RTEMS 6.3
Scheduler Handler
This group contains the Scheduler Handler implementation. More...
Topics
 Constant Bandwidth Server (CBS) Scheduler
 This group contains the Constant Bandwidth Server (CBS) Scheduler implementation.
 Deterministic Priority Scheduler
 This group contains the Deterministic Priority Scheduler implementation.
 EDF Scheduler
 This group contains the EDF Scheduler implementation.
 SMP Scheduler
 This group contains the SMP Scheduler implementation.
 Simple Priority Scheduler
 This group contains the Simple Priority Scheduler implementation.
file  cpukit/include/rtems/score/scheduler.h
 This header file provides interfaces of the Scheduler Handler which are used by the implementation and the Application Configuration.
file  cpukit/include/rtems/score/schedulerimpl.h
 This header file provides interfaces of the Scheduler Handler which are only used by the implementation.
file  cpukit/include/rtems/score/schedulernode.h
 This header file provides interfaces of the Scheduler Handler related to scheduler nodes which are used by the implementation and the Application Configuration.
file  cpukit/include/rtems/score/schedulernodeimpl.h
 This header file provides interfaces of the Scheduler Handler related to scheduler nodes which are only used by the implementation.
file  cpukit/include/rtems/score/scheduleruniimpl.h
 This header file provides interfaces of the supporting the implementation of uniprocessor schedulers.
file  cpukit/score/src/sched.c
 This source file contains the implementation of _Sched_Count(), _Sched_Index(), _Sched_Name_to_index(), and _Sched_Processor_count().
file  cpukit/score/src/scheduler.c
 This source file contains the implementation of _Scheduler_Handler_initialization().
file  cpukit/score/src/schedulerdefaultmakecleansticky.c
 This source file contains the implementation of _Scheduler_default_Sticky_do_nothing().
file  cpukit/score/src/schedulerdefaultmappriority.c
 This source file contains the implementation of _Scheduler_default_Map_priority() and _Scheduler_default_Unmap_priority().
file  cpukit/score/src/schedulerdefaultnodedestroy.c
 This source file contains the implementation of _Scheduler_default_Node_destroy().
file  cpukit/score/src/schedulerdefaultnodeinit.c
 This source file contains the implementation of _Scheduler_default_Node_initialize().
file  cpukit/score/src/schedulerdefaultpinunpin.c
 This source file contains the implementation of _Scheduler_default_Pin_or_unpin_not_supported().
file  cpukit/score/src/schedulerdefaultpinunpindonothing.c
 This source file contains the implementation of _Scheduler_default_Pin_or_unpin_do_nothing().
file  cpukit/score/src/schedulerdefaultreleasejob.c
 This source file contains the implementation of _Scheduler_default_Release_job() and _Scheduler_default_Cancel_job().
file  cpukit/score/src/schedulerdefaultschedule.c
 This source file contains the implementation of _Scheduler_default_Schedule().
file  cpukit/score/src/schedulerdefaultsetaffinity.c
 This source file contains the implementation of _Scheduler_default_Set_affinity().
file  cpukit/score/src/schedulerdefaultstartidle.c
 This source file contains the implementation of _Scheduler_default_Start_idle().
file  cpukit/score/src/schedulergetaffinity.c
 This source file contains the implementation of _Scheduler_Get_affinity().
file  cpukit/score/src/schedulersetaffinity.c
 This source file contains the implementation of _Scheduler_Set_affinity().
file  cpukit/score/src/schedulersmp.c
 This source file contains the implementation of _Scheduler_Request_ask_for_help().
file  cpukit/score/src/schedulersmpstartidle.c
 This source file contains the implementation of _Scheduler_SMP_Start_idle().
struct  Scheduler_Operations
 The scheduler operations. More...
struct  Scheduler_Context
 Scheduler context. More...
struct  _Scheduler_Control
 Scheduler control. More...
struct  Scheduler_Node
 Scheduler node for per-thread data. More...
struct  Scheduler_Node::[struct].Wait
 Thread wait support block. More...
struct  Scheduler_Node::[struct].Priority
 The thread priority information used by the scheduler. More...
#define _Scheduler_Count   ( (size_t) 1 )
 This constant contains the count of configured schedulers.
#define SCHEDULER_DEFAULT_SMP_OPERATIONS
 This define provides a set of default implementations for SMP-specific scheduler operations.
#define SCHEDULER_DEFAULT_SET_AFFINITY_OPERATION
 This define provides the default implementation for the SMP-specific set affinity operation.
#define PRIORITY_MAXIMUM   ( _Scheduler_Table[ 0 ].maximum_priority )
 This defines the lowest (least important) thread priority of the first scheduler instance.
#define SCHEDULER_NODE_OF_WAIT_PRIORITY_NODE(node)
#define SCHEDULER_NODE_OF_WAIT_PRIORITY(node)
#define SCHEDULER_PRIORITY_MAP(priority)
 Maps a priority value to support the append indicator.
#define SCHEDULER_PRIORITY_UNMAP(priority)
 Returns the plain priority value.
#define SCHEDULER_PRIORITY_PURIFY(priority)
 Clears the priority append indicator bit.
