40#ifndef _RTEMS_SCORE_THREADIMPL_H
41#define _RTEMS_SCORE_THREADIMPL_H
57#include <rtems/config.h>
78 ISR_lock_Control Lock;
110#if ( CPU_HARDWARE_FP == TRUE ) || ( CPU_SOFTWARE_FP == TRUE )
114#if defined(RTEMS_SMP)
115#define THREAD_OF_SCHEDULER_HELP_NODE( node ) \
116 RTEMS_CONTAINER_OF( node, Thread_Control, Scheduler.Help_node )
119typedef bool ( *Thread_Visitor )( Thread_Control *the_thread,
void *arg );
130 Thread_Visitor visitor,
246 Thread_Control *the_thread,
262 Thread_Control *the_thread
299 Thread_Control *the_thread,
318 Thread_Control *the_thread,
400 Thread_Control *the_thread,
402 Thread_Control *executing,
434 Thread_Control *the_thread,
435 Thread_Control *executing,
458 Thread_Control *the_thread,
459 Thread_Control *executing,
471static inline bool _Thread_Is_ready(
const Thread_Control *the_thread )
488 Thread_Control *the_thread,
504 Thread_Control *the_thread,
520 Thread_Control *the_thread,
536 Thread_Control *the_thread,
549 Thread_Control *the_thread
598static inline void _Thread_State_acquire_critical(
599 Thread_Control *the_thread,
603 _Thread_queue_Do_acquire_critical( &the_thread->
Join_queue, lock_context );
612static inline void _Thread_State_acquire(
613 Thread_Control *the_thread,
618 _Thread_State_acquire_critical( the_thread, lock_context );
629static inline Thread_Control *_Thread_State_acquire_for_executing(
633 Thread_Control *executing;
636 executing = _Thread_Executing;
637 _Thread_State_acquire_critical( executing, lock_context );
648static inline void _Thread_State_release_critical(
649 Thread_Control *the_thread,
653 _Thread_queue_Do_release_critical( &the_thread->
662static inline void _Thread_State_release(
663 Thread_Control *the_thread,
667 _Thread_State_release_critical( the_thread, lock_context );
679#if defined(RTEMS_DEBUG)
680static inline bool _Thread_State_is_owner(
681 const Thread_Control *the_thread
684 return _Thread_queue_Is_lock_owner( &the_thread->
Join_queue );
701 Thread_Control *start_of_path,
721 Thread_Control *the_thread,
742 Thread_Control *the_thread,
767 Thread_Control *the_thread,
794static inline void _Thread_Priority_change(
795 Thread_Control *the_thread,
802 _Priority_Node_set_priority( priority_node, new_priority );
804#if defined(RTEMS_SCORE_THREAD_REAL_PRIORITY_MAY_BE_INACTIVE)
805 if ( !_Priority_Node_is_active( priority_node ) ) {
814 priority_group_order,
819#if defined(RTEMS_SMP)
832void _Thread_Priority_replace(
833 Thread_Control *the_thread,
852#if defined(RTEMS_SMP)
859void _Thread_Priority_update_and_make_sticky( Thread_Control *the_thread );
867void _Thread_Priority_update_and_clean_sticky( Thread_Control *the_thread );
874void _Thread_Priority_update_ignore_sticky( Thread_Control *the_thread );
887static inline bool _Thread_Priority_less_than(
909 return _Thread_Priority_less_than( left, right ) ? right : left;
930 the_api = _Objects_Get_API(
id );
932 if ( !_Objects_Is_api_valid( the_api ) ) {
953 Thread_Control *the_thread
959 the_api = (size_t) _Objects_Get_API( the_thread->
Object.
