RTEMS 6.3
Deterministic Priority SMP Scheduler
This group contains the Deterministic Priority SMP Scheduler implementation. More...
Topics
 Deterministic Priority Affinity SMP Scheduler
 This group contains the Deterministic Priority Affinity SMP Scheduler implementation.
file  cpukit/include/rtems/score/schedulerprioritysmp.h
 This header file provides interfaces of the Deterministic Priority SMP Scheduler which are used by the implementation and the Application Configuration.
file  cpukit/include/rtems/score/schedulerprioritysmpimpl.h
 This header file provides interfaces of the Deterministic Priority SMP Scheduler which are only used by the implementation.
file  cpukit/score/src/schedulerprioritysmp.c
 This source file contains the implementation of _Scheduler_priority_SMP_Add_processor(), _Scheduler_priority_SMP_Ask_for_help(), _Scheduler_priority_SMP_Block(), _Scheduler_priority_SMP_Initialize(), _Scheduler_priority_SMP_Node_initialize(), _Scheduler_priority_SMP_Reconsider_help_request(), _Scheduler_priority_SMP_Remove_processor(), _Scheduler_priority_SMP_Unblock(), _Scheduler_priority_SMP_Update_priority(), _Scheduler_priority_SMP_Withdraw_node(), _Scheduler_priority_SMP_Make_sticky(), _Scheduler_priority_SMP_Clean_sticky(), and _Scheduler_priority_SMP_Yield().
struct  Scheduler_priority_SMP_Context
 Scheduler context specialization for Deterministic Priority SMP schedulers. More...
struct  Scheduler_priority_SMP_Node
 Scheduler node specialization for Deterministic Priority SMP schedulers. More...
#define SCHEDULER_PRIORITY_SMP_ENTRY_POINTS
 Entry points for the Priority SMP Scheduler.
void _Scheduler_priority_SMP_Initialize (const Scheduler_Control *scheduler)
 Initializes the priority SMP scheduler.
void _Scheduler_priority_SMP_Node_initialize (const Scheduler_Control *scheduler, Scheduler_Node *node, Thread_Control *the_thread, Priority_Control priority)
 Initializes the node with the given priority.
void _Scheduler_priority_SMP_Block (const Scheduler_Control *scheduler, Thread_Control *thread, Scheduler_Node *node)
 Blocks the thread.
void _Scheduler_priority_SMP_Unblock (const Scheduler_Control *scheduler, Thread_Control *thread, Scheduler_Node *node)
 Unblocks the thread.
void _Scheduler_priority_SMP_Update_priority (const Scheduler_Control *scheduler, Thread_Control *the_thread, Scheduler_Node *node)
 Updates the priority of the node.
bool _Scheduler_priority_SMP_Ask_for_help (const Scheduler_Control *scheduler, Thread_Control *the_thread, Scheduler_Node *node)
 Asks for help operation.
void _Scheduler_priority_SMP_Reconsider_help_request (const Scheduler_Control *scheduler, Thread_Control *the_thread, Scheduler_Node *node)
 Reconsiders help operation.
void _Scheduler_priority_SMP_Withdraw_node (const Scheduler_Control *scheduler, Thread_Control *the_thread, Scheduler_Node *node, Thread_Scheduler_state next_state)
 Withdraws node operation.
void _Scheduler_priority_SMP_Make_sticky (const Scheduler_Control *scheduler, Thread_Control *the_thread, Scheduler_Node *node)
 Makes the node sticky.
void _Scheduler_priority_SMP_Clean_sticky (const Scheduler_Control *scheduler, Thread_Control *the_thread, Scheduler_Node *node)
 Cleans the sticky property from the node.
void _Scheduler_priority_SMP_Add_processor (const Scheduler_Control *scheduler, Thread_Control *idle)
 Adds idle to scheduler.
Thread_Control * _Scheduler_priority_SMP_Remove_processor (const Scheduler_Control *scheduler, struct Per_CPU_Control *cpu)
 Removes an idle thread from the given cpu.
void _Scheduler_priority_SMP_Yield (const Scheduler_Control *scheduler, Thread_Control *thread, Scheduler_Node *node)
 Performs the yield of a thread.