#define SCHEDULER_PRIORITY_APPEND(priority)
 Returns the priority control with the append indicator bit set.
#define SCHEDULER_PRIORITY_IS_APPEND(priority)
 Returns true, if the item should be appended to its priority group, otherwise returns false and the item should be prepended to its priority group.
typedef struct _Scheduler_Control Scheduler_Control
typedef struct Scheduler_Context Scheduler_Context
 Scheduler context.
typedef struct Scheduler_Node Scheduler_Node
Priority_Control _Scheduler_default_Map_priority (const Scheduler_Control *scheduler, Priority_Control priority)
 Returns the scheduler internal thread priority mapped by SCHEDULER_PRIORITY_MAP().
Priority_Control _Scheduler_default_Unmap_priority (const Scheduler_Control *scheduler, Priority_Control priority)
 Returns the user visible thread priority unmapped by SCHEDULER_PRIORITY_UNMAP().
void _Scheduler_default_Schedule (const Scheduler_Control *scheduler, Thread_Control *the_thread)
 Does nothing.
void _Scheduler_default_Node_initialize (const Scheduler_Control *scheduler, Scheduler_Node *node, Thread_Control *the_thread, Priority_Control priority)
 Performs the scheduler base node initialization.
void _Scheduler_default_Node_destroy (const Scheduler_Control *scheduler, Scheduler_Node *node)
 Does nothing.
void _Scheduler_default_Release_job (const Scheduler_Control *scheduler, Thread_Control *the_thread, Priority_Node *priority_node, uint64_t deadline, Thread_queue_Context *queue_context)
 Does nothing.
void _Scheduler_default_Cancel_job (const Scheduler_Control *scheduler, Thread_Control *the_thread, Priority_Node *priority_node, Thread_queue_Context *queue_context)
 Does nothing.
void _Scheduler_default_Start_idle (const Scheduler_Control *scheduler, Thread_Control *the_thread, struct Per_CPU_Control *cpu)
 Starts an idle thread.
void _Scheduler_Handler_initialization (void)
 Initializes the scheduler to the policy chosen by the user.
Status_Control _Scheduler_Get_affinity (Thread_Control *the_thread, size_t cpusetsize, cpu_set_t *cpuset)
 Copies the thread's scheduler's affinity to the given cpuset.
Status_Control _Scheduler_Set_affinity (Thread_Control *the_thread, size_t cpusetsize, const cpu_set_t *cpuset)
 Sets the thread's scheduler's affinity.
const Scheduler_Control _Scheduler_Table []
 This table contains the configured schedulers.
This handler encapsulates functionality related to managing sets of threads that are ready for execution.
Schedulers are used by the system to manage sets of threads that are ready for execution. A scheduler consists of
  • a scheduler algorithm implementation,
  • a scheduler index and an associated name, and
  • a set of processors owned by the scheduler (may be empty, but never overlaps with a set owned by another scheduler).
Each thread uses exactly one scheduler as its home scheduler. Threads may temporarily use another scheduler due to actions of locking protocols.
All properties of a scheduler can be configured and controlled by the user. Some properties are fixed at link time (defined by application configuration options), other properties can be changed at runtime through directive calls.
The scheduler index, name, and initial processor set are defined for a particular application by the application configuration. The schedulers are registered in the _Scheduler_Table which has _Scheduler_Count entries.
◆ _Scheduler_Count
In SMP configurations, the constant is defined by <rtems/confdefs.h> through the count of entries of the CONFIGURE_SCHEDULER_TABLE_ENTRIES application configuration option.
In uniprocessor configurations, this is a compile time constant set to one. This is important so that the compiler can optimize some loops away.
See also
_Scheduler_Table.
◆ SCHEDULER_DEFAULT_SET_AFFINITY_OPERATION
The default implementation _Scheduler_default_Set_affinity() is intended for uniprocessor schedulers and SMP schedulers which only support an affinity to all online processors.
If SMP support is disabled, the define evaluates to nothing.
◆ SCHEDULER_DEFAULT_SMP_OPERATIONS
The default implementations are intended for uniprocessor schedulers. SMP schedulers shall implement the operations properly.
If SMP support is enabled and the system has exactly one processor, then it may use an uniprocessor scheduler. The ask for help, reconsider help request, and withdraw node operations are NULL, since they are only used if a thread has at least one helping scheduler node. At least two schedulers are required to get a helping node and each scheduler involved must own at least one processor. This is not possible on a system with exactly one processor. The processor add operation is NULL, since there is no other processor to add. The processor remove operation is NULL, since the one and only processor cannot be removed.
◆ SCHEDULER_NODE_OF_WAIT_PRIORITY
#define SCHEDULER_NODE_OF_WAIT_PRIORITY ( node)
Value:
RTEMS_CONTAINER_OF( node, Scheduler_Node, Wait.Priority )
#define RTEMS_CONTAINER_OF(_m, _type, _member_name)
Gets the container of a member.
