RTEMS 6.3
Priority Bitmap
This group contains the implementation to support priority bitmaps. More...
file  cpukit/include/rtems/score/prioritybitmap.h
 This header file provides interfaces of the Priority Bitmap which are used by the implementation and the Application Configuration.
file  cpukit/include/rtems/score/prioritybitmapimpl.h
 This header file provides interfaces of the Priority Bitmap which are only used by the implementation.
file  cpukit/score/src/log2table.c
 This source file contains the definition of _Bitfield_Leading_zeros.
struct  Priority_bit_map_Control
struct  Priority_bit_map_Information
typedef uint16_t Priority_bit_map_Word