This is an implementation of the global fixed priority scheduler (G-FP). It uses one ready chain per priority to ensure constant time insert operations. The scheduled chain uses linear insert operations and has at most processor count entries. Since the processor and priority count are constants all scheduler operations complete in a bounded execution time.
The thread preempt mode will be ignored.
◆ SCHEDULER_PRIORITY_SMP_ENTRY_POINTS
Value:
_Scheduler_default_Pin_or_unpin_not_supported, \
_Scheduler_SMP_Start_idle \
SCHEDULER_DEFAULT_SET_AFFINITY_OPERATION \
void _Scheduler_priority_SMP_Unblock(const Scheduler_Control *scheduler, Thread_Control *thread, Scheduler_Node *node)
Definition schedulerprioritysmp.c:184
void _Scheduler_priority_SMP_Add_processor(const Scheduler_Control *scheduler, Thread_Control *idle)
Definition schedulerprioritysmp.c:328
void _Scheduler_priority_SMP_Yield(const Scheduler_Control *scheduler, Thread_Control *thread, Scheduler_Node *node)
Definition schedulerprioritysmp.c:362
void _Scheduler_priority_SMP_Withdraw_node(const Scheduler_Control *scheduler, Thread_Control *the_thread, Scheduler_Node *node, Thread_Scheduler_state next_state)
Definition schedulerprioritysmp.c:270
void _Scheduler_priority_SMP_Clean_sticky(const Scheduler_Control *scheduler, Thread_Control *the_thread, Scheduler_Node *node)
Definition schedulerprioritysmp.c:308
void _Scheduler_priority_SMP_Update_priority(const Scheduler_Control *scheduler, Thread_Control *the_thread, Scheduler_Node *node)
Definition schedulerprioritysmp.c:222
void _Scheduler_priority_SMP_Initialize(const Scheduler_Control *scheduler)
Definition schedulerprioritysmp.c:60
void _Scheduler_priority_SMP_Reconsider_help_request(const Scheduler_Control *scheduler, Thread_Control *the_thread, Scheduler_Node *node)
Definition schedulerprioritysmp.c:254
void _Scheduler_priority_SMP_Block(const Scheduler_Control *scheduler, Thread_Control *thread, Scheduler_Node *node)
Blocks the thread.
Definition schedulerprioritysmp.c:119
void _Scheduler_priority_SMP_Node_initialize(const Scheduler_Control *scheduler, Scheduler_Node *node, Thread_Control *the_thread, Priority_Control priority)
Definition schedulerprioritysmp.c:74
Thread_Control * _Scheduler_priority_SMP_Remove_processor(const Scheduler_Control *scheduler, struct Per_CPU_Control *cpu)
Definition schedulerprioritysmp.c:344
bool _Scheduler_priority_SMP_Ask_for_help(const Scheduler_Control *scheduler, Thread_Control *the_thread, Scheduler_Node *node)
Definition schedulerprioritysmp.c:243
void _Scheduler_priority_SMP_Make_sticky(const Scheduler_Control *scheduler, Thread_Control *the_thread, Scheduler_Node *node)
Definition schedulerprioritysmp.c:293
void _Scheduler_default_Release_job(const Scheduler_Control *scheduler, Thread_Control *the_thread, Priority_Node *priority_node, uint64_t deadline, Thread_queue_Context *queue_context)
Does nothing.
Definition schedulerdefaultreleasejob.c:44
void _Scheduler_default_Node_destroy(const Scheduler_Control *scheduler, Scheduler_Node *node)
Does nothing.
Definition schedulerdefaultnodedestroy.c:45
Priority_Control _Scheduler_default_Map_priority(const Scheduler_Control *scheduler, Priority_Control priority)
Returns the scheduler internal thread priority mapped by SCHEDULER_PRIORITY_MAP().
Definition schedulerdefaultmappriority.c:43
void _Scheduler_default_Schedule(const Scheduler_Control *scheduler, Thread_Control *the_thread)
Does nothing.
Definition schedulerdefaultschedule.c:43
Priority_Control _Scheduler_default_Unmap_priority(const Scheduler_Control *scheduler, Priority_Control priority)
Returns the user visible thread priority unmapped by SCHEDULER_PRIORITY_UNMAP().
