RTEMS
6.3
Toggle main menu visibility
include
score
processormask.h
1
/* SPDX-License-Identifier: BSD-2-Clause */
2
11
12
13
* Copyright (C) 2016, 2017 embedded brains GmbH & Co. KG
14
15
16
* modification, are permitted provided that the following conditions
17
* are met:
18
* 1. Redistributions of source code must retain the above copyright
19
* notice, this list of conditions and the following disclaimer.
20
* 2. Redistributions in binary form must reproduce the above copyright
21
* notice, this list of conditions and the following disclaimer in the
22
* documentation and/or other materials provided with the distribution.
23
24
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
25
* AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
26
* IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
27
* ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
28
* LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
29
* CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
30
* SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
31
* INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
32
* CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
33
* ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
34
* POSSIBILITY OF SUCH DAMAGE.
35
36
37
#ifndef _RTEMS_SCORE_PROCESSORMASK_H
38
#define _RTEMS_SCORE_PROCESSORMASK_H
39
40
#include <rtems/score/cpu.h>
41
42
#include <sys/_bitset.h>
43
44
#ifdef __cplusplus
45
extern
"C"
46
#endif
/* __cplusplus */
47
48
49
* Recent Newlib versions provide the bitset defines in the system reserved
50
* namespace.
51
52
#ifndef __BIT_AND2
53
#define __BIT_AND2 BIT_AND2
54
#endif
55
#ifndef __BIT_CLR
56
#define __BIT_CLR BIT_CLR
57
#endif
58
#ifndef __BIT_CMP
59
#define __BIT_CMP BIT_CMP
60
#endif
61
#ifndef __BIT_COPY
62
#define __BIT_COPY BIT_COPY
63
#endif
64
#ifndef __BIT_COUNT
65
#define __BIT_COUNT BIT_COUNT
66
#endif
67
#ifndef __BITSET_DEFINE
68
#define __BITSET_DEFINE BITSET_DEFINE
69
#endif
70
#ifndef __BIT_EMPTY
71
#define __BIT_EMPTY BIT_EMPTY
72
#endif
73
#ifndef __BIT_FILL
74
#define __BIT_FILL BIT_FILL
75
#endif
76
#ifndef __BIT_FLS
77
#define __BIT_FLS BIT_FLS
78
#endif
79
#ifndef __BIT_ISSET
80
#define __BIT_ISSET BIT_ISSET
81
#endif
82
#ifndef __BIT_OR2
83
#define __BIT_OR2 BIT_OR2
84
#endif
85
#ifndef __BIT_OVERLAP
86
#define __BIT_OVERLAP BIT_OVERLAP
87
#endif
88
#ifndef __BIT_SET
89
#define __BIT_SET BIT_SET
90
#endif
91
#ifndef __BIT_SETOF
92
#define __BIT_SETOF BIT_SETOF
93
#endif
94
#ifndef __BIT_SUBSET
95
#define __BIT_SUBSET BIT_SUBSET
96
#endif
97
#ifndef __BIT_XOR2
98
#define __BIT_XOR2 BIT_XOR2
99
#endif
100
#ifndef __BIT_ZERO
101
#define __BIT_ZERO BIT_ZERO
102
#endif
103
117
122
typedef
__BITSET_DEFINE( Processor_mask, CPU_MAXIMUM_PROCESSORS ) Processor_mask;
123
125
126
#ifdef __cplusplus
127
128
#endif
/* __cplusplus */
129
130
#endif
/* _RTEMS_SCORE_PROCESSORMASK_H */
