGIC 0x1077
565
#define PCI_DEVICE_ID_QLOGIC_ISP1020 0x1020
566
#define PCI_DEVICE_ID_QLOGIC_ISP1022 0x1022
567
568
#define PCI_VENDOR_ID_CYRIX 0x1078
569
#define PCI_DEVICE_ID_CYRIX_5510 0x0000
570
#define PCI_DEVICE_ID_CYRIX_PCI_MASTER 0x0001
571
#define PCI_DEVICE_ID_CYRIX_5520 0x0002
572
#define PCI_DEVICE_ID_CYRIX_5530_LEGACY 0x0100
573
#define PCI_DEVICE_ID_CYRIX_5530_SMI 0x0101
574
#define PCI_DEVICE_ID_CYRIX_5530_IDE 0x0102
575
#define PCI_DEVICE_ID_CYRIX_5530_AUDIO 0x0103
576
#define PCI_DEVICE_ID_CYRIX_5530_VIDEO 0x0104
577
578
#define PCI_VENDOR_ID_LEADTEK 0x107d
579
#define PCI_DEVICE_ID_LEADTEK_805 0x0000
580
581
#define PCI_VENDOR_ID_CONTAQ 0x1080
582
#define PCI_DEVICE_ID_CONTAQ_82C599 0x0600
583
#define PCI_DEVICE_ID_CONTAQ_82C693 0xc693
584
585
#define PCI_VENDOR_ID_FOREX 0x1083
586
587
#define PCI_VENDOR_ID_OLICOM 0x108d
588
#define PCI_DEVICE_ID_OLICOM_OC3136 0x0001
589
#define PCI_DEVICE_ID_OLICOM_OC2315 0x0011
590
#define PCI_DEVICE_ID_OLICOM_OC2325 0x0012
591
#define PCI_DEVICE_ID_OLICOM_OC2183 0x0013
592
#define PCI_DEVICE_ID_OLICOM_OC2326 0x0014
593
#define PCI_DEVICE_ID_OLICOM_OC6151 0x0021
594
595
#define PCI_VENDOR_ID_SUN 0x108e
596
#define PCI_DEVICE_ID_SUN_EBUS 0x1000
597
#define PCI_DEVICE_ID_SUN_HAPPYMEAL 0x1001
598
#define PCI_DEVICE_ID_SUN_SIMBA 0x5000
599
#define PCI_DEVICE_ID_SUN_PBM 0x8000
600
#define PCI_DEVICE_ID_SUN_SABRE 0xa000
601
602
#define PCI_VENDOR_ID_CMD 0x1095
603
#define PCI_DEVICE_ID_CMD_640 0x0640
604
#define PCI_DEVICE_ID_CMD_643 0x0643
605
#define PCI_DEVICE_ID_CMD_646 0x0646
606
#define PCI_DEVICE_ID_CMD_647 0x0647
607
#define PCI_DEVICE_ID_CMD_670 0x0670
608
609
#define PCI_VENDOR_ID_VISION 0x1098
610
#define PCI_DEVICE_ID_VISION_QD8500 0x0001
611
#define PCI_DEVICE_ID_VISION_QD8580 0x0002
612
613
#define PCI_VENDOR_ID_BROOKTREE 0x109e
614
#define PCI_DEVICE_ID_BROOKTREE_848 0x0350
615
#define PCI_DEVICE_ID_BROOKTREE_849A 0x0351
616
#define PCI_DEVICE_ID_BROOKTREE_8474 0x8474
617
618
#define PCI_VENDOR_ID_SIERRA 0x10a8
619
#define PCI_DEVICE_ID_SIERRA_STB 0x0000
620
621
#define PCI_VENDOR_ID_ACC 0x10aa
622
#define PCI_DEVICE_ID_ACC_2056 0x0000
623
624
#define PCI_VENDOR_ID_WINBOND 0x10ad
625
#define PCI_DEVICE_ID_WINBOND_83769 0x0001
626
#define PCI_DEVICE_ID_WINBOND_82C105 0x0105
627
#define PCI_DEVICE_ID_WINBOND_83C553 0x0565
628
629
#define PCI_VENDOR_ID_DATABOOK 0x10b3
630
#define PCI_DEVICE_ID_DATABOOK_87144 0xb106
631
632
#define PCI_VENDOR_ID_PLX 0x10b5
633
#define PCI_DEVICE_ID_PLX_9050 0x9050
634
#define PCI_DEVICE_ID_PLX_9060 0x9060
635
#define PCI_DEVICE_ID_PLX_9060ES 0x906E
636
#define PCI_DEVICE_ID_PLX_9060SD 0x906D
637
#define PCI_DEVICE_ID_PLX_9080 0x9080
638
639
#define PCI_VENDOR_ID_PLX2 0x3388
640
#define PCI_DEVICE_ID_PLX2_PCI6154_HB2 0x0026
641
642
#define PCI_VENDOR_ID_MADGE 0x10b6
643
#define PCI_DEVICE_ID_MADGE_MK2 0x0002
644
#define PCI_DEVICE_ID_MADGE_C155S 0x1001
645
646
#define PCI_VENDOR_ID_3COM 0x10b7
