39#ifndef _RTEMS_SCORE_TODIMPL_H
40#define _RTEMS_SCORE_TODIMPL_H
71#define TOD_SECONDS_PER_MINUTE (uint32_t)60
76#define TOD_MINUTES_PER_HOUR (uint32_t)60
81#define TOD_MONTHS_PER_YEAR (uint32_t)12
86#define TOD_DAYS_PER_YEAR (uint32_t)365
91#define TOD_HOURS_PER_DAY (uint32_t)24
97#define TOD_SECONDS_PER_DAY (uint32_t) (TOD_SECONDS_PER_MINUTE * \
98 TOD_MINUTES_PER_HOUR * \
104#define TOD_SECONDS_PER_NON_LEAP_YEAR (365 * TOD_SECONDS_PER_DAY)
109#define TOD_MILLISECONDS_PER_SECOND (uint32_t)1000
114#define TOD_MICROSECONDS_PER_SECOND (uint32_t)1000000
119#define TOD_NANOSECONDS_PER_SECOND (uint32_t)1000000000
124#define TOD_NANOSECONDS_PER_MICROSECOND (uint32_t)1000
133#define TOD_SECONDS_1970_THROUGH_1988 \
134 (((1987 - 1970 + 1) * TOD_SECONDS_PER_NON_LEAP_YEAR) + \
135 (4 * TOD_SECONDS_PER_DAY))
144#define TOD_SECONDS_1970_THROUGH_2400 13569465600
153#define TOD_BASE_YEAR 1988
173#define TOD_LATEST_YEAR 2099
225#if defined(RTEMS_DEBUG)
226bool _TOD_Is_owner(
void );
258static inline size_t _TOD_Get_leap_year_index( uint32_t year )
260 _Assert( year % 4 != 0 || year % 100 != 0 || year % 400 == 0 );
261 return ( ( year % 4 ) + 3 ) / 4;
291 const struct timespec *tod,
300static inline void _TOD_Get(
304 _Timecounter_Nanotime( tod );
317static inline void _TOD_Get_uptime(
331static inline void _TOD_Get_zero_based_uptime(
345static inline void _TOD_Get_zero_based_uptime_as_timespec(
346 struct timespec *time
349 _Timecounter_Nanouptime( time );
361static inline uint32_t _TOD_Seconds_since_epoch(
void )
363 return (uint32_t) _Timecounter_Time_second;
369#define TOD_TICKS_PER_SECOND _Watchdog_Ticks_per_second
377static inline void _TOD_Get_timeval(
381 _Timecounter_Microtime( time );
390static inline bool _TOD_Is_set(
void )
475 const struct timespec *tod
This header file provides interfaces of the Watchdog Handler which are used by the implementation and...
#define _Assert(_e)
Assertion similar to assert() controlled via RTEMS_DEBUG instead of NDEBUG and static analysis runs.
Definition assert.h:96
Status_Control
Status codes.
Definition status.h:111
Status_Control _TOD_Hook_Run(TOD_Action action, const struct timespec *tod)
Run the TOD Action Hooks.
Definition coretodhookrun.c:46
Chain_Control _TOD_Hooks
Set of registered methods for TOD Actions.
Definition coretodhookdata.c:45
void _TOD_Hook_Unregister(TOD_Hook *hook)
Remove a TOD Action Hook.
Definition coretodhookunregister.c:45
void _TOD_Hook_Register(TOD_Hook *hook)
Add a TOD Action Hook.
Definition coretodhookregister.c:45
TOD_Action
Possible actions where a registered hook could be invoked.
Definition todimpl.h:417
@ TOD_ACTION_SET_CLOCK
Constant to indicate the TOD is being set.
Definition todimpl.h:421
Status_Control _TOD_Is_valid_new_time_of_day(const struct timespec *tod)
Checks the time point is a valid new time of day for _TOD_Set().
Definition coretodcheck.c:44
Status_Control _TOD_Set(const struct timespec *tod, ISR_lock_Context *lock_context)
Sets the time of day.
Definition coretodset.c:45
TOD_Control _TOD
TOD Management information.
Definition coretod.c:44
void _TOD_Unlock(void)
Unlocks the time of day mutex.
Definition coretod.c:53
const uint16_t _TOD_Days_to_date[2][13]
This array contains the number of days in all months up to the month indicated by the index of the se...
Definition clocktodtoseconds.c:45
void _TOD_Lock(void)
Locks the time of day mutex.
Definition coretod.c:48
int64_t _Timecounter_Sbinuptime(void)
Returns the uptime in the sbintime_t format.
#define _Timecounter_Release(lock_context)
Releases the timecounter lock.
Definition timecounter.h:227
#define _Timecounter_Acquire(lock_context)
Acquires the timecounter lock.
Definition timecounter.h:217
int64_t Timestamp_Control
Definition timestamp.h:76
This header file provides the interfaces of the Operation Status Support.
This structure represents a chain node.
Definition chain.h:78
Local ISR lock context for acquire and release pairs.
Definition isrlock.h:94
TOD control.
Definition todimpl.h:186
bool is_set
Indicates if the time of day is set.
Definition todimpl.h:193
Structure to manage each TOD action hook.
Definition todimpl.h:427
Status_Control(*) handler(TOD_Action, const struct timespec *)
Definition todimpl.h:432
Chain_Node Node
Definition todimpl.h:429
This header file provides interfaces of the Timecounter Handler which are only used by the implementa...
This header file provides interfaces of the Timestamp Handler which are used by the implementation an...
This union represents a chain control block.
Definition chain.h:96
This header file provides the interfaces of the Watchdog Handler related to watchdog ticks which are ...
