RTEMS
6.3
Toggle main menu visibility
include
score
percpudata.h
1
/* SPDX-License-Identifier: BSD-2-Clause */
2
11
12
13
* Copyright (c) 2018 embedded brains GmbH & Co. KG
14
15
16
* modification, are permitted provided that the following conditions
17
* are met:
18
* 1. Redistributions of source code must retain the above copyright
19
* notice, this list of conditions and the following disclaimer.
20
* 2. Redistributions in binary form must reproduce the above copyright
21
* notice, this list of conditions and the following disclaimer in the
22
* documentation and/or other materials provided with the distribution.
23
24
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
25
* AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
26
* IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
27
* ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
28
* LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
29
* CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
30
* SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
31
* INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
32
* CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
33
* ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
34
* POSSIBILITY OF SUCH DAMAGE.
35
36
37
#ifndef _RTEMS_SCORE_PERCPUDATA_H
38
#define _RTEMS_SCORE_PERCPUDATA_H
39
40
rtems/score/percpu.h
41
rtems/linkersets.h
42
43
#ifdef __cplusplus
44
extern
"C"
45
#endif
/* __cplusplus */
46
63
64
RTEMS_LINKER_RWSET_DECLARE( _Per_CPU_Data,
char
65
70
#ifdef RTEMS_SMP
71
#define PER_CPU_DATA_NEED_INITIALIZATION() \
72
static const char * const _Per_CPU_Data_reference \
73
RTEMS_SECTION( ".rtemsroset.reference" ) RTEMS_USED = \
74
RTEMS_LINKER_SET_BEGIN( _Per_CPU_Data )
75
#else
76
77
RTEMS_LINKER_RWSET_DECLARE( _Per_CPU_Data, char )
78
#endif
79
88
#define PER_CPU_DATA_ITEM_DECLARE( type, item ) \
89
RTEMS_LINKER_RWSET_ITEM_DECLARE( _Per_CPU_Data, type, item )
90
97
#define PER_CPU_DATA_ITEM( type, item ) \
98
RTEMS_LINKER_RWSET_ITEM( _Per_CPU_Data, type, item )
99
106
#define PER_CPU_DATA_OFFSET( item ) \
107
( (uintptr_t) &_Linker_set__Per_CPU_Data_##item \
108
- (uintptr_t) RTEMS_LINKER_SET_BEGIN( _Per_CPU_Data ) )
109
118
#ifdef RTEMS_SMP
119
#define PER_CPU_DATA_GET_BY_OFFSET( cpu, type, offset ) \
120
(type *) ( cpu->data + offset )
121
#else
122
123
(type *) ( (uintptr_t) RTEMS_LINKER_SET_BEGIN( _Per_CPU_Data ) + offset ), \
124
(void) cpu
125
#endif
126
135
#ifdef RTEMS_SMP
136
#define PER_CPU_DATA_GET( cpu, type, item ) \
137
PER_CPU_DATA_GET_BY_OFFSET( cpu, type, PER_CPU_DATA_OFFSET( item ) )
138
#else
139
140
&_Linker_set__Per_CPU_Data_##item, (void) cpu
141
#endif
142
144
145
#ifdef __cplusplus
146
147
#endif
/* __cplusplus */
148
149
#endif
/* _RTEMS_SCORE_PERCPUDATA_H */
linkersets.h
This header file provides the linker sets API.
percpu.h
This header file provides the interfaces of the Per-CPU Information.