647
#define PCI_DEVICE_ID_3COM_3C339 0x3390
648
#define PCI_DEVICE_ID_3COM_3C590 0x5900
649
#define PCI_DEVICE_ID_3COM_3C595TX 0x5950
650
#define PCI_DEVICE_ID_3COM_3C595T4 0x5951
651
#define PCI_DEVICE_ID_3COM_3C595MII 0x5952
652
#define PCI_DEVICE_ID_3COM_3C900TPO 0x9000
653
#define PCI_DEVICE_ID_3COM_3C900COMBO 0x9001
654
#define PCI_DEVICE_ID_3COM_3C905TX 0x9050
655
#define PCI_DEVICE_ID_3COM_3C905T4 0x9051
656
#define PCI_DEVICE_ID_3COM_3C905B_TX 0x9055
657
658
#define PCI_VENDOR_ID_SMC 0x10b8
659
#define PCI_DEVICE_ID_SMC_EPIC100 0x0005
660
661
#define PCI_VENDOR_ID_AL 0x10b9
662
#define PCI_DEVICE_ID_AL_M1445 0x1445
663
#define PCI_DEVICE_ID_AL_M1449 0x1449
664
#define PCI_DEVICE_ID_AL_M1451 0x1451
665
#define PCI_DEVICE_ID_AL_M1461 0x1461
666
#define PCI_DEVICE_ID_AL_M1489 0x1489
667
#define PCI_DEVICE_ID_AL_M1511 0x1511
668
#define PCI_DEVICE_ID_AL_M1513 0x1513
669
#define PCI_DEVICE_ID_AL_M1521 0x1521
670
#define PCI_DEVICE_ID_AL_M1523 0x1523
671
#define PCI_DEVICE_ID_AL_M1531 0x1531
672
#define PCI_DEVICE_ID_AL_M1533 0x1533
673
#define PCI_DEVICE_ID_AL_M3307 0x3307
674
#define PCI_DEVICE_ID_AL_M4803 0x5215
675
#define PCI_DEVICE_ID_AL_M5219 0x5219
676
#define PCI_DEVICE_ID_AL_M5229 0x5229
677
#define PCI_DEVICE_ID_AL_M5237 0x5237
678
#define PCI_DEVICE_ID_AL_M7101 0x7101
679
680
#define PCI_VENDOR_ID_MITSUBISHI 0x10ba
681
682
#define PCI_VENDOR_ID_SURECOM 0x10bd
683
#define PCI_DEVICE_ID_SURECOM_NE34 0x0e34
684
685
#define PCI_VENDOR_ID_NEOMAGIC 0x10c8
686
#define PCI_DEVICE_ID_NEOMAGIC_MAGICGRAPH_NM2070 0x0001
687
#define PCI_DEVICE_ID_NEOMAGIC_MAGICGRAPH_128V 0x0002
688
#define PCI_DEVICE_ID_NEOMAGIC_MAGICGRAPH_128ZV 0x0003
689
#define PCI_DEVICE_ID_NEOMAGIC_MAGICGRAPH_NM2160 0x0004
690
691
#define PCI_VENDOR_ID_ASP 0x10cd
692
#define PCI_DEVICE_ID_ASP_ABP940 0x1200
693
#define PCI_DEVICE_ID_ASP_ABP940U 0x1300
694
#define PCI_DEVICE_ID_ASP_ABP940UW 0x2300
695
696
#define PCI_VENDOR_ID_MACRONIX 0x10d9
697
#define PCI_DEVICE_ID_MACRONIX_MX98713 0x0512
698
#define PCI_DEVICE_ID_MACRONIX_MX987x5 0x0531
699
700
#define PCI_VENDOR_ID_CERN 0x10dc
701
#define PCI_DEVICE_ID_CERN_SPSB_PMC 0x0001
702
#define PCI_DEVICE_ID_CERN_SPSB_PCI 0x0002
703
#define PCI_DEVICE_ID_CERN_HIPPI_DST 0x0021
704
#define PCI_DEVICE_ID_CERN_HIPPI_SRC 0x0022
705
706
#define PCI_VENDOR_ID_NVIDIA 0x10de
707
708
#define PCI_VENDOR_ID_IMS 0x10e0
709
#define PCI_DEVICE_ID_IMS_8849 0x8849
710
711
#define PCI_VENDOR_ID_TEKRAM2 0x10e1
712
#define PCI_DEVICE_ID_TEKRAM2_690c 0x690c
713
714
#define PCI_VENDOR_ID_TUNDRA 0x10e3
715
#define PCI_DEVICE_ID_TUNDRA_CA91C042 0x0000
716
717
#define PCI_VENDOR_ID_AMCC 0x10e8
718
#define PCI_DEVICE_ID_AMCC_MYRINET 0x8043
719
#define PCI_DEVICE_ID_AMCC_PARASTATION 0x8062
720
#define PCI_DEVICE_ID_AMCC_S5933 0x807d
721
#define PCI_DEVICE_ID_AMCC_S5933_HEPC3 0x809c
722
723
#define PCI_VENDOR_ID_INTERG 0x10ea
724
#define PCI_DEVICE_ID_INTERG_1680 0x1680
725