Definition schedulerdefaultmappriority.c:51
void _Scheduler_default_Cancel_job(const Scheduler_Control *scheduler, Thread_Control *the_thread, Priority_Node *priority_node, Thread_queue_Context *queue_context)
Does nothing.
Definition schedulerdefaultreleasejob.c:59
◆ _Scheduler_priority_SMP_Add_processor()
void _Scheduler_priority_SMP_Add_processor ( const Scheduler_Control * scheduler,
Thread_Control * idle )
Parameters
[in,out]schedulerThe scheduler instance to add the processor to.
idleThe idle thrad control.
◆ _Scheduler_priority_SMP_Ask_for_help()
bool _Scheduler_priority_SMP_Ask_for_help ( const Scheduler_Control * scheduler,
Thread_Control * the_thread,
Scheduler_Node * node )
Parameters
schedulerThe scheduler instance to ask for help.
the_threadThe thread needing help.
nodeThe scheduler node.
Return values
trueAsk for help was successful.
falseAsk for help was not successful.
◆ _Scheduler_priority_SMP_Block()
void _Scheduler_priority_SMP_Block ( const Scheduler_Control * scheduler,
Thread_Control * thread,
Blocks the thread.
Parameters
schedulerThe scheduler instance.
[in,out]the_threadThe thread to block.
[in,out]nodeThe thread's scheduler node.
◆ _Scheduler_priority_SMP_Clean_sticky()
void _Scheduler_priority_SMP_Clean_sticky ( const Scheduler_Control * scheduler,
Parameters
scheduleris the scheduler of the node.
[in,out]the_threadis the thread owning the node.
[in,out]nodeis the scheduler node to clean the sticky property.
◆ _Scheduler_priority_SMP_Initialize()
void _Scheduler_priority_SMP_Initialize ( const Scheduler_Control * scheduler)
This routine initializes the priority SMP scheduler.
Parameters
schedulerThe scheduler to initialize.
◆ _Scheduler_priority_SMP_Make_sticky()
void _Scheduler_priority_SMP_Make_sticky ( const Scheduler_Control * scheduler,
Parameters
[in,out]nodeis the scheduler node to make sticky.
◆ _Scheduler_priority_SMP_Node_initialize()
void _Scheduler_priority_SMP_Node_initialize ( const Scheduler_Control * scheduler,
Scheduler_Node * node,
Priority_Control priority )
Parameters
[out]nodeThe node to initialize.
the_threadThe thread of the scheduler node.
priorityThe priority for the initialization.
◆ _Scheduler_priority_SMP_Reconsider_help_request()
void _Scheduler_priority_SMP_Reconsider_help_request ( const Scheduler_Control * scheduler,
Parameters
schedulerThe scheduler instance to reconsider the help request.
the_threadThe thread reconsidering a help request.
◆ _Scheduler_priority_SMP_Remove_processor()
Thread_Control * _Scheduler_priority_SMP_Remove_processor ( const Scheduler_Control * scheduler,
struct Per_CPU_Control * cpu )
Parameters
cpuThe cpu control to remove from scheduler.
Returns
The idle thread of the processor.
◆ _Scheduler_priority_SMP_Unblock()
void _Scheduler_priority_SMP_Unblock ( const Scheduler_Control * scheduler,
Parameters
[in,out]the_threadThe thread to unblock.
◆ _Scheduler_priority_SMP_Update_priority()
void _Scheduler_priority_SMP_Update_priority ( const Scheduler_Control * scheduler,
Parameters
the_threadThe thread for the operation.
base_nodeThe thread's scheduler node.
◆ _Scheduler_priority_SMP_Withdraw_node()
void _Scheduler_priority_SMP_Withdraw_node ( const Scheduler_Control * scheduler,
Thread_Scheduler_state next_state )
Parameters
schedulerThe scheduler instance to withdraw the node.
the_threadThe thread using the node.
nodeThe scheduler node to withdraw.
next_stateThe next thread scheduler state in case the node is scheduled.
◆ _Scheduler_priority_SMP_Yield()
void _Scheduler_priority_SMP_Yield ( const Scheduler_Control * scheduler,
Parameters
[in,out]the_threadThe thread that performed the yield operation.
nodeThe scheduler node of the_thread.
