RTEMS 6.3
Memory Handler
This group contains the Memory Handler implementation. More...
file  bsps/arm/altera-cyclone-v/start/bspgetworkarea.c
 This source file contains the arm/altera-cyclone-v implementation of _Memory_Get().
file  bsps/i386/pc386/start/bspgetworkarea.c
 This source file contains the i386/pc386 implementation of _Memory_Get().
file  bsps/powerpc/mpc55xxevb/start/bspgetworkarea.c
 This source file contains the powerpc/mpc55xxevb implementation of _Memory_Get().
file  bsps/powerpc/tqm8xx/start/bspgetworkarea.c
 This source file contains the powerpc/tqm8xx implementation of _Memory_Get().
file  bsps/shared/start/bspgetworkarea-default.c
 This source file contains the default implementation of _Memory_Get().
file  bsps/sparc/shared/start/bspgetworkarea.c
 This source file contains an implementation of _Memory_Get().
file  cpukit/include/rtems/score/memory.h
 This header file provides the interfaces of the Memory Handler.
file  cpukit/score/src/memoryallocate.c
 This source file contains the implementation of _Memory_Allocate().
file  cpukit/score/src/memorydirtyfreeareas.c
 This source file contains the implementation of _Memory_Dirty_free_areas().
file  cpukit/score/src/memoryfill.c
 This source file contains the implementation of _Memory_Fill().
file  cpukit/score/src/memorynoinit.c
 This source file contains the definition of _Memory_Noinit_begin and _Memory_Noinit_end.
file  cpukit/score/src/memoryzerobeforeuse.c
 This source file contains the definition of _Memory_Zero_before_use.
file  cpukit/score/src/memoryzerofreeareas.c
 This source file contains the implementation of _Memory_Zero_free_areas().
struct  Memory_Area
 The memory area description. More...
struct  Memory_Information
 The memory information. More...
#define MEMORY_INFORMATION_INITIALIZER(areas)
 Statically initialize a memory information.
#define MEMORY_INITIALIZER(begin, end)
 Statically initialize a memory area.
const Memory_Information * _Memory_Get (void)
 Return the memory information of this platform.
void * _Memory_Allocate (const Memory_Information *information, uintptr_t size, uintptr_t alignment)
 Allocate a memory area from the memory information.
void _Memory_Fill (const Memory_Information *information, int c)
 Fill all free memory areas of the memory information with a constant byte.
void _Memory_Zero_free_areas (void)
 Zeros all free memory areas of the system.
void _Memory_Dirty_free_areas (void)
 Dirty all free memory areas of the system.
const bool _Memory_Zero_before_use
 Indicates if the memory is zeroed during system initialization.
char _Memory_Noinit_begin []
 This symbol marks the begin of the non-initialized section used by RTEMS.
char _Memory_Noinit_end []
 This symbol marks the end of the non-initialized section used by RTEMS.
The Memory Handler provides memory areas supplied by the BSP to higher level memory consumers such as the Workspace Handler and the Malloc Support.
◆ MEMORY_INFORMATION_INITIALIZER
#define MEMORY_INFORMATION_INITIALIZER ( areas)
Value:
{ RTEMS_ARRAY_SIZE( areas ), ( areas ) }
#define RTEMS_ARRAY_SIZE(_array)
Gets the element count of the array.
Definition basedefs.h:244
Parameters
areasThe designator of an array of the memory areas.
◆ MEMORY_INITIALIZER
#define MEMORY_INITIALIZER ( begin,
end )
Value:
{ ( begin ), ( begin ), ( end ) }
Parameters
beginThe begin of the memory area.
endThe end of the memory area.
◆ _Memory_Allocate()
void * _Memory_Allocate ( const Memory_Information * information,
uintptr_t size,
uintptr_t alignment )
It is not possible to free the memory area allocated by this function.
Parameters
informationThe memory information.
sizeThe size in bytes of the memory area to allocate.
alignmentThe alignment in bytes of the memory area to allocate. It must be a power of two.
Return values
NULLNo such memory area available.
beginThe begin of the allocated memory area.
◆ _Memory_Fill()
void _Memory_Fill ( const Memory_Information * information,
int c )
Parameters
cThe constant byte to fill the free memory areas.
◆ _Memory_Get()
const Memory_Information * _Memory_Get ( void )
This function is provided by the Board Support Package (BSP). Using a function gives the BSPs a bit more freedom with respect to the implementation. Calling this function shall not have side-effects. Initialization steps to set up the memory information shall be done in a system initialization handler (RTEMS_SYSINIT_MEMORY).
Returns
Variable Documentation
◆ _Memory_Zero_before_use
extern
This value is provided via <rtems/confdefs.h> in case CONFIGURE_ZERO_WORKSPACE_AUTOMATICALLY is defined.