#define PCI_DEVICE_ID_INTERG_1682 0x1682
726
727
#define PCI_VENDOR_ID_REALTEK 0x10ec
728
#define PCI_DEVICE_ID_REALTEK_8029 0x8029
729
#define PCI_DEVICE_ID_REALTEK_8129 0x8129
730
#define PCI_DEVICE_ID_REALTEK_8139 0x8139
731
732
#define PCI_VENDOR_ID_TRUEVISION 0x10fa
733
#define PCI_DEVICE_ID_TRUEVISION_T1000 0x000c
734
735
#define PCI_VENDOR_ID_INIT 0x1101
736
#define PCI_DEVICE_ID_INIT_320P 0x9100
737
#define PCI_DEVICE_ID_INIT_360P 0x9500
738
739
#define PCI_VENDOR_ID_TTI 0x1103
740
#define PCI_DEVICE_ID_TTI_HPT343 0x0003
741
742
#define PCI_VENDOR_ID_VIA 0x1106
743
#define PCI_DEVICE_ID_VIA_82C505 0x0505
744
#define PCI_DEVICE_ID_VIA_82C561 0x0561
745
#define PCI_DEVICE_ID_VIA_82C586_1 0x0571
746
#define PCI_DEVICE_ID_VIA_82C576 0x0576
747
#define PCI_DEVICE_ID_VIA_82C585 0x0585
748
#define PCI_DEVICE_ID_VIA_82C586_0 0x0586
749
#define PCI_DEVICE_ID_VIA_82C595 0x0595
750
#define PCI_DEVICE_ID_VIA_82C597_0 0x0597
751
#define PCI_DEVICE_ID_VIA_82C926 0x0926
752
#define PCI_DEVICE_ID_VIA_82C416 0x1571
753
#define PCI_DEVICE_ID_VIA_82C595_97 0x1595
754
#define PCI_DEVICE_ID_VIA_82C586_2 0x3038
755
#define PCI_DEVICE_ID_VIA_82C586_3 0x3040
756
#define PCI_DEVICE_ID_VIA_86C100A 0x6100
757
#define PCI_DEVICE_ID_VIA_82C597_1 0x8597
758
759
#define PCI_VENDOR_ID_VORTEX 0x1119
760
#define PCI_DEVICE_ID_VORTEX_GDT60x0 0x0000
761
#define PCI_DEVICE_ID_VORTEX_GDT6000B 0x0001
762
#define PCI_DEVICE_ID_VORTEX_GDT6x10 0x0002
763
#define PCI_DEVICE_ID_VORTEX_GDT6x20 0x0003
764
#define PCI_DEVICE_ID_VORTEX_GDT6530 0x0004
765
#define PCI_DEVICE_ID_VORTEX_GDT6550 0x0005
766
#define PCI_DEVICE_ID_VORTEX_GDT6x17 0x0006
767
#define PCI_DEVICE_ID_VORTEX_GDT6x27 0x0007
768
#define PCI_DEVICE_ID_VORTEX_GDT6537 0x0008
769
#define PCI_DEVICE_ID_VORTEX_GDT6557 0x0009
770
#define PCI_DEVICE_ID_VORTEX_GDT6x15 0x000a
771
#define PCI_DEVICE_ID_VORTEX_GDT6x25 0x000b
772
#define PCI_DEVICE_ID_VORTEX_GDT6535 0x000c
773
#define PCI_DEVICE_ID_VORTEX_GDT6555 0x000d
774
#define PCI_DEVICE_ID_VORTEX_GDT6x17RP 0x0100
775
#define PCI_DEVICE_ID_VORTEX_GDT6x27RP 0x0101
776
#define PCI_DEVICE_ID_VORTEX_GDT6537RP 0x0102
777
#define PCI_DEVICE_ID_VORTEX_GDT6557RP 0x0103
778
#define PCI_DEVICE_ID_VORTEX_GDT6x11RP 0x0104
779
#define PCI_DEVICE_ID_VORTEX_GDT6x21RP 0x0105
780
#define PCI_DEVICE_ID_VORTEX_GDT6x17RP1 0x0110
781
#define PCI_DEVICE_ID_VORTEX_GDT6x27RP1 0x0111
782
#define PCI_DEVICE_ID_VORTEX_GDT6537RP1 0x0112
783
#define PCI_DEVICE_ID_VORTEX_GDT6557RP1 0x0113
784
#define PCI_DEVICE_ID_VORTEX_GDT6x11RP1 0x0114
785
#define PCI_DEVICE_ID_VORTEX_GDT6x21RP1 0x0115
786
#define PCI_DEVICE_ID_VORTEX_GDT6x17RP2 0x0120
787
#define PCI_DEVICE_ID_VORTEX_GDT6x27RP2 0x0121
788
#define PCI_DEVICE_ID_VORTEX_GDT6537RP2 0x0122
789
#define PCI_DEVICE_ID_VORTEX_GDT6557RP2 0x0123
790
#define PCI_DEVICE_ID_VORTEX_GDT6x11RP2 0x0124
791
#define PCI_DEVICE_ID_VORTEX_GDT6x21RP2 0x0125
792
793
#define PCI_VENDOR_ID_EF 0x111a
794