id );
960 _Assert( _Objects_Is_api_valid( the_api ) );
964 _Assert( information != NULL );
997 const Thread_Control *thread
1000#if defined(RTEMS_SMP)
1005 return _Per_CPU_Get();
1015static inline void _Thread_Set_CPU(
1016 Thread_Control *thread,
1020#if defined(RTEMS_SMP)
1039static inline bool _Thread_Is_executing (
1040 const Thread_Control *the_thread
1043 return ( the_thread == _Thread_Executing );
1046#if defined(RTEMS_SMP)
1059static inline bool _Thread_Is_executing_on_a_processor(
1060 const Thread_Control *the_thread
1063 return _CPU_Context_Get_is_executing( &the_thread->
Registers );
1078static inline bool _Thread_Is_heir (
1079 const Thread_Control *the_thread
1082 return ( the_thread == _Thread_Heir );
1094static inline void _Thread_Unblock (
1095 Thread_Control *the_thread
1116#if ( CPU_HARDWARE_FP == TRUE ) || ( CPU_SOFTWARE_FP == TRUE )
1117static inline bool _Thread_Is_allocated_fp (
1118 const Thread_Control *the_thread
1143static inline void _Thread_Save_fp( Thread_Control *executing )
1145#if ( CPU_HARDWARE_FP == TRUE ) || ( CPU_SOFTWARE_FP == TRUE )
1146#if ( CPU_USE_DEFERRED_FP_SWITCH != TRUE )
1158static inline void _Thread_Restore_fp( Thread_Control *executing )
1160#if ( CPU_HARDWARE_FP == TRUE ) || ( CPU_SOFTWARE_FP == TRUE )
1161#if ( CPU_USE_DEFERRED_FP_SWITCH == TRUE )
1163 !_Thread_Is_allocated_fp( executing ) ) {
1182#if ( CPU_HARDWARE_FP == TRUE ) || ( CPU_SOFTWARE_FP == TRUE )
1183static inline void _Thread_Deallocate_fp(
void )
1198static inline bool _Thread_Is_context_switch_necessary(
void )
1200 return ( _Thread_Dispatch_necessary );
1208static inline uint32_t _Thread_Get_maximum_internal_threads(
void)
1211 uint32_t maximum_internal_threads =
1215#if defined(RTEMS_MULTIPROCESSING)
1216 if ( _System_state_Is_multiprocessing ) {
1217 ++maximum_internal_threads;
1221 return maximum_internal_threads;
1230static inline Thread_Control *_Thread_Internal_allocate(
void )
1232 return (Thread_Control *)
1249static inline Thread_Control *_Thread_Get_heir_and_make_it_executing(
1253 Thread_Control *heir;
1255 heir = cpu_self->
heir;
1269static inline void _Thread_Update_CPU_time_used(
1270 Thread_Control *the_thread,
1290#if defined( RTEMS_SMP )
1291static inline void _Thread_Dispatch_update_heir(
1294 Thread_Control *heir
1297 _Thread_Update_CPU_time_used( cpu_for_heir->
heir, cpu_for_heir );
1299 cpu_for_heir->
heir = heir;
1301 _Thread_Dispatch_request( cpu_self, cpu_for_heir );
1327 Thread_Control *the_thread
1340 Thread_Control *the_thread
1348static inline void _Thread_Action_control_initialize(
1352 _Chain_Initialize_empty( &action_control->Chain );
1360static inline void _Thread_Action_initialize(
1364 _Chain_Set_off_chain( &action->Node );
1379static inline void _Thread_Add_post_switch_action(
1380 Thread_Control *the_thread,
1387 _Assert( _Thread_State_is_owner( the_thread ) );
1389 cpu_of_thread = _Thread_Get_CPU( the_thread );
1391 action->handler = handler;
1393 _Thread_Dispatch_request( _Per_CPU_Get(), cpu_of_thread );
1395 _Chain_Append_if_is_off_chain_unprotected(
1396 &the_thread->Post_switch_actions.Chain,
1412static inline void _Thread_Append_post_switch_action(
1413 Thread_Control *the_thread,
1417 _Assert( _Thread_State_is_owner( the_thread ) );
1418 _Assert( action->handler != NULL );
1420 _Chain_Append_unprotected(
1421 &the_thread->Post_switch_actions.Chain,
1434static inline bool _Thread_Is_life_restarting(
1449static inline bool _Thread_Is_life_terminating(
1464static inline bool _Thread_Is_life_change_allowed(
1480static inline bool _Thread_Is_life_changing(
1496static inline bool _Thread_Is_joinable(
1497 const Thread_Control *the_thread
1500 _Assert( _Thread_State_is_owner( the_thread ) );
1509static inline void _Thread_Resource_count_increment(
1510 Thread_Control *the_thread
1513#if defined(RTEMS_SCORE_THREAD_ENABLE_RESOURCE_COUNT)
1514 ++the_thread->resource_count;
1525static inline void _Thread_Resource_count_decrement(
1526 Thread_Control *the_thread
1529#if defined(RTEMS_SCORE_THREAD_ENABLE_RESOURCE_COUNT)
1530 --the_thread->resource_count;
1536#if defined(RTEMS_SCORE_THREAD_ENABLE_RESOURCE_COUNT)
1548static inline bool _Thread_Owns_resources(
1549 const Thread_Control *the_thread
