RTEMS 6.3
This header file provides the interfaces of the Per-CPU Information. More...
#include <rtems/score/cpuimpl.h>#include <rtems/score/assert.h>#include <rtems/score/chain.h>#include <rtems/score/isrlock.h>#include <rtems/score/smp.h>#include <rtems/score/timestamp.h>#include <rtems/score/watchdog.h>Go to the source code of this file.
| struct | Per_CPU_Stats |
| Per-CPU statistics. More... | |
| struct | Per_CPU_Control |
| Per CPU Core Structure. More... | |
| struct | Per_CPU_Control_envelope |
| #define | _Per_CPU_Acquire(cpu, lock_context) |
| #define | _Per_CPU_Release(cpu, lock_context) |
| #define | _Per_CPU_Get_snapshot() |
| #define | _Per_CPU_Get() |
| #define | _Thread_Dispatch_disable_level _Per_CPU_Get()->thread_dispatch_disable_level |
| #define | _Thread_Heir _Per_CPU_Get()->heir |
| #define | _Thread_Executing _Per_CPU_Get_executing( _Per_CPU_Get() ) |
| #define | _ISR_Nest_level _Per_CPU_Get()->isr_nest_level |
| #define | _CPU_Interrupt_stack_low _Per_CPU_Get()->interrupt_stack_low |
| #define | _CPU_Interrupt_stack_high _Per_CPU_Get()->interrupt_stack_high |
| #define | _Thread_Dispatch_necessary _Per_CPU_Get()->dispatch_necessary |
Typedefs | |
| typedef struct Per_CPU_Control | Per_CPU_Control |
| Per CPU Core Structure. | |
Enumerations | |
| enum | Per_CPU_Watchdog_index { PER_CPU_WATCHDOG_TICKS , PER_CPU_WATCHDOG_REALTIME , PER_CPU_WATCHDOG_MONOTONIC , PER_CPU_WATCHDOG_COUNT } |
| Per-CPU watchdog header index. More... | |
| CPU_STRUCTURE_ALIGNMENT Per_CPU_Control_envelope | _Per_CPU_Information [] |
| Set of Per CPU Core Information. | |