#define PCI_DEVICE_ID_EF_ATM_FPGA 0x0000
795
#define PCI_DEVICE_ID_EF_ATM_ASIC 0x0002
796
797
#define PCI_VENDOR_ID_FORE 0x1127
798
#define PCI_DEVICE_ID_FORE_PCA200PC 0x0210
799
#define PCI_DEVICE_ID_FORE_PCA200E 0x0300
800
801
#define PCI_VENDOR_ID_IMAGINGTECH 0x112f
802
#define PCI_DEVICE_ID_IMAGINGTECH_ICPCI 0x0000
803
804
#define PCI_VENDOR_ID_PHILIPS 0x1131
805
#define PCI_DEVICE_ID_PHILIPS_SAA7145 0x7145
806
#define PCI_DEVICE_ID_PHILIPS_SAA7146 0x7146
807
808
#define PCI_VENDOR_ID_CYCLONE 0x113c
809
#define PCI_DEVICE_ID_CYCLONE_SDK 0x0001
810
811
#define PCI_VENDOR_ID_ALLIANCE 0x1142
812
#define PCI_DEVICE_ID_ALLIANCE_PROMOTIO 0x3210
813
#define PCI_DEVICE_ID_ALLIANCE_PROVIDEO 0x6422
814
#define PCI_DEVICE_ID_ALLIANCE_AT24 0x6424
815
#define PCI_DEVICE_ID_ALLIANCE_AT3D 0x643d
816
817
#define PCI_VENDOR_ID_SK 0x1148
818
#define PCI_DEVICE_ID_SK_FP 0x4000
819
#define PCI_DEVICE_ID_SK_TR 0x4200
820
#define PCI_DEVICE_ID_SK_GE 0x4300
821
822
#define PCI_VENDOR_ID_VMIC 0x114a
823
#define PCI_DEVICE_ID_VMIC_VME 0x7587
824
825
#define PCI_VENDOR_ID_DIGI 0x114f
826
#define PCI_DEVICE_ID_DIGI_EPC 0x0002
827
#define PCI_DEVICE_ID_DIGI_RIGHTSWITCH 0x0003
828
#define PCI_DEVICE_ID_DIGI_XEM 0x0004
829
#define PCI_DEVICE_ID_DIGI_XR 0x0005
830
#define PCI_DEVICE_ID_DIGI_CX 0x0006
831
#define PCI_DEVICE_ID_DIGI_XRJ 0x0009
832
#define PCI_DEVICE_ID_DIGI_EPCJ 0x000a
833
#define PCI_DEVICE_ID_DIGI_XR_920 0x0027
834
835
#define PCI_VENDOR_ID_MUTECH 0x1159
836
#define PCI_DEVICE_ID_MUTECH_MV1000 0x0001
837
838
#define PCI_VENDOR_ID_RENDITION 0x1163
839
#define PCI_DEVICE_ID_RENDITION_VERITE 0x0001
840
#define PCI_DEVICE_ID_RENDITION_VERITE2100 0x2000
841
842
#define PCI_VENDOR_ID_TOSHIBA 0x1179
843
#define PCI_DEVICE_ID_TOSHIBA_601 0x0601
844
#define PCI_DEVICE_ID_TOSHIBA_TOPIC95 0x060a
845
#define PCI_DEVICE_ID_TOSHIBA_TOPIC97 0x060f
846
847
#define PCI_VENDOR_ID_RICOH 0x1180
848
#define PCI_DEVICE_ID_RICOH_RL5C465 0x0465
849
#define PCI_DEVICE_ID_RICOH_RL5C466 0x0466
850
#define PCI_DEVICE_ID_RICOH_RL5C475 0x0475
851
#define PCI_DEVICE_ID_RICOH_RL5C478 0x0478
852
853
#define PCI_VENDOR_ID_ARTOP 0x1191
854
#define PCI_DEVICE_ID_ARTOP_ATP8400 0x0004
855
#define PCI_DEVICE_ID_ARTOP_ATP850UF 0x0005
856
857
#define PCI_VENDOR_ID_ZEITNET 0x1193
858
#define PCI_DEVICE_ID_ZEITNET_1221 0x0001
859
#define PCI_DEVICE_ID_ZEITNET_1225 0x0002
860
861
#define PCI_VENDOR_ID_OMEGA 0x119b
862
#define PCI_DEVICE_ID_OMEGA_82C092G 0x1221
863
864
#define PCI_VENDOR_ID_MARVELL 0x11ab
865
#define PCI_DEVICE_ID_MARVELL_GT6426xAB 0x6430
866
867
#define PCI_VENDOR_ID_LITEON 0x11ad
868
#define PCI_DEVICE_ID_LITEON_LNE100TX 0x0002
869
870
#define PCI_VENDOR_ID_NP 0x11bc
871
#define PCI_DEVICE_ID_NP_PCI_FDDI 0x0001
872
873
#define PCI_VENDOR_ID_ATT 0x11c1
874
#define PCI_DEVICE_ID_ATT_L56XMF 0x0440
875
876
#define PCI_VENDOR_ID_SPECIALIX 0x11cb
877
#define PCI_DEVICE_ID_SPECIALIX_IO8 0x2000
878