1552 return the_thread->resource_count != 0;
1563static inline const Scheduler_Control *_Thread_Scheduler_get_home(
1564 const Thread_Control *the_thread
1567#if defined(RTEMS_SMP)
1568 return the_thread->
Scheduler.home_scheduler;
1583 const Thread_Control *the_thread
1586#if defined(RTEMS_SMP)
1588 return SCHEDULER_NODE_OF_THREAD_WAIT_NODE(
1589 _Chain_First( &the_thread->
Scheduler.Wait_nodes )
1604static inline Scheduler_Node *_Thread_Scheduler_get_node_by_index(
1605 const Thread_Control *the_thread,
1606 size_t scheduler_index
1610#if defined(RTEMS_SMP)
1613 + scheduler_index * _Scheduler_Node_size );
1615 (void) scheduler_index;
1620#if defined(RTEMS_SMP)
1627static inline void _Thread_Scheduler_acquire_critical(
1628 Thread_Control *the_thread,
1641static inline void _Thread_Scheduler_release_critical(
1642 Thread_Control *the_thread,
1654void _Thread_Scheduler_process_requests( Thread_Control *the_thread );
1663static inline void _Thread_Scheduler_add_request(
1664 Thread_Control *the_thread,
1666 Scheduler_Node_request request
1670 Scheduler_Node_request current_request;
1672 _Thread_Scheduler_acquire_critical( the_thread, &lock_context );
1674 current_request = scheduler_node->Thread.request;
1676 if ( current_request == SCHEDULER_NODE_REQUEST_NOT_PENDING ) {
1678 request == SCHEDULER_NODE_REQUEST_ADD
1679 || request == SCHEDULER_NODE_REQUEST_REMOVE
1681 _Assert( scheduler_node->Thread.next_request == NULL );
1682 scheduler_node->Thread.next_request = the_thread->
Scheduler.requests;
1683 the_thread->
Scheduler.requests = scheduler_node;
1684 }
else if ( current_request != SCHEDULER_NODE_REQUEST_NOTHING ) {
1686 ( current_request == SCHEDULER_NODE_REQUEST_ADD
1687 && request == SCHEDULER_NODE_REQUEST_REMOVE )
1688 || ( current_request == SCHEDULER_NODE_REQUEST_REMOVE
1689 && request == SCHEDULER_NODE_REQUEST_ADD )
1691 request = SCHEDULER_NODE_REQUEST_NOTHING;
1694 scheduler_node->Thread.request = request;
1696 _Thread_Scheduler_release_critical( the_thread, &lock_context );
1706static inline void _Thread_Scheduler_add_wait_node(
1707 Thread_Control *the_thread,
1711 _Chain_Append_unprotected(
1713 &scheduler_node->Thread.Wait_node
1715 _Thread_Scheduler_add_request(
1718 SCHEDULER_NODE_REQUEST_ADD
1729static inline void _Thread_Scheduler_remove_wait_node(
1730 Thread_Control *the_thread,
1734 _Chain_Extract_unprotected( &scheduler_node->Thread.Wait_node );
1735 _Thread_Scheduler_add_request(
1738 SCHEDULER_NODE_REQUEST_REMOVE
1755 const Thread_Control *the_thread
1760 scheduler_node = _Thread_Scheduler_get_home_node( the_thread );
1761 return _Priority_Get_priority( &scheduler_node->Wait.Priority );
1772 const Thread_Control *the_thread
1786 const Thread_Control *the_thread
1802static inline void _Thread_Wait_acquire_default_critical(
1803 Thread_Control *the_thread,
1821static inline Thread_Control *_Thread_Wait_acquire_default_for_executing(
1825 Thread_Control *executing;
1828 executing = _Thread_Executing;
1829 _Thread_Wait_acquire_default_critical( executing, lock_context );
1843static inline void _Thread_Wait_acquire_default(
1844 Thread_Control *the_thread,
1849 _Thread_Wait_acquire_default_critical( the_thread, lock_context );
1862static inline void _Thread_Wait_release_default_critical(
1863 Thread_Control *the_thread,
1878static inline void _Thread_Wait_release_default(
1879 Thread_Control *the_thread,
1883 _Thread_Wait_release_default_critical( the_thread, lock_context );
1887#if defined(RTEMS_SMP)
1888#define THREAD_QUEUE_CONTEXT_OF_REQUEST( node ) \
1889 RTEMS_CONTAINER_OF( node, Thread_queue_Context, Lock_context.Wait.Gate.Node )
1897static inline void _Thread_Wait_remove_request_locked(
1898 Thread_Control *the_thread,
1904 _Chain_Extract_unprotected( &queue_lock_context->Wait.Gate.Node );
1905 first = _Chain_First( &the_thread->
Wait.Lock.Pending_requests );
1907 if ( first != _Chain_Tail( &the_thread->
Wait.Lock.Pending_requests ) ) {
1908 _Thread_queue_Gate_open( (Thread_queue_Gate *) first );
1918static inline void _Thread_Wait_acquire_queue_critical(
1923 _Thread_queue_Queue_acquire_critical(
1925 &_Thread_Executing->Potpourri_stats,
1936static inline void _Thread_Wait_release_queue_critical(
1941 _Thread_queue_Queue_release_critical(
