39#ifndef _RTEMS_SCORE_SCHEDULERCBS_H
40#define _RTEMS_SCORE_SCHEDULERCBS_H
66#define SCHEDULER_CBS_MAXIMUM_PRIORITY SCHEDULER_EDF_MAXIMUM_PRIORITY
74#define SCHEDULER_CBS_ENTRY_POINTS \
76 _Scheduler_EDF_Initialize, \
77 _Scheduler_EDF_Schedule, \
78 _Scheduler_EDF_Yield, \
79 _Scheduler_EDF_Block, \
80 _Scheduler_CBS_Unblock, \
81 _Scheduler_EDF_Update_priority, \
82 _Scheduler_EDF_Map_priority, \
83 _Scheduler_EDF_Unmap_priority, \
84 SCHEDULER_DEFAULT_SMP_OPERATIONS \
85 _Scheduler_CBS_Node_initialize, \
86 _Scheduler_default_Node_destroy, \
87 _Scheduler_CBS_Release_job, \
88 _Scheduler_CBS_Cancel_job, \
89 _Scheduler_default_Start_idle \
90 SCHEDULER_DEFAULT_SET_AFFINITY_OPERATION \
94#define SCHEDULER_CBS_OK 0
95#define SCHEDULER_CBS_ERROR_GENERIC -16
96#define SCHEDULER_CBS_ERROR_NO_MEMORY -17
97#define SCHEDULER_CBS_ERROR_INVALID_PARAMETER -18
98#define SCHEDULER_CBS_ERROR_UNAUTHORIZED -19
99#define SCHEDULER_CBS_ERROR_UNIMPLEMENTED -20
100#define SCHEDULER_CBS_ERROR_MISSING_COMPONENT -21
101#define SCHEDULER_CBS_ERROR_INCONSISTENT_STATE -22
102#define SCHEDULER_CBS_ERROR_SYSTEM_OVERLOAD -23
103#define SCHEDULER_CBS_ERROR_INTERNAL_ERROR -24
104#define SCHEDULER_CBS_ERROR_NOT_FOUND -25
105#define SCHEDULER_CBS_ERROR_FULL -26
106#define SCHEDULER_CBS_ERROR_EMPTY -27
107#define SCHEDULER_CBS_ERROR_NOSERVER SCHEDULER_CBS_ERROR_NOT_FOUND
180 const Scheduler_Control *scheduler,
181 Thread_Control *the_thread,
195 const Scheduler_Control *scheduler,
196 Thread_Control *the_thread,
211 const Scheduler_Control *scheduler,
212 Thread_Control *the_thread,
324 time_t *approved_budget
341 time_t *remaining_budget
428 const Scheduler_Control *scheduler,
430 Thread_Control *the_thread,
This header file provides the Timer Manager API.
Objects_Id rtems_id
This type represents RTEMS object identifiers.
Definition types.h:94
uint64_t Priority_Control
The thread priority control.
Definition priority.h:91
int _Scheduler_CBS_Get_server_id(rtems_id task_id, Scheduler_CBS_Server_id *server_id)
Gets a thread server id.
Definition schedulercbsgetserverid.c:46
Scheduler_CBS_Server _Scheduler_CBS_Server_list[]
void _Scheduler_CBS_Release_job(const Scheduler_Control *scheduler, Thread_Control *the_thread, Priority_Node *priority_node, uint64_t deadline, Thread_queue_Context *queue_context)
Releases a job.
Definition schedulercbsreleasejob.c:44
int _Scheduler_CBS_Create_server(Scheduler_CBS_Parameters *params, Scheduler_CBS_Budget_overrun budget_overrun_callback, rtems_id *server_id)
Creates a new server with specified parameters.
Definition schedulercbscreateserver.c:45
int _Scheduler_CBS_Cleanup(void)
Cleans up resources associated to the CBS Library.
Definition schedulercbscleanup.c:44
void(*) Scheduler_CBS_Budget_overrun(Scheduler_CBS_Server_id server_id)
Definition schedulercbs.h:116
int _Scheduler_CBS_Get_remaining_budget(Scheduler_CBS_Server_id server_id, time_t *remaining_budget)
Retrieves remaining budget for the current server instance.
