RTEMS
6.3
Toggle main menu visibility
include
sparse-disk.h
1
/* SPDX-License-Identifier: BSD-2-Clause */
2
10
11
12
* Copyright (c) 2012 embedded brains GmbH & Co. KG
13
14
15
* modification, are permitted provided that the following conditions
16
* are met:
17
* 1. Redistributions of source code must retain the above copyright
18
* notice, this list of conditions and the following disclaimer.
19
* 2. Redistributions in binary form must reproduce the above copyright
20
* notice, this list of conditions and the following disclaimer in the
21
* documentation and/or other materials provided with the distribution.
22
23
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
24
* AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
25
* IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
26
* ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
27
* LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
28
* CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
29
* SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
30
* INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
31
* CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
32
* ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
33
* POSSIBILITY OF SUCH DAMAGE.
34
35
36
#ifndef SPARSE_DISK_H
37
#define SPARSE_DISK_H
38
39
#include <stddef.h>
40
#include <stdint.h>
41
rtems.h
42
rtems/diskdevs.h
43
rtems/thread.h
44
45
#ifdef __cplusplus
46
extern
"C"
47
#endif
/* __cplusplus */
48
56
57
typedef
struct
58
rtems_blkdev_bnum
block;
59
void
*data;
60
rtems_sparse_disk_key
61
62
typedef
struct
rtems_sparse_disk
rtems_sparse_disk
63
64
typedef
void (*rtems_sparse_disk_delete_handler)(
rtems_sparse_disk
*sparse_disk);
65
66
struct
rtems_sparse_disk
67
rtems_mutex mutex;
68
rtems_blkdev_bnum
blocks_with_buffer;
69
size_t
used_count;
70
uint32_t media_block_size;
71
rtems_sparse_disk_delete_handler delete_handler;
72
uint8_t fill_pattern;
73
*key_table;
74
75
97
rtems_status_code
rtems_sparse_disk_create_and_register
98
const
char
*device_file_name,
99
uint32_t media_block_size,
100
rtems_blkdev_bnum
blocks_with_buffer,
101
rtems_blkdev_bnum
media_block_count,
102
103
104
110
void
rtems_sparse_disk_free
rtems_sparse_disk
*sparse_disk );
111
135
rtems_status_code
rtems_sparse_disk_register
136
const
char
*device_file_name,
137
rtems_sparse_disk
*sparse_disk,
138
139
rtems_blkdev_bnum
blocks_with_buffer,
140
rtems_blkdev_bnum
media_block_count,
141
uint8_t fill_pattern,
142
rtems_sparse_disk_delete_handler sparse_disk_delete
143
144
146
147
#ifdef __cplusplus
148
149
#endif
/* __cplusplus */
150
151
#endif
/* SPARSE_DISK_H */
diskdevs.h
Block Device Disk Management API.
rtems_status_code
rtems_status_code
Definition
status.h:85
rtems_blkdev_bnum
uint32_t rtems_blkdev_bnum
Block device block index type.
Definition
diskdevs.h:45
rtems_status_code rtems_sparse_disk_create_and_register(const char *device_file_name, uint32_t media_block_size, rtems_blkdev_bnum blocks_with_buffer, rtems_blkdev_bnum media_block_count, uint8_t fill_pattern)
Creates and registers a sparse disk.
Definition
sparse-disk.c:320
rtems_status_code rtems_sparse_disk_register(const char *device_file_name, rtems_sparse_disk *sparse_disk, uint32_t media_block_size, rtems_blkdev_bnum blocks_with_buffer, rtems_blkdev_bnum media_block_count, uint8_t fill_pattern, rtems_sparse_disk_delete_handler sparse_disk_delete)
Initializes and registers a sparse disk.
Definition
sparse-disk.c:350
void rtems_sparse_disk_free(rtems_sparse_disk *sparse_disk)
Frees a sparse disk.
Definition
sparse-disk.c:315
rtems.h
Definition
sparse-disk.h:57
rtems_sparse_disk
Definition
sparse-disk.h:66
thread.h
This header file provides the API of Self-Contained Objects.