1956static inline void _Thread_Wait_acquire_critical(
1957 Thread_Control *the_thread,
1961#if defined(RTEMS_SMP)
1964 _Thread_Wait_acquire_default_critical(
1972 if ( queue != NULL ) {
1973 _Thread_queue_Gate_add(
1974 &the_thread->
Wait.Lock.Pending_requests,
1977 _Thread_Wait_release_default_critical(
1981 _Thread_Wait_acquire_queue_critical( queue, &queue_context->
Lock_context );
1983 if ( queue_context->
Lock_context.Wait.queue == NULL ) {
1984 _Thread_Wait_release_queue_critical(
1988 _Thread_Wait_acquire_default_critical(
1992 _Thread_Wait_remove_request_locked(
2001 (void) queue_context;
2012static inline void _Thread_Wait_acquire(
2013 Thread_Control *the_thread,
2018 _Thread_Wait_acquire_critical( the_thread, queue_context );
2031static inline void _Thread_Wait_release_critical(
2032 Thread_Control *the_thread,
2036#if defined(RTEMS_SMP)
2041 if ( queue != NULL ) {
2042 _Thread_Wait_release_queue_critical(
2045 _Thread_Wait_acquire_default_critical(
2049 _Thread_Wait_remove_request_locked(
2055 _Thread_Wait_release_default_critical(
2061 (void) queue_context;
2073static inline void _Thread_Wait_release(
2074 Thread_Control *the_thread,
2078 _Thread_Wait_release_critical( the_thread, queue_context );
2096static inline void _Thread_Wait_claim(
2097 Thread_Control *the_thread,
2103 _Thread_Wait_acquire_default_critical( the_thread, &lock_context );
2107#if defined(RTEMS_SMP)
2108 _Chain_Initialize_empty( &the_thread->
2109 _Chain_Initialize_node( &the_thread->
Wait.Lock.Tranquilizer.Node );
2110 _Thread_queue_Gate_close( &the_thread->
Wait.Lock.Tranquilizer );
2115 _Thread_Wait_release_default_critical( the_thread, &lock_context );
2125static inline void _Thread_Wait_claim_finalize(
2126 Thread_Control *the_thread,
2144static inline void _Thread_Wait_remove_request(
2145 Thread_Control *the_thread,
2149#if defined(RTEMS_SMP)
2152 _Thread_Wait_acquire_default( the_thread, &lock_context );
2153 _Thread_Wait_remove_request_locked( the_thread, queue_lock_context );
2154 _Thread_Wait_release_default( the_thread, &lock_context );
2157 (void) queue_lock_context;
2173static inline void _Thread_Wait_restore_default(
2174 Thread_Control *the_thread
2177#if defined(RTEMS_SMP)
2182 _Thread_Wait_acquire_default_critical( the_thread, &lock_context );
2184 node = _Chain_First( &the_thread->
2185 tail = _Chain_Immutable_tail( &the_thread->
2187 if ( node != tail ) {
2191 queue_context = THREAD_QUEUE_CONTEXT_OF_REQUEST( node );
2194 node = _Chain_Next( node );
2195 }
while ( node != tail );
2197 _Thread_queue_Gate_add(
2198 &the_thread->
2199 &the_thread->
2202 _Thread_queue_Gate_open( &the_thread->
2209#if defined(RTEMS_SMP)
2210 _Thread_Wait_release_default_critical( the_thread, &lock_context );
2232static inline void _Thread_Wait_tranquilize(
2233 Thread_Control *the_thread
2236#if defined(RTEMS_SMP)
2237 _Thread_queue_Gate_wait( &the_thread->
2250static inline void _Thread_Wait_cancel(
2251 Thread_Control *the_thread,
2259 if ( queue != NULL ) {
2260#if defined(RTEMS_SMP)
2269 _Thread_Wait_restore_default( the_thread );
2271#if defined(RTEMS_SMP)
2281#define THREAD_WAIT_STATE_MASK 0xffU
2290#define THREAD_WAIT_STATE_READY 0x0U
2299#define THREAD_WAIT_STATE_INTEND_TO_BLOCK 0x1U
2304#define THREAD_WAIT_STATE_BLOCKED 0x2U
2309#define THREAD_WAIT_CLASS_MASK 0xff00U
2314#define THREAD_WAIT_CLASS_EVENT 0x100U
2319#define THREAD_WAIT_CLASS_SYSTEM_EVENT 0x200U
2324#define THREAD_WAIT_CLASS_OBJECT 0x400U
2329#define THREAD_WAIT_CLASS_PERIOD 0x800U
2337static inline void _Thread_Wait_flags_set(
2338 Thread_Control *the_thread,
2342#if defined(RTEMS_SMP)
2343 _Atomic_Store_uint( &the_thread->
Wait.
flags, flags, ATOMIC_ORDER_RELAXED );
2357 const Thread_Control *the_thread
2360#if defined(RTEMS_SMP)
2361 return _Atomic_Load_uint( &the_thread->
Wait.
2375 const Thread_Control *the_thread
2378#if defined(RTEMS_SMP)
2379 return _Atomic_Load_uint( &the_thread->
Wait.
flags, ATOMIC_ORDER_ACQUIRE );
2401static inline bool _Thread_Wait_flags_try_change_release(
2402 Thread_Control *the_thread,
2409#if defined(RTEMS_SMP)
2410 return _Atomic_Compare_exchange_uint(
2414 ATOMIC_ORDER_RELEASE,
2415 ATOMIC_ORDER_RELAXED
2418 bool success = ( the_thread->
Wait.