Definition schedulercbsgetremainingbudget.c:45
int _Scheduler_CBS_Get_approved_budget(Scheduler_CBS_Server_id server_id, time_t *approved_budget)
Retrieves the approved budget.
Definition schedulercbsgetapprovedbudget.c:46
int _Scheduler_CBS_Detach_thread(Scheduler_CBS_Server_id server_id, rtems_id task_id)
Detaches from the CBS Server.
Definition schedulercbsdetachthread.c:45
int _Scheduler_CBS_Destroy_server(Scheduler_CBS_Server_id server_id)
Detaches all tasks from a server and destroys it.
Definition schedulercbsdestroyserver.c:44
void _Scheduler_CBS_Cancel_job(const Scheduler_Control *scheduler, Thread_Control *the_thread, Priority_Node *priority_node, Thread_queue_Context *queue_context)
Cancels a job.
Definition schedulercbsreleasejob.c:74
int _Scheduler_CBS_Get_execution_time(Scheduler_CBS_Server_id server_id, time_t *exec_time, time_t *abs_time)
Gets relative time info.
Definition schedulercbsgetexecutiontime.c:45
void _Scheduler_CBS_Node_initialize(const Scheduler_Control *scheduler, Scheduler_Node *node, Thread_Control *the_thread, Priority_Control priority)
Initializes a CBS specific scheduler node of the_thread.
Definition schedulercbsnodeinit.c:44
const Thread_CPU_budget_operations _Scheduler_CBS_Budget
These are the CBS CPU budget operations.
Definition schedulercbs.c:103
int _Scheduler_CBS_Attach_thread(Scheduler_CBS_Server_id server_id, rtems_id task_id)
Attaches a task to an already existing server.
Definition schedulercbsattachthread.c:45
const uint32_t _Scheduler_CBS_Maximum_servers
int _Scheduler_CBS_Initialize(void)
Definition schedulercbs.c:109
void _Scheduler_CBS_Unblock(const Scheduler_Control *scheduler, Thread_Control *the_thread, Scheduler_Node *node)
Unblocks a thread.
Definition schedulercbsunblock.c:48
int _Scheduler_CBS_Get_parameters(Scheduler_CBS_Server_id server_id, Scheduler_CBS_Parameters *params)
Retrieves CBS scheduling parameters.
Definition schedulercbsgetparameters.c:46
uint32_t Scheduler_CBS_Server_id
Definition schedulercbs.h:113
int _Scheduler_CBS_Set_parameters(Scheduler_CBS_Server_id server_id, Scheduler_CBS_Parameters *parameters)
Sets parameters for CBS scheduling.
Definition schedulercbssetparameters.c:45
This header file defines the parts of the Signal Manager API.
This header file provides interfaces of the Priority Handler which are used by the implementation and...
This header file provides interfaces of the Red-Black Tree Handler which are used by the implementati...
This header file provides interfaces of the EDF Scheduler which are used by the implementation and th...
This header file provides interfaces of the Chain Handler which are used by the implementation and th...
This header file provides interfaces of the Scheduler Handler which are used by the implementation an...
This header file provides interfaces of the Thread Handler which are used by the implementation and t...
The priority node to build up a priority aggregation.
Definition priority.h:112
Definition schedulercbs.h:156
Scheduler_CBS_Server * cbs_server
Definition schedulercbs.h:160
Scheduler_EDF_Node Base
Definition schedulercbs.h:158
Definition schedulercbs.h:123
time_t deadline
Definition schedulercbs.h:125
time_t budget
Definition schedulercbs.h:127
Definition schedulercbs.h:133
Scheduler_CBS_Parameters parameters
Definition schedulercbs.h:141
rtems_id task_id
Definition schedulercbs.h:139
bool initialized
Indicates if this CBS server is initialized.
Definition schedulercbs.h:150
Scheduler_CBS_Budget_overrun cbs_budget_overrun
Definition schedulercbs.h:143
Scheduler node specialization for EDF schedulers.
Definition scheduleredf.h:107
Scheduler node for per-thread data.
Definition schedulernode.h:94
This structure contains operations which manage the CPU budget of a thread.
Definition thread.h:188
Thread queue context for the thread queue methods.
Definition threadq.h:216
