RTEMS 6.3
This header file provides interfaces of the Scheduler Handler which are used by the implementation and the Application Configuration. More...
| struct | Scheduler_Operations |
| The scheduler operations. More... | |
| struct | Scheduler_Context |
| Scheduler context. More... | |
| struct | _Scheduler_Control |
| Scheduler control. More... | |
| #define | _Scheduler_Count ( (size_t) 1 ) |
| This constant contains the count of configured schedulers. | |
| #define | SCHEDULER_DEFAULT_SMP_OPERATIONS |
| This define provides a set of default implementations for SMP-specific scheduler operations. | |
| #define | SCHEDULER_DEFAULT_SET_AFFINITY_OPERATION |
| This define provides the default implementation for the SMP-specific set affinity operation. | |
| #define | PRIORITY_MAXIMUM ( _Scheduler_Table[ 0 ].maximum_priority ) |
| This defines the lowest (least important) thread priority of the first scheduler instance. | |
Typedefs | |
| typedef struct _Scheduler_Control | Scheduler_Control |
| typedef struct Scheduler_Context | Scheduler_Context |
| Scheduler context. | |
| Priority_Control | _Scheduler_default_Map_priority (const Scheduler_Control *scheduler, Priority_Control priority) |
| Returns the scheduler internal thread priority mapped by SCHEDULER_PRIORITY_MAP(). | |
| Priority_Control | _Scheduler_default_Unmap_priority (const Scheduler_Control *scheduler, Priority_Control priority) |
| Returns the user visible thread priority unmapped by SCHEDULER_PRIORITY_UNMAP(). | |
| void | _Scheduler_default_Schedule (const Scheduler_Control *scheduler, Thread_Control *the_thread) |
| Does nothing. | |
| void | _Scheduler_default_Node_initialize (const Scheduler_Control *scheduler, Scheduler_Node *node, Thread_Control *the_thread, Priority_Control priority) |
| Performs the scheduler base node initialization. | |
| void | _Scheduler_default_Node_destroy (const Scheduler_Control *scheduler, Scheduler_Node *node) |
| Does nothing. | |
| void | _Scheduler_default_Release_job (const Scheduler_Control *scheduler, Thread_Control *the_thread, Priority_Node *priority_node, uint64_t deadline, Thread_queue_Context *queue_context) |
| Does nothing. | |
| void | _Scheduler_default_Cancel_job (const Scheduler_Control *scheduler, Thread_Control *the_thread, Priority_Node *priority_node, Thread_queue_Context *queue_context) |
| Does nothing. | |
| void | _Scheduler_default_Start_idle (const Scheduler_Control *scheduler, Thread_Control *the_thread, struct Per_CPU_Control *cpu) |
| Starts an idle thread. | |
| const Scheduler_Control | _Scheduler_Table [] |
| This table contains the configured schedulers. | |