#define PCI_DEVICE_ID_SPECIALIX_XIO 0x4000
879
#define PCI_DEVICE_ID_SPECIALIX_RIO 0x8000
880
881
#define PCI_VENDOR_ID_AURAVISION 0x11d1
882
#define PCI_DEVICE_ID_AURAVISION_VXP524 0x01f7
883
884
#define PCI_VENDOR_ID_IKON 0x11d5
885
#define PCI_DEVICE_ID_IKON_10115 0x0115
886
#define PCI_DEVICE_ID_IKON_10117 0x0117
887
888
#define PCI_VENDOR_ID_ZORAN 0x11de
889
#define PCI_DEVICE_ID_ZORAN_36057 0x6057
890
#define PCI_DEVICE_ID_ZORAN_36120 0x6120
891
892
#define PCI_VENDOR_ID_KINETIC 0x11f4
893
#define PCI_DEVICE_ID_KINETIC_2915 0x2915
894
895
#define PCI_VENDOR_ID_COMPEX 0x11f6
896
#define PCI_DEVICE_ID_COMPEX_ENET100VG4 0x0112
897
#define PCI_DEVICE_ID_COMPEX_RL2000 0x1401
898
899
#define PCI_VENDOR_ID_RP 0x11fe
900
#define PCI_DEVICE_ID_RP32INTF 0x0001
901
#define PCI_DEVICE_ID_RP8INTF 0x0002
902
#define PCI_DEVICE_ID_RP16INTF 0x0003
903
#define PCI_DEVICE_ID_RP4QUAD 0x0004
904
#define PCI_DEVICE_ID_RP8OCTA 0x0005
905
#define PCI_DEVICE_ID_RP8J 0x0006
906
#define PCI_DEVICE_ID_RPP4 0x000A
907
#define PCI_DEVICE_ID_RPP8 0x000B
908
#define PCI_DEVICE_ID_RP8M 0x000C
909
910
#define PCI_VENDOR_ID_CYCLADES 0x120e
911
#define PCI_DEVICE_ID_CYCLOM_Y_Lo 0x0100
912
#define PCI_DEVICE_ID_CYCLOM_Y_Hi 0x0101
913
#define PCI_DEVICE_ID_CYCLOM_Z_Lo 0x0200
914
#define PCI_DEVICE_ID_CYCLOM_Z_Hi 0x0201
915
916
#define PCI_VENDOR_ID_ESSENTIAL 0x120f
917
#define PCI_DEVICE_ID_ESSENTIAL_ROADRUNNER 0x0001
918
919
#define PCI_VENDOR_ID_O2 0x1217
920
#define PCI_DEVICE_ID_O2_6729 0x6729
921
#define PCI_DEVICE_ID_O2_6730 0x673a
922
#define PCI_DEVICE_ID_O2_6832 0x6832
923
#define PCI_DEVICE_ID_O2_6836 0x6836
924
925
#define PCI_VENDOR_ID_3DFX 0x121a
926
#define PCI_DEVICE_ID_3DFX_VOODOO 0x0001
927
#define PCI_DEVICE_ID_3DFX_VOODOO2 0x0002
928
929
#define PCI_VENDOR_ID_SIGMADES 0x1236
930
#define PCI_DEVICE_ID_SIGMADES_6425 0x6401
931
932
#define PCI_VENDOR_ID_CCUBE 0x123f
933
934
#define PCI_VENDOR_ID_DIPIX 0x1246
935
936
#define PCI_VENDOR_ID_STALLION 0x124d
937
#define PCI_DEVICE_ID_STALLION_ECHPCI832 0x0000
938
#define PCI_DEVICE_ID_STALLION_ECHPCI864 0x0002
939
#define PCI_DEVICE_ID_STALLION_EIOPCI 0x0003
940
941
#define PCI_VENDOR_ID_OPTIBASE 0x1255
942
#define PCI_DEVICE_ID_OPTIBASE_FORGE 0x1110
943
#define PCI_DEVICE_ID_OPTIBASE_FUSION 0x1210
944
#define PCI_DEVICE_ID_OPTIBASE_VPLEX 0x2110
945
#define PCI_DEVICE_ID_OPTIBASE_VPLEXCC 0x2120
946
#define PCI_DEVICE_ID_OPTIBASE_VQUEST 0x2130
947
948
#define PCI_VENDOR_ID_SATSAGEM 0x1267
949
#define PCI_DEVICE_ID_SATSAGEM_PCR2101 0x5352
950
#define PCI_DEVICE_ID_SATSAGEM_TELSATTURBO 0x5a4b
951
952
#define PCI_VENDOR_ID_HUGHES 0x1273
953
#define PCI_DEVICE_ID_HUGHES_DIRECPC 0x0002
954
955
#define PCI_VENDOR_ID_ENSONIQ 0x1274
956
#define PCI_DEVICE_ID_ENSONIQ_AUDIOPCI 0x5000
957
958
#define PCI_VENDOR_ID_ALTEON 0x12ae
959
#define PCI_DEVICE_ID_ALTEON_ACENIC 0x0001
960
961
#define PCI_VENDOR_ID_PICTUREL 0x12c5
962
#define PCI_DEVICE_ID_PICTUREL_PCIVST 0x0081
963