flags == expected_flags );
2441static inline bool _Thread_Wait_flags_try_change_acquire(
2442 Thread_Control *the_thread,
2447#if defined(RTEMS_SMP)
2448 return _Atomic_Compare_exchange_uint(
2452 ATOMIC_ORDER_ACQUIRE,
2453 ATOMIC_ORDER_ACQUIRE
2461 success = _Thread_Wait_flags_try_change_release(
2496 const Thread_Control *the_thread
2529static inline void _Thread_Timer_initialize(
2536 _Watchdog_Preinitialize( &timer->Watchdog, cpu );
2546static inline void _Thread_Add_timeout_ticks(
2547 Thread_Control *the_thread,
2556 the_thread->
Timer.header =
2559 _Watchdog_Per_CPU_insert_ticks( &the_thread->
Timer.Watchdog, cpu, ticks );
2572static inline void _Thread_Timer_insert_realtime(
2573 Thread_Control *the_thread,
2585 the_thread->
Timer.header = header;
2587 _Watchdog_Per_CPU_insert( &the_thread->
Timer.Watchdog, cpu, header, expire );
2597static inline void _Thread_Timer_remove( Thread_Control *the_thread )
2603 _Watchdog_Per_CPU_remove(
2604 &the_thread->
Timer.Watchdog,
2605#
2606 the_thread->
Timer.Watchdog.cpu,
2610 the_thread->
Timer.header
2623static inline void _Thread_Remove_timer_and_unblock(
2624 Thread_Control *the_thread,
2628 _Thread_Wait_tranquilize( the_thread );
2629 _Thread_Timer_remove( the_thread );
2631#if defined(RTEMS_MULTIPROCESSING)
2632 if ( _Objects_Is_local_id( the_thread->
Object.
id ) ) {
2633 _Thread_Unblock( the_thread );
2635 _Thread_queue_Unblock_proxy( queue, the_thread );
2639 _Thread_Unblock( the_thread );
2653 Thread_Control *the_thread,
2667 const Thread_Control *the_thread,
2672#if defined(RTEMS_SMP)
2673#define THREAD_PIN_STEP 2
2675#define THREAD_PIN_PREEMPTION 1
2683void _Thread_Do_unpin(
2684 Thread_Control *executing,
2694static inline void _Thread_Pin( Thread_Control *executing )
2696#if defined(RTEMS_SMP)
2697 _Assert( executing == _Thread_Get_executing() );
2699 executing->
Scheduler.pin_level += THREAD_PIN_STEP;
2711static inline void _Thread_Unpin(
2712 Thread_Control *executing,
2716#if defined(RTEMS_SMP)
2717 unsigned int pin_level;
2719 _Assert( executing == _Per_CPU_Get_executing( cpu_self ) );
2721 pin_level = executing->
Scheduler.pin_level;
2726 pin_level != ( THREAD_PIN_STEP | THREAD_PIN_PREEMPTION )
2729 executing->
Scheduler.pin_level = pin_level - THREAD_PIN_STEP;
2731 _Thread_Do_unpin( executing, cpu_self );
2745#if defined(RTEMS_MULTIPROCESSING)
2763static inline void _Thread_Timer_remove_and_continue(
2764 Thread_Control *the_thread,
2768 _Thread_Timer_remove( the_thread );
2769#if defined(RTEMS_MULTIPROCESSING)
This header file provides the interfaces of the Assert Handler.
This header file provides interfaces of the Chain Handler which are only used by the implementation.
#define RTEMS_PREDICT_TRUE(_exp)
Evaluates the integral expression and tells the compiler that the predicted value is true (1).
Definition basedefs.h:751
#define RTEMS_NO_RETURN
Tells the compiler in a function declaration that this function does not return.
Definition basedefs.h:386
#define rtems_configuration_get_maximum_processors()
Gets the maximum number of processors configured for this application.
Definition config.h:500
#define _Assert(_e)
Assertion similar to assert() controlled via RTEMS_DEBUG instead of NDEBUG and static analysis runs.
Definition assert.h:96
#define _Context_Restore_fp(_fp)
Restore floating point context area.
Definition context.h:159
#define _Context_Save_fp(_fp)
Save floating point context area.
Definition context.h:170
#define _ISR_lock_ISR_enable(_context)
Restores the saved interrupt state of the ISR lock context.
Definition isrlock.h:385
#define _ISR_lock_Release(_lock, _context)
Releases an ISR lock inside an ISR disabled section.
Definition isrlock.h:282
#define _ISR_lock_ISR_disable(_context)
Disables interrupts and saves the previous interrupt state in the ISR lock context.
Definition isrlock.h:364
#define _ISR_lock_Acquire(_lock, _context)
Acquires an ISR lock inside an ISR disabled section.
Definition isrlock.h:259
#define _ISR_lock_Release_and_ISR_enable(_lock, _context)
Releases an ISR lock.
Definition isrlock.h:229
#define _ISR_lock_ISR_disable_and_acquire(_lock, _context)
Acquires an ISR lock.
Definition isrlock.h:204
#define _ISR_lock_Initialize(_lock, _name)
Initializes an ISR lock.
Definition isrlock.h:150
#define _ISR_Local_disable(_level)
Disables interrupts on this processor.
Definition isrlevel.h:76
#define _ISR_Local_enable(_level)
Enables interrupts on this processor.
Definition isrlevel.h:93
#define _ISR_Get_level()
Return current interrupt level.
Definition isrlevel.h:147
uint32_t ISR_Level
Definition isrlevel.h:60
Objects_Information **const _Objects_Information_table[OBJECTS_APIS_LAST+1]
uint32_t Objects_Id
Definition object.h:101
@ PER_CPU_WATCHDOG_REALTIME
Index for realtime clock per-CPU watchdog header.
