RTEMS 6.3
This group contains the Workspace Handler implementation. More...
Files | |
| file | bsps/shared/start/wkspaceinitmulti.c |
| This source file contains the _Workspace_Handler_initialization() implementation which supports more than one memory area. | |
| file | bsps/shared/start/wkspaceinitone.c |
| This source file contains the _Workspace_Handler_initialization() implementation which supports exactly one memory area. | |
| file | cpukit/include/rtems/score/wkspace.h |
| This header file provides interfaces of the Workspace Handler which are only used by the implementation. | |
| file | cpukit/include/rtems/score/wkspacedata.h |
| This header file provides data structures used by the implementation and the Application Configuration to define _Workspace_Size, _Workspace_Is_unified, and _Workspace_Malloc_initializer. | |
| file | cpukit/include/rtems/score/wkspaceinitmulti.h |
| This header file provides the implementation of _Workspace_Initialize_for_multiple_areas(). | |
| file | cpukit/include/rtems/score/wkspaceinitone.h |
| This header file provides the implementation of _Workspace_Initialize_for_one_area(). | |
| file | cpukit/score/src/wkspace.c |
| This source file contains the definition of _Workspace_Area and the Workspace Handler system initialization. | |
| file | cpukit/score/src/wkspaceallocate.c |
| This source file contains the implementation of _Workspace_Allocate(). | |
| file | cpukit/score/src/wkspacefree.c |
| This source file contains the implementation of _Workspace_Free(). | |
| file | cpukit/score/src/wkspaceisunifieddefault.c |
| This source file contains the default definition of _Workspace_Is_unified. | |
| file | cpukit/score/src/wkspacemallocinitdefault.c |
| This source file contains the default definition of _Workspace_Malloc_initializer. | |
| file | cpukit/score/src/wkspacemallocinitunified.c |
| This source file contains the implementation of _Workspace_Malloc_initialize_unified(). | |
| file | cpukit/score/src/wkstringduplicate.c |
| This source file contains the implementation of _Workspace_String_duplicate(). | |
| void | _Workspace_Handler_initialization (void) |
| Initializes the workspace handler. | |
| void * | _Workspace_Allocate (size_t size) |
| Allocates a memory block of the specified size from the workspace. | |
| void | _Workspace_Free (void *block) |
| Frees memory to the workspace. | |
| char * | _Workspace_String_duplicate (const char *string, size_t len) |
| Duplicates string with memory from the workspace. | |
| struct Heap_Control * | _Workspace_Malloc_initialize_separate (void) |
| Initializes the C Program Heap separated from the RTEMS Workspace. | |
| struct Heap_Control * | _Workspace_Malloc_initialize_unified (void) |
| Initializes the C Program Heap so that it is unified with the RTEMS Workspace. | |
| Heap_Control | _Workspace_Area |
| Executive workspace control. | |
| const uintptr_t | _Workspace_Size |
| The workspace size in bytes. | |
| const bool | _Workspace_Is_unified |
| Indicates if the workspace and C program heap are unified. | |
| struct Heap_Control *(*const) | _Workspace_Malloc_initializer (void) |
| This constant provides the C Program Heap initialization handler. | |
This handler encapsulates functionality related to the management of the RTEMS Workspace. It provides mechanisms which can be used to define, initialize and manipulate the RTEMS Workspace.
| void * _Workspace_Allocate | ( | size_t | size | ) |
| size | The size of the memory block. |
| pointer | The pointer to the memory block. The pointer is at least aligned by CPU_HEAP_ALIGNMENT. |
| NULL | No memory block with the requested size is available in the workspace. |
| void _Workspace_Free | ( | void * | block | ) |
This function frees the specified block of memory.
| block | The memory to free. |
| void _Workspace_Handler_initialization | ( | void | ) |
This routine performs the initialization necessary for this handler.
| struct Heap_Control * _Workspace_Malloc_initialize_separate | ( | void | ) |
| struct Heap_Control * _Workspace_Malloc_initialize_unified | ( | void | ) |
| char * _Workspace_String_duplicate | ( | const char * | string, |
| size_t | len ) |
| string | The pointer to a zero terminated string. |
| len | The length of the string (equal to strlen(string)). |
| other | Duplicated string. |
| NULL | Not enough memory. |
extern |
This is the heap control structure used to manage the RTEMS Executive Workspace.
extern |
This constant is defined by the application configuration via <rtems/confdefs.h>.
extern |
This constant is defined by the application configuration option CONFIGURE_UNIFIED_WORK_AREAS via <rtems/confdefs.h> or a default configuration.
extern |