964
#define PCI_VENDOR_ID_NVIDIA_SGS 0x12d2
965
#define PCI_DEVICE_ID_NVIDIA_SGS_RIVA128 0x0018
966
967
#define PCI_VENDOR_ID_CBOARDS 0x1307
968
#define PCI_DEVICE_ID_CBOARDS_DAS1602_16 0x0001
969
970
#define PCI_VENDOR_ID_SYMPHONY 0x1c1c
971
#define PCI_DEVICE_ID_SYMPHONY_101 0x0001
972
973
#define PCI_VENDOR_ID_TEKRAM 0x1de1
974
#define PCI_DEVICE_ID_TEKRAM_DC290 0xdc29
975
976
#define PCI_VENDOR_ID_3DLABS 0x3d3d
977
#define PCI_DEVICE_ID_3DLABS_300SX 0x0001
978
#define PCI_DEVICE_ID_3DLABS_500TX 0x0002
979
#define PCI_DEVICE_ID_3DLABS_DELTA 0x0003
980
#define PCI_DEVICE_ID_3DLABS_PERMEDIA 0x0004
981
#define PCI_DEVICE_ID_3DLABS_MX 0x0006
982
983
#define PCI_VENDOR_ID_AVANCE 0x4005
984
#define PCI_DEVICE_ID_AVANCE_ALG2064 0x2064
985
#define PCI_DEVICE_ID_AVANCE_2302 0x2302
986
987
#define PCI_VENDOR_ID_NETVIN 0x4a14
988
#define PCI_DEVICE_ID_NETVIN_NV5000SC 0x5000
989
990
#define PCI_VENDOR_ID_S3 0x5333
991
#define PCI_DEVICE_ID_S3_PLATO_PXS 0x0551
992
#define PCI_DEVICE_ID_S3_ViRGE 0x5631
993
#define PCI_DEVICE_ID_S3_TRIO 0x8811
994
#define PCI_DEVICE_ID_S3_AURORA64VP 0x8812
995
#define PCI_DEVICE_ID_S3_TRIO64UVP 0x8814
996
#define PCI_DEVICE_ID_S3_ViRGE_VX 0x883d
997
#define PCI_DEVICE_ID_S3_868 0x8880
998
#define PCI_DEVICE_ID_S3_928 0x88b0
999
#define PCI_DEVICE_ID_S3_864_1 0x88c0
1000
#define PCI_DEVICE_ID_S3_864_2 0x88c1
1001
#define PCI_DEVICE_ID_S3_964_1 0x88d0
1002
#define PCI_DEVICE_ID_S3_964_2 0x88d1
1003
#define PCI_DEVICE_ID_S3_968 0x88f0
1004
#define PCI_DEVICE_ID_S3_TRIO64V2 0x8901
1005
#define PCI_DEVICE_ID_S3_PLATO_PXG 0x8902
1006
#define PCI_DEVICE_ID_S3_ViRGE_DXGX 0x8a01
1007
#define PCI_DEVICE_ID_S3_ViRGE_GX2 0x8a10
1008
#define PCI_DEVICE_ID_S3_ViRGE_MX 0x8c01
1009
#define PCI_DEVICE_ID_S3_ViRGE_MXP 0x8c02
1010
#define PCI_DEVICE_ID_S3_ViRGE_MXPMV 0x8c03
1011
#define PCI_DEVICE_ID_S3_SONICVIBES 0xca00
1012
1013
#define PCI_VENDOR_ID_INTEL 0x8086
1014
#define PCI_DEVICE_ID_INTEL_82375 0x0482
1015
#define PCI_DEVICE_ID_INTEL_82424 0x0483
1016
#define PCI_DEVICE_ID_INTEL_82378 0x0484
1017
#define PCI_DEVICE_ID_INTEL_82430 0x0486
1018
#define PCI_DEVICE_ID_INTEL_82434 0x04a3
1019
#define PCI_DEVICE_ID_INTEL_82544EI_COPPER 0x1008
1020
#define PCI_DEVICE_ID_INTEL_82092AA_0 0x1221
1021
#define PCI_DEVICE_ID_INTEL_82092AA_1 0x1222
1022
#define PCI_DEVICE_ID_INTEL_7116 0x1223
1023
#define PCI_DEVICE_ID_INTEL_82596 0x1226
1024
#define PCI_DEVICE_ID_INTEL_82865 0x1227
1025
#define PCI_DEVICE_ID_INTEL_82557 0x1229
1026
#define PCI_DEVICE_ID_INTEL_82437 0x122d
1027
#define PCI_DEVICE_ID_INTEL_82371FB_0 0x122e
1028
#define PCI_DEVICE_ID_INTEL_82371FB_1 0x1230
1029
#define PCI_DEVICE_ID_INTEL_82371MX 0x1234
1030
#define PCI_DEVICE_ID_INTEL_82437MX 0x1235
1031
#define PCI_DEVICE_ID_INTEL_82441 0x1237
1032
#define PCI_DEVICE_ID_INTEL_82380FB 0x124b
1033
#define PCI_DEVICE_ID_INTEL_82439 0x1250
1034
#define PCI_DEVICE_ID_INTEL_82371SB_0 0x7000
1035