Definition percpu.h:362
@ PER_CPU_WATCHDOG_TICKS
Index for tick clock per-CPU watchdog header.
Definition percpu.h:353
uint64_t Priority_Control
The thread priority control.
Definition priority.h:91
Priority_Group_order
The priority group order determines if a priority node is inserted as the first or last node into its...
Definition priorityimpl.h:62
#define _Scheduler_Count
This constant contains the count of configured schedulers.
Definition scheduler.h:395
const Scheduler_Control _Scheduler_Table[]
This table contains the configured schedulers.
#define SCHEDULER_PRIORITY_UNMAP(priority)
Returns the plain priority value.
Definition schedulernodeimpl.h:70
#define STATES_BLOCKED
Definition statesimpl.h:152
uint32_t States_Control
Definition states.h:65
Status_Control
Status codes.
Definition status.h:111
void _Thread_MP_Extract_proxy(Thread_Control *the_thread)
Extracts the proxy of the thread if necessary.
Definition threadqextractwithproxy.c:46
const Thread_queue_Operations _Thread_queue_Operations_default
The default thread queue operations are used when a thread is not enqueued on a thread queue.
Definition threadqops.c:1500
Status_Control _Thread_Restart(Thread_Control *the_thread, const Thread_Entry_information *entry, ISR_lock_Context *lock_context)
Restarts the thread.
Definition threadrestart.c:536
void _Thread_Continue(Thread_Control *the_thread, Status_Control status)
Cancels a blocking operation so that the thread can continue its execution.
Definition threadtimeout.c:45
RTEMS_NO_RETURN void _Thread_Exit(void *exit_value, Thread_Life_state life_states_to_set)
Exits the currently executing thread.
Definition threadrestart.c:501
void _Thread_Entry_adaptor_idle(Thread_Control *executing)
Calls the start kinds idle entry of the thread.
Definition threadentryadaptoridle.c:43
Thread_Information _Thread_Information
The internal thread objects information.
void _Thread_Timeout(Watchdog_Control *the_watchdog)
General purpose thread wait timeout.
Definition threadtimeout.c:101
Thread_Cancel_state _Thread_Cancel(Thread_Control *the_thread, Thread_Control *executing, Thread_Life_state life_states_to_clear)
Cancels the thread.
Definition threadrestart.c:434
Thread_Control * _Thread_Get(Objects_Id id, ISR_lock_Context *lock_context)
Gets a thread by its identifier.
Definition threadget.c:44
Status_Control _Thread_Initialize(Thread_Information *information, Thread_Control *the_thread, const Thread_Configuration *config)
Initializes thread.
Definition threadinitialize.c:368
void(*) Thread_Action_handler(Thread_Control *the_thread, Thread_Action *action, ISR_lock_Context *lock_context)
This type defines the prototype of thread action handlers.
Definition thread.h:686
void _Thread_Priority_update(Thread_queue_Context *queue_context)
Updates the priority of all threads in the set.
Definition threadchangepriority.c:396
void _Thread_Handler_initialization(void)
Initializes thread handler.
Definition thread.c:80
Timestamp_Control _Thread_Get_CPU_time_used_locked(Thread_Control *the_thread)
Gets the used processor time of the thread throughout its entire lifetime if the caller already acqui...
Definition threadgetcputimeused.c:53
Objects_Id _Thread_Global_constructor
Object identifier of the global constructor thread.
Definition threadhandler.c:74
void _Thread_Priority_add(Thread_Control *the_thread, Priority_Node *priority_node, Thread_queue_Context *queue_context)
Adds the specified thread priority node to the corresponding thread priority aggregation.
Definition threadchangepriority.c:332
size_t _Thread_Get_name(const Thread_Control *the_thread, char *buffer, size_t buffer_size)
Gets the name of the thread.
Definition threadname.c:65
void _Thread_Priority_perform_actions(Thread_Control *start_of_path, Thread_queue_Context *queue_context)
Checks if the thread is owner of the lock of the join queue.
Definition threadchangepriority.c:223
#define THREAD_LIFE_TERMINATING
Indicates that thread is terminating.
Definition thread.h:772
Thread_Cancel_state
Indicates the resulting state of _Thread_Cancel().
Definition threadimpl.h:409
States_Control _Thread_Set_state(Thread_Control *the_thread, States_Control state)
Sets the specified thread state.
Definition threadsetstate.c:70
#define THREAD_LIFE_PROTECTED
Indicates that the thread life is protected.
Definition thread.h:756
RTEMS_NO_RETURN void _Thread_Start_multitasking(void)
Starts thread multitasking.
Definition threadstartmultitasking.c:46
unsigned int Thread_Life_state
This type represents the thread life state.
Definition thread.h:747
Timestamp_Control _Thread_Get_CPU_time_used(Thread_Control *the_thread)
Updates the used cpu time for the heir and dispatches a new heir.
Definition threadgetcputimeused.c:71
Timestamp_Control _Thread_Get_CPU_time_used_after_last_reset(Thread_Control *the_thread)
Gets the used processor time of the thread after the last CPU usage reset.
