RTEMS 6.3
timecounterimpl.h
2
11
12/*
13 * Copyright (c) 2015 embedded brains GmbH & Co. KG
14 *
16 * modification, are permitted provided that the following conditions
17 * are met:
18 * 1. Redistributions of source code must retain the above copyright
19 * notice, this list of conditions and the following disclaimer.
20 * 2. Redistributions in binary form must reproduce the above copyright
21 * notice, this list of conditions and the following disclaimer in the
22 * documentation and/or other materials provided with the distribution.
23 *
24 * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
25 * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
26 * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
27 * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
28 * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
29 * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
30 * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
31 * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
32 * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
33 * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
34 * POSSIBILITY OF SUCH DAMAGE.
35 */
36
37#ifndef _RTEMS_SCORE_TIMECOUNTERIMPL_H
38#define _RTEMS_SCORE_TIMECOUNTERIMPL_H
39
41#include <sys/timetc.h>
42
43#ifdef __cplusplus
44extern "C" {
45#endif /* __cplusplus */
46
52
60 const struct bintime *bt,
61 ISR_lock_Context *lock_context
62);
63
65
66#ifdef __cplusplus
67}
68#endif /* __cplusplus */
69
70#endif /* _RTEMS_SCORE_TIMECOUNTERIMPL_H */
void _Timecounter_Set_clock(const struct bintime *bt, ISR_lock_Context *lock_context)
Sets the timecounter clock to the given value.
This header file provides interfaces of the Timecounter Handler which are used by the implementation ...
Local ISR lock context for acquire and release pairs.
Definition isrlock.h:94
This header file provides interfaces of the timecounter implementation.