#define PCI_DEVICE_ID_INTEL_82371SB_1 0x7010
1036
#define PCI_DEVICE_ID_INTEL_82371SB_2 0x7020
1037
#define PCI_DEVICE_ID_INTEL_82437VX 0x7030
1038
#define PCI_DEVICE_ID_INTEL_82439TX 0x7100
1039
#define PCI_DEVICE_ID_INTEL_82371AB_0 0x7110
1040
#define PCI_DEVICE_ID_INTEL_82371AB 0x7111
1041
#define PCI_DEVICE_ID_INTEL_82371AB_2 0x7112
1042
#define PCI_DEVICE_ID_INTEL_82371AB_3 0x7113
1043
#define PCI_DEVICE_ID_INTEL_82443LX_0 0x7180
1044
#define PCI_DEVICE_ID_INTEL_82443LX_1 0x7181
1045
#define PCI_DEVICE_ID_INTEL_82443BX_0 0x7190
1046
#define PCI_DEVICE_ID_INTEL_82443BX_1 0x7191
1047
#define PCI_DEVICE_ID_INTEL_82443BX_2 0x7192
1048
#define PCI_DEVICE_ID_INTEL_P6 0x84c4
1049
#define PCI_DEVICE_ID_INTEL_82450GX 0x84c5
1050
1051
#define PCI_VENDOR_ID_KTI 0x8e2e
1052
#define PCI_DEVICE_ID_KTI_ET32P2 0x3000
1053
1054
#define PCI_VENDOR_ID_ADAPTEC 0x9004
1055
#define PCI_DEVICE_ID_ADAPTEC_7810 0x1078
1056
#define PCI_DEVICE_ID_ADAPTEC_7850 0x5078
1057
#define PCI_DEVICE_ID_ADAPTEC_7855 0x5578
1058
#define PCI_DEVICE_ID_ADAPTEC_5800 0x5800
1059
#define PCI_DEVICE_ID_ADAPTEC_1480A 0x6075
1060
#define PCI_DEVICE_ID_ADAPTEC_7860 0x6078
1061
#define PCI_DEVICE_ID_ADAPTEC_7861 0x6178
1062
#define PCI_DEVICE_ID_ADAPTEC_7870 0x7078
1063
#define PCI_DEVICE_ID_ADAPTEC_7871 0x7178
1064
#define PCI_DEVICE_ID_ADAPTEC_7872 0x7278
1065
#define PCI_DEVICE_ID_ADAPTEC_7873 0x7378
1066
#define PCI_DEVICE_ID_ADAPTEC_7874 0x7478
1067
#define PCI_DEVICE_ID_ADAPTEC_7895 0x7895
1068
#define PCI_DEVICE_ID_ADAPTEC_7880 0x8078
1069
#define PCI_DEVICE_ID_ADAPTEC_7881 0x8178
1070
#define PCI_DEVICE_ID_ADAPTEC_7882 0x8278
1071
#define PCI_DEVICE_ID_ADAPTEC_7883 0x8378
1072
#define PCI_DEVICE_ID_ADAPTEC_7884 0x8478
1073
#define PCI_DEVICE_ID_ADAPTEC_1030 0x8b78
1074
1075
#define PCI_VENDOR_ID_ADAPTEC2 0x9005
1076
#define PCI_DEVICE_ID_ADAPTEC2_2940U2 0x0010
1077
#define PCI_DEVICE_ID_ADAPTEC2_7890 0x001f
1078
#define PCI_DEVICE_ID_ADAPTEC2_3940U2 0x0050
1079
#define PCI_DEVICE_ID_ADAPTEC2_7896 0x005f
1080
1081
#define PCI_VENDOR_ID_ATRONICS 0x907f
1082
#define PCI_DEVICE_ID_ATRONICS_2015 0x2015
1083
1084
#define PCI_VENDOR_ID_HOLTEK 0x9412
1085
#define PCI_DEVICE_ID_HOLTEK_6565 0x6565
1086
1087
#define PCI_VENDOR_ID_TIGERJET 0xe159
1088
#define PCI_DEVICE_ID_TIGERJET_300 0x0001
1089
1090
#define PCI_VENDOR_ID_ARK 0xedd8
1091
#define PCI_DEVICE_ID_ARK_STING 0xa091
1092
#define PCI_DEVICE_ID_ARK_STINGARK 0xa099
1093
#define PCI_DEVICE_ID_ARK_2000MT 0xa0a1
1094
1095
* The PCI interface treats multi-function devices as independent
1096
* devices. The slot/function address of each device is encoded
1097
* in a single byte as follows:
1098
1099
* 7:3 = slot
1100
* 2:0 = function
1101
1102
#define PCI_DEVFN(_slot,_func) ((((_slot) & 0x1f) << 3) | ((_func) & 0x07))
1103
#define PCI_SLOT(_devfn) (((_devfn) >> 3) & 0x1f)
1104
#define PCI_FUNC(_devfn) ((_devfn) & 0x07)
1105
1106
1107
* Error values that may be returned by the PCI bios.