Definition threadgetcputimeusedafterreset.c:44
#define THREAD_LIFE_RESTARTING
Indicates that thread is restarting.
Definition thread.h:764
States_Control _Thread_Clear_state(Thread_Control *the_thread, States_Control state)
Clears the specified thread state.
Definition threadclearstate.c:72
void _Thread_Yield(Thread_Control *executing)
Yields the currently executing thread.
Definition threadyield.c:44
void _Thread_Create_idle(void)
Creates idle thread.
Definition threadcreateidle.c:125
Thread_Control * _Thread_Allocated_fp
Definition threaddispatch.c:56
void _Thread_Free(Thread_Information *information, Thread_Control *the_thread)
Frees the thread.
Definition threadinitialize.c:50
Status_Control _Thread_Start(Thread_Control *the_thread, const Thread_Entry_information *entry, ISR_lock_Context *lock_context)
Starts the specified thread.
Definition threadstart.c:46
void _Thread_Priority_remove(Thread_Control *the_thread, Priority_Node *priority_node, Thread_queue_Context *queue_context)
Removes the specified thread priority node from the corresponding thread priority aggregation.
Definition threadchangepriority.c:347
void _Thread_Entry_adaptor_numeric(Thread_Control *executing)
Calls the start kinds numeric entry of the thread.
Definition threadentryadaptornumeric.c:43
void _Thread_Kill_zombies(void)
Kills all zombie threads in the system.
Definition threadrestart.c:168
unsigned int Thread_Wait_flags
This type is able to contain several flags used to control the wait class and state of a thread.
Definition thread.h:451
void _Thread_Entry_adaptor_pointer(Thread_Control *executing)
Calls the start kinds pointer entry of the thread.
Definition threadentryadaptorpointer.c:43
Objects_Id _Thread_Self_id(void)
Gets the identifier of the calling thread.
Definition threadselfid.c:46
Thread_Zombie_registry _Thread_Zombies
This object is a registry for threads in the STATES_ZOMBIE state.
Definition threadrestart.c:66
void _Thread_Priority_changed(Thread_Control *the_thread, Priority_Node *priority_node, Priority_Group_order priority_group_order, Thread_queue_Context *queue_context)
Propagates a thread priority value change in the specified thread priority node to the corresponding ...
Definition threadchangepriority.c:362
void _Thread_Iterate(Thread_Visitor visitor, void *arg)
Calls the visitor with all threads and the given argument until it is done.
Definition threaditerate.c:43
void _Thread_Initialize_information(Thread_Information *information)
Initializes the thread information.
Definition thread.c:68
#define THREAD_LIFE_CHANGE_DEFERRED
Indicates that thread life changes are deferred.
Definition thread.h:781
Thread_Life_state _Thread_Set_life_protection(Thread_Life_state state)
Set the thread to life protected.
Definition threadrestart.c:624
Objects_Id _Thread_Wait_get_id(const Thread_Control *the_thread)
Returns the object identifier of the object containing the current thread wait queue.
Definition threadwaitgetid.c:43
States_Control _Thread_Set_state_locked(Thread_Control *the_thread, States_Control state)
Sets the specified thread state without locking the lock context.
Definition threadsetstate.c:48
#define THREAD_LIFE_DETACHED
Indicates that thread is detached.
Definition thread.h:790
Status_Control _Thread_Close(Thread_Control *the_thread, Thread_Control *executing, Thread_queue_Context *queue_context)
Closes the thread.
Definition threadrestart.c:465
void _Thread_Load_environment(Thread_Control *the_thread)
Initializes enviroment for a thread.
Definition threadloadenv.c:44
Status_Control _Thread_Set_name(Thread_Control *the_thread, const char *name)
Sets the name of the thread.
Definition threadname.c:45
void _Thread_Handler(void)
Wrapper function for all threads.
Definition threadhandler.c:97
Status_Control _Thread_Join(Thread_Control *the_thread, States_Control waiting_for_join, Thread_Control *executing, Thread_queue_Context *queue_context)
Joins the currently executing thread with the thread.
Definition threadrestart.c:380
States_Control _Thread_Clear_state_locked(Thread_Control *the_thread, States_Control state)
Clears the specified thread state without locking the lock context.
Definition threadclearstate.c:46
Thread_Life_state _Thread_Change_life(Thread_Life_state life_states_to_clear, Thread_Life_state life_states_to_set, Thread_Life_state ignored_life_states)
Changes the life of currently executing thread.
Definition threadrestart.c:597
@ THREAD_CANCEL_IN_PROGRESS
Indicates that the thread cancel operation is in progress.
Definition threadimpl.h:420
@ THREAD_CANCEL_DONE
Indicates that the thread cancel operation is done.
Definition threadimpl.h:413
int64_t Timestamp_Control
Definition timestamp.h:76
uint32_t Watchdog_Interval
Type is used to specify the length of intervals.
Definition watchdogticks.h:59
Watchdog_Service_routine(*) Watchdog_Service_routine_entry(Watchdog_Control *)
Pointer to a watchdog service routine.
