RTEMS
6.3
Toggle main menu visibility
include
score
schedulercbsimpl.h
1
/* SPDX-License-Identifier: BSD-2-Clause */
2
11
12
13
* Copyright (c) 2014 embedded brains GmbH & Co. KG
14
15
16
* modification, are permitted provided that the following conditions
17
* are met:
18
* 1. Redistributions of source code must retain the above copyright
19
* notice, this list of conditions and the following disclaimer.
20
* 2. Redistributions in binary form must reproduce the above copyright
21
* notice, this list of conditions and the following disclaimer in the
22
* documentation and/or other materials provided with the distribution.
23
24
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
25
* AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
26
* IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
27
* ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
28
* LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
29
* CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
30
* SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
31
* INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
32
* CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
33
* ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
34
* POSSIBILITY OF SUCH DAMAGE.
35
36
37
#ifndef _RTEMS_SCORE_SCHEDULERCBSIMPL_H
38
#define _RTEMS_SCORE_SCHEDULERCBSIMPL_H
39
40
rtems/score/schedulercbs.h
41
rtems/score/schedulerimpl.h
42
43
#ifdef __cplusplus
44
extern
"C"
45
#endif
/* __cplusplus */
46
52
60
static
inline
Scheduler_CBS_Node
*_Scheduler_CBS_Thread_get_node(
61
Thread_Control *the_thread
62
63
64
return
Scheduler_CBS_Node
*) _Thread_Scheduler_get_home_node( the_thread );
65
66
74
static
inline
Scheduler_CBS_Node
*_Scheduler_CBS_Node_downcast(
75
Scheduler_Node
*node
76
77
78
return
Scheduler_CBS_Node
*) node;
79
80
82
83
#ifdef __cplusplus
84
85
#endif
/* __cplusplus */
86
87
#endif
/* _RTEMS_SCORE_SCHEDULERCBSIMPL_H */
schedulercbs.h
This header file provides interfaces of the Constant Bandwidth Server (CBS) Scheduler which are used ...
schedulerimpl.h
This header file provides interfaces of the Scheduler Handler which are only used by the implementati...
Scheduler_CBS_Node
Definition
schedulercbs.h:156
Scheduler_Node
Scheduler node for per-thread data.
Definition
schedulernode.h:94