1108
1109
#define PCIBIOS_SUCCESSFUL 0x00
1110
#define PCIBIOS_FUNC_NOT_SUPPORTED 0x81
1111
#define PCIBIOS_BAD_VENDOR_ID 0x83
1112
#define PCIBIOS_DEVICE_NOT_FOUND 0x86
1113
#define PCIBIOS_BAD_REGISTER_NUMBER 0x87
1114
#define PCIBIOS_SET_FAILED 0x88
1115
#define PCIBIOS_BUFFER_TOO_SMALL 0x89
1116
1117
/* T. Straumann, 7/31/2001: increased to 32 - PMC slots are not
1118
* scanned on mvme2306 otherwise
1119
1120
#define PCI_MAX_DEVICES 32
1121
#define PCI_MAX_FUNCTIONS 8
1122
1123
typedef
struct
1124
int (*read_config_byte)(
unsigned
char,
unsigned
char,
unsigned
char,
1125
unsigned
char, uint8_t *);
1126
int (*read_config_word)(
unsigned
char,
unsigned
char,
unsigned
char,
1127
unsigned
char, uint16_t *);
1128
int (*read_config_dword)(
unsigned
char,
unsigned
char,
unsigned
char,
1129
unsigned
char, uint32_t *);
1130
int (*write_config_byte)(
unsigned
char,
unsigned
char,
unsigned
char,
1131
unsigned
char, uint8_t);
1132
int (*write_config_word)(
unsigned
char,
unsigned
char,
unsigned
char,
1133
unsigned
char, uint16_t);
1134
int (*write_config_dword)(
unsigned
char,
unsigned
char,
unsigned
char,
1135
unsigned
char, uint32_t);
1136
pci_config_access_functions
1137
1138
/* Error codes for pci_initialize */
1139
#define PCIB_ERR_SUCCESS (0)
1140
#define PCIB_ERR_UNINITIALIZED (-1)
/* PCI BIOS is not initilized */
1141
#define PCIB_ERR_NOTPRESENT (-2)
/* PCI BIOS not present */
1142
#define PCIB_ERR_NOFUNC (-3)
/* Function not supported */
1143
#define PCIB_ERR_BADVENDOR (-4)
/* Bad Vendor ID */
1144
#define PCIB_ERR_DEVNOTFOUND (-5)
/* Device not found */
1145
#define PCIB_ERR_BADREG (-6)
/* Bad register number */
1146
1147
extern
int
pci_initialize(
void
1148
1149
typedef
struct
1150
volatile
unsigned
char
* pci_config_addr;
1151
volatile
unsigned
char
* pci_config_data;
1152
const
* pci_functions;
1153
rtems_pci_config_t
1154
1155
extern
rtems_pci_config_t
BSP_pci_configuration;
1156
1157
static
inline
int
1158
pci_read_config_byte(
1159
unsigned
char
bus,
1160
unsigned
char
slot,
1161
unsigned
char
function,
1162
unsigned
char
where,
1163
uint8_t *val)
1164
1165
return
BSP_pci_configuration.pci_functions->read_config_byte(
1166
bus, slot, function, where, val);
1167
1168
1169
static
inline
int
1170
pci_read_config_word(
1171
unsigned
char
bus,
1172
unsigned
char
slot,
1173
unsigned
char
function,
1174
unsigned
char
where,
1175
uint16_t *val)
1176
1177
return
BSP_pci_configuration.pci_functions->read_config_word(
1178
1179
1180
1181
static
inline
int
1182
pci_read_config_dword(
1183
unsigned
char
bus,
1184
unsigned
char
slot,
1185
unsigned
char
function,
1186
unsigned
char
where,
1187
uint32_t *val)
1188
1189
return
BSP_pci_configuration.pci_functions->read_config_dword(bus, slot, function, where, val);
1190
1191
1192
static
inline
int
1193
pci_write_config_byte(
1194
unsigned
char
bus,
1195
unsigned
char
slot,
1196
unsigned
char
function,
1197
unsigned
char
where,
1198
uint8_t val)
1199
1200
return
BSP_pci_configuration.pci_functions->write_config_byte(
1201
1202
1203
1204
static
inline
int
1205
pci_write_config_word(
1206
unsigned
char
bus,
1207
unsigned
char
slot,
1208
unsigned
char
function,
1209
unsigned
char
where,
1210
uint16_t val)
1211
1212
return
BSP_pci_configuration.pci_functions->write_config_word(
1213
1214
1215
1216
static
inline
int
1217
pci_write_config_dword(
1218
unsigned
char
bus,
1219
unsigned
char
slot,
1220
unsigned
char
function,
1221
unsigned
char
where,
1222
uint32_t val)
1223
1224
return
BSP_pci_configuration.pci_functions->write_config_dword(
1225
1226
1227
1228
/* scan for a specific device */
1229
/* find a particular PCI device
1230
* (currently, only bus0 is scanned for device/fun0)
1231
1232
* RETURNS: zero on success, bus/dev/fun in *pbus / *pdev / *pfun
1233
1234
int
1235
pci_find_device(
1236
unsigned
short
vendorid,
1237
unsigned
short
deviceid,
1238
int
instance,
1239
int
*pbus,
1240
int
*pdev,
1241
int
*pfun
1242
1243
1244
1245
* Return the number of PCI busses in the system
1246
1247
extern
unsigned
char
pci_bus_count(
void
1248
1249
#ifdef __cplusplus
1250
1251
#endif
1252
1253
#endif
/* _RTEMS_PCI_H */
Definition
pci.h:1123
rtems_pci_config_t
Definition
pci.h:1149