Definition watchdog.h:85
This header file provides the interfaces of the Internal Error Handler.
This header file provides the main interfaces of the ISR Handler.
This header file provides interfaces of the Scheduler Handler related to scheduler nodes which are on...
This header file provides interfaces of the Object Handler which are only used by the implementation.
This header file provides the interfaces of the Operation Status Support.
This header file provides interfaces of the Thread Handler which are used by the implementation and t...
This header file provides interfaces of the Thread States which are only used by the implementation.
This structure represents a chain node.
Definition chain.h:78
Local ISR lock context for acquire and release pairs.
Definition isrlock.h:94
Objects_Id id
Definition objectdata.h:65
Per CPU Core Structure.
Definition percpu.h:384
struct _Thread_Control * heir
This is the heir thread for this processor.
Definition percpu.h:473
volatile bool dispatch_necessary
This is set to true when this processor needs to run the thread dispatcher.
Definition percpu.h:437
Timestamp_Control cpu_usage_timestamp
The CPU usage timestamp contains the time point of the last heir thread change or last CPU usage upda...
Definition percpu.h:489
struct _Thread_Control * executing
This is the thread executing on this processor.
Definition percpu.h:457
The priority node to build up a priority aggregation.
Definition priority.h:112
Priority_Control priority
The priority value of this node.
Definition priority.h:124
Scheduler node for per-thread data.
Definition schedulernode.h:94
Control block to manage thread actions.
Definition thread.h:733
Thread action.
Definition thread.h:706
This structure contains operations which manage the CPU budget of a thread.
Definition thread.h:188
The configuration of a new thread to initialize.
Definition threadimpl.h:169
The new thread's priority.
Definition threadimpl.h:195
void(*) stack_free(void *)
This member contains the handler to free the stack.
Definition threadimpl.h:190
const struct _Scheduler_Control * scheduler
The scheduler control instance for the thread.
Definition threadimpl.h:173
void * stack_area
The starting address of the stack area.
Definition threadimpl.h:178
size_t stack_size
The size of the stack area in bytes.
Definition threadimpl.h:183
bool is_preemptible
Indicates whether the new thread is preemptible.
Definition threadimpl.h:220
const Thread_CPU_budget_operations * cpu_budget_operations
The thread's initial CPU budget operations.
Definition threadimpl.h:200
uint32_t isr_level
The thread's initial ISR level.
Definition threadimpl.h:210
uint32_t name
32-bit unsigned integer name of the object for the thread.
Definition threadimpl.h:205
bool is_fp
Indicates whether the thread needs a floating-point area.
Definition threadimpl.h:215
Thread entry information.
Definition thread.h:163
The current thread life state.
Definition thread.h:805
Scheduler_Node * nodes
The scheduler nodes of this thread.
Definition thread.h:419
The thread zombie registry is used to register threads in the STATES_ZOMBIE state.
Definition threadimpl.h:73
Chain_Control Chain
This chain contains the registered zombie threads.
Definition threadimpl.h:84
Thread queue context for the thread queue methods.
Definition threadq.h:216
Thread_queue_Lock_context Lock_context
The lock context for the thread queue acquire and release operations.
Definition threadq.h:221
ISR_lock_Context Lock_context
Definition threadq.h:148
The thread queue operations are used to manage the threads of a thread queue.
Definition threadq.h:554
Thread_queue_Extract_operation extract
This operation is used to extract the thread from the thread queue.
Definition threadq.h:580
The control block used to manage each watchdog timer.
Definition watchdog.h:109
Watchdog_Service_routine_entry routine
This field is the function to invoke.
Definition watchdog.h:133
Scheduler control.
Definition scheduler.h:337
Context_Control Registers
This member contains the context of this thread.
Definition thread.h:893
Objects_Control Object
Definition thread.h:839
Timestamp_Control cpu_time_used
This member contains the amount of CPU time consumed by this thread since it was created.
Definition thread.h:944
Thread_Wait_information Wait
Definition thread.h:877
Context_Control_fp * fp_context
Definition thread.h:964
Priority_Node Real_priority
The base priority of this thread in its home scheduler instance.
Definition thread.h:864
States_Control current_state
Definition thread.h:859
Thread_Scheduler_control Scheduler
Scheduler related control.
Definition thread.h:874
Thread_queue_Control Join_queue
Thread queue for thread join operations and multi-purpose lock.
Definition thread.h:856
Thread_Timer_information Timer
Definition thread.h:879
Thread_Life_control Life
Thread life-cycle control.
Definition thread.h:985
Definition mmu-config.c:53
This header file provides the interfaces of the System State Handler.
This header file provides the interfaces of the Thread Handler Multiprocessing (MP) Support.
This header file provides interfaces of the Thread Queue Handler which are only used by the implement...
This header file provides interfaces of the Timestamp Handler which are only used by the implementati...
This header file provides the interfaces of the Time of Day Handler and the Time of Day Handler Actio...
This union represents a chain control block.
Definition chain.h:96
This header file provides interfaces of the Watchdog Handler which are only used by the implementatio...
