RTEMS 6.3
Thread Handler Multiprocessing (MP) Support
This group contains the implementation to support the Thread Handler in multiprocessing (MP) configurations. More...
file  cpukit/include/rtems/score/threadmp.h
 This header file provides the interfaces of the Thread Handler Multiprocessing (MP) Support.
file  cpukit/score/src/threadmp.c
 This source file contains the implementation of _Thread_MP_Handler_initialization(), _Thread_MP_Allocate_proxy(), _Thread_MP_Find_proxy(), _Thread_MP_Free_proxy().
#define _Thread_MP_Is_receive(_the_thread)
void _Thread_MP_Handler_initialization (uint32_t maximum_proxies)
 Initialize MP thread handler.
Thread_Control * _Thread_MP_Allocate_proxy (States_Control the_state)
 Allocates a MP proxy control block from the inactive chain of free proxy control blocks.
Thread_Control * _Thread_MP_Find_proxy (Objects_Id the_id)
 Removes the MP proxy control block for the specified id from the active chain of proxy control blocks.
void _Thread_MP_Extract_proxy (Thread_Control *the_thread)
 Extracts the proxy of the thread if necessary.
void _Thread_MP_Free_proxy (Thread_Control *the_thread)
 Trees a proxy control block to the inactive chain of free proxy control blocks.
This handler encapsulates functionality which is related to managing threads in a multiprocessor system configuration. This handler must manage proxies which represent remote threads blocking on local operations.
◆ _Thread_MP_Is_receive
#define _Thread_MP_Is_receive ( _the_thread)
Value:
((_the_thread) == _MPCI_Receive_server_tcb)
Thread_Control * _MPCI_Receive_server_tcb
Pointer to MP thread control block.
Definition mpci.c:84
This function returns true if the thread in question is the multiprocessing receive thread.
Note
This is a macro to avoid needing a prototype for _MPCI_Receive_server_tcb until it is used.
◆ _Thread_MP_Allocate_proxy()
Thread_Control * _Thread_MP_Allocate_proxy ( States_Control the_state)
This allocates a proxy control block from the inactive chain of free proxy control blocks.
Note
This function returns a thread control pointer because proxies are substitutes for remote threads.
  • Parameters
    the_stateThe state for the allocated MP proxy control block.
◆ _Thread_MP_Extract_proxy()
void _Thread_MP_Extract_proxy ( Thread_Control * the_thread)
This routine ensures that if there is a proxy for this thread on another node, it is also dealt with. A proxy is a data that is on the thread queue on the remote node and acts as a proxy for the local thread. If the local thread was waiting on a remote operation, then the remote side of the operation must be cleaned up.
Parameters
[in,out]the_threadis the thread to determine the proxy.
◆ _Thread_MP_Find_proxy()
Thread_Control * _Thread_MP_Find_proxy ( Objects_Id the_id)
This function removes the proxy control block for the specified id from the active red-black tree of proxy control blocks.
Parameters
the_idThe id of the proxy control block to remove.
Returns
The removed proxy control block.
◆ _Thread_MP_Handler_initialization()
void _Thread_MP_Handler_initialization ( uint32_t maximum_proxies)
This routine initializes the multiprocessing portion of the Thread Handler.
Parameters
maximum_proxiesThe maximum number of proxies for the MP thread handler.