Definition basedefs.h:306
Definition schedulernode.h:94
◆ SCHEDULER_NODE_OF_WAIT_PRIORITY_NODE
#define SCHEDULER_NODE_OF_WAIT_PRIORITY_NODE ( node)
Value:
RTEMS_CONTAINER_OF( node, Scheduler_Node, Wait.Priority.Node.Node.Chain )
◆ SCHEDULER_PRIORITY_APPEND
#define SCHEDULER_PRIORITY_APPEND ( priority)
Value:
( ( priority ) | ( (Priority_Control) PRIORITY_GROUP_LAST ) )
uint64_t Priority_Control
The thread priority control.
Definition priority.h:91
@ PRIORITY_GROUP_LAST
Priority group last option requests that the priority node is inserted as the last node into its prio...
Definition priorityimpl.h:73
◆ SCHEDULER_PRIORITY_IS_APPEND
#define SCHEDULER_PRIORITY_IS_APPEND ( priority)
Value:
( ( ( priority ) & ( (Priority_Control) PRIORITY_GROUP_LAST ) ) != 0 )
◆ SCHEDULER_PRIORITY_MAP
#define SCHEDULER_PRIORITY_MAP ( priority)
Value:
( ( priority ) << 1 )
◆ SCHEDULER_PRIORITY_PURIFY
#define SCHEDULER_PRIORITY_PURIFY ( priority)
Value:
( ( priority ) & ~( (Priority_Control) PRIORITY_GROUP_LAST ) )
◆ SCHEDULER_PRIORITY_UNMAP
#define SCHEDULER_PRIORITY_UNMAP ( priority)
Value:
( ( priority ) >> 1 )
Typedef Documentation
◆ Scheduler_Context
Scheduler context.
The scheduler context of a particular scheduler implementation must place this structure at the begin of its context structure.
◆ _Scheduler_default_Cancel_job()
void _Scheduler_default_Cancel_job ( const Scheduler_Control * scheduler,
Thread_Control * the_thread,
Priority_Node * priority_node,
Thread_queue_Context * queue_context )
Does nothing.
Parameters
schedulerThis parameter is unused.
the_threadThis parameter is unused.
priority_nodeThis parameter is unused.
queue_contextThis parameter is unused.
Returns
Always returns NULL.
◆ _Scheduler_default_Map_priority()
Priority_Control _Scheduler_default_Map_priority ( const Scheduler_Control * scheduler,
Priority_Control priority )
Parameters
schedulerUnused.
priorityThe user visible thread priority.
Returns
The scheduler internal thread priority.
◆ _Scheduler_default_Node_destroy()
void _Scheduler_default_Node_destroy ( const Scheduler_Control * scheduler,
Scheduler_Node * node )
Does nothing.
Parameters
◆ _Scheduler_default_Node_initialize()
void _Scheduler_default_Node_initialize ( const Scheduler_Control * scheduler,
Scheduler_Node * node,
Parameters
[out]nodeThe node to initialize.
priorityThe thread priority.
◆ _Scheduler_default_Release_job()
void _Scheduler_default_Release_job ( const Scheduler_Control * scheduler,
uint64_t deadline,
Does nothing.
Parameters
deadlineThis parameter is unused.
Returns
◆ _Scheduler_default_Schedule()
void _Scheduler_default_Schedule ( const Scheduler_Control * scheduler,
Thread_Control * the_thread )
Does nothing.
Parameters
◆ _Scheduler_default_Start_idle()
void _Scheduler_default_Start_idle ( const Scheduler_Control * scheduler,
struct Per_CPU_Control * cpu )
Parameters
[in,out]the_threadAn idle thread.
cpuThis parameter is unused.
◆ _Scheduler_default_Unmap_priority()
Priority_Control _Scheduler_default_Unmap_priority ( const Scheduler_Control * scheduler,
Parameters
schedulerUnused.
priorityThe scheduler internal thread priority.
Returns
priority The user visible thread priority.
◆ _Scheduler_Get_affinity()
Status_Control _Scheduler_Get_affinity ( Thread_Control * the_thread,
size_t cpusetsize,
cpu_set_t * cpuset )
Parameters
the_threadThe thread to get the affinity of its scheduler.
cpusetsizeThe size of cpuset.
[out]cpusetThe cpuset that serves as destination for the copy operation
Return values
STATUS_SUCCESSFULThe operation succeeded.
STATUS_INVALID_SIZEThe processor set was too small.
◆ _Scheduler_Handler_initialization()
void _Scheduler_Handler_initialization ( void )
This routine initializes the scheduler to the policy chosen by the user through confdefs, or to the priority scheduler with ready chains by default.
◆ _Scheduler_Set_affinity()
Status_Control _Scheduler_Set_affinity ( Thread_Control * the_thread,
size_t cpusetsize,
const cpu_set_t * cpuset )
Parameters
[in,out]the_threadThe thread to set the affinity of.
cpusetThe cpuset to set the affinity.
Return values
STATUS_INVALID_NUMBERThe processor set was not a valid new processor affinity set for the thread.
Variable Documentation
◆ _Scheduler_Table
const Scheduler_Control _Scheduler_Table[]
extern
The table is defined by <rtems/confdefs.h> through the CONFIGURE_SCHEDULER_TABLE_ENTRIES application configuration option.
See also
_Scheduler_Count.
