RTEMS
6.3
Toggle main menu visibility
include
score
mrsp.h
1
/* SPDX-License-Identifier: BSD-2-Clause */
2
12
13
14
* Copyright (C) 2014, 2016 embedded brains GmbH & Co. KG
15
16
17
* modification, are permitted provided that the following conditions
18
* are met:
19
* 1. Redistributions of source code must retain the above copyright
20
* notice, this list of conditions and the following disclaimer.
21
* 2. Redistributions in binary form must reproduce the above copyright
22
* notice, this list of conditions and the following disclaimer in the
23
* documentation and/or other materials provided with the distribution.
24
25
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
26
* AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
27
* IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
28
* ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
29
* LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
30
* CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
31
* SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
32
* INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
33
* CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
34
* ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
35
* POSSIBILITY OF SUCH DAMAGE.
36
37
38
#ifndef _RTEMS_SCORE_MRSP_H
39
#define _RTEMS_SCORE_MRSP_H
40
41
42
rtems/score/threadq.h
43
44
#ifdef __cplusplus
45
extern
"C"
46
#endif
/* __cplusplus */
47
71
72
#if defined(RTEMS_SMP)
73
77
typedef
struct
81
Thread_queue_Control
Wait_queue;
82
86
Priority_Node
Ceiling_priority;
87
91
Priority_Control
ceiling_priorities[
RTEMS_ZERO_LENGTH_ARRAY
92
} MRSP_Control;
93
94
#endif
/* RTEMS_SMP */
95
97
98
#ifdef __cplusplus
99
100
#endif
/* __cplusplus */
101
102
#endif
/* _RTEMS_SCORE_MRSP_H */
#define RTEMS_ZERO_LENGTH_ARRAY
This constant represents the element count of a zero-length array.
Definition
basedefs.h:1032
Priority_Control
uint64_t Priority_Control
The thread priority control.
Definition
priority.h:91
Priority_Node
The priority node to build up a priority aggregation.
Definition
priority.h:112
Definition
threadq.h:609
threadq.h
This header file provides interfaces of the Thread Queue Handler which are used by the implementation...
