RTEMS
6.3
Toggle main menu visibility
include
score
hash.h
1
/* SPDX-License-Identifier: BSD-2-Clause */
2
11
12
13
* Copyright (C) 2021 embedded brains GmbH & Co. KG
14
15
16
* modification, are permitted provided that the following conditions
17
* are met:
18
* 1. Redistributions of source code must retain the above copyright
19
* notice, this list of conditions and the following disclaimer.
20
* 2. Redistributions in binary form must reproduce the above copyright
21
* notice, this list of conditions and the following disclaimer in the
22
* documentation and/or other materials provided with the distribution.
23
24
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
25
* AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
26
* IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
27
* ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
28
* LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
29
* CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
30
* SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
31
* INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
32
* CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
33
* ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
34
* POSSIBILITY OF SUCH DAMAGE.
35
36
37
#ifndef _RTEMS_SCORE_HASH_H
38
#define _RTEMS_SCORE_HASH_H
39
40
rtems/score/basedefs.h
41
42
sha256.h
43
45
#ifdef __cplusplus
46
extern
"C"
47
#endif
48
58
64
#define HASH_CONTROL_STRING_SIZE 45
65
71
typedef
struct
77
char
chars
78
Hash_Control
79
87
static
inline
const
char
*_Hash_Get_string(
const
Hash_Control
*hash )
88
89
return
&hash->
chars
[ 0 ];
90
91
95
typedef
struct
99
SHA256_CTX
Context
100
104
Hash_Control
hash
105
109
size_t
index
110
Hash_Context
111
117
static
inline
void
_Hash_Initialize(
Hash_Context
context
118
119
SHA256_Init( &
context
->Context );
120
121
131
static
inline
void
_Hash_Add_data(
132
Hash_Context
context
133
const
void
*begin,
134
size_t
size
135
136
137
SHA256_Update( &
context
->Context, begin, size );
138
139
147
static
inline
void
_Hash_Add_string(
148
Hash_Context
context
149
const
char
*str
150
151
152
SHA256_Update( &
context
->Context, str, strlen( str ) );
153
154
162
void
_Hash_Finalize
Hash_Context
context
Hash_Control
*hash );
163
165
166
#ifdef __cplusplus
167
168
#endif
169
170
#endif
/* _RTEMS_SCORE_HASH_H */
basedefs.h
This header file provides basic definitions used by the API and the implementation.
This constant represents the size of a hash string.
Definition
hash.h:64
_Hash_Finalize
void _Hash_Finalize(Hash_Context *context, Hash_Control *hash)
Finalizes the hash value computation and produces the hash value.
Definition
hash.c:58
sha256.h
This header file contains interfaces of the SHA256 hash algorithm support.
Hash_Context
This type represents the context to compute a hash value.
Definition
hash.h:95
Hash_Context::hash
Hash_Control * hash
This member references a hash value if needed.
Definition
hash.h:104
Hash_Context::Context
SHA256_CTX Context
This member contains the hash algorithm context.
Definition
hash.h:99
Hash_Context::index
size_t index
This member contains an index into the hash value bytes if needed.
Definition
hash.h:109
Hash_Control
This type represents a hash value.
Definition
hash.h:71
Hash_Control::chars
char chars[HASH_CONTROL_STRING_SIZE]
This member contains the hash value encoded as a base64url string.
Definition
hash.h:77
context
unsigned context
Definition
tlb.h:1
